Tunable LED Light Strips for Personalized Indoor Ambience
Tunable LED Light Strips for Personalized Indoor Ambience Lighting
Transform your indoor spaces with tunable LED light strips designed to create personalized room ambience. Whether you want vibrant colors, soft whites, or dynamic lighting effects synced to your music, these LED light strips offer versatile solutions to elevate your home environment. Explore the top Wyze smart lighting products that bring 16 million colors and customizable zones right to your fingertips.
Wyze Light Strip: Brilliant Accent Lighting Made Simple
Color your world with the Wyze Light Strip, available in 16.4 feet and 32.8 feet lengths, perfect for adding vibrant LED accent lighting indoors. This corded electric light strip supports 16 million colors, allowing you to customize your room’s mood with a single color zone.
Key Features:
  • Length Options: 16.4 ft or 32.8 ft
  • Colors: 16 million vibrant hues
  • Power: 18 watts (16.4 ft), 36 watts (32.8 ft)
  • Connectivity: Wi-Fi (802.11 b/g/n, 2.4 GHz) and Bluetooth
  • Cuttable: Yes, trim to fit your space
  • Mounting: Easy adhesive backing for quick installation
  • Music Sync: Built-in microphone lets lights pulse to your favorite tunes
  • Indoor Use Only: Designed specifically for indoor ambience lighting
  • Life Expectancy: 25,000 hours
This light strip is ideal for under cabinets, behind TVs, or along shelves to add a splash of color and personality to any room. Wyze Light Strip in cozy living room Create vibrant indoor lighting with Wyze Light Strip
Wyze Light Strip Pro: Multi-Color Segment Control for Ultimate Customization
For those seeking advanced control, the Wyze Light Strip Pro offers multi-color segment control with 16 customizable zones. This means you can display multiple colors simultaneously along the strip, perfect for dynamic lighting designs and personalized ambience.
Highlights:
  • Length Options: 16.4 ft and 32.8 ft
  • Colors: 16 million colors including tunable white
  • Customizable Zones: 16 segments for multi-color effects
  • Music Mode: Sync lights to music beats for immersive experiences
  • Voice Control: Compatible with Alexa and Google Assistant
  • Trimmable: Cut to fit any room size or shape
  • Power: 24 watts (16.4 ft), 48 watts (32.8 ft)
  • Connectivity: Wi-Fi and Bluetooth
  • Indoor Use: Perfect for bedrooms, living rooms, and entertainment areas
This strip is perfect for creating personalized lighting scenes that match your mood or occasion, from relaxing evenings to lively parties. Wyze Light Strip Pro behind sofa Dynamic multi-color lighting with Wyze Light Strip Pro
Wyze Light Party: Complete Tunable Lighting Bundle for Any Occasion
Elevate your space with the Wyze Light Party bundle, which combines a 32.8 ft Wyze Light Strip with smart bulbs for a full-room lighting makeover. This set offers 16 million colors including RGB and tunable white, adjustable via the Wyze app for effortless control.
Bundle Features:
  • Includes: Wyze Light Strip 32 ft + Wyze Bulb Color packs (2, 4, or more bulbs)
  • Color Temperature: 1800K to 6500K tunable white
  • Brightness: Up to 1100 lumens per bulb
  • Connectivity: Wi-Fi and Bluetooth with Alexa, Google Assistant, and IFTTT integration
  • Suitable for Damp Locations: Safe for kitchens and bathrooms
  • Customizable Zones: Single zone on the light strip
  • Perfect For: Parties, ambient lighting, and smart home automation
This bundle is ideal for users who want a comprehensive smart lighting solution that covers both accent strips and overhead bulbs.
Smart Lighting Kits: Bulb Color BR30 + Light Strip Pro Bundles
For a seamless smart lighting experience, consider the Smart Lighting Kits that pair Wyze Bulb Color BR30 bulbs with the Light Strip Pro. These kits provide brilliant LED accent lighting with multi-zone control and tunable white options.
