Wyze Battery Cam Pro & Outdoor Power Adapter Compatibility Guide
Wyze Battery Cam Pro Compatibility with Wyze Outdoor Power Adapter
When it comes to securing your home or outdoor spaces with smart, reliable technology, the Wyze Battery Cam Pro stands out as a top choice. If you're wondering about the compatibility of the Wyze Battery Cam Pro with the Wyze Outdoor Power Adapter, this guide will provide you with all the essential details to help you make the best decision for your security setup.
Wyze Battery Cam Pro: Features and Power Options
Advanced Wireless Security Camera
The Wyze Battery Cam Pro offers a powerful combination of features designed for flexible, wire-free security:
  • 2.5K HDR Video Resolution for crystal-clear footage day and night.
  • Wire-Free Operation with no hub required, allowing easy installation anywhere.
  • Integrated Spotlight & Siren to deter intruders.
  • Radar + PIR Motion Detection for precise and early alerts.
  • Removable, Rechargeable Battery Packs for convenient power management.
  • IP65 Weatherproof Rating ensures durability in rain or shine.
  • Supports both 2.4 GHz and 5 GHz WiFi for fast, reliable connectivity.
Flexible Power Solutions
The Battery Cam Pro is designed to be versatile in power options:
  • Use the removable battery packs to keep your camera running without downtime by hot-swapping batteries.
  • Extend your camera’s runtime by pairing it with the Wyze Solar Panel, turning your camera into a solar-powered security device.
  • For continuous wired power, the Wyze Outdoor Power Adapter is fully compatible when used with the necessary USB-C adapter.
"No wires. No hubs. Ultimate battery-operated go-anywhere security."
Outdoor security camera in use Alt text: Wyze Battery Cam Pro installed outdoors on a home exterior wall
Wyze Outdoor Power Adapter: Reliable Outdoor Power Supply
Designed for Outdoor Use
The Wyze Outdoor Power Adapter is built to withstand the elements:
  • IP67 Weather Resistance means it’s ready for rain, snow, or shine.
  • Rated for temperatures from -22°F to 122°F (-30°C to 50°C).
  • Comes with weatherproof L-shaped Micro-USB and USB-C adapters to ensure safe, secure connections outdoors.
  • Includes wire clips, screws, and anchors for easy and tidy installation.
Compatibility with Wyze Battery Cam Pro
  • The Wyze Battery Cam Pro requires both the Outdoor Power Adapter and the USB-C adapter to connect properly.
  • This adapter setup will NOT work with the original OG Stack Kit.
  • Cable lengths provide flexibility: 12.5 ft (3.8 m) total cable length, with 3.9 ft AC cable and 8.5 ft DC cable.
"Keep your Wyze Battery Cam Pro powered continuously without worrying about battery life."
Wyze Battery Cam Pro + Solar Panel Bundle: The Ultimate Outdoor Security Solution
For those seeking the perfect balance between wire-free convenience and continuous power, the Wyze Battery Cam Pro + Solar Panel bundle is an excellent choice.
Bundle Highlights
  • Includes one Wyze Battery Cam Pro and one Wyze Solar Panel.
  • Solar panel converts sunlight into power, reducing the need for frequent battery charging.
  • Maintains all the advanced features of the Battery Cam Pro, including 2.5K HDR video, integrated spotlight, and dual motion sensors.
  • Weatherproof and designed for outdoor use, ensuring reliable performance in all conditions.
"Turn your wireless camera into a solar-powered security powerhouse."
Solar powered security camera Alt text: Wyze Battery Cam Pro with solar panel mounted outdoors in sunlight
Additional Accessories to Enhance Your Wyze Battery Cam Pro Experience
Wyze Removable Battery Pack
  • Rechargeable 6200mAh battery designed specifically for the Battery Cam Pro.
  • Provides up to 6 months of battery life on a single charge.
  • USB-C charging port for fast and convenient recharging.
Wyze Battery Charging Dock
  • Charge two battery packs simultaneously.
  • Compact and easy to use, ensuring your batteries are always ready.
Summary: Seamless Compatibility and Power Flexibility
The Wyze Battery Cam Pro is fully compatible with the Wyze Outdoor Power Adapter when paired with the required USB-C adapter, making it easy to power your camera continuously outdoors. For those who prefer a solar-powered option, the Wyze Battery Cam Pro + Solar Panel bundle offers an eco-friendly and maintenance-free solution. Whether you choose battery power, solar, or wired power with the outdoor adapter, Wyze provides flexible options to keep your home security system running smoothly and reliably.
Home security lifestyle Alt text: Family enjoying outdoor space with visible Wyze security camera installed
Key Takeaways
  • Wyze Battery Cam Pro supports multiple power options: battery, solar panel, and outdoor power adapter.
  • The Wyze Outdoor Power Adapter is weatherproof and designed for safe outdoor use with the Battery Cam Pro.
  • Using the outdoor power adapter requires the USB-C adapter for the Battery Cam Pro.
  • The solar panel bundle offers extended runtime with eco-friendly power.
  • Additional accessories like removable batteries and charging docks enhance convenience.
Secure your home with confidence using Wyze’s versatile and compatible power solutions for the Battery Cam Pro.
