Wyze Cam OG Bundle: Complete Indoor & Outdoor Security Cameras
Wyze Cam OG Bundle: The Ultimate Indoor & Outdoor Security Setup
Looking for a comprehensive security solution that covers every corner of your home? The Wyze Cam OG Bundle offers a complete, reliable, and smart security setup with indoor and outdoor cameras designed to keep your property safe 24/7. Whether you want to monitor your front porch, backyard, or indoor spaces, this bundle combines the best of Wyze’s innovative camera technology with easy installation and smart home integration.
Wyze Cam OG: Compact, Fast, and Versatile Indoor/Outdoor Camera
The Wyze Cam OG is the next generation of Wyze’s popular camera line, designed for both indoor and outdoor use with IP65 weather resistance. It features:
  • 1080p Full HD video resolution with smooth 20 FPS daytime and 15 FPS nighttime streaming.
  • Faster live streaming with 50% quicker video feed compared to previous models.
  • Built-in 40-lumen spotlight and a 90-decibel siren for active deterrence.
  • Enhanced two-way audio with noise and echo cancellation for crystal-clear communication.
  • Custom detection zones to focus on important areas and reduce false alerts.
  • Supports up to 256 GB microSD local storage and cloud storage options.
  • Works seamlessly with Alexa and Google Assistant for voice control.
  • Compact size (1.89 in cube) and lightweight (4.1 oz) for flexible mounting options.
This camera is perfect for monitoring entryways, patios, or indoor rooms with quick alerts and clear video day or night.
Wyze Cam v4: High-Resolution Outdoor Security with Color Night Vision
For those who want ultra-clear video and advanced night vision, the Wyze Cam v4 is an excellent choice:
  • 2.5K QHD resolution (2560x1440) delivers crystal-clear images and video.
  • Enhanced Color Night Vision with 4 IR LEDs plus 2 white spotlight LEDs (72 lumens) to see vivid colors even in the dark.
  • Motion-activated spotlight to illuminate and deter intruders.
  • Wi-Fi 6 support for faster and more reliable connectivity.
  • 24/7 local recording with microSD card support up to 512 GB.
  • Weather-resistant IP65 rating ensures durability in harsh outdoor conditions.
  • Compatible with Alexa, Google Assistant, and IFTTT for smart home automation.
  • Multiple mounting options including magnetic wall mount, ceiling, and stand.
Ideal for front yards, driveways, or any outdoor area where high-quality video and color night vision are essential.
Wyze Cam Pan v3: 360° Pan & 180° Tilt for Full Coverage
Cover every angle with the Wyze Cam Pan v3, a versatile indoor/outdoor camera with dynamic movement:
  • 360° horizontal and 180° vertical field of view with smooth pan and tilt capabilities.
  • 1080p HD video resolution with 20 FPS daytime and 15 FPS nighttime.
  • IP65 weather resistance for reliable outdoor use (requires Wyze Outdoor Power Adapter).
  • Fast rotation speed up to 110° per second to track movement instantly.
  • Two-way audio with noise and echo cancellation for clear communication.
  • Supports up to 256 GB microSD local storage.
  • Compatible with Alexa, Google Assistant, and IFTTT.
  • Push notifications for real-time alerts.
This camera is perfect for large areas like backyards or garages where you need flexible viewing angles and full coverage. Wyze Cam Pan v3 in snowy outdoor setting Wyze Cam Pan v3 providing weather-resistant outdoor security
Wyze Cam Floodlight v2: Brighten and Secure Your Outdoor Spaces
Add powerful illumination and security with the Wyze Cam Floodlight v2, combining a floodlight and camera in one:
  • 2800 lumens of dimmable LED light panels with 5000K daylight color temperature.
  • 2K video resolution (2304 x 1296) with color night vision.
  • 160° wide-angle field of view to cover large outdoor areas.
  • AI-powered light control and dusk-to-dawn automation for smart lighting.
  • Built-in 105 dB siren and two-way audio for active deterrence and communication.
  • IP65 weather resistance for all-season durability.
  • Integrates with Alexa, Google Assistant, and IFTTT.
