Wyze Battery Cam Pro: Wire-Free Camera with Spotlight & Night Protection
Wyze Battery Cam Pro: Wire-Free Smart Home Camera with Built-In Spotlight
Protect your home day and night with the Wyze Battery Cam Pro, a cutting-edge wire-free smart home camera designed for ultimate convenience and security. Featuring a built-in spotlight, this camera ensures nighttime protection by illuminating potential intruders with 150 lumens of motion-activated LED light. No power outlet or hub is required, making it easy to install anywhere around your home.
Key Features of Wyze Battery Cam Pro
  • 2.5K HDR Video Resolution: Capture crystal-clear, high dynamic range video with richer colors and balanced images, ensuring every detail is visible both day and night.
  • Integrated Spotlight & Siren: The built-in spotlight not only lights up dark areas but also acts as a deterrent with a loud siren to scare off intruders.
  • Radar + PIR Motion Detection: Dual motion sensors provide earlier and more precise detection, reducing false alarms and allowing you to set custom detection zones.
  • Removable, Rechargeable Battery Packs: Easily swap out batteries to keep your camera running without downtime.
  • IP65 Weatherproof: Durable and weather-resistant, the camera withstands rain, dust, and extreme temperatures.
  • Dual-Band Wi-Fi Support: Connects seamlessly to both 2.4 GHz and 5 GHz Wi-Fi networks for reliable streaming.
  • No Hub Required: Completely wire-free and independent, simplifying setup and placement.
Flexible Power & Mounting Options
The Wyze Battery Cam Pro offers versatile mounting solutions including wall, ceiling, or eave installation with the optional Wyze Universal Mount. For extended power, you can add the Wyze Solar Panel to convert sunlight into energy, reducing the need for frequent battery charging.
Wyze Battery Cam Pro + Solar Panel: Continuous Power for Non-Stop Security
Take your home security to the next level with the Wyze Battery Cam Pro + Solar Panel bundle. This package combines the powerful features of the Battery Cam Pro with a solar panel that keeps your camera charged using renewable energy.
Why Choose the Solar Panel Bundle?
  • Continuous Power Supply: The solar panel converts sunlight into power, allowing your camera to stay up longer without manual recharging.
  • Eco-Friendly & Convenient: Reduce battery swaps and enjoy hassle-free, sustainable security.
  • All Features of Battery Cam Pro Included: Enjoy 2.5K HDR video, integrated spotlight, radar + PIR motion detection, and IP65 weatherproofing.
  • Easy Installation: The solar panel is designed specifically for the Wyze Battery Cam Pro, ensuring a seamless fit and optimal charging.
This bundle is perfect for those who want reliable, wire-free security with minimal maintenance.
Enhance Your Wyze Battery Cam Pro Experience with Accessories
Wyze Removable Battery Pack
Keep your camera powered without interruption by having extra rechargeable battery packs on hand. Each pack offers:
  • 6200mAh Capacity: Lasts up to 6 months on a single charge under typical usage.
  • USB-C Charging: Convenient and fast charging with a built-in USB-C port.
  • Compact & Lightweight: Easy to swap and carry.
Wyze Battery Charging Dock
Charge two battery packs simultaneously with this compact charging dock, ensuring you always have a fresh battery ready to go.
  • Fast Charging: Fully charges batteries in approximately 8.5 hours.
  • Includes Power Adapter & USB-C Cable: Everything you need to keep your batteries topped up.
Why Choose Wyze Battery Cam Pro for Nighttime Protection?
"Light up potential intruders with 150 lumens of LED, motion-activated light."
The integrated spotlight is a game-changer for nighttime security. Unlike traditional cameras that rely solely on infrared night vision, the Wyze Battery Cam Pro’s color night vision combined with a powerful spotlight lets you see vivid, full-color video even in complete darkness. This not only improves identification but also deters unwanted visitors by flooding the area with bright light.
Product Images
Wyze Battery Cam Pro in outdoor home setting Experience seamless home security with Wyze Battery Cam Pro wire-free installation.
Summary
The Wyze Battery Cam Pro and its Solar Panel bundle offer a comprehensive, wire-free smart home camera solution with built-in spotlight functionality for superior nighttime protection. With high-resolution video, advanced motion detection, and flexible power options, these cameras provide peace of mind and convenience for any home.
