Wyze Battery Cam Pro: Color Night Vision Security Camera
Discover the Wyze Battery Cam Pro: Color Night Vision for Nighttime Security
When it comes to capturing clear, vibrant footage in dark areas, the Wyze Battery Cam Pro stands out as a top choice. Designed for enhanced nighttime surveillance, this camera offers color night vision that brings your nighttime footage to life with rich, true-to-life colors instead of the usual black-and-white infrared images.
Stunning 2.5K HDR Video Resolution with Color Night Vision
The Wyze Battery Cam Pro delivers crystal-clear 2.5K HDR video resolution, ensuring every detail is captured with precision. Its advanced color night vision technology uses a high dynamic range sensor to balance light and color, allowing you to see more than just shadows in the dark. Whether it’s a dimly lit backyard or a poorly lit alley, this camera reveals vibrant colors and sharp images for better identification and security.
Wireless Freedom with No Hub Required
Forget about complicated wiring or hubs. The Wyze Battery Cam Pro is completely wire-free and operates on removable, rechargeable battery packs. This means you can place it anywhere—on walls, ceilings, or even under eaves—without worrying about power outlets or messy cables. Plus, it supports both 2.4 GHz and 5 GHz Wi-Fi for a stable and fast connection.
Integrated Spotlight & Siren for Added Security
Equipped with a 150-lumen motion-activated LED spotlight, the Wyze Battery Cam Pro can illuminate dark areas instantly, deterring intruders and improving video clarity. You can also manually control the spotlight via the Wyze app, perfect for extra visibility when walking your dog or checking your property at night. The built-in siren adds an extra layer of protection by alerting you and scaring off unwanted visitors.
Advanced Motion Detection with Radar + PIR Sensors
This camera features a dual motion detection system combining radar and PIR sensors. This powerful combo detects movement earlier and more accurately, reducing false alarms. Customize detection zones in the app to focus on specific areas, ensuring you only get alerts that matter.
Weatherproof and Built to Last
With an IP65 weatherproof rating, the Wyze Battery Cam Pro is ready to withstand rain, dust, and extreme temperatures. Whether it’s a rainy night or a snowy morning, this camera keeps working reliably to protect your home or business.
Wyze Battery Cam Pro + Solar Panel: Continuous Power for Endless Protection
For those who want to extend their camera’s uptime without frequent battery swaps, the Wyze Battery Cam Pro + Solar Panel bundle is the perfect solution.
Solar-Powered Convenience
The included Wyze Solar Panel converts sunlight into power, keeping your camera charged throughout the day. This means less hassle with recharging and more consistent security coverage. Ideal for remote locations or areas without easy access to power outlets.
All the Features of the Battery Cam Pro
This bundle includes the same 2.5K HDR resolution, color night vision, integrated spotlight, and dual motion sensors as the standalone Battery Cam Pro. You get the best of both worlds: advanced security features plus sustainable, continuous power.
Easy Setup and Flexible Mounting
Just mount the solar panel in a sunny spot and connect it to your camera. The wireless design and multiple mounting options make installation quick and adaptable to your environment.
Enhance Your Outdoor Experience with the Bird Feeder Wireless Camera Bundle
For bird lovers and outdoor enthusiasts, the Bird Feeder Wireless Camera Bundle combines the Wyze Battery Cam Pro, Wyze Solar Panel, and a vibrant Wyze Bird Feeder to bring nature closer to you.
Watch and Record Every Feathered Visitor
The included Wyze Bird Feeder features a colorful design that attracts a variety of birds, while the Wyze Battery Cam Pro captures live video in stunning 2.5K HDR with color night vision. Watch your backyard come alive day and night with vivid, detailed footage.
Weather-Resistant and Wire-Free
This bundle is designed for outdoor use with IP65 weatherproof ratings on both the camera and solar panel. The wire-free setup means you can place the camera and feeder wherever you want without worrying about cables.
