Weatherproof Adapter for Continuous Wyze Cam Outdoor Recording
Weatherproof Adapter for Continuous Video Recording on Wyze Cam Outdoor
When it comes to securing your outdoor spaces with Wyze cameras, having a reliable, weatherproof power source is essential for continuous video recording. The Wyze Outdoor Power Adapter is specifically designed to keep your Wyze Cam outdoor devices powered through rain, snow, or shine, ensuring uninterrupted surveillance no matter the weather conditions.
Wyze Outdoor Power Adapter: The Ultimate Weatherproof Solution
Built for All Weather Conditions
The Wyze Outdoor Power Adapter boasts an IP67 weather resistance rating, making it fully capable of withstanding harsh outdoor environments including heavy rain, snow, and dust. This means you can confidently install your Wyze Cam outdoors without worrying about power interruptions caused by weather.
Compatibility and Convenience
  • Compatible with multiple Wyze camera models including Wyze Cam v3, Wyze Cam v4, Pan v3, and Battery Cam Pro.
  • Requires pairing with the L-shaped Micro USB Adapter for Wyze Cam v3 Pro and Pan v3.
  • For Wyze Battery Cam Pro, it works alongside the USB-C adapter.
  • Note: Not compatible with the OG Stack Kit.
Cable Length and Power Specs
  • Total cable length of 12.5 feet (3.8 meters) provides flexible installation options.
  • Input power range: 100V-240V, output power: 5V 2A.
  • Operating temperature range from -30°C to 50°C (-22°F to 122°F) ensures durability in extreme climates.
Included Accessories
The adapter kit comes complete with:
  • Wyze Outdoor Power Adapter
  • Wire clips and screws for secure mounting
  • Weatherproof L-shaped Micro-USB Adapter
Ready for rain, snow, or shine, this adapter is your go-to for continuous outdoor video recording with Wyze cameras.
Wyze Cam Pan v3 in snowy outdoor setting Wyze Cam Pan v3 powered outdoors in winter weather
Wyze Cam Pan v3: 360° Pan and Tilt with Weather Resistance
Dynamic Outdoor Surveillance
The Wyze Cam Pan v3 is a versatile indoor/outdoor camera featuring a 360° horizontal pan and 180° vertical tilt, allowing you to cover large areas with a single device. Its IP65 weather resistance rating means it can handle outdoor conditions when paired with the Wyze Outdoor Power Adapter.
Video and Audio Features
  • Full HD 1080p video resolution with H.264 encoding.
  • Night vision with 4 IR LEDs for clear images in the dark.
  • Built-in speaker and microphone enable two-way audio with noise and echo cancellation.
  • Automatic motion tracking keeps moving subjects in frame.
Installation and Power
  • Mounts easily with a screw mount (1/4" - 20).
  • Powered via micro USB port, compatible with the Wyze Outdoor Power Adapter for outdoor use.
  • Operating temperature range: -20°C to 50°C (-4°F to 122°F).
The Pan v3 combined with the weatherproof adapter ensures your outdoor video recording is continuous and reliable.
Wyze Cam v4: Advanced Outdoor Camera with Crisp 2.5K Video
Superior Video Quality and Features
The Wyze Cam v4 offers stunning 2.5K QHD (2560x1440) video resolution, providing crystal-clear footage for outdoor monitoring. It features a CMOS Starlight Sensor for enhanced low-light performance and color night vision with 4 IR LEDs plus 2 white spotlight LEDs.
Weatherproof and Durable
  • Rated IP65 for weather resistance, suitable for outdoor use when paired with the Wyze Outdoor Power Adapter.
  • Operating temperature range from -20°C to 50°C (-4°F to 122°F).
  • Polycarbonate body with glass and plastic lens materials ensures durability.
Smart Features
  • Two-way talk with a 99dB waterproof speaker and built-in siren.
  • Supports Wi-Fi 6 and Bluetooth 5.2 for fast, reliable connectivity.
  • Compatible with Alexa, Google Assistant, and IFTTT integrations.
  • Local storage support up to 512GB microSD card and cloud storage options.
Power and Mounting
  • Comes with an indoor USB power adapter; outdoor use requires the Wyze Outdoor Power Adapter.
  • Multiple mounting options including stand, wall, ceiling, and magnetic mounts.
For continuous outdoor video recording with superior image quality, the Wyze Cam v4 paired with the weatherproof power adapter is an unbeatable combination.
Wyze Cam v4 two-way audio with pet Wyze Cam v4 enabling two-way audio for interactive monitoring
Why Choose Wyze Outdoor Power Adapter for Your Wyze Outdoor Cameras?
  • Weatherproof design ensures uninterrupted power supply outdoors.
  • Long cable length allows flexible camera placement.
  • Compatibility with multiple Wyze camera models.
  • Easy installation with included mounting accessories.
  • Certified safety with FCC and UL certifications.
  • 1-year warranty for peace of mind.
Summary
For anyone looking to maintain continuous video recording on their Wyze outdoor cameras, the Wyze Outdoor Power Adapter is an essential accessory. It guarantees a weatherproof power connection that keeps your cameras running smoothly through all seasons. When paired with the Wyze Cam Pan v3 or Wyze Cam v4, you get a powerful, reliable outdoor security system with excellent video quality, smart features, and robust weather resistance. Invest in the Wyze Outdoor Power Adapter today to ensure your Wyze outdoor cameras never miss a moment.