FeatureWyze Battery Cam ProWyze Battery Cam Pro + Solar PanelWyze Removable Battery PackWyze Battery Charging Dock
TypeCameraCameraAccessoryAccessory
Video Resolution2560 x 1440 (2.5K)2560 x 1440 (2.5K)N/AN/A
Video EncodingH.264H.264N/AN/A
WirelessYesYesN/AN/A
Power SourceRemovable, Rechargeable Battery PacksRemovable, Rechargeable Battery PacksRechargeable Battery PackCharging Dock for Batteries
Battery Capacity6200 mAh6200 mAh6200 mAhN/A
Battery LifeUp to 6 MonthsUp to 6 MonthsUp to 6 Months (per charge)N/A
Charging TimeApproximately 9 hoursApproximately 9 hoursApproximately 9 hoursApproximately 8.5 hours
Weather ResistanceIP65IP65N/AN/A
Operating Temperature-20°C to +50°C (-4°F to +122°F)-20°C to +50°C (-4°F to +122°F)-20°C to +50°C (-4°F to +122°F)+10°C to +40°C (+50°F to +104°F)
Humidity< 90%< 90%< 90%< 90%
Storage Temperature-40°C to +50°C (-40°F to +122°F)-40°C to +50°C (-40°F to +122°F)N/AN/A
Local StorageSupports up to 256 GB microSD cardsSupports up to 256 GB microSD cardsN/AN/A
Cloud StorageN/ARecord to cloud with Cam PlusN/AN/A
Image SensorCMOS-Starlight SensorCMOS-Starlight SensorN/AN/A
Lens ApertureF1.6F1.6N/AN/A
Field of View134° (DFOV), 108° (HFOV), 56° (VFOV)134° (DFOV), 108° (HFOV), 56° (VFOV)N/AN/A
Night Vision2 IR LEDs (850 nm), 2 White LEDs (5500K, 187 lumens)2 IR LEDs (850 nm), 2 White LEDs (5500K, 187 lumens)N/AN/A
AudioTwo-way Audio with built-in speaker and microphoneTwo-way AudioN/AN/A
MicrophoneMEMS Digital MicMEMS Digital MicN/AN/A
Siren100 dB SPL @ 0.1m100 dB SPL @ 0.1mN/AN/A
CPU Speed500 MHz500 MHzN/AN/A
Memory128 MB RAM128 MB RAMN/AN/A
Mounting Methods1/4” - 20 standard1/4” - 20 standardN/AN/A
Wall Mount IncludedYesYesN/AN/A
Wall Mount Dimensions2 in x 2 in x 2.2 in2 in x 2 in x 2.2 inN/AN/A
Wall Mount Weight1.5 oz (44 g)1.5 oz (44 g)N/AN/A
BluetoothBLE 5.1BLE 5.1N/AN/A
WiFi2.4 GHz and 5 GHz, 802.11a/n/g/b2.4 GHz and 5 GHz, 802.11a/n/g/bN/AN/A
Phone CompatibilityAndroid 9.0+, iOS 15.0+Android 9.0+, iOS 15.0+N/AN/A
Color OptionsBlack, WhiteBlack, WhiteWhiteWhite
Dimensions2.5 x 1.8 x 3.5 inches2.5 x 1.8 x 3.5 inches2.9 in x 1.6 in x 0.9 inCharging Dock: 2.6in x 2in x 1in
Weight0.94 lbs0.94 lbs3.9 oz (110 g)2.75 oz (78 g)
FinishMatte finishN/AN/AN/A
Mechanical StructurePC plasticsN/AN/AN/A
ConnectorUSB-CUSB-CUSB-CUSB-A to USB-C power cable
Charging CurrentN/AN/A800 mAN/A
Power Adapter IncludedNoNoNoYes (5V, 2A)
Charging CapabilityN/AN/AN/ACharges up to two batteries simultaneously
Price Range$89.98 - $219.98 (depending on pack size)$109.98$22.99$17.99
What is the Wyze Battery Cam Pro?The Wyze Battery Cam Pro is a wire-free smart home security camera featuring a built-in spotlight, 2.5K HDR video resolution, radar and PIR motion detection, and weatherproof design. It is designed for easy installation anywhere around your home without the need for a power outlet or hub.
How does the built-in spotlight on the Wyze Battery Cam Pro enhance nighttime security?The Wyze Battery Cam Pro features a 150-lumen motion-activated LED spotlight that illuminates dark areas and deters potential intruders. Combined with color night vision, it allows you to capture vivid, full-color video even in complete darkness, improving identification and overall nighttime protection.
Does the Wyze Battery Cam Pro require a hub or power outlet for installation?No, the Wyze Battery Cam Pro is completely wire-free and does not require a hub or power outlet. Its removable, rechargeable battery packs make it easy to install anywhere around your home.
What are the key features of the Wyze Battery Cam Pro?Key features include 2.5K HDR video resolution, integrated spotlight and siren, radar plus PIR motion detection with custom detection zones, removable rechargeable battery packs, IP65 weatherproof rating, and dual-band Wi-Fi support (2.4 GHz and 5 GHz).
Can I use the Wyze Battery Cam Pro with a solar panel?Yes, the Wyze Battery Cam Pro can be paired with the Wyze Solar Panel for continuous, eco-friendly power. The solar panel converts sunlight into energy, reducing the need for frequent battery charging and providing hassle-free, sustainable security.
What mounting options are available for the Wyze Battery Cam Pro?The Wyze Battery Cam Pro offers flexible mounting solutions, including wall, ceiling, or eave installation. The optional Wyze Universal Mount makes it easy to place the camera in the optimal location for your home.
How long does the Wyze removable battery pack last on a single charge?The Wyze removable battery pack has a 6200mAh capacity and can last up to 6 months on a single charge under typical usage conditions.
What is included with the Wyze Battery Charging Dock?The Wyze Battery Charging Dock allows you to charge two battery packs simultaneously. It includes a power adapter and USB-C cable, and can fully charge batteries in approximately 8.5 hours.
Is the Wyze Battery Cam Pro weatherproof?Yes, the Wyze Battery Cam Pro is IP65 weatherproof, making it durable and resistant to rain, dust, and extreme temperatures for reliable outdoor use.
What are the benefits of the Wyze Battery Cam Pro + Solar Panel bundle?The Wyze Battery Cam Pro + Solar Panel bundle provides continuous power using renewable energy, reducing the need for manual recharging. It includes all the advanced features of the Battery Cam Pro and is easy to install for reliable, wire-free security with minimal maintenance.
What are the installation options for the Wyze Battery Cam Pro?Can the Wyze Battery Cam Pro be used outdoors?How does the radar and PIR motion detection work in the Wyze Battery Cam Pro?