Perfect for Nature Lovers
Whether you’re a casual birdwatcher or a serious birder, this bundle offers an easy way to monitor and record wildlife activity, all accessible through the Wyze app.
Why Choose Wyze Battery Cam Pro for Nighttime Security?
"Capture vibrant, detailed footage even in complete darkness with Wyze’s color night vision technology."
  • 2.5K HDR Video: See every detail with high-resolution clarity.
  • Color Night Vision: Experience true-to-life colors at night.
  • Wireless & Battery-Powered: Install anywhere without wiring.
  • Integrated Spotlight & Siren: Illuminate and deter intruders.
  • Dual Motion Sensors: Radar + PIR for precise detection.
  • Weatherproof Design: Reliable in all weather conditions.
  • Solar Panel Option: Continuous power for uninterrupted security.
Additional Accessories to Maximize Your Wyze Battery Cam Pro
  • Wyze Removable Battery Pack: Extend your camera’s runtime with extra rechargeable batteries.
  • Wyze Battery Charging Dock: Charge two batteries simultaneously for convenience.
  • Wyze Universal Mount: Flexible mounting options including ceiling installation.
Outdoor Night Security Camera in Use Experience vibrant color night vision with Wyze Battery Cam Pro in your outdoor spaces. Solar Panel Powering Wireless Camera Keep your Wyze Battery Cam Pro powered all day with the Wyze Solar Panel. Bird Feeder with Wireless Camera Enjoy birdwatching and security with the Wyze Bird Feeder Wireless Camera Bundle.
Choose the Wyze Battery Cam Pro and its bundles for advanced color night vision and flexible, wire-free security solutions that keep you protected day and night.
FeatureWyze Battery Cam ProWyze Battery Cam Pro + Solar PanelBird Feeder Wireless Camera BundleWyze Cam v4
Video Resolution2.5K HDR (2560 x 1440)2.5K HDR (2560 x 1440)Not specified2.5K QHD (2560 x 1440)
Power SourceRemovable, Rechargeable BatteryRemovable, Rechargeable BatteryNot specifiedWired (requires power adapter)
Battery Capacity6200mAh6200mAhNot specifiedN/A
Battery LifeUp to 6 MonthsUp to 6 MonthsNot specifiedN/A
Charging TimeApprox. 9 hoursApprox. 9 hoursNot specifiedN/A
Weather ResistanceIP65IP65Not specifiedIP65
WirelessYesYesYesNo (wired)
Wi-Fi Support2.4 & 5 GHz2.4 & 5 GHzNot specified2.4 GHz & Wi-Fi 6
Field of View (FOV)134° DFOV, 108° HFOV, 56° VFOV134° DFOV, 108° HFOV, 56° VFOVNot specified115.8° DFOV, 98.5° HFOV, 53.1° VFOV
Night Vision2 IR LEDs + 2 White LEDs2 IR LEDs + 2 White LEDsNot specified4 IR LEDs + 2 White Spotlight LEDs
Color Night VisionYesYesNot specifiedYes
Integrated SpotlightYesYesNot specifiedYes
Siren100 dB SPL100 dB SPLNot specified99 dB
AudioTwo-way audio with MEMS micTwo-way audio with MEMS micNot specifiedEnhanced two-way talk
Local StoragemicroSD up to 256 GBmicroSD up to 256 GBNot specifiedmicroSD up to 512 GB
Continuous RecordingYesYesNot specifiedYes
Motion DetectionRadar + PIRRadar + PIRNot specifiedYes
Motion Detection ZonesNot specifiedNot specifiedNot specifiedYes
Smoke & CO AlertsNot specifiedNot specifiedNot specifiedYes
Mounting Methods1/4" - 20 standard, wall mount included1/4" - 20 standard, wall mount includedNot specifiedStand, wall, ceiling, magnetic mount
Dimensions2.5 x 1.8 x 3.5 inches2.5 x 1.8 x 3.5 inchesNot specified2 x 2 x 2 3/8 inches
Weight0.94 lbs0.94 lbsNot specified0.49 lbs
Bluetooth VersionBLE 5.1BLE 5.1Not specified5.2
IntegrationsAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTNot specifiedAlexa, Google Assistant, IFTTT
Operating Temperature-20°C to +50°C (-4°F to 122°F)-20°C to +50°C (-4°F to 122°F)Not specified-20°C to +50°C (-4°F to 122°F)
WarrantyNot specifiedNot specifiedNot specified1 Year
Price (approximate)$159.98 (1 pack)$109.98Not specified$35.98 - $107.94 (varies by pack/color)
What is the Wyze Battery Cam Pro and how does it enhance nighttime security?The Wyze Battery Cam Pro is a wireless outdoor security camera designed for enhanced nighttime surveillance. It features advanced color night vision technology, allowing you to capture clear, vibrant footage in the dark with true-to-life colors, rather than traditional black-and-white images.
