Wyze Cam OG with Built-In Spotlight: Bright, Smart Home Security
Discover the Wyze Cam OG with Built-In Spotlight
The Wyze Cam OG is the next generation of Wyze's popular security cameras, designed to provide enhanced home security with advanced features including a built-in spotlight. Whether you need indoor or outdoor surveillance, this camera offers a powerful combination of clarity, speed, and smart functionality.
Key Features of Wyze Cam OG
  • Built-In Spotlight: Equipped with a 40-lumen spotlight (5000K color temperature) that illuminates your surroundings, enhancing visibility during nighttime or low-light conditions.
  • Video Quality: Full HD 1080p resolution with a CMOS-Starlight Sensor ensures crisp and clear video both day and night.
  • Field of View: Wide 120° field of view captures more area, reducing blind spots.
  • Fast Live Streaming: Experience 50% faster live streaming compared to previous Wyze models, so you never miss a moment.
  • Two-Way Audio: Upgraded microphone and speaker with noise and echo cancellation allow clear communication.
  • Night Vision: Four IR LEDs provide reliable night vision, complemented by the spotlight for color night vision.
  • Weather Resistant: Rated IP65, suitable for outdoor use in various weather conditions.
  • Local Storage: Supports up to 256 GB microSD cards for continuous local recording.
  • Additional Security: Includes a 90-decibel user-activated siren for deterrence.
  • Compatibility: Works seamlessly with Android 9.0+ and iOS 15.0+ devices.
This camera is perfect for homeowners looking for a reliable, affordable security solution with the added benefit of a built-in spotlight to brighten dark areas and deter unwanted visitors.
Wyze Cam OG Telephoto: Zoom In with Precision
For those who want to focus on details from a distance, the Wyze Cam OG Telephoto is an excellent choice. It shares many features with the OG but adds a powerful 3x telephoto lens for enhanced zoom capabilities.
Highlights of Wyze Cam OG Telephoto
  • 3x Telephoto Lens: Narrower field of view (27° diagonal) allows you to zoom in on specific areas or objects without losing image quality.
  • 1080p HD Video: Same high-definition video quality with CMOS-Starlight Sensor.
  • Night Vision: Four IR LEDs for clear night-time footage.
  • Two-Way Audio: Built-in speaker and microphone with noise and echo cancellation.
  • Weatherproof: IP65 rating for reliable outdoor use.
  • Smart Integrations: Compatible with Alexa, Google Assistant, and IFTTT for smart home automation.
  • Mounting Flexibility: Can be mounted on walls, ceilings, or used with a stand.
  • Local Storage: Supports up to 256 GB microSD cards.
This camera is ideal for users who want to monitor specific points of interest like driveways, gates, or distant entryways with sharp zoomed-in views.
Wyze Cam OG Bundle: Best of Both Worlds
The Wyze Cam OG Bundle combines the standard Wyze Cam OG with the Telephoto version, giving you a comprehensive security setup with two complementary perspectives.
Bundle Features
  • Dual Cameras: One wide-angle Wyze Cam OG with built-in spotlight and one Wyze Cam OG Telephoto with 3x zoom.
  • Spotlight & Night Vision: Both cameras feature 40-lumen spotlights and IR night vision for clear color video day and night.
  • Smart Home Compatibility: Works with Alexa, Google Assistant, and IFTTT.
  • Weather Resistant: Both cameras rated IP65 for indoor/outdoor use.
  • Local Storage: Supports microSD cards up to 256 GB.
  • Enhanced Audio: Two-way audio with noise and echo cancellation.
  • Fast Notifications: 3X faster alerts keep you informed instantly.
  • Easy Setup: Includes power adapters and mounting hardware.
This bundle is perfect for users who want a versatile security system that covers wide areas and zoomed-in details simultaneously, all with the convenience of built-in spotlights.
