Best Outdoor Power Solution for Wyze Cameras—No Battery Swaps
Best Solution to Power a Wyze Camera Outdoors Without Battery Swaps
When it comes to powering your Wyze cameras outdoors without the hassle of frequent battery swaps, the Wyze Outdoor Power Adapter stands out as the ultimate solution. Designed specifically to keep your Wyze cameras running continuously in any weather condition, this accessory ensures your security system remains reliable and maintenance-free.
Wyze Outdoor Power Adapter: Reliable Power Rain or Shine
Weather-Resistant and Durable Design
The Wyze Outdoor Power Adapter is built to withstand the elements with an IP67 weather-resistant rating, making it perfect for outdoor use in rain, snow, or shine. Its robust construction ensures your camera stays powered even in harsh weather conditions, providing peace of mind year-round.
Compatibility and Convenience
  • Compatible with popular Wyze cameras including Wyze Cam v3 Pro, Pan v3, and Battery Cam Pro (note: some models require additional adapters like the L-shaped MicroUSB or USB-C adapter).
  • Comes with a 12.5 ft (3.8 m) cable for flexible installation options.
  • Includes wire clips, screws, and anchors for secure mounting.
  • Operates efficiently within a wide temperature range of -22°F to 122°F (-30°C to 50°C).
Power Specifications
  • Input Power: 100V-240V
  • Output Power: 5V 2A
  • Connector to Camera: Micro USB
  • Connector to Wall Plug: 2 pin flat (US standard)
With this adapter, you can say goodbye to battery swaps and enjoy uninterrupted power for your outdoor Wyze cameras.
Wyze Cam Pan v3: 360° Outdoor Surveillance with Continuous Power
Wyze Cam Pan v3 in snowy outdoor setting
Key Features
  • 360° horizontal and 180° vertical pan and tilt for full coverage.
  • IP65 weather resistance ensures durability outdoors.
  • Requires the Wyze Outdoor Power Adapter for safe outdoor use.
  • Full HD 1080p video resolution with night vision powered by 4 IR LEDs.
  • Two-way audio with built-in speaker and microphone for real-time communication.
  • Compatible with Alexa, Google Assistant, and IFTTT for smart home integration.
Specs at a Glance
  • Dimensions: 124mm x 60mm x 63mm
  • Weight: 320g
  • Video FPS: 20 fps daytime, 15 fps nighttime
  • Power Cable Length: 6 ft (1.8 m)
  • Connectivity: 2.4 GHz Wi-Fi
The Pan v3 combined with the Outdoor Power Adapter creates a seamless, always-on security solution that covers every angle of your property.
Wyze Cam v4: Crystal Clear 2.5K QHD Security with Outdoor Power
Advanced Imaging and Night Vision
The Wyze Cam v4 delivers stunning 2.5K QHD resolution with enhanced color night vision and a motion-activated spotlight, making it ideal for detailed outdoor surveillance day and night.
Outdoor Ready with Power Adapter
  • Rated IP65 for weather resistance, perfect for outdoor environments.
  • Requires the Wyze Outdoor Power Adapter for continuous power outdoors.
  • Supports Wi-Fi 6 for faster and more reliable connectivity.
  • Features an 8x digital zoom and wide dynamic range for clear images in varied lighting.
Additional Highlights
  • Built-in 99dB waterproof speaker and two-way talk.
  • Built-in siren and noise/echo cancellation.
  • Multiple mounting options including wall, ceiling, and magnetic mounts.
  • Supports local microSD storage up to 512 GB and cloud storage options.
The Wyze Cam v4 paired with the Outdoor Power Adapter offers a powerful, maintenance-free outdoor security setup with superior video quality.
Why Choose the Wyze Outdoor Power Adapter for Your Wyze Cameras?
  • Eliminate Battery Swaps: Continuous power means no more interruptions or manual battery changes.
  • Weatherproof Reliability: IP67 rating ensures your camera stays powered in all weather conditions.
  • Easy Installation: Comes with all necessary mounting hardware and adapters for various Wyze camera models.
  • Versatile Compatibility: Works with multiple Wyze cameras including the Pan v3, Cam v3 Pro, Battery Cam Pro, and Cam v4.
Conclusion
For anyone looking to power their Wyze cameras outdoors without the inconvenience of battery swaps, the Wyze Outdoor Power Adapter is the best solution. When paired with advanced cameras like the Wyze Cam Pan v3 or the Wyze Cam v4, it creates a robust, weather-resistant security system that keeps your home or property monitored 24/7 with crystal-clear video and smart features. Invest in the Wyze Outdoor Power Adapter today to enjoy uninterrupted, hassle-free outdoor camera power and elevate your home security experience.
