Best Wyze Cam Outdoor Power Adapters for Bird Feeder Setups
Power Supply Solutions for Wyze Cam Outdoor Near Backyard Bird Feeders
When setting up a Wyze Cam Outdoor near your backyard bird feeder, having a reliable and weather-resistant power supply is essential. Whether you want continuous monitoring of your feathered visitors or seamless integration with your Wyze ecosystem, choosing the right power adapter ensures your camera stays powered rain or shine. This guide highlights the best Wyze products designed for outdoor birdwatching setups, focusing on power supply options and compatible camera bundles.
Wyze Outdoor Power Adapter: Reliable Power for Outdoor Cameras
The Wyze Outdoor Power Adapter is specifically engineered to keep your Wyze cameras running smoothly in all weather conditions. With an IP67 weather resistance rating, this adapter is ready for rain, snow, or shine, making it perfect for outdoor use near bird feeders.
Key Features:
  • Weatherproof Design: IP67 rating ensures protection against dust and water immersion.
  • Compatibility: Works with Wyze Cam v3, Cam v4, Pan v3, and Wyze Battery Cam Pro (with required adapters).
  • Cable Lengths: 12.5 ft cable to camera and 3.9 ft AC cable for flexible installation.
  • Included Accessories: Comes with wire clips, screws, anchors, and weatherproof L-shaped Micro-USB adapter.
  • Operating Range: Functions in temperatures from -22°F to 122°F (-30°C to 50°C).
  • Power Output: 5V/2A output suitable for continuous camera operation.
  • Warranty: 1-year limited warranty for peace of mind.
This adapter is ideal for powering your Wyze Cam Outdoor near a bird feeder, ensuring uninterrupted live video streaming and recording.
Bird Feeder Plug-in Cam v4 Bundle: Complete Birdwatching Setup
For bird enthusiasts looking for an all-in-one solution, the Bird Feeder Plug-in Cam v4 Bundle combines a vibrant Wyze Bird Feeder, Wyze Cam v4, and the Wyze Outdoor Power Adapter.
Bundle Highlights:
  • Wyze Bird Feeder: Designed with a bright blue body and orange top to attract a variety of birds.
  • Wyze Cam v4: A top-selling camera with excellent video quality and weather resistance.
  • Outdoor Power Adapter: Included to keep your camera powered reliably outdoors.
  • Weather Resistance: Both feeder and camera are built to withstand all seasons.
  • Easy Installation: Multiple mounting options including wall, tree, pole, suction cup, and cord.
  • Macro Lens Adapter: Included for detailed close-up birdwatching.
  • Compatibility: Works seamlessly with Wyze Solar Panel for alternative power options.
This bundle is perfect for those who want a hassle-free birdwatching experience with continuous power and high-quality video.
Bird Feeder Wireless Camera Bundle: Wire-Free Birdwatching
If you prefer a wire-free setup, the Bird Feeder Wireless Camera Bundle offers a Wyze Bird Feeder paired with the Wyze Battery Cam Pro and Wyze Solar Panel.
Features:
  • Wireless Convenience: Battery-powered camera eliminates the need for constant wiring.
  • Solar Panel: Provides sustainable power to extend battery life.
  • High-Resolution Video: 2.5K (2560 x 1440) resolution for crystal-clear bird footage.
  • Weatherproof: IP65 rating for both feeder and camera ensures durability.
  • Macro Lens Adapter: Included for detailed bird close-ups.
  • Smart Integrations: Compatible with Alexa, Google Assistant, and IFTTT.
  • Mounting Flexibility: Standard 1/4” - 20 mounts included for versatile placement.
This bundle is ideal for backyard birdwatchers who want a clean, wireless setup with solar-assisted power.
Wyze Bird Feeder Accessory: Enhance Your Birdwatching Experience
For those who already own a Wyze camera and want to add a bird feeder, the Wyze Bird Feeder accessory is a great choice.
Product Details:
  • Attractive Design: Blue or brown polycarbonate body with an orange top to attract birds.
  • Capacity: Holds 1 liter of bird seed.
  • Weather Resistant: IP65 rating for all-season use.
  • Compatibility: Works with Wyze Cam Outdoor v1 & v2, Battery Cam Pro, Cam v3, and Cam v4.
  • Installation: Multiple mounting options including suction cups, cords, and poles.