FeatureWyze Outdoor Power AdapterWyze Cam Pan v3Wyze Cam v4
TypeAccessoryCameraCamera
Weather ResistanceIP67IP65IP65
Outdoor Use RequirementRequired for outdoor use of Wyze Cam v3 Pro, Pan v3, Battery Cam Pro (with adapters)Requires Wyze Outdoor Power Adapter (sold separately) for outdoor useOutdoor compatible; Outdoor Power Adapter sold separately
Power Adapter OutputNot specified (compatible with 5V/1A or 5V/2A devices)5V/2000mAIndoor 5V/1A
CompatibilityWyze Cam v4, OG series, Cam Pan v3, Cam v3 Pro, Battery Cam Pro (with adapters)Wyze Cam Pan v3Wyze Cam v4
Price Range$5.99 - $19.99 (depending on variant)$39.98 (single camera)$35.98 - $107.94 (depending on variant)
Video ResolutionN/A1080p (1920x1080)2.5K QHD (2560x1440)
Field of ViewN/A360° pan, 180° tilt, 120° FOVDFOV 115.8°, HFOV 98.5°, VFOV 53.1°
Night VisionN/A4 IR LEDs (850 nm), Color Night Vision4 IR LEDs (850 nm) + 2 white spotlight LEDs (72 lumens), Enhanced Color Night Vision
AudioN/ABuilt-in speaker, microphone, 2-way audio99dB waterproof speaker, simultaneous 2-way talk
Motion DetectionN/AYesYes
Additional FeaturesIP67 weather resistant for outdoor power supplyAutomatic motion tracking, Privacy Mode, Pan Scan™ Patrol, Noise & Echo cancellationMotion-activated spotlight, Wide Dynamic Range (WDR), Alexa & Google Assistant integration
StorageN/ASupports up to 256GB microSD in ExFAT formatmicroSD card up to 512GB, local and cloud storage
ConnectivityN/A802.11 b/g/n 2.4GHz Wi-Fi (no 5GHz)2.4 GHz Wi-Fi, Wi-Fi 6
DimensionsN/A124mm (H) x 60mm (W) x 63mm (D)2in x 2in x 2 3/8in
WeightN/A11.29 oz (320 g)0.49 lb (222 g)
WarrantyNot specified1 Year1 Year
What is the Wyze Outdoor Power Adapter and why do I need it for my Wyze outdoor cameras?The Wyze Outdoor Power Adapter is a weatherproof power solution designed to provide continuous power to your Wyze outdoor cameras. It ensures uninterrupted video recording by protecting against rain, snow, and dust, making it essential for reliable outdoor surveillance.
Which Wyze camera models are compatible with the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter is compatible with Wyze Cam v3, Wyze Cam v4, Pan v3, and Battery Cam Pro. For Wyze Cam v3 Pro and Pan v3, it requires the L-shaped Micro USB Adapter, and for Battery Cam Pro, it works with the USB-C adapter. It is not compatible with the OG Stack Kit.
Is the Wyze Outdoor Power Adapter weatherproof?Yes, the Wyze Outdoor Power Adapter has an IP67 weather resistance rating, making it fully weatherproof and capable of withstanding harsh outdoor conditions such as heavy rain, snow, and dust.
What is the cable length of the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter features a total cable length of 12.5 feet (3.8 meters), providing flexible installation options for your outdoor cameras.
What are the power specifications and operating temperature range for the Wyze Outdoor Power Adapter?The adapter supports an input power range of 100V-240V and outputs 5V 2A. It operates in temperatures from -30°C to 50°C (-22°F to 122°F), ensuring durability in extreme climates.
What accessories are included with the Wyze Outdoor Power Adapter kit?The kit includes the Wyze Outdoor Power Adapter, wire clips and screws for secure mounting, and a weatherproof L-shaped Micro-USB Adapter.
Can I use the Wyze Cam Pan v3 outdoors with continuous power?Yes, the Wyze Cam Pan v3 is designed for both indoor and outdoor use. When paired with the Wyze Outdoor Power Adapter, it provides continuous power and reliable 360° pan and 180° tilt surveillance in all weather conditions.
Does the Wyze Cam v4 support outdoor installation and continuous video recording?Yes, the Wyze Cam v4 is rated IP65 for weather resistance and, when used with the Wyze Outdoor Power Adapter, supports continuous outdoor video recording with advanced 2.5K QHD video quality.
What smart features do Wyze outdoor cameras offer when powered by the Outdoor Power Adapter?Wyze outdoor cameras offer features such as two-way audio, night vision, motion tracking, smart assistant integration (Alexa, Google Assistant, IFTTT), and local/cloud storage options, all supported by continuous power from the Outdoor Power Adapter.
Is the Wyze Outdoor Power Adapter safe and certified?Yes, the Wyze Outdoor Power Adapter is certified for safety with FCC and UL certifications and comes with a 1-year warranty for peace of mind.
How easy is it to install the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter is easy to install and comes with mounting accessories such as wire clips and screws, allowing for secure and flexible placement of your outdoor cameras.
What are the installation requirements for the Wyze Outdoor Power Adapter?Can the Wyze Outdoor Power Adapter be used with the Wyze Cam v3 Pro?Do you have any deals, ongoing sales, discounts, or promotions?
