Wyze Battery Cam Pro: Black & White Color Options Explained
Wyze Battery Cam Pro Color Options and Features
The Wyze Battery Cam Pro is a versatile wireless security camera designed to provide high-quality surveillance with flexible installation options. One of the key aspects users often inquire about is the available color options, which allow the camera to blend seamlessly with different home or business aesthetics.
Available Colors
Black White These two classic colors ensure that whether you prefer a sleek, modern look or a subtle, clean appearance, the Wyze Battery Cam Pro can match your style and environment.
Key Features of Wyze Battery Cam Pro
  • 2.5K HDR Video Resolution: Capture crystal-clear footage with 2560 x 1440 resolution, providing sharp and detailed images day and night.
  • Wire-Free Design: Completely wireless with no hub required, making installation quick and hassle-free.
  • Integrated Spotlight & Siren: Enhance security with built-in lighting and an audible siren to deter intruders.
  • Radar + PIR Motion Detection: Advanced motion sensors reduce false alerts by combining radar and passive infrared technology.
  • Removable, Rechargeable Battery Packs: Equipped with 6200mAh batteries that are easy to swap and recharge.
  • IP65 Weatherproof: Durable enough to withstand rain, dust, and other outdoor elements.
  • Dual-Band WiFi Support: Compatible with both 2.4 GHz and 5 GHz WiFi networks for reliable connectivity.
The Wyze Battery Cam Pro’s color options and robust features make it an excellent choice for those seeking a stylish yet powerful wireless security camera.
Outdoor security camera in use Alt text: Wyze Battery Cam Pro installed outdoors on a modern home exterior
Other Wyze Camera Color Options in Security Kits
If you are exploring more Wyze camera options with color variety, consider these popular kits and bundles that include cameras with multiple color choices:
Whole Home Security Enhanced Kit
  • Wyze Cam v4 Colors: Black, Grey, White
  • Wyze Cam Floodlight v2 Colors: Black, White
This kit combines the Wyze Cam v4 and Floodlight v2, offering a range of color combinations to suit your home’s exterior or interior design preferences.
Whole Home Security Starter Kit
  • Includes one Wyze Cam v4 available in Black, Grey, and White
  • Also features the Wyze Video Doorbell v2 and Home Monitoring Starter Kit for comprehensive security.
Pan v3 + Lamp Socket v2 Bundle
  • Wyze Cam Pan v3 available in Black and White
  • This bundle allows you to power the Pan v3 camera via a lamp socket, eliminating the need for an outlet.
Cam v4 + Lamp Socket v2 Bundle
  • Wyze Cam v4 available in Black, Grey, and White
  • Similar to the Pan v3 bundle, this setup offers flexible power options with stylish color choices.
These kits provide a variety of color options to match your home’s style while delivering advanced security features.
Home security cameras installed Alt text: Multiple Wyze cameras installed around a home exterior
Why Choose Wyze Battery Cam Pro?
The Wyze Battery Cam Pro stands out for its combination of high-resolution video, wire-free convenience, and weatherproof durability. Its two color options, black and white, are thoughtfully selected to fit most environments without drawing unwanted attention. Whether you want a camera that blends into dark corners or one that matches lighter walls and trims, the Wyze Battery Cam Pro offers flexibility without compromising on performance.
For those prioritizing wireless installation and advanced motion detection, the Wyze Battery Cam Pro in black or white is a top-tier choice.
Summary of Wyze Battery Cam Pro
  • Colors: Black, White
  • Video: 2.5K HDR (2560 x 1440)
  • Power: Removable rechargeable battery (6200mAh)
  • Connectivity: 2.4 & 5 GHz WiFi
  • Weatherproof: IP65 rating
  • Additional: Integrated spotlight, siren, radar + PIR motion detection
Enhance your home security with a camera that fits your style and keeps you connected. Family enjoying home security Alt text: Family feeling safe at home with Wyze security cameras
FeatureWyze Battery Cam Pro (Single Pack)Wyze Battery Cam Pro + Solar Panel Bundle
Video Resolution2.5K HDR2.5K HDR
Power SourceRemovable, Rechargeable Battery PacksRemovable, Rechargeable Battery Packs + Solar Panel for continuous power
WirelessYes, Wire-FreeYes, Wire-Free
Hub RequiredNoNo
Integrated Spotlight & SirenYesYes
Motion DetectionRadar + PIRRadar + PIR
Weatherproof RatingIP65IP65
WiFi Support2.4 & 5 GHz2.4 & 5 GHz
Local RecordingYes, with MicroSD card (not included)Yes, with MicroSD card (not included)
Color OptionsBlack, WhiteBlack, White
Pack Options1 Pack, 2 Pack, 3 PackBundle includes 1 Camera + 1 Solar Panel
Price (Approximate)$89.98 (1 Pack)$109.98 (Bundle)
SetupBluetoothⓇ Setup, no QR codeBluetoothⓇ Setup, no QR code
Additional FeaturesHot-swap battery packs, dual-band WiFi, two-way audioContinuous power via solar panel, all features of Battery Cam Pro
Mounting OptionsFlexible, includes ceiling mount option (sold separately)Same as Battery Cam Pro
What color options are available for the Wyze Battery Cam Pro?The Wyze Battery Cam Pro is available in two classic colors: black and white. These options allow you to choose a camera that best matches your home or business décor.
What are the key features of the Wyze Battery Cam Pro?The Wyze Battery Cam Pro offers 2.5K HDR video resolution, a completely wire-free design, integrated spotlight and siren, advanced radar plus PIR motion detection, removable and rechargeable 6200mAh battery packs, IP65 weatherproof rating, and dual-band WiFi support (2.4 GHz and 5 GHz).
Is the Wyze Battery Cam Pro weatherproof?Yes, the Wyze Battery Cam Pro is IP65 weatherproof, making it suitable for outdoor use and able to withstand rain, dust, and other environmental elements.
Does the Wyze Battery Cam Pro require a hub for installation?No, the Wyze Battery Cam Pro features a wire-free design and does not require a hub, making installation quick and hassle-free.
What type of motion detection does the Wyze Battery Cam Pro use?The Wyze Battery Cam Pro uses advanced radar and passive infrared (PIR) motion detection to reduce false alerts and provide accurate security monitoring.
Are there other Wyze cameras available in different colors?Yes, other Wyze cameras such as the Wyze Cam v4 are available in black, grey, and white. The Wyze Cam Floodlight v2 and Wyze Cam Pan v3 are available in black and white. These options are included in various security kits and bundles.
What is included in the Wyze Whole Home Security Enhanced Kit?The Wyze Whole Home Security Enhanced Kit includes Wyze Cam v4 cameras (available in black, grey, and white) and Wyze Cam Floodlight v2 cameras (available in black and white), offering a range of color combinations for comprehensive home security.
Can I power Wyze cameras using a lamp socket?Yes, the Pan v3 + Lamp Socket v2 Bundle and the Cam v4 + Lamp Socket v2 Bundle allow you to power your Wyze cameras via a lamp socket, providing flexible installation options without the need for an electrical outlet.
Why should I choose the Wyze Battery Cam Pro for my home security?The Wyze Battery Cam Pro combines high-resolution video, wire-free convenience, weatherproof durability, and advanced motion detection. Its black and white color options ensure it fits seamlessly into most environments, making it a top choice for stylish and effective home security.
What are the key features of the Wyze Battery Cam Pro?Can you tell me more about the Whole Home Security Enhanced Kit?What is the warranty policy for the Wyze Battery Cam Pro?
