Weatherproof Wyze Outdoor Power Adapter for Fence Camera Installations
Reliable Power Adapter for Outdoor Wyze Camera Installation on a Fence
When installing your Wyze outdoor camera on a fence, having a reliable power source is essential to ensure continuous monitoring and security. The Wyze Outdoor Power Adapter is specifically designed to provide a weather-resistant, durable power solution for your Wyze cameras, making it the perfect choice for outdoor setups like fence installations.
Wyze Outdoor Power Adapter: Built for All Weather Conditions
Weather-Resistant and Durable
The Wyze Outdoor Power Adapter is rated IP67 weather-resistant, meaning it can withstand rain, snow, and harsh outdoor elements without compromising performance. This makes it ideal for powering your Wyze cameras mounted on fences or other outdoor locations where exposure to weather is inevitable.
Compatibility and Convenience
  • Works seamlessly with Wyze Cam v4, Wyze Cam Pan v3, Wyze Cam v3 Pro, and Wyze Battery Cam Pro (with the appropriate adapters).
  • Comes in variants including the Outdoor Adapter combined with L-shaped MicroUSB and USB-C adapters to fit different Wyze camera models.
  • Note: Requires the L-shaped MicroUSB Adapter for Cam v3 Pro and Pan v3, and USB-C adapter for Battery Cam Pro.
Easy Installation
The adapter’s design allows for straightforward installation on fences or outdoor walls, providing a stable power connection without the worry of weather damage.
Ready for rain, snow, or shine — the Wyze Outdoor Power Adapter ensures your camera stays powered no matter the season.
Wyze Cam Pan v3 Outdoor Installation Wyze Cam Pan v3 powered by Wyze Outdoor Power Adapter, installed on a snowy fence
Wyze Cam Pan v3: 360° Pan and Tilt with Outdoor Power Support
Full Outdoor Capability
The Wyze Cam Pan v3 is a versatile indoor/outdoor camera with a 360° horizontal and 180° vertical viewing range, perfect for fence monitoring. It is IP65 weather-resistant, making it suitable for outdoor use when paired with the Wyze Outdoor Power Adapter.
Key Features
  • 1080p HD video resolution with smooth pan and tilt functionality.
  • Night vision with 4 IR LEDs for clear images in low light.
  • Two-way audio with built-in speaker and microphone for real-time communication.
  • Supports microSD cards up to 256 GB for local storage.
  • Compatible with Alexa, Google Assistant, and IFTTT for smart home integration.
Power Requirements
  • Requires the Wyze Outdoor Power Adapter and L-shaped MicroUSB Adapter for safe outdoor power supply.
  • Power cable length of 6" (1.8 m) allows flexible placement on fences or poles.
Wyze Cam v4: High-Resolution Outdoor Security with Power Adapter Support
Superior Video Quality and Night Vision
The Wyze Cam v4 offers 2.5K QHD resolution and enhanced color night vision, providing crystal-clear footage day and night. Its IP65 weather resistance rating ensures it can handle outdoor environments like fence installations.
Features Tailored for Outdoor Use
  • Motion-activated spotlight to illuminate your fence area when activity is detected.
  • 24/7 local recording with microSD card support up to 512 GB.
  • Wi-Fi 6 support for faster and more reliable connectivity.
  • Multiple mounting options including wall, ceiling, and magnetic mounts for versatile fence installation.
  • Two-way audio and built-in siren for active deterrence.
Power Compatibility
  • Can be powered outdoors using the Wyze Outdoor Power Adapter, ensuring continuous operation without battery concerns.
Wyze Cam Floodlight v2 Lifestyle Outdoor security with Wyze Cam v4 powered by Wyze Outdoor Power Adapter
Why Choose Wyze Outdoor Power Adapter for Your Fence Installation?
  • Reliable Power Supply: Keeps your Wyze cameras running 24/7 without interruption.
  • Weatherproof Design: IP67 rating protects against water and dust, perfect for outdoor fence mounting.
  • Versatile Compatibility: Supports multiple Wyze camera models with necessary adapters.
  • Easy Setup: Plug-and-play design with durable cables suited for outdoor environments.
For a secure, weatherproof, and hassle-free outdoor camera setup on your fence, the Wyze Outdoor Power Adapter is the trusted choice.
Summary of Recommended Products for Outdoor Fence Camera Setup
ProductKey FeaturePrice (Starting)
Wyze Outdoor Power AdapterIP67 weather-resistant power supply$19.99
Wyze Cam Pan v3360° pan & tilt, IP65 rated$39.98
Wyze Cam v42.5K QHD, color night vision, IP65$35.98
By combining the Wyze Outdoor Power Adapter with either the Wyze Cam Pan v3 or Wyze Cam v4, you get a powerful, weatherproof security solution perfect for fence installations. Enjoy peace of mind with continuous power and crystal-clear video monitoring, no matter the weather.