What You Get:
  • Wyze Bulb Color BR30: 30-950 lumens, 1800K-6500K color temperature, CRI 90+
  • Wyze Light Strip Pro: 16.4 ft, 16 customizable color zones, 16 million colors
  • Connectivity: Wi-Fi and Bluetooth with voice assistant support
  • Indoor Use: Designed for living rooms, bedrooms, and more
  • Warranty: 1 year
These kits are perfect for users who want to integrate smart bulbs and LED strips for a cohesive lighting setup with advanced control.
Wyze Bulb Color: The Ultimate Smart Color Bulb for Tunable White Lighting
Complement your LED strips with the Wyze Bulb Color, a smart bulb offering 16 million colors and tunable white light from warm 1800K to cool 6500K. It delivers up to 1100 lumens of brightness and supports voice control and app-based customization.
Features:
  • Colors: 16 million colors + tunable white
  • Power: 12 watts
  • Connectivity: Wi-Fi and Bluetooth, compatible with Alexa, Google Assistant, and IFTTT
  • Suitable for Damp Locations: Yes, safe for kitchens and bathrooms
  • Dimmable: Yes, with smooth brightness control
  • Base Type: Standard E26 for easy installation
Use these bulbs alongside your LED strips to create layered lighting effects and personalized room ambience. Wyze Bulb Color in cozy bedroom Add vibrant color and tunable white with Wyze Bulb Color
Why Choose Wyze Tunable LED Light Strips for Your Room Ambience?
"Personalize your space with smart LED lighting that adapts to your mood, music, and lifestyle."
Wyze offers a range of tunable LED light strips and smart bulbs that combine ease of use, vibrant color options, and smart home integration. Whether you want simple accent lighting or advanced multi-zone control, Wyze products deliver long-lasting, energy-efficient lighting solutions that transform any indoor space into a personalized ambience haven.
Summary of Featured Products
Product NameLength OptionsColor OptionsCustom ZonesSpecial Features
Wyze Light Strip16.4 ft, 32.8 ft16 million colors1Music sync, cuttable, adhesive
Wyze Light Strip Pro16.4 ft, 32.8 ft16 million colors16Multi-zone, music mode, voice control
Wyze Light Party Bundle32.8 ft + bulbs16 million colors + tunable white1Full room lighting, app control
Smart Lighting Kit (Bulb + Strip Pro)16.4 ft strip + bulbs16 million colors + tunable white16Bundle convenience, voice control
Wyze Bulb ColorN/A16 million colors + tunable whiteN/ADimmable, voice control, bright
Enhance your indoor ambience with Wyze tunable LED light strips and smart bulbs — the perfect combination for personalized, vibrant, and dynamic room lighting.
Feature / ProductWyze Light StripWyze Light PartyWyze Light Strip ProSmart Lighting Kit - Bulb Color + Light Strip Pro BundleWyze Bulb Color
TypeConnected HomeConnected HomeSmart LightingSmart LightingSmart Lighting
Variants16.4 ft ($19.99), 32.8 ft ($35.99)Bundles with bulbs + 32 ft strip (from $59.98)16.4 ft ($29.99), 32.8 ft ($44.99)Bulb Color 2 or 4 Pack + 16.4 ft Strip Pro ($52.98/$74.97)2 Pack ($26.26), 4 Pack ($44.44), 6 Pack ($64.98)
Colors16 million colors16 million colors + RGB + tunable white16 million colors RGB + tunable white16 million colors RGB + tunable white16 million colors + tunable white
Multi-color segment controlNoNoYes (16 customizable segments)Yes (16 customizable segments)No
Music ModeYes (built-in mic)Yes (sync bulbs + strip)Yes (sync to music)Yes (sync bulbs + strip)Yes
Voice ControlAlexa, Google AssistantAlexa, Google AssistantAlexa, Google AssistantAlexa, Google AssistantAlexa, Google Assistant
Vacation ModeYesYesYesYesYes
Sleep RoutinesYesNot specifiedYesYesYes
Timers & AutomationsYesYesYesYesYes
TrimmableYesYes (32 ft strip)YesYesN/A
Protective CoatingNo epoxy coatingN/AEpoxy coatingEpoxy coatingN/A
Brightness ControlYesYesYesYesYes
Included ItemsLight StripBulbs + 32 ft Light StripLight Strip Pro + accessoriesBulb Color Pack + Light Strip ProBulb Packs
Price Range$19.99 - $35.99 (sold out)$59.98 - $83.97 (bundles)$29.99 - $44.99$52.98 - $74.97$26.26 - $64.98
UsageIndoor onlyIndoorIndoor onlyIndoor onlyIndoor, suitable for damp locations
What are Wyze tunable LED light strips and how do they enhance indoor ambience?Wyze tunable LED light strips are smart lighting solutions designed to transform your indoor spaces with customizable colors, brightness, and dynamic effects. They offer up to 16 million colors, tunable white options, and features like music sync and multi-zone control, allowing you to personalize your room ambience for any mood or occasion.
