Wyze Battery Cam Pro: Wireless Camera with Integrated Spotlight
The
Wyze Battery Cam Pro is a top-tier wireless security camera designed to illuminate and monitor dark corners effectively. Featuring a powerful
2.5K HDR video resolution, this camera captures crystal-clear footage day and night. Its
integrated spotlight and
siren provide active deterrence against unwanted visitors, making it ideal for home security.
Key Features:
- 2.5K HDR Video Resolution (2560 x 1440) for sharp, detailed images.
- Integrated Spotlight & Siren: Bright 187-lumen white LEDs illuminate dark areas while a 100 dB siren alerts intruders.
- Radar + PIR Motion Detection: Advanced sensors detect movement with precision.
- Wire-Free & No Hub Required: Easy installation with removable, rechargeable 6200mAh battery packs lasting up to 6 months.
- Weatherproof IP65 Rating: Durable in rain, snow, and extreme temperatures (-20°C to 50°C).
- Dual Band WiFi Support: Connects to both 2.4 GHz and 5 GHz networks for reliable streaming.
- Two-Way Audio: Communicate through the built-in speaker and microphone.
- Wide Field of View: 134° diagonal, 108° horizontal, and 56° vertical coverage.
- Local Storage Support: Up to 256 GB microSD card compatibility.
Available in sleek
Black or
White finishes, the Wyze Battery Cam Pro blends seamlessly with any home exterior.
Experience peace of mind with a camera that not only watches but actively lights up and protects your property.
Wyze Battery Cam Pro + Solar Panel: Sustainable Spotlight Security
For those seeking continuous power without frequent recharging, the
Wyze Battery Cam Pro + Solar Panel bundle offers the same advanced features as the standard Battery Cam Pro, enhanced with a solar panel for eco-friendly, uninterrupted operation.
Highlights:
- Solar-Powered Battery Charging: Keeps your camera running longer by harnessing sunlight.
- Color Night Vision: Thanks to the integrated spotlight, see vibrant colors even in low light.
- Radar + PIR Motion Detection: Detects movement accurately to trigger alerts and spotlight activation.
- Weatherproof Design: IP65 rating ensures reliable performance in all weather conditions.
- Wireless & Hub-Free Setup: Easy to install anywhere with WiFi connectivity.
- Supports Local and Cloud Storage: Record locally or subscribe to Cam Plus for cloud access.
This bundle is perfect for remote locations or areas with limited access to power outlets, providing a sustainable security solution.
Wyze Bird Feeder Wireless Camera Bundle: Security Meets Nature
Combine security with nature observation using the
Wyze Bird Feeder Wireless Camera Bundle. This unique package includes the Wyze Battery Cam Pro, a vibrant bird feeder, and a solar panel, allowing you to monitor your yard while attracting feathered visitors.
Bundle Features:
- Wyze Battery Cam Pro: 2.5K HDR video with spotlight and siren.
- Weather-Resistant Bird Feeder: Durable polycarbonate construction with a 1-liter seed capacity.
- Solar Panel: Keeps the camera powered sustainably.
- Live Streaming via Wyze App: Watch birds and monitor your property in real-time.
- IP65 Weatherproof Rating: Suitable for outdoor use in various climates.
This bundle is ideal for bird enthusiasts who want to enjoy wildlife while maintaining home security.
Why Choose Wyze Battery Cam Pro Series?
Wyze cameras stand out for their combination of
high-resolution video,
wireless convenience, and
integrated lighting that brightens dark areas automatically. The rechargeable battery packs provide long-lasting power, and the option to add solar panels ensures minimal maintenance. With smart home integrations like Alexa, Google Assistant, and IFTTT, these cameras fit seamlessly into your connected lifestyle.
Whether you want a standalone spotlight camera or a sustainable solar-powered setup, Wyze offers versatile solutions to keep your home safe and well-lit.