FeatureWyze Outdoor Power AdapterWyze Cam Pan v3Wyze Cam v4
TypeAccessoryCameraCamera
Weather ResistanceIP67IP65IP65
UsagePowers Wyze cameras outdoorsIndoor/outdoor 360° pan & 180° tilt security camIndoor/outdoor security camera
Compatible CamerasWyze Cam v4, OG series, Cam Pan v3, Cam v3 Pro, Battery Cam Pro (with adapters)Standalone cameraStandalone camera
Power Adapter RequiredYesYes (sold separately for outdoor use)Yes (sold separately for outdoor use)
Video ResolutionN/A1080p (1920x1080)2.5K QHD (2560x1440)
Field of ViewN/A120° FOVDFOV 115.8°, HFOV 98.5°, VFOV 53.1°
Pan & TiltN/A360° pan, 180° tiltFixed angle
Night VisionN/AColor Night Vision, 4 IR LEDs (850 nm)Enhanced Color Night Vision, 4 IR LEDs + 2 white spotlight LEDs
Audio FeaturesN/A2-way audio, built-in speaker & microphone2-way audio, 99dB waterproof speaker
ConnectivityN/A2.4 GHz Wi-Fi (no 5 GHz)2.4 GHz Wi-Fi, Wi-Fi 6
Motion DetectionN/AYesYes
DimensionsN/A124mm (H) x 60mm (W) x 63mm (D)2in x 2in x 2 3/8in
WeightN/A11.29 oz (320 g)0.49 lb (222 g)
Mounting OptionsN/AScrew 1/4" - 20Stand, Wall mount, Ceiling mount, Magnetic wall mount (adhesive)
StorageN/ASupports up to 256 GB microSDmicroSD card up to 512 GB
Additional FeaturesIP67 weather resistant, works with specific adaptersAutomatic motion tracking, Privacy Mode, Pan Scan™ PatrolMotion-activated spotlight, Alexa & Google Assistant compatible
Price$5.99 - $19.99 (depending on variant)$39.98 (single camera)$35.98 - $107.94 (depending on pack and variant)
What is the best way to power a Wyze camera outdoors without battery swaps?The best solution to power a Wyze camera outdoors without frequent battery swaps is the Wyze Outdoor Power Adapter. It provides continuous, maintenance-free power to your Wyze cameras, ensuring uninterrupted security monitoring in any weather condition.
Is the Wyze Outdoor Power Adapter weatherproof?Yes, the Wyze Outdoor Power Adapter is built with an IP67 weather-resistant rating, making it highly durable and suitable for outdoor use in rain, snow, or shine.
Which Wyze cameras are compatible with the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter is compatible with several Wyze cameras, including the Wyze Cam v3 Pro, Wyze Cam Pan v3, Battery Cam Pro, and Wyze Cam v4. Some models may require additional adapters, such as an L-shaped MicroUSB or USB-C adapter.
What are the power specifications of the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter has an input power of 100V-240V and an output power of 5V 2A. It features a Micro USB connector for the camera and a 2-pin flat (US standard) connector for the wall plug.
How long is the cable included with the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter comes with a 12.5 ft (3.8 m) cable, providing flexible installation options for your outdoor cameras.
Can the Wyze Cam Pan v3 be used outdoors?Yes, the Wyze Cam Pan v3 is designed for outdoor use with an IP65 weather resistance rating. However, it requires the Wyze Outdoor Power Adapter for safe and continuous outdoor power.
What are the key features of the Wyze Cam Pan v3 for outdoor surveillance?The Wyze Cam Pan v3 offers 360° horizontal and 180° vertical pan and tilt, IP65 weather resistance, Full HD 1080p video with night vision, two-way audio, and compatibility with Alexa, Google Assistant, and IFTTT.
Is the Wyze Cam v4 suitable for outdoor use?Yes, the Wyze Cam v4 is rated IP65 for weather resistance, making it ideal for outdoor environments. It requires the Wyze Outdoor Power Adapter for continuous outdoor power.
What are the video and audio features of the Wyze Cam v4?The Wyze Cam v4 delivers 2.5K QHD resolution, enhanced color night vision, an 8x digital zoom, a built-in 99dB waterproof speaker, two-way talk, a built-in siren, and noise/echo cancellation.
What mounting options are available for Wyze outdoor cameras?Wyze outdoor cameras, such as the Cam v4, offer multiple mounting options including wall, ceiling, and magnetic mounts. The Wyze Outdoor Power Adapter includes wire clips, screws, and anchors for secure installation.
Why should I choose the Wyze Outdoor Power Adapter for my Wyze cameras?The Wyze Outdoor Power Adapter eliminates the need for battery swaps, offers weatherproof reliability with an IP67 rating, is easy to install with included hardware, and is compatible with multiple Wyze camera models for versatile outdoor security.
What are the installation requirements for the Wyze Outdoor Power Adapter?Can the Wyze Outdoor Power Adapter be used with all Wyze camera models?Do you have any deals, ongoing sales, discounts, or promotions?