Does the Wyze Battery Cam Pro offer high-resolution video quality?Yes, the Wyze Battery Cam Pro delivers stunning 2.5K HDR video resolution, ensuring every detail is captured with precision, both during the day and at night.
Is the Wyze Battery Cam Pro completely wireless?Yes, the Wyze Battery Cam Pro is 100% wire-free and operates on removable, rechargeable battery packs. It does not require a hub and supports both 2.4 GHz and 5 GHz Wi-Fi for a stable connection.
What security features are included with the Wyze Battery Cam Pro?The Wyze Battery Cam Pro includes a 150-lumen motion-activated LED spotlight, a built-in siren, and advanced dual motion detection using radar and PIR sensors. These features help deter intruders, improve video clarity, and reduce false alarms.
Can I customize motion detection zones with the Wyze Battery Cam Pro?Yes, you can customize detection zones in the Wyze app to focus on specific areas, ensuring you only receive alerts that matter to you.
Is the Wyze Battery Cam Pro weatherproof?Absolutely. The Wyze Battery Cam Pro has an IP65 weatherproof rating, making it resistant to rain, dust, and extreme temperatures for reliable outdoor use.
What is included in the Wyze Battery Cam Pro + Solar Panel bundle?The Wyze Battery Cam Pro + Solar Panel bundle includes the camera and a Wyze Solar Panel. The solar panel keeps your camera charged using sunlight, providing continuous power and reducing the need for frequent battery recharging.
How easy is it to install the Wyze Battery Cam Pro and Solar Panel?Installation is quick and flexible. The camera and solar panel are both wire-free and come with multiple mounting options, allowing you to place them wherever you need security coverage.
What is the Bird Feeder Wireless Camera Bundle?The Bird Feeder Wireless Camera Bundle combines the Wyze Battery Cam Pro, Wyze Solar Panel, and a colorful Wyze Bird Feeder. This bundle is perfect for birdwatchers, allowing you to watch and record birds in stunning 2.5K HDR with color night vision.
Can I use the Wyze Battery Cam Pro for birdwatching?Yes, the Wyze Battery Cam Pro is ideal for birdwatching, especially when paired with the Wyze Bird Feeder. It captures vivid, detailed footage of birds day and night, and the wire-free, weatherproof design makes it perfect for outdoor use.
What accessories are available for the Wyze Battery Cam Pro?Available accessories include the Wyze Removable Battery Pack for extended runtime, the Wyze Battery Charging Dock for charging two batteries simultaneously, and the Wyze Universal Mount for flexible installation options, including ceiling mounting.
How does the Wyze Battery Cam Pro compare to traditional night vision cameras?Unlike traditional cameras that use black-and-white infrared night vision, the Wyze Battery Cam Pro features color night vision technology, providing vibrant, true-to-life colors even in complete darkness for better identification and security.
What are the key features of the Wyze Battery Cam Pro?How does the color night vision technology work in the Wyze Battery Cam Pro?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Battery Cam Pro?
