Wyze Cam v3 Smart Security Kit for Indoor and Outdoor Monitoring
When it comes to securing your home both inside and out, the
Wyze Cam v3 Smart Security Kit offers a comprehensive solution that combines cutting-edge technology, versatile mounting options, and seamless smart home integration. Whether you want to monitor your living room, backyard, or front porch, Wyze provides reliable, high-resolution cameras and accessories designed to keep your property safe 24/7.
Explore the Wyze Cam v4 Series: The Heart of Your Security Kit
Wyze Cam v4 – Indoor and Outdoor Ready
The Wyze Cam v4 is the latest evolution in Wyze’s lineup, perfect for both indoor and outdoor use thanks to its IP65 weather resistance rating. It delivers crystal-clear
2.5K QHD (2560x1440) video resolution with an ultra-wide field of view (DFOV 115.8°), ensuring you capture every detail.
- Enhanced Color Night Vision: See vibrant colors even in low light with 4 IR LEDs and 2 white spotlight LEDs.
- Motion-Activated Spotlight: Automatically lights up when motion is detected, deterring intruders.
- Two-Way Audio & Built-in Siren: Communicate through the camera or scare off unwanted visitors with a loud 99dB siren.
- Wi-Fi 6 Support: Faster, more reliable wireless connectivity.
- Multiple Mounting Options: Stand, wall, ceiling, or magnetic mounts for flexible placement.
- Local and Cloud Storage: Supports microSD cards up to 512GB and optional cloud subscriptions.
- Smart Home Integration: Works seamlessly with Alexa, Google Assistant, and IFTTT.
This camera is designed to withstand temperatures from -4°F to 122°F (-20°C to 50°C), making it ideal for year-round outdoor monitoring.
Experience reliable outdoor security with Wyze Cam v4’s enhanced night vision and spotlight.
Wyze Cam v4 Outdoor Bundle – Complete Outdoor Protection
For those focused on outdoor security, the
Wyze Cam v4 Outdoor Bundle includes everything you need:
- Wyze Cam v4 Camera with all the features above.
- Wyze Outdoor Power Adapter for continuous wired power.
- Wyze MicroSD Card 128GB for 24/7 local recording.
This bundle is tailored for outdoor use with enhanced weatherproofing and smart features like motion detection zones and smoke/CO alerts. It supports Wi-Fi 6 and integrates with Alexa and Google Assistant for voice control.
Wyze Cam v4 Home Security Bundle – Indoor and Outdoor Coverage
The
Wyze Cam v4 Home Security Bundle is an all-in-one package designed for comprehensive home monitoring:
- Includes multiple Wyze Cam v4 cameras suitable for both indoor and outdoor use.
- Features person detection and motion-activated spotlight to reduce false alarms.
- Supports 128GB microSD card for extensive local video storage.
- Offers improved two-way audio for clear communication.
- Weather-resistant with IP65 rating, perfect for any environment.
This bundle is ideal for homeowners who want to secure multiple areas with a single purchase, combining convenience and advanced technology.
Power Your Wyze Cam v3 with the Cam v4 + Lamp Socket v2 Bundle
If you already own a Wyze Cam v3 or v4 and want to simplify outdoor power setup, the
Cam v4 + Lamp Socket v2 Bundle is a smart accessory:
- Powers Wyze Cams directly from a lamp socket without needing an outlet.
- Features motion-activated lights and dusk-to-dawn scheduling.
- Compatible with Wyze Cam v3, v3 Pro, v4, OG, and Pan v3.
- Easy installation with standard E26 socket.
- Suitable for damp locations (not fully waterproof).
This bundle enhances your outdoor lighting and security setup by combining power and smart automation in one device.
Whole Home Security Starter Kit – The Ultimate Smart Security Solution
For those looking to start with a complete smart security system, the
Whole Home Security Starter Kit includes:
- 1x Wyze Cam v4 for versatile indoor/outdoor monitoring.
- 1x Wyze Video Doorbell v2 to monitor your front door.
- 1x Wyze Home Monitoring Starter Kit for comprehensive home security.
Available in multiple colors, this kit offers a seamless smart home experience with easy app control, voice assistant compatibility, and robust security features.
Why Choose Wyze Cam v3 Smart Security Kit?
Wyze combines affordability with advanced features like 2.5K QHD video, color night vision, and smart home integration. Whether you need indoor peace of mind or outdoor vigilance, Wyze’s cameras and bundles provide flexible, reliable solutions tailored to your home’s unique needs.
Keep an eye on your indoor spaces with Wyze Cam’s crystal-clear video and smart alerts.
