Recessed Can Smart Bulbs: 16 Million Colors & Bright Lumens
Recessed Can Smart Lighting Bulbs with 16 Million Colors and Bright Lumens
Transform your home lighting with advanced recessed can smart bulbs that offer vibrant color options and powerful brightness. Whether you want to set the perfect mood for game day, create relaxing ambiance, or brighten your workspace, these smart bulbs deliver exceptional performance with 16 million colors and adjustable lumens. Explore the top Wyze smart lighting products designed specifically for recessed fixtures and beyond.
Wyze Bulb Color BR30: The Ultimate Recessed Can Smart Bulb
Brilliant Color and Brightness for Recessed Fixtures
The
Wyze Bulb Color BR30 is engineered to fit standard E26 recessed/can lighting sockets, making it the perfect upgrade for your existing fixtures. With a wide lumen range from 30 lumens to a bright 950 lumens (equivalent to 75W), this bulb outshines most competitors in its class. Enjoy precise control over 16 million ultra-accurate colors to create any atmosphere you desire.
Key Features
- Wide Lumen Range: Adjustable brightness from a subtle 30 lumens to a powerful 950 lumens.
- 16 Million Colors: Customize your lighting with a full spectrum of colors for every occasion.
- White Light Temperature Control: Tune from warm to cool white (1800K - 6500K) to match your mood or task.
- 90+ CRI Rating: See true, vibrant colors in your home with enhanced color rendering.
- Sun Match Technology: Automatically adjusts color temperature throughout the day to support your natural rhythm.
- Smart Notifications: Use color alerts for reminders and security notifications integrated with Wyze sensors.
- Sleep Routines: Wake up or fall asleep gently with gradual light changes mimicking sunrise and sunset.
- Voice Control: Compatible with Alexa and Google Assistant for hands-free operation.
- Vacation Mode: Simulate occupancy when you're away for added security.
Not compatible with dimmer switches.
Technical Specs
- Base Type: E26
- Shape: BR30
- Power: 11.5W
- Life Expectancy: 25,000 hours
- Connectivity: Wi-Fi (802.11 b/g/n 2.4GHz), Bluetooth
- Suitable for Damp Locations: Yes
- Operating Temperature: -4°F to 104°F
Create vibrant, customizable lighting in your recessed fixtures.
Wyze Bulb Color: Versatile Smart Bulb with Exceptional Brightness
Bright and Colorful Lighting for Any Room
The
Wyze Bulb Color is a versatile A19 smart bulb that delivers up to 1100 lumens of brightness, making it one of the brightest color bulbs available. Perfect for table lamps, ceiling fixtures, or recessed cans with compatible sockets, it offers 16 million colors and a wide dimming range from 30 lumens to 1100 lumens.
Highlights
- Dimmable and Bright: Adjust brightness from a soft 30 lumens to a brilliant 1100 lumens.
- 16 Million Colors: Choose from an extensive palette to set the perfect scene.
- White Light Temperature Control: Fine-tune from warm to cool white light.
- 90+ CRI: Experience true-to-life colors in your home.
- Custom Presets: Save your favorite lighting scenes for quick access.
- Smart Notifications & Automations: Integrate with Wyze sensors for visual alerts.
- Music Mode: Sync your lights to the beat when grouped with Wyze Light Strips.
- Voice and App Control: Works seamlessly with Alexa, Google Assistant, and the Wyze app.
- Vacation Mode & Sleep Routines: Enhance your lifestyle with smart automation.
Technical Details
- Base Type: E26
- Shape: A19
- Power: 12W
Brighten your home with vivid colors and smart control.
Smart Lighting Kits: Bulb Color BR30 + Light Strip Pro Bundles
Complete Smart Lighting Solutions for Recessed Fixtures and Accent Lighting
For those looking to elevate their smart lighting setup, Wyze offers bundled kits combining the
Wyze Bulb Color BR30 with the
Wyze Light Strip Pro. These kits provide both recessed can lighting and customizable LED accent lighting to color your world with brilliant effects.