Perfect for driveways, porches, and garages where bright lighting and clear video are critical for security. Wyze Cam Floodlight v2 illuminating driveway at night Wyze Cam Floodlight v2 lighting up outdoor spaces with smart security
Why Choose the Wyze Cam OG Bundle for Your Security Setup?
The Wyze Cam OG Bundle offers a complete, smart, and scalable security solution for your home. Combining compact, fast, and weather-resistant cameras with advanced features like color night vision, pan-tilt-zoom, floodlight illumination, and two-way audio, this bundle ensures you never miss a moment—indoors or outdoors.
  • All-weather durability with IP65 ratings on all outdoor cameras.
  • Smart home integration with Alexa, Google Assistant, and IFTTT.
  • Flexible storage options including local microSD and cloud plans.
  • Easy installation and multiple mounting options for any space.
  • Real-time alerts and fast live streaming keep you connected wherever you are.
Secure your home with confidence using the Wyze Cam OG Bundle — the ultimate indoor and outdoor security setup.
Product Summary
ProductResolutionKey FeaturesWeather ResistancePrice Range (USD)
Wyze Cam OG1080p HDFast live stream, spotlight, sirenIP65$29.98 - $86.98
Wyze Cam v42.5K QHDColor night vision, spotlight, Wi-Fi 6IP65$35.98 - $107.94
Wyze Cam Pan v31080p HD360° pan, 180° tilt, push alertsIP65$39.98 - $116.98
Wyze Cam Floodlight v22K HD2800 lumens floodlight, AI lightingIP65$89.98
Secure your home today with the Wyze Cam OG Bundle — the perfect combination of indoor and outdoor cameras for complete peace of mind.
FeatureWyze Cam OGWyze Cam v4Wyze Cam Pan v3Wyze Cam Floodlight v2
Resolution1080p HD2.5K QHD1080p HD2K (2304 x 1296)
Field of View120°115.9° (D) x 98.5° (H) x 53.1° (V)120°160° Diagonal
Night VisionColor Night VisionEnhanced Color Night Vision4 IR LEDs (850 nm) B&W Night VisionColor Night Vision
SpotlightBuilt-in 40-lumen spotlightMotion-activated spotlightNoIntegrated LED floodlight (2800 lumens)
Siren90 dB user-activated siren99 dB sirenNo105 dB siren
Two-Way AudioUpgraded two-way audioEnhanced two-way talk (AAC)Built-in speaker & mic; 2-way audioBuilt-in speaker & mic; 2-way audio
Weather ResistanceIP65IP65IP65IP65
Indoor/Outdoor UseIndoor/outdoor*Indoor/outdoor**Indoor/outdoor*Outdoor (hardwired)
Continuous Local RecordingSupports microSD up to 256GB24/7 local recording, up to 512GBSupports microSD up to 256GBSupports microSD up to 256GB
ConnectivityWiredWired, Wi-Fi 6 supportWired, 2.4 GHz Wi-Fi onlyWired, 2.4 GHz Wi-Fi only
MountingFixedFixed360° pan, 180° tiltWall or ceiling mount
Dimensions (approx.)Not specifiedNot specified124mm x 60mm x 63mm9.5in x 7.7in x 7.0in (24.13cm x 19.56cm x 17.78cm)
WeightNot specifiedNot specified11.29 oz (320 g)2.76 lbs (1.25 kg)
Smart Assistant IntegrationYes (Alexa, Google Assistant)Yes (Alexa, Google Assistant, IFTTT)Yes (Alexa, Google Assistant, IFTTT)Yes (Alexa, Google Assistant, IFTTT)
Special Features3x faster notifications, built-in spotlight, improved 2-way audioAuto-zoom with AI, Wi-Fi 6, enhanced color night vision, smoke & CO alerts360° pan & 180° tilt, noise & echo cancellation2800 lumens LED floodlight, ambient light mode, AI-powered light control, dusk-to-dawn automation
Price Range (single pack)$29.98$35.98$39.98$89.98
What is included in the Wyze Cam OG Bundle?The Wyze Cam OG Bundle includes a selection of Wyze’s top security cameras designed for both indoor and outdoor use. The bundle features the Wyze Cam OG, Wyze Cam v4, Wyze Cam Pan v3, and Wyze Cam Floodlight v2, providing comprehensive coverage for your home with advanced features like HD video, color night vision, pan and tilt, floodlight illumination, and smart home integration.