What is the difference between Wyze Light Strip and Wyze Light Strip Pro?The Wyze Light Strip offers vibrant accent lighting with a single color zone, while the Wyze Light Strip Pro features 16 customizable color zones for advanced multi-color effects. The Pro version also supports music sync, voice control with Alexa and Google Assistant, and higher wattage for brighter lighting.
Can Wyze LED light strips be cut to fit my space?Yes, both Wyze Light Strip and Wyze Light Strip Pro are trimmable, allowing you to cut them to the desired length for a perfect fit in your room.
How do I control Wyze LED light strips and bulbs?Wyze LED light strips and bulbs can be controlled via the Wyze app, which allows you to adjust colors, brightness, and lighting effects. They also support voice control through Alexa and Google Assistant, and can be integrated with IFTTT for smart home automation.
Are Wyze Light Strips and Bulbs suitable for use in kitchens and bathrooms?Yes, Wyze Bulb Color and the Wyze Light Party bundle are suitable for damp locations, making them safe for use in kitchens and bathrooms.
What is the lifespan of Wyze LED light strips and bulbs?Wyze LED light strips and bulbs have a life expectancy of up to 25,000 hours, providing long-lasting and energy-efficient lighting for your home.
What is included in the Wyze Light Party bundle?The Wyze Light Party bundle includes a 32.8 ft Wyze Light Strip and Wyze Bulb Color packs (available in 2, 4, or more bulbs). This bundle offers full-room lighting with 16 million colors, tunable white, and app-based control.
What are the key features of the Wyze Bulb Color?Wyze Bulb Color offers 16 million colors, tunable white from 1800K to 6500K, up to 1100 lumens brightness, dimmable settings, Wi-Fi and Bluetooth connectivity, voice assistant compatibility, and suitability for damp locations.
Do Wyze smart lighting products support music sync?Yes, both Wyze Light Strip and Wyze Light Strip Pro feature music sync modes, allowing the lights to pulse and change colors in sync with your favorite tunes for immersive lighting experiences.
Are Wyze smart lighting kits compatible with voice assistants?Yes, Wyze smart lighting kits, including the Light Strip Pro and Bulb Color BR30, are compatible with Alexa and Google Assistant for convenient voice control.
What connectivity options do Wyze LED light strips and bulbs offer?Wyze LED light strips and bulbs connect via Wi-Fi (2.4 GHz) and Bluetooth, ensuring easy setup and reliable smart home integration.
Where can I install Wyze Light Strips for the best effect?Wyze Light Strips are ideal for indoor use, such as under cabinets, behind TVs, along shelves, in bedrooms, living rooms, and entertainment areas to create vibrant accent lighting and personalized ambience.
What is the warranty on Wyze smart lighting products?Wyze smart lighting kits, such as the Smart Lighting Kit with Bulb Color BR30 and Light Strip Pro, come with a 1-year warranty for peace of mind.
What are the different lengths available for the Wyze Light Strip?Can the Wyze Light Strip be cut to fit specific spaces?Do you have any deals, ongoing sales, discounts, or promotions?