FeatureWyze Outdoor Power AdapterWyze Cam Pan v3Wyze Cam v4
TypeAccessoryCameraCamera
Weather ResistanceIP67IP65IP65
UsagePowers Wyze cameras outdoorsIndoor/outdoor 360° pan & 180° tilt security cameraIndoor/outdoor security camera
CompatibilityWyze Cam v4, OG series, Cam Pan v3, Cam v3 Pro, Battery Cam Pro (with adapters)Works with Wyze Outdoor Power Adapter (sold separately)Requires Outdoor Power Adapter (sold separately)
Power Adapter VariantsL-shaped Micro USB Adapter, Outdoor Adapter + L-shaped Adapter, Outdoor Adapter + L-shaped Adapter + USB-C AdapterIncluded power adapter (5V/2000mA)Indoor USB Power Adapter included (5V/1A), Outdoor adapter sold separately
Video ResolutionN/A1080p (1920x1080)2.5K QHD (2560x1440)
Field of ViewN/A360° horizontal, 180° vertical, 120° FOVDFOV 115.8°, HFOV 98.5°, VFOV 53.1°
Night VisionN/A4 IR LEDs (850 nm), Color Night Vision4 IR LEDs (850 nm) + 2 white spotlight LEDs, Color Night Vision
Audio FeaturesN/ABuilt-in speaker, microphone, 2-way audio, noise & echo cancellation99dB waterproof speaker, simultaneous 2-way talk, noise & echo cancellation
Motion TrackingN/AAutomatic motion trackingMotion-activated spotlight, person detection
ConnectivityN/A802.11 b/g/n 2.4 GHz Wi-Fi2.4 GHz Wi-Fi, Wi-Fi 6
StorageN/ASupports up to 256 GB microSDmicroSD card up to 512 GB, cloud storage with subscription
DimensionsN/A124mm x 60mm x 63mm2in x 2in x 2 3/8in
WeightN/A11.29 oz (320 g)0.49 lb (222 g)
Mounting OptionsN/AScrew 1/4" - 20 mountStand, Wall mount, Ceiling mount, Magnetic wall mount (adhesive)
Operating TemperatureN/A-4°F to 122°F (-20°C to 50°C)-4°F to 122°F (-20°C to 50°C)
WarrantyNot specified1 Year1 Year
Price Range$5.99 - $19.99 (depending on variant)$39.98 (single camera)$35.98 - $107.94 (depending on pack and variant)
What is the Wyze Outdoor Power Adapter and why is it recommended for fence installations?The Wyze Outdoor Power Adapter is a weather-resistant, durable power solution specifically designed for Wyze cameras. It is recommended for fence installations because it provides a reliable, continuous power supply and is rated IP67, making it resistant to rain, snow, and harsh outdoor conditions.
Which Wyze cameras are compatible with the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter is compatible with Wyze Cam v4, Wyze Cam Pan v3, Wyze Cam v3 Pro, and Wyze Battery Cam Pro (with the appropriate adapters). For Cam v3 Pro and Pan v3, use the L-shaped MicroUSB Adapter, and for Battery Cam Pro, use the USB-C adapter.
Is the Wyze Outdoor Power Adapter weatherproof?Yes, the Wyze Outdoor Power Adapter is IP67 weather-resistant, meaning it is protected against water and dust, making it ideal for outdoor use on fences or other exposed locations.
How easy is it to install the Wyze Outdoor Power Adapter on a fence?The Wyze Outdoor Power Adapter is designed for easy installation on fences or outdoor walls. Its plug-and-play design and durable cables make setup straightforward and secure, ensuring a stable power connection for your Wyze camera.
What are the power requirements for Wyze Cam Pan v3 when used outdoors?For outdoor use, the Wyze Cam Pan v3 requires the Wyze Outdoor Power Adapter and the L-shaped MicroUSB Adapter to ensure safe and reliable power supply. The included 6-foot (1.8 m) power cable allows flexible placement on fences or poles.
Can the Wyze Cam v4 be used outdoors on a fence, and what features does it offer?Yes, the Wyze Cam v4 is IP65 weather-resistant and can be used outdoors on a fence. It offers 2.5K QHD resolution, enhanced color night vision, a motion-activated spotlight, 24/7 local recording with microSD support up to 512 GB, Wi-Fi 6 connectivity, and multiple mounting options.
Why should I choose the Wyze Outdoor Power Adapter for my outdoor camera setup?The Wyze Outdoor Power Adapter ensures your Wyze cameras have a reliable, uninterrupted power supply, is weatherproof with an IP67 rating, supports multiple camera models, and features an easy, durable setup ideal for outdoor environments like fences.
Do I need any special adapters to use the Wyze Outdoor Power Adapter with my camera?Yes, depending on your Wyze camera model, you may need the L-shaped MicroUSB Adapter (for Cam v3 Pro and Pan v3) or the USB-C adapter (for Battery Cam Pro) to ensure proper connection and compatibility.
What is the price of the Wyze Outdoor Power Adapter and compatible cameras for fence installation?The Wyze Outdoor Power Adapter starts at $19.99. Compatible cameras include the Wyze Cam Pan v3 at $39.98 and the Wyze Cam v4 at $35.98.
Can I use the Wyze Outdoor Power Adapter for continuous 24/7 camera monitoring?Yes, the Wyze Outdoor Power Adapter is designed to provide continuous, reliable power to your Wyze cameras, enabling 24/7 monitoring and security for your outdoor fence installation.
What are the installation requirements for the Wyze Outdoor Power Adapter?Can the Wyze Outdoor Power Adapter be used with other Wyze camera models?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Outdoor Power Adapter?