Are Wyze Cam OG Bundle cameras suitable for outdoor use?Yes, all cameras in the Wyze Cam OG Bundle are designed with IP65 weather resistance, making them suitable for both indoor and outdoor use. This ensures reliable performance in various weather conditions, including rain and snow.
What video resolution do the Wyze Cam OG Bundle cameras offer?The Wyze Cam OG offers 1080p Full HD resolution, the Wyze Cam v4 provides 2.5K QHD (2560x1440) resolution, the Wyze Cam Pan v3 features 1080p HD, and the Wyze Cam Floodlight v2 delivers 2K HD (2304x1296) resolution. This range ensures clear and detailed video for all your security needs.
Do Wyze Cam OG Bundle cameras support night vision?Yes, all cameras in the Wyze Cam OG Bundle support night vision. The Wyze Cam v4 and Wyze Cam Floodlight v2 offer enhanced color night vision, allowing you to see vivid colors even in low-light conditions. Other cameras provide clear infrared night vision for reliable monitoring after dark.
Can I use voice assistants with Wyze Cam OG Bundle cameras?Absolutely. The Wyze Cam OG Bundle cameras are compatible with Alexa and Google Assistant, allowing you to control your cameras and view live feeds using voice commands. They also support IFTTT for advanced smart home automation.
What storage options are available for Wyze Cam OG Bundle cameras?Wyze Cam OG Bundle cameras support both local and cloud storage. You can use microSD cards (up to 256 GB or 512 GB depending on the model) for continuous local recording, or opt for Wyze’s cloud storage plans for secure, remote access to your video footage.
How easy is it to install Wyze Cam OG Bundle cameras?Installation is straightforward and user-friendly. The cameras come with multiple mounting options, including magnetic wall mounts, ceiling mounts, and stands, making it easy to set up in any location. The compact and lightweight design further simplifies installation.
What are the key features of the Wyze Cam OG?The Wyze Cam OG features 1080p HD video, a built-in 40-lumen spotlight, a 90-decibel siren, enhanced two-way audio, custom detection zones, fast live streaming, and IP65 weather resistance. It is ideal for both indoor and outdoor monitoring.
What makes the Wyze Cam v4 ideal for outdoor security?The Wyze Cam v4 offers 2.5K QHD resolution, enhanced color night vision, a motion-activated spotlight, Wi-Fi 6 support for faster connectivity, and IP65 weather resistance. These features make it perfect for monitoring outdoor areas like front yards and driveways.
How does the Wyze Cam Pan v3 provide full coverage?The Wyze Cam Pan v3 offers a 360° horizontal and 180° vertical field of view with smooth pan and tilt capabilities. It can quickly rotate to track movement, making it ideal for large areas where you need flexible and comprehensive coverage.
What are the benefits of the Wyze Cam Floodlight v2?The Wyze Cam Floodlight v2 combines a powerful 2800-lumen dimmable LED floodlight with a 2K HD camera, color night vision, AI-powered light control, a 105 dB siren, and two-way audio. It is perfect for illuminating and securing large outdoor spaces like driveways and garages.
Do Wyze Cam OG Bundle cameras send real-time alerts?Yes, the cameras in the Wyze Cam OG Bundle provide real-time push notifications for motion and sound detection, ensuring you are instantly alerted to any activity around your home.
Is the Wyze Cam OG Bundle scalable for expanding security needs?Yes, the Wyze Cam OG Bundle is a scalable security solution. You can easily add more Wyze cameras and integrate them with your existing smart home setup to expand coverage as your security needs grow.
What are the key features of the Wyze Cam v4 compared to the Wyze Cam OG?Can you explain how the two-way audio feature works on the Wyze Cam OG?Do you have any ongoing sales or discounts for the Wyze Cam products?