Summary of Wyze Wireless Spotlight Cameras
Feature | Wyze Battery Cam Pro | Wyze Battery Cam Pro + Solar Panel | Wyze Bird Feeder Wireless Camera Bundle |
Video Resolution | 2.5K HDR (2560 x 1440) | 2.5K HDR (2560 x 1440) | 2.5K HDR (2560 x 1440) |
Spotlight | Integrated, 187 lumens | Integrated, 187 lumens | Integrated, 187 lumens |
Power Source | Rechargeable Battery (6200mAh) | Battery + Solar Panel | Battery + Solar Panel |
Motion Detection | Radar + PIR | Radar + PIR | Radar + PIR |
Weather Resistance | IP65 | IP65 | IP65 |
Battery Life | Up to 6 months | Extended with solar | Extended with solar |
Two-Way Audio | Yes | Yes | Yes |
Smart Home Integration | Alexa, Google Assistant, IFTTT | Alexa, Google Assistant, IFTTT | Alexa, Google Assistant, IFTTT |
What is the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro is a wireless security camera featuring 2.5K HDR video resolution, an integrated 187-lumen spotlight, and a 100 dB siren. It is designed for easy installation, offers advanced motion detection, and is ideal for monitoring and illuminating dark areas around your home.How long does the Wyze Battery Cam Pro battery last?
The Wyze Battery Cam Pro uses removable, rechargeable 6200mAh battery packs that can last up to 6 months on a single charge, depending on usage and environmental conditions.Is the Wyze Battery Cam Pro weatherproof?
Yes, the Wyze Battery Cam Pro has an IP65 weatherproof rating, making it suitable for outdoor use in rain, snow, and extreme temperatures ranging from -20°C to 50°C.Does the Wyze Battery Cam Pro require a hub for installation?
No, the Wyze Battery Cam Pro is completely wire-free and does not require a hub. It connects directly to your WiFi network for easy setup and operation.What motion detection technology does the Wyze Battery Cam Pro use?
The Wyze Battery Cam Pro uses advanced radar and PIR (Passive Infrared) motion detection sensors to accurately detect movement and trigger alerts, spotlight, and siren.Can I store video footage locally on the Wyze Battery Cam Pro?
Yes, the Wyze Battery Cam Pro supports local storage with a microSD card of up to 256 GB, allowing you to record and access footage without a cloud subscription.Does the Wyze Battery Cam Pro support cloud storage?
Yes, you can subscribe to Wyze Cam Plus for cloud storage, which allows you to access and review your video footage remotely.What is included in the Wyze Battery Cam Pro + Solar Panel bundle?
The Wyze Battery Cam Pro + Solar Panel bundle includes the Wyze Battery Cam Pro camera and a solar panel, providing sustainable, continuous power by harnessing sunlight for extended battery life.What are the benefits of the Wyze Bird Feeder Wireless Camera Bundle?
The Wyze Bird Feeder Wireless Camera Bundle combines the Wyze Battery Cam Pro, a weather-resistant bird feeder, and a solar panel. It allows you to monitor your yard, enjoy live bird watching, and maintain security with sustainable power.Does the Wyze Battery Cam Pro have two-way audio?
Yes, the Wyze Battery Cam Pro features built-in two-way audio, allowing you to listen and speak through the camera using the Wyze app.Is the Wyze Battery Cam Pro compatible with smart home systems?
Yes, the Wyze Battery Cam Pro integrates with Alexa, Google Assistant, and IFTTT, making it easy to incorporate into your smart home ecosystem.What WiFi networks does the Wyze Battery Cam Pro support?
The Wyze Battery Cam Pro supports both 2.4 GHz and 5 GHz WiFi networks, ensuring reliable and flexible connectivity.Does the Wyze Battery Cam Pro offer color night vision?
Yes, thanks to its integrated spotlight, the Wyze Battery Cam Pro provides color night vision, allowing you to see vibrant details even in low-light conditions.What is the field of view of the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro offers a wide field of view with 134° diagonal, 108° horizontal, and 56° vertical coverage, ensuring comprehensive monitoring of your property.In what colors is the Wyze Battery Cam Pro available?
The Wyze Battery Cam Pro is available in sleek Black or White finishes, allowing it to blend seamlessly with any home exterior.
