Wyze Bulb Color BR30: The Perfect Smart Bulb for Recessed Can Lighting
If you're searching for a smart bulb that fits recessed can lighting fixtures, the
Wyze Bulb Color BR30 is your ideal choice. Designed specifically for recessed lighting, this smart BR30 bulb offers vibrant color options and dimmable brightness to transform any room's ambiance effortlessly.
Key Features and Specifications
- Dimmable & Color-Changing: Customize your lighting with 16 million ultra-accurate colors and a wide lumen range from 30 to 950 lumens, perfect for setting the mood or brightening up your space.
- Fits Recessed Fixtures: The BR30 shape and E26 base ensure compatibility with most recessed can lighting fixtures you already own.
- Color Temperature Range: Adjustable from warm 1800K to cool 6500K white light, allowing you to tailor the lighting to your preference.
- Power & Efficiency: Consumes 11.5W with a 75W equivalent brightness, offering energy-efficient lighting.
- Long Life Expectancy: Rated for 25,000 hours, providing durable and reliable performance.
- Connectivity: Supports 802.11 b/g/n WiFi (2.4GHz) and Bluetooth for seamless smart home integration.
- Smart Features: Includes voice control, custom lighting scenes, sleep routines, vacation mode, and music mode to sync lighting with your lifestyle.
- Suitable for Damp Locations: Safe for use in bathrooms and kitchens but not for dimmer switches or totally enclosed fixtures.
Light up your life with a smart bulb that fits perfectly into your recessed can lighting, offering both style and functionality.
Alt text: Wyze Bulb Color BR30 smart bulb illuminating a cozy living room with colorful lighting
Why Choose Wyze Bulb Color BR30 for Your Recessed Lighting?
The Wyze Bulb Color BR30 stands out because it is specifically designed for recessed can fixtures, unlike standard bulbs that may not fit or perform optimally. Its wide lumen range means it can both brighten a room or create a soft, relaxing atmosphere. The extensive color palette and smart features make it perfect for any occasion, from lively parties to quiet evenings.
Other Wyze Smart Bulbs to Consider
While the BR30 is perfect for recessed can lighting, Wyze also offers other smart bulbs that might suit different fixtures or preferences:
Wyze Bulb Color (A19)
- Shape & Size: A19 bulb shape with E26 base, ideal for standard lamps and fixtures.
- Brightness: Extra bright with up to 1100 lumens.
- Color Options: 16 million colors with tunable white (1800K - 6500K).
- Power: 12 watts, energy-efficient.
- Smart Features: Voice control, app integration, and compatibility with Alexa, Google Assistant, and IFTTT.
- Life Expectancy: 25,000 hours.
- Suitable for Damp Locations: Yes, but not for enclosed luminaires.
This bulb is great for general smart lighting needs but is not designed for recessed can fixtures like the BR30.
Wyze Bulb White (A19)
- Brightness: 30-800 lumens with warm to cool white light (2700K - 6500K).
- Dimmable: Yes, with easy app control.
- Power: 9.5 watts.
- Smart Features: Voice control, sleep routines, vacation mode.
- Suitable for Damp Locations: Yes.
Ideal for those who prefer white light only and want simple smart lighting without color options.
Enhance Your Smart Lighting Setup
Pair your Wyze Bulb Color BR30 with other Wyze smart home devices for a fully integrated experience:
- Wyze Plug: Control non-smart devices with your voice or app, perfect for lamps or holiday lights.
- Wyze Light Strip: Add accent lighting with 16 million colors to complement your recessed lighting.
Alt text: Wyze Plug controlling kitchen appliances with smart home app
Summary
The
Wyze Bulb Color BR30 is the ultimate smart bulb for recessed can lighting, offering:
- Perfect fit for recessed fixtures
- 16 million colors and tunable white light
- Wide brightness range (30-950 lumens)
- Long-lasting and energy-efficient
- Advanced smart features including voice control and custom scenes
Upgrade your recessed lighting with Wyze Bulb Color BR30 and enjoy a smart, colorful, and customizable lighting experience.
What is the Wyze Bulb Color BR30 and what makes it ideal for recessed can lighting?
The Wyze Bulb Color BR30 is a smart LED bulb specifically designed for recessed can lighting fixtures. Its BR30 shape and E26 base ensure a perfect fit in most recessed cans, providing vibrant color options, dimmable brightness, and advanced smart features for a customizable lighting experience.What are the key features of the Wyze Bulb Color BR30 smart bulb?
Key features of the Wyze Bulb Color BR30 include 16 million color options, adjustable white light from 1800K to 6500K, dimmable brightness from 30 to 950 lumens, energy-efficient 11.5W power usage (75W equivalent), 25,000-hour lifespan, WiFi and Bluetooth connectivity, voice control, custom scenes, sleep routines, vacation mode, music mode, and suitability for damp locations.Is the Wyze Bulb Color BR30 compatible with my existing recessed can fixtures?
Yes, the Wyze Bulb Color BR30 is designed with a BR30 shape and E26 base, making it compatible with most standard recessed can lighting fixtures.Can I use the Wyze Bulb Color BR30 in bathrooms or kitchens?
Yes, the Wyze Bulb Color BR30 is suitable for damp locations, making it safe for use in bathrooms and kitchens. However, it should not be used in totally enclosed fixtures or with dimmer switches.What smart home features does the Wyze Bulb Color BR30 offer?
The Wyze Bulb Color BR30 offers voice control, custom lighting scenes, sleep routines, vacation mode, and music mode. It integrates seamlessly with your smart home via WiFi and Bluetooth.How energy efficient is the Wyze Bulb Color BR30?
The Wyze Bulb Color BR30 consumes only 11.5 watts of power while providing brightness equivalent to a 75W traditional bulb, making it highly energy efficient.How long does the Wyze Bulb Color BR30 last?
The Wyze Bulb Color BR30 is rated for a lifespan of 25,000 hours, ensuring long-lasting and reliable performance.Can I use the Wyze Bulb Color BR30 with dimmer switches or in fully enclosed fixtures?
No, the Wyze Bulb Color BR30 is not compatible with dimmer switches or totally enclosed fixtures.What is the difference between Wyze Bulb Color BR30 and Wyze Bulb Color (A19)?
The Wyze Bulb Color BR30 is designed for recessed can lighting with a BR30 shape, while the Wyze Bulb Color (A19) is intended for standard lamps and fixtures with an A19 shape. The A19 bulb is slightly brighter (up to 1100 lumens) but is not suitable for recessed can fixtures.Are there other Wyze smart bulbs available for different lighting needs?
Yes, Wyze offers the Bulb Color (A19) for standard fixtures and the Bulb White (A19) for those who prefer white light only. Both offer smart features and are suitable for damp locations, but only the BR30 is designed for recessed can lighting.Can I integrate the Wyze Bulb Color BR30 with other Wyze smart home devices?
Absolutely. The Wyze Bulb Color BR30 can be paired with other Wyze devices like the Wyze Plug and Wyze Light Strip for a fully integrated smart home lighting setup.