Bundle Features
- Wyze Bulb Color BR30: Bright, color-changing recessed bulb with 950 lumens max brightness.
- Wyze Light Strip Pro: 16.4 feet of multicolor LED strip with 16 customizable zones and 16 million colors.
- Music Mode: Sync both bulbs and light strips to your favorite music.
- Smart Controls: Voice commands, app control, and automation routines.
- Durability: Both products have a 25,000-hour life expectancy.
- Connectivity: Wi-Fi and Bluetooth for seamless integration.
Technical Highlights of Light Strip Pro
- Length: 16.4 feet
- Colors: 16 million RGB + tunable white
- Customizable Zones: 16 segments for precise color control
- Power: 24 watts (16.4 ft)
- Indoor Use Only
These kits are perfect for creating immersive lighting environments in living rooms, home theaters, or gaming setups.
Why Choose Wyze Smart Lighting for Your Recessed Can Fixtures?
- Unmatched Color Range: 16 million colors let you customize every moment.
- Bright and Adjustable: From subtle night lights to bright task lighting.
- Smart Automation: Integrate with sensors and routines for convenience and security.
- Voice and App Control: Compatible with Alexa, Google Assistant, and Wyze app.
- Energy Efficient: Long-lasting bulbs with low power consumption.
- Designed for Recessed Fixtures: BR30 bulbs fit standard recessed cans perfectly.
Summary of Featured Products
Product Name | Max Lumens | Color Options | Shape/Base | Special Features |
Wyze Bulb Color BR30 | 950 lm | 16 million colors | BR30/E26 | Sun Match, Sleep Routines |
Wyze Bulb Color | 1100 lm | 16 million colors | A19/E26 | Music Mode, Custom Presets |
Smart Lighting Kit (BR30 + Strip) | 950 lm + LED strip | 16 million colors | BR30/E26 + Strip | Multi-zone control, Music Sync |
Elevate your home lighting with Wyze’s recessed can smart bulbs and lighting kits. Experience vibrant colors, bright illumination, and smart features that bring your space to life.
Feature | Wyze Bulb Color BR30 | Smart Lighting Kit - Bulb Color BR30 + Light Strip Pro Bundle |
Product Type | Connected Home, Smart Lighting | Smart Lighting Kit (Bulb + Light Strip) |
Bulb Shape | BR30 | BR30 |
Base Type | E26 | E26 |
Color Options | 16 million colors | 16 million colors |
Lumen Output | 30 lm (min) to 950 lm (max) | Same as Wyze Bulb Color BR30 |
White Light Temperature Control | Yes | Yes |
Color Rendering Index (CRI) | 90+ | 90+ |
Connectivity | Wi-Fi 2.4 GHz, Bluetooth | Wi-Fi 2.4 GHz, Bluetooth |
App Control | Wyze app | Wyze app |
Voice Control | Alexa, Google Assistant | Alexa, Google Assistant |
Special Features | Sun Match, Brilliant notifications, Music Mode, Vacation Mode, Sleep Routines | Includes all Wyze Bulb Color BR30 features plus Wyze Light Strip Pro features |
Light Strip Included | No | Yes, 16.4 ft Wyze Light Strip Pro |
Light Strip Features | N/A | Trim to length, adhere to surfaces, sync with bulbs, Music Mode |
Bundled Variants | 2-Pack, 4-Pack | Bulb 2-Pack + 16.4 ft Light Strip Pro, Bulb 4-Pack + 16.4 ft Light Strip Pro |
Price Range | $27.98 (2-Pack) to $49.98 (4-Pack) | $53.98 (2-Pack + Strip) to $77.97 (4-Pack + Strip) |
Suitable for Recessed Lighting | Yes | Yes |
Dimmable | Yes | Yes |
Not for Use in Dimmer Switches | Yes | Yes |
Return Policy | 30-day hassle-free returns | 30-day hassle-free returns |
What are recessed can smart lighting bulbs?
