Buy Yeelight Smart Cube Kit with RGB Pixel Graffiti Online
Where to Buy Yeelight Smart Cube Kit with RGB Pixel Graffiti
If you're searching for the Yeelight Smart Cube Kit featuring vibrant RGB pixel graffiti effects, this page highlights everything you need to know about this innovative lighting solution and where to find it. The Yeelight Smart Cube Kit is a modular LED lighting system designed to unleash your creativity with customizable RGB lighting, perfect for home décor, gaming setups, or artistic lighting displays.
Yeelight Smart Cube Kit: Modular RGB Pixel Graffiti Lighting
Overview
The Yeelight Smart Cube Kit is a unique lighting bundle that allows you to freely assemble 2 to 3 different types of Cube Lights included in the kit. It offers a stunning palette of 16 million colors, enabling you to create spectacular lighting effects with ease.
Key Features
  • Beat Kit Composition: Includes 1 Base Cube, 4 Panel Cubes, 2 Spotlight Cubes, and 1 Adapter.
  • RGB Pixel Matrix: Each cube features 25 RGB color light clusters arranged in a 5x5 grid, supporting up to 16,000K color variations.
  • Soft RGB Panels: The panel cubes use soft light panels with RGB technology for smooth, customizable lighting.
  • Spotlight Cubes: Project focused 15-degree colored beams with adjustable directionality for dynamic effects.
  • Magnetic Connections: Modules connect magnetically, allowing 360-degree rotation and flexible arrangements.
  • Customization: Addressable LED beads can be programmed into emojis, letters, numbers, and more.
  • Integration: Seamlessly integrates with other Yeelight products for an immersive smart lighting experience.
  • Control: Requires the Yeelight app for full functionality and customization.
Why Choose Yeelight Smart Cube Kit?
This kit is perfect for those who want to add a personalized, artistic touch to their space with smart lighting. Whether you want to create pixel art, ambient lighting, or interactive light shows, the Yeelight Smart Cube Kit offers unmatched flexibility and color depth. Lifestyle image of Yeelight Smart Cube Kit in a creative room setup Alt text: Creative room with colorful modular LED cube lighting
Additional Smart Lighting Options: Wyze Light Strip
While the Yeelight Smart Cube Kit is ideal for pixelated RGB lighting, the Wyze Light Strip offers another excellent option for brilliant LED accent lighting in your home.
Wyze Light Strip Highlights
  • Available in 16.4 feet and 32.8 feet lengths.
  • Supports 16 million colors with vibrant LED lighting.
  • Features adhesive backing for easy mounting under cabinets, behind sofas, or along walls.
  • Cuttable design allows customization of length.
  • Includes a built-in microphone for music sync lighting effects.
  • Controlled via Wi-Fi and Bluetooth for seamless smart home integration.
This product is perfect for adding colorful accent lighting to kitchens, living rooms, or entertainment areas complementing your Yeelight setup. Lifestyle image of Wyze Light Strip installed under kitchen cabinets Alt text: Modern kitchen with colorful LED light strip under cabinets
Summary
If your goal is to buy the Yeelight Smart Cube Kit with RGB pixel graffiti, this modular lighting kit is available as the Beat Kit bundle priced at $69.99 USD, offering a rich palette of colors and customizable lighting modules. For additional smart lighting solutions, the Wyze Light Strip provides versatile LED accent lighting options.
The Yeelight Smart Cube Kit stands out for its modular design, magnetic connections, and deep customization, making it a top choice for creative RGB lighting enthusiasts.
Product Tags Recap:
Enhance your home or creative space with the Yeelight Smart Cube Kit and complement it with Wyze Light Strips for a full spectrum of smart lighting possibilities.
FeatureYeelight Smart Cube KitWyze Light Strip
TypePartnership ItemConnected Home
Price$69.99$19.99 (16.4 ft), $35.99 (32.8 ft)
Color Options16 million colors16 million colors
Components IncludedBase (1), Panel Cube (4), Spotlight Cube (2), Adapter (1)LED light strip
Lighting TechnologyModular LED cubes with RGB and addressable LEDsLED accent lighting
CustomizationFreely assemble cubes; customizable LEDs for emojis, letters, numbersPeel, stick, and plug; basic color control
Connectivity/App RequiredYeelight app (Apple & Google Play)Wyze app (Apple & Google Play)
Special FeaturesMagnetic 360° rotation connection; DIY lighting effectsMusic Mode with built-in microphone; Sun Match; Voice Control; Vacation Mode; Sleep Routines; Timers & Automations
IntegrationYeelight ecosystemAlexa, Google Assistant
UsageIndoorIndoor
WarrantyManufacturer warranty (contact Yeelight)30-day hassle-free returns
What is the Yeelight Smart Cube Kit with RGB Pixel Graffiti?The Yeelight Smart Cube Kit with RGB Pixel Graffiti is a modular LED lighting system designed for creative and customizable lighting. It features multiple cube modules with 16 million color options, allowing you to create pixel art, ambient lighting, and interactive displays for home décor, gaming setups, or artistic projects.
What does the Yeelight Smart Cube Kit Beat Kit include?The Yeelight Smart Cube Kit Beat Kit includes 1 Base Cube, 4 Panel Cubes, 2 Spotlight Cubes, and 1 Adapter. This combination allows for flexible assembly and a wide range of lighting effects.
How many colors can the Yeelight Smart Cube Kit display?The Yeelight Smart Cube Kit supports a stunning palette of 16 million colors, enabling you to create vibrant and dynamic lighting effects.
What are the key features of the Yeelight Smart Cube Kit?Key features of the Yeelight Smart Cube Kit include modular design, magnetic connections for 360-degree rotation, customizable RGB pixel matrix, soft RGB panels, spotlight cubes with adjustable beams, addressable LED beads for pixel art, and seamless integration with other Yeelight products via the Yeelight app.
How do I control and customize the Yeelight Smart Cube Kit?You can control and customize the Yeelight Smart Cube Kit using the Yeelight app. The app allows you to adjust colors, create lighting effects, program pixel art, and integrate the kit with other Yeelight smart lighting products.
Is the Yeelight Smart Cube Kit suitable for gaming setups and home décor?Yes, the Yeelight Smart Cube Kit is perfect for gaming setups, home décor, and artistic lighting displays. Its modular design and customizable RGB lighting make it ideal for adding a personalized and creative touch to any space.
What is the price of the Yeelight Smart Cube Kit Beat Kit?The Yeelight Smart Cube Kit Beat Kit is available for $69.99 USD.
Are there other smart lighting options to complement the Yeelight Smart Cube Kit?Yes, the Wyze Light Strip is an excellent smart lighting option that complements the Yeelight Smart Cube Kit. It offers vibrant LED accent lighting, supports 16 million colors, is available in 16.4 and 32.8 feet lengths, and features music sync, Wi-Fi, and Bluetooth control.
Where can I buy the Yeelight Smart Cube Kit with RGB Pixel Graffiti?You can purchase the Yeelight Smart Cube Kit with RGB Pixel Graffiti as the Beat Kit bundle for $69.99 USD. Check the official Yeelight website or authorized retailers for availability.
What makes the Yeelight Smart Cube Kit stand out from other smart lighting products?The Yeelight Smart Cube Kit stands out due to its modular design, magnetic connections for flexible arrangements, deep customization options, and the ability to create pixel art and dynamic lighting effects, making it a top choice for creative RGB lighting enthusiasts.
Can you tell me more about the features of the Yeelight Smart Cube Kit?How does the customization work with the Yeelight Smart Cube Kit?Are there any ongoing sales or discounts for the Yeelight Smart Cube Kit?