Enhance Your Setup with Wyze Cam OG Stack Kit
For users who want to maximize their surveillance coverage, the Wyze Cam OG Stack Kit allows you to stack and power two Wyze Cam OG or OG Telephoto cameras together. This kit includes a stack mount, dual USB power cable, and a power adapter, making it easy to install multiple cameras in one location for layered security views.
Why Choose Wyze Cam OG with Built-In Spotlight?
The built-in spotlight not only improves night-time visibility but also acts as a deterrent to potential intruders. Combined with fast live streaming, two-way audio, and weather resistance, the Wyze Cam OG is a smart, affordable choice for modern home security.
Home Security with Wyze Cam OG Spotlight Alt text: Family monitoring their home security with Wyze Cam OG spotlight at night Wyze Cam OG Telephoto Zoom Alt text: Close-up view of driveway monitored by Wyze Cam OG Telephoto camera Wyze Cam OG Bundle Setup Alt text: Dual Wyze Cam OG cameras installed on a porch for comprehensive coverage
Summary of Wyze Cam OG Series with Spotlight
FeatureWyze Cam OGWyze Cam OG TelephotoWyze Cam OG Bundle
Video Resolution1080p HD1080p HD1080p HD
Built-In SpotlightYes (40 lumens)NoYes (40 lumens each)
Telephoto LensNoYes (3x zoom)Yes (1 standard, 1 telephoto)
Field of View120°27°120° + 27°
Night VisionIR LEDs + SpotlightIR LEDsIR LEDs + Spotlight
Two-Way AudioYesYesYes
Weather ResistanceIP65IP65IP65
Local Storage SupportUp to 256 GB microSDUp to 256 GB microSDUp to 256 GB microSD
Smart Home IntegrationAlexa, Google, IFTTTAlexa, Google, IFTTTAlexa, Google, IFTTT
Warranty1 Year1 Year1 Year
Invest in the Wyze Cam OG with built-in spotlight to secure your home with bright, clear video and smart features that keep you connected anytime, anywhere. Whether you choose the standard model, the telephoto lens, or the bundle, you get reliable, affordable security designed for modern living.
FeatureWyze Cam OGWyze Cam OG BundleWyze Cam OG Telephoto
Price$29.98 (1 Pack)$74.99$25.98 (1 Pack)
Pack Options1, 2, 3 PacksBundle (includes 2 cams + accessories)1, 2 Packs
Field of View120°Includes 1x Wyze Cam OG (120°) + 1x Telephoto (27°)27° DFOV, 23.6° HFOV, 13.6° VFOV
Night VisionColor Night VisionColor Night VisionColor Night Vision
SpotlightBuilt-in 40-lumen spotlightBuilt-in spotlight (40 lumens)No spotlight
Telephoto LensNoYes (3x Telephoto lens included)Yes (3x Telephoto lens)
Two-Way AudioUpgraded two-way audioUpgraded two-way audioBuilt-in speaker & microphone
Motion Notifications3x faster notifications3x faster notifications3x faster notifications
Weather ResistanceIP65 (Indoor/Outdoor)IP65 (Indoor/Outdoor)IP65 (Indoor/Outdoor*)
Local Storage SupportmicroSD up to 256GBmicroSD up to 256GBmicroSD up to 256GB
Cloud StorageCam Plus subscription availableCam Plus subscription availableCam Plus subscription available
Connectivity2.4 GHz Wi-Fi2.4 GHz Wi-Fi2.4 GHz Wi-Fi
DimensionsNot specifiedNot specified1.89" x 1.89" x 1.89" (48mm x 48mm x 48mm)
WeightNot specifiedNot specified4.1 oz (116 g)
Power Adapter Input110-240V AC/DC110-240V AC/DC110-240V AC/DC
Power Adapter Output5V/1A5V/1A5V/1A
Additional FeaturesBuilt-in mini-siren, customizable detection zones, smoke & CO alertsIncludes Stack Kit for dual camera setup, built-in sirenNoise & echo cancellation, 8x digital zoom
WarrantyNot specifiedNot specified1 Year
What is the Wyze Cam OG with Built-In Spotlight?The Wyze Cam OG with Built-In Spotlight is a next-generation security camera from Wyze, featuring a 40-lumen built-in spotlight, full HD 1080p video, two-way audio, night vision, and weather resistance. It is designed for both indoor and outdoor home security, providing enhanced visibility and smart features for reliable surveillance.