Recessed can smart lighting bulbs are advanced LED bulbs designed to fit into standard recessed or can lighting fixtures. They offer features like adjustable brightness, millions of color options, and smart controls for a customizable lighting experience.What is the Wyze Bulb Color BR30 and what makes it ideal for recessed fixtures?
The Wyze Bulb Color BR30 is a smart LED bulb engineered to fit standard E26 recessed or can lighting sockets. It offers a wide brightness range from 30 to 950 lumens, 16 million color options, and advanced features like Sun Match technology, sleep routines, and voice control, making it perfect for upgrading your recessed lighting.How many colors can Wyze smart bulbs display?
Wyze smart bulbs, including the Bulb Color BR30 and Bulb Color A19, can display up to 16 million colors, allowing you to customize your lighting for any mood or occasion.Can I adjust the brightness and color temperature of Wyze smart bulbs?
Yes, Wyze smart bulbs offer adjustable brightness ranging from 30 lumens up to 950 or 1100 lumens, depending on the model. You can also fine-tune the white light temperature from warm (1800K) to cool (6500K) to suit your preferences.Are Wyze smart bulbs compatible with voice assistants?
Yes, Wyze smart bulbs are compatible with popular voice assistants like Amazon Alexa and Google Assistant, enabling hands-free control of your lighting.What is Sun Match technology in Wyze Bulb Color BR30?
Sun Match technology automatically adjusts the color temperature of your Wyze Bulb Color BR30 throughout the day to support your natural circadian rhythm, helping you feel more energized during the day and relaxed at night.Can Wyze smart bulbs be used with dimmer switches?
No, Wyze smart bulbs are not compatible with dimmer switches. They are designed to be dimmed and controlled via the Wyze app, voice assistants, or automation routines.What is the difference between Wyze Bulb Color BR30 and Wyze Bulb Color A19?
The Wyze Bulb Color BR30 is designed for recessed can fixtures and offers up to 950 lumens, while the Wyze Bulb Color A19 is a versatile bulb suitable for table lamps, ceiling fixtures, and some recessed cans, offering up to 1100 lumens. Both provide 16 million colors and smart features.What is included in the Wyze Smart Lighting Kit?
The Wyze Smart Lighting Kit includes the Wyze Bulb Color BR30 for recessed lighting and the Wyze Light Strip Pro, a 16.4-foot multicolor LED strip with 16 customizable zones. The kit offers synchronized music mode, smart controls, and is ideal for immersive lighting setups.How long do Wyze smart bulbs and light strips last?
Wyze smart bulbs and light strips have a life expectancy of up to 25,000 hours, providing long-lasting and energy-efficient lighting for your home.Are Wyze smart bulbs energy efficient?
Yes, Wyze smart bulbs are energy efficient, consuming only 11.5W (BR30) or 12W (A19) while delivering bright and vibrant lighting. Their long lifespan also reduces the need for frequent replacements.Can Wyze smart bulbs be used in damp locations?
Yes, Wyze Bulb Color BR30 is suitable for use in damp locations, making it a great choice for bathrooms, kitchens, and other areas with higher humidity.What smart features do Wyze bulbs offer?
Wyze smart bulbs offer features such as customizable color presets, smart notifications, sleep routines, vacation mode, music sync (with Wyze Light Strip Pro), and integration with Wyze sensors for automation and security.How do I control Wyze smart bulbs?
You can control Wyze smart bulbs using the Wyze app, voice assistants like Alexa and Google Assistant, and through automation routines for scheduling and smart notifications.What connectivity options do Wyze smart bulbs support?
Wyze smart bulbs support Wi-Fi (802.11 b/g/n 2.4GHz) and Bluetooth connectivity for easy setup and reliable smart home integration.
Can you tell me more about the features of the Wyze Bulb Color BR30?How does the Sun Match Technology work in the Wyze smart bulbs?Do you have any ongoing sales or promotions for smart lighting products?