  • Included Items: Food tray, camera bracket, lens bracket, mounting accessories, and quick start guide.
  • Macro Lens Adapter: Included for enhanced close-up viewing.
Pair this feeder with your Wyze Cam Outdoor and the Wyze Outdoor Power Adapter for a reliable, powered birdwatching station.
Wyze Cam Pan v3: Versatile Outdoor Camera with Power Adapter Support
The Wyze Cam Pan v3 is a 360° pan and 180° tilt camera designed for both indoor and outdoor use. When used outdoors, it requires the Wyze Outdoor Power Adapter for continuous power.
Camera Features:
  • Full Coverage: 360° horizontal and 180° vertical view with 120° field of view.
  • 1080p HD Video: Crisp video quality with night vision via 4 IR LEDs.
  • Two-Way Audio: Built-in speaker and microphone with noise and echo cancellation.
  • Weather Resistant: IP65 rating for outdoor durability.
  • Fast Rotation: Up to 110° per second for quick tracking.
  • Connectivity: 2.4 GHz Wi-Fi support.
  • Storage: Supports up to 256 GB microSD card.
  • Smart Home Integration: Works with Alexa, Google Assistant, and IFTTT.
Paired with the Wyze Outdoor Power Adapter, the Pan v3 is a powerful option for monitoring your backyard bird feeder and surrounding areas.
Wyze Cam Pan v3 Outdoor Setup Experience reliable outdoor security and birdwatching with Wyze Cam Pan v3 powered by the Wyze Outdoor Power Adapter.
Conclusion
For powering your Wyze Cam Outdoor near a backyard bird feeder, the Wyze Outdoor Power Adapter is the most dependable choice, offering weatherproof durability and compatibility with multiple Wyze cameras. Bundles like the Bird Feeder Plug-in Cam v4 Bundle provide an all-in-one solution with feeder, camera, and power adapter included, making birdwatching effortless. Whether you prefer wired or wireless setups, Wyze offers versatile options to keep your cameras powered and your birdwatching experience seamless.
Feature / ProductBird Feeder Plug-in Cam v4 BundleBird Feeder Wireless Camera BundleWyze Bird FeederWyze Outdoor Power AdapterWyze Cam Pan v3
IncludesWyze Bird Feeder, Wyze Cam v4, Wyze Outdoor Power AdapterWyze Bird Feeder, Wyze Battery Cam Pro, Wyze Solar PanelWyze Bird Feeder onlyOutdoor Power Adapter (various adapter combos)Wyze Cam Pan v3 camera only
Price$89.98$139.98 - $154.96$39.99$14.99 - $19.99$39.98
Bird Feeder ColorsBlue, Brown (both sold out/unavailable)Blue, Brown (both sold out/unavailable)Blue, BrownN/AN/A
Camera IncludedWyze Cam v4Wyze Battery Cam ProNoneNoneWyze Cam Pan v3
Power SourcePlug-in power (via Outdoor Power Adapter)Battery powered with Solar PanelN/AOutdoor power adapter for camerasPowered via included adapter
Weather ResistanceBird Feeder: IP65; Power Adapter: IP67; Cam v4: IP65Bird Feeder: IP65; Battery Cam Pro: wireless, weather resistantBird Feeder: IP65IP67IP65
Camera FeaturesWyze Cam v4: 1080p, color night vision, 2-way audioWyze Battery Cam Pro: wireless, bird detection, 1080pN/AN/A1080p, 360° pan, 180° tilt, color night vision, 2-way audio
Mounting Options (Bird Feeder)Wall, tree, pole, cord, suction cupWall, tree, pole, cord, suction cupWall, tree, pole, cord, suction cupN/AMount with screw 1/4"-20
Macro Lens Adapter IncludedYesYesYesN/AN/A
Solar Panel CompatibleNoYesYesN/AN/A
Dimensions (Bird Feeder)7.48" x 10.12" x 8.58"Same as Wyze Bird Feeder7.48" x 10.12" x 8.58"78.7 mm x 62.5 mm x 29.4 mm124 mm x 60 mm x 63 mm
WeightBird Feeder: 2.5 lb; Power Adapter: 235 g; Cam v4: 320 gBird Feeder: 2.5 lb; Battery Cam Pro weight not specified2.5 lb235 g320 g
Operating TemperatureBird Feeder: -4°F to 122°F; Power Adapter: -22°F to 122°FBird Feeder: -4°F to 122°F; Battery Cam Pro: not specified-4°F to 122°F-22°F to 122°F-4°F to 122°F
ConnectivityWyze Cam v4: Wi-Fi 2.4 GHz onlyBattery Cam Pro: wirelessN/AN/AWi-Fi 2.4 GHz only
App FeaturesLive stream, record, notifications via Wyze appLive stream, record, notifications via Wyze appLive stream, record, notifications via Wyze appN/ALive stream, motion tracking, notifications
Warranty1 year1 year1 year1 year1 year
Special NotesNo squirrel defense systemBird detection available with Cam PlusNo squirrel defense systemRequired for outdoor use of some Wyze camerasRequires Outdoor Power Adapter for outdoor use
What is the best power supply solution for Wyze Cam Outdoor near a backyard bird feeder?The Wyze Outdoor Power Adapter is the best power supply solution for Wyze Cam Outdoor near a backyard bird feeder. It is weather-resistant with an IP67 rating, ensuring reliable performance in rain, snow, or shine, and is compatible with multiple Wyze camera models.