What are the key features of the Wyze Cam OG?Key features of the Wyze Cam OG include a 40-lumen built-in spotlight, 1080p HD video with a CMOS-Starlight Sensor, 120° wide field of view, 50% faster live streaming, two-way audio with noise and echo cancellation, IR night vision, IP65 weather resistance, support for up to 256 GB microSD cards, a 90-decibel siren, and compatibility with Android 9.0+ and iOS 15.0+ devices.
How does the built-in spotlight on the Wyze Cam OG improve security?The built-in 40-lumen spotlight on the Wyze Cam OG enhances night-time and low-light visibility, allowing for clear color video even in darkness. It also acts as a deterrent to potential intruders by illuminating the area when motion is detected or when activated by the user.
Is the Wyze Cam OG suitable for outdoor use?Yes, the Wyze Cam OG is rated IP65 weather resistant, making it suitable for both indoor and outdoor use in various weather conditions.
What is the difference between the Wyze Cam OG and Wyze Cam OG Telephoto?The Wyze Cam OG features a wide 120° field of view and a built-in spotlight, making it ideal for general surveillance. The Wyze Cam OG Telephoto, on the other hand, has a 3x telephoto lens with a narrower 27° field of view, allowing you to zoom in on specific areas or objects for detailed monitoring. The Telephoto version does not have a built-in spotlight but shares other features like 1080p HD video, night vision, and weather resistance.
Can I use both the Wyze Cam OG and Telephoto together?Yes, the Wyze Cam OG Bundle includes both the standard Wyze Cam OG and the Wyze Cam OG Telephoto, allowing you to cover wide areas and zoomed-in details simultaneously for comprehensive home security.
Does the Wyze Cam OG support local video storage?Yes, the Wyze Cam OG supports local storage with microSD cards up to 256 GB, enabling continuous recording and easy access to your footage.
Is the Wyze Cam OG compatible with smart home systems?Yes, the Wyze Cam OG and Wyze Cam OG Telephoto are compatible with Alexa, Google Assistant, and IFTTT, allowing for seamless integration with your smart home setup.
What is included in the Wyze Cam OG Bundle?The Wyze Cam OG Bundle includes one Wyze Cam OG with a built-in spotlight and one Wyze Cam OG Telephoto with a 3x zoom lens. Both cameras feature IR night vision, weather resistance, two-way audio, support for up to 256 GB microSD cards, and smart home compatibility. The bundle also comes with power adapters and mounting hardware for easy setup.
What is the Wyze Cam OG Stack Kit and how does it work?The Wyze Cam OG Stack Kit allows you to stack and power two Wyze Cam OG or OG Telephoto cameras together in one location. It includes a stack mount, dual USB power cable, and a power adapter, making it easy to install multiple cameras for layered security coverage.
Does the Wyze Cam OG have two-way audio?Yes, the Wyze Cam OG features upgraded two-way audio with a built-in microphone and speaker, including noise and echo cancellation for clear communication.
What is the warranty period for Wyze Cam OG products?All Wyze Cam OG series products, including the standard, Telephoto, and bundle options, come with a 1-year warranty.
How fast are the notifications from Wyze Cam OG cameras?Wyze Cam OG cameras provide 3X faster alerts compared to previous models, ensuring you receive instant notifications about activity detected by your cameras.
What are the main differences between the Wyze Cam OG and the Wyze Cam OG Telephoto?Can you tell me more about the local storage options for the Wyze Cam OG?Do you have any ongoing sales or discounts for the Wyze Cam OG?