Summary of Wyze Cam v3 Smart Security Kit Components
Product Name | Key Features | Ideal Use |
Wyze Cam v4 | 2.5K QHD, color night vision, IP65, Wi-Fi 6 | Indoor & Outdoor |
Wyze Cam v4 Outdoor Bundle | Includes power adapter & 128GB microSD | Outdoor continuous power |
Wyze Cam v4 Home Security Bundle | Multi-camera kit, person detection, spotlight | Whole home indoor/outdoor |
Cam v4 + Lamp Socket v2 Bundle | Powers Wyze cams via lamp socket, motion lights | Outdoor power convenience |
Whole Home Security Starter Kit | Cam v4, video doorbell, monitoring kit | Complete home security kit |
By choosing the Wyze Cam v3 Smart Security Kit and its related Wyze Cam v4 products, you get a powerful, flexible, and affordable security system that covers every corner of your home with smart technology and reliable performance.
What is included in the Wyze Cam v3 Smart Security Kit?
The Wyze Cam v3 Smart Security Kit includes high-resolution Wyze cameras and accessories designed for both indoor and outdoor monitoring. It offers advanced features like 2.5K QHD video, color night vision, motion-activated spotlight, two-way audio, and smart home integration for comprehensive home security.What are the key features of the Wyze Cam v4?
The Wyze Cam v4 features 2.5K QHD (2560x1440) video resolution, enhanced color night vision, motion-activated spotlight, two-way audio with a built-in 99dB siren, Wi-Fi 6 support, multiple mounting options, local and cloud storage, and seamless integration with Alexa, Google Assistant, and IFTTT. It is IP65 weather-resistant and suitable for both indoor and outdoor use.Is the Wyze Cam v4 suitable for outdoor use?
Yes, the Wyze Cam v4 is designed for both indoor and outdoor use. It has an IP65 weather resistance rating and can operate in temperatures ranging from -4°F to 122°F (-20°C to 50°C), making it ideal for year-round outdoor monitoring.What is included in the Wyze Cam v4 Outdoor Bundle?
The Wyze Cam v4 Outdoor Bundle includes a Wyze Cam v4 camera, a Wyze Outdoor Power Adapter for continuous wired power, and a Wyze MicroSD Card 128GB for 24/7 local recording. This bundle is tailored for outdoor use with enhanced weatherproofing and smart features like motion detection zones and smoke/CO alerts.What does the Wyze Cam v4 Home Security Bundle offer?
The Wyze Cam v4 Home Security Bundle includes multiple Wyze Cam v4 cameras for both indoor and outdoor coverage, person detection, motion-activated spotlight, 128GB microSD card for local storage, improved two-way audio, and IP65 weather resistance. It is ideal for homeowners seeking comprehensive security for multiple areas.How can I power my Wyze Cam v3 or v4 outdoors without an outlet?
You can use the Cam v4 + Lamp Socket v2 Bundle to power your Wyze Cam v3, v3 Pro, v4, OG, or Pan v3 directly from a standard E26 lamp socket. This accessory also features motion-activated lights and dusk-to-dawn scheduling, making it a convenient solution for outdoor power and lighting.What is included in the Whole Home Security Starter Kit?
The Whole Home Security Starter Kit includes one Wyze Cam v4 for versatile indoor/outdoor monitoring, one Wyze Video Doorbell v2 for front door security, and one Wyze Home Monitoring Starter Kit for comprehensive home protection. It offers easy app control, voice assistant compatibility, and robust security features.Does Wyze Cam v4 support local and cloud storage?
Yes, the Wyze Cam v4 supports both local and cloud storage. It is compatible with microSD cards up to 512GB for continuous local recording and also offers optional cloud subscription plans for additional storage and features.Is Wyze Cam v4 compatible with smart home systems?
Yes, Wyze Cam v4 integrates seamlessly with popular smart home systems, including Amazon Alexa, Google Assistant, and IFTTT, allowing for voice control and automation within your smart home ecosystem.What are the mounting options for Wyze Cam v4?
Wyze Cam v4 offers multiple mounting options, including stand, wall, ceiling, and magnetic mounts, providing flexible placement for optimal indoor or outdoor coverage.What makes Wyze Cam v3 Smart Security Kit a good choice for home security?
The Wyze Cam v3 Smart Security Kit is an affordable yet advanced solution, offering high-resolution video, color night vision, smart alerts, and compatibility with major smart home platforms. Its flexible bundles and accessories make it easy to secure both indoor and outdoor areas of your home.