Which Wyze cameras are compatible with the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter is compatible with Wyze Cam v3, Cam v4, Pan v3, and Wyze Battery Cam Pro (with required adapters).
Is the Wyze Outdoor Power Adapter weatherproof?Yes, the Wyze Outdoor Power Adapter is weatherproof with an IP67 rating, providing protection against dust and water immersion, making it ideal for outdoor use.
What is included with the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter comes with a 12.5 ft cable to the camera, a 3.9 ft AC cable, wire clips, screws, anchors, and a weatherproof L-shaped Micro-USB adapter.
What is the operating temperature range for the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter operates in temperatures ranging from -22°F to 122°F (-30°C to 50°C).
What is the Bird Feeder Plug-in Cam v4 Bundle?The Bird Feeder Plug-in Cam v4 Bundle is an all-in-one birdwatching solution that includes a Wyze Bird Feeder, Wyze Cam v4, and the Wyze Outdoor Power Adapter. It offers continuous power, high-quality video, and weather-resistant components.
Does Wyze offer a wireless bird feeder camera bundle?Yes, the Bird Feeder Wireless Camera Bundle includes a Wyze Bird Feeder, Wyze Battery Cam Pro, and Wyze Solar Panel for a wire-free, solar-assisted birdwatching setup.
Can I use a solar panel to power my Wyze camera near a bird feeder?Yes, the Wyze Solar Panel is compatible with the Wyze Battery Cam Pro and can be used in the Bird Feeder Wireless Camera Bundle to provide sustainable, solar-assisted power.
What mounting options are available for the Wyze Bird Feeder?The Wyze Bird Feeder offers multiple mounting options, including wall, tree, pole, suction cup, and cord, for flexible installation near your backyard bird feeder.
Is the Wyze Bird Feeder weather resistant?Yes, the Wyze Bird Feeder is weather resistant with an IP65 rating, making it suitable for all-season outdoor use.
What is included with the Wyze Bird Feeder accessory?The Wyze Bird Feeder accessory includes the feeder, food tray, camera bracket, lens bracket, mounting accessories, a macro lens adapter, and a quick start guide.
Can I use the Wyze Cam Pan v3 outdoors to monitor my bird feeder?Yes, the Wyze Cam Pan v3 is designed for both indoor and outdoor use. For outdoor installation, it requires the Wyze Outdoor Power Adapter for continuous power and weather resistance.
What are the video quality and features of the Wyze Cam Pan v3?The Wyze Cam Pan v3 offers 1080p HD video, 360° pan, 180° tilt, night vision with 4 IR LEDs, two-way audio, and fast rotation for comprehensive coverage of your backyard bird feeder.
Are Wyze cameras compatible with smart home systems?Yes, Wyze cameras such as the Battery Cam Pro and Cam Pan v3 are compatible with Alexa, Google Assistant, and IFTTT for smart home integration.
What warranty is provided with the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter comes with a 1-year limited warranty for added peace of mind.
Can you tell me more about the Bird Feeder Plug-in Cam v4 Bundle?What are the key features of the Wyze Outdoor Power Adapter?Do you have any deals, ongoing sales, discounts, or promotions available?