# Product Tags Summary
FeatureWyze Battery Cam ProWyze Outdoor Power AdapterWyze Battery Cam Pro + Solar Panel
TypeCameraAccessoryCamera Bundle (Camera + Solar Panel)
Video Resolution2.5K HDR (2560 x 1440)N/A2.5K HDR (2560 x 1440)
Power SourceRemovable, Rechargeable Battery Packs (6200mAh)Outdoor Power Adapter (requires USB-C adapter for Battery Cam Pro)Battery Cam Pro powered by rechargeable battery + Solar Panel for extended power
Battery LifeUp to 6 monthsN/AExtended battery life with solar charging
Charging TimeApproximately 9 hoursN/ASame as Battery Cam Pro; solar panel reduces charging frequency
Weather ResistanceIP65IP67IP65 (Camera) + IP65 (Solar Panel)
WirelessYes (2.4 & 5 GHz WiFi)NoYes (2.4 & 5 GHz WiFi)
Motion DetectionRadar + PIRN/ARadar + PIR
Integrated Spotlight & SirenYes (150 lumens LED spotlight, 100 dB siren)N/AYes
Local StorageSupports up to 256 GB microSD cardN/ASupports up to 256 GB microSD card
Mounting1/4" - 20 standard, wall mount includedN/ASame as Battery Cam Pro
Dimensions2.5 x 1.8 x 3.5 inchesN/ACamera: 2.5 x 1.8 x 3.5 inches; Solar Panel: 173 x 120 x 17 mm
Weight0.94 lbsN/ACamera: 0.94 lbs; Solar Panel weight not specified
ConnectivityBluetooth 5.1, WiFi 2.4 & 5 GHzN/ABluetooth 5.1, WiFi 2.4 & 5 GHz
SetupInstant Bluetooth setup, no hub requiredN/AInstant Bluetooth setup, no hub required
Included ItemsCamera onlyOutdoor Power Adapter + USB-C adapter (for Battery Cam Pro)Wyze Battery Cam Pro + Wyze Solar Panel + accessories (mount, cables, screws)
Price$109.98 (single)$19.99 (Outdoor Adapter + L-shaped Adapter + USB-C Adapter)$109.98 (bundle deal)
CompatibilityN/ACompatible with Battery Cam Pro (with USB-C adapter)N/A
Is the Wyze Battery Cam Pro compatible with the Wyze Outdoor Power Adapter?Yes, the Wyze Battery Cam Pro is fully compatible with the Wyze Outdoor Power Adapter when used with the required USB-C adapter. This allows you to power your camera continuously outdoors without worrying about battery life.
What power options are available for the Wyze Battery Cam Pro?The Wyze Battery Cam Pro supports multiple power options: removable rechargeable battery packs, the Wyze Solar Panel for solar-powered operation, and the Wyze Outdoor Power Adapter for continuous wired power when paired with the USB-C adapter.
Do I need a USB-C adapter to use the Wyze Outdoor Power Adapter with the Battery Cam Pro?Yes, to connect the Wyze Outdoor Power Adapter to the Wyze Battery Cam Pro, you must use the included USB-C adapter for proper compatibility and a secure connection.
Can I use the Wyze Outdoor Power Adapter with the original OG Stack Kit?No, the Wyze Outdoor Power Adapter setup will NOT work with the original OG Stack Kit. It is designed specifically for use with compatible Wyze cameras like the Battery Cam Pro.
Is the Wyze Outdoor Power Adapter weatherproof?Yes, the Wyze Outdoor Power Adapter is IP67 weather resistant, making it suitable for outdoor use in rain, snow, or shine. It is rated for temperatures from -22°F to 122°F (-30°C to 50°C).
What is included with the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter comes with weatherproof L-shaped Micro-USB and USB-C adapters, wire clips, screws, and anchors for easy and secure installation. The total cable length is 12.5 ft (3.8 m), with a 3.9 ft AC cable and an 8.5 ft DC cable.
How does the Wyze Battery Cam Pro + Solar Panel bundle work?The Wyze Battery Cam Pro + Solar Panel bundle includes one Battery Cam Pro and one Wyze Solar Panel. The solar panel converts sunlight into power, reducing the need for frequent battery charging and providing an eco-friendly, maintenance-free power solution.
What are the benefits of using the Wyze Solar Panel with the Battery Cam Pro?Using the Wyze Solar Panel with the Battery Cam Pro extends the camera’s runtime by harnessing solar energy, minimizing the need for manual battery recharging and ensuring reliable, wire-free outdoor security.
What accessories are available for the Wyze Battery Cam Pro?Accessories for the Wyze Battery Cam Pro include removable rechargeable battery packs (providing up to 6 months of battery life per charge) and a battery charging dock that allows you to charge two battery packs simultaneously for added convenience.
Can I use both the Wyze Solar Panel and the Outdoor Power Adapter at the same time with the Battery Cam Pro?No, the Wyze Battery Cam Pro is designed to be powered by either the removable battery packs, the Wyze Solar Panel, or the Wyze Outdoor Power Adapter (with USB-C adapter), but not all at once. Choose the power solution that best fits your installation needs.
What are the features of the Wyze Battery Cam Pro?Can the Wyze Battery Cam Pro be used without the Wyze Outdoor Power Adapter?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Battery Cam Pro?
