Wyze Battery Cam Pro: Advanced Night Vision for Barns & Sheds
Advanced Night Vision Cameras for Barn and Shed Monitoring
When it comes to monitoring barns or sheds, especially during the night, having a reliable camera with advanced night vision capabilities is essential. The Wyze Battery Cam Pro series offers cutting-edge features tailored for outdoor security, making it an excellent choice for protecting your property with crystal-clear video and smart detection technology.
Wyze Battery Cam Pro: Powerful Night Vision and Wireless Freedom
Stunning 2.5K HDR Video Resolution
The Wyze Battery Cam Pro delivers sharp, high-definition 2.5K HDR video, ensuring every detail is captured with clarity. Whether it’s day or night, the camera’s high dynamic range balances lighting for vibrant, true-to-life colors and crisp images.
Color Night Vision for Clear Low-Light Monitoring
Unlike traditional black-and-white night vision, this camera features color night vision, allowing you to see more details in low-light conditions. This is especially useful for barns or sheds where lighting may be minimal but security is critical.
Wire-Free and Weatherproof Design
With a removable, rechargeable battery pack, the Wyze Battery Cam Pro is completely wire-free—no need for power outlets or complicated wiring. Its IP65 weatherproof rating means it can withstand rain, dust, and harsh outdoor conditions, making it perfect for barns, sheds, or any outdoor structure.
Integrated Spotlight and Siren
The camera includes a 150-lumen motion-activated spotlight and a siren to deter intruders immediately. You can also manually control the spotlight via the Wyze app, providing extra security when you’re nearby.
Advanced Motion Detection with Radar + PIR Sensors
Combining radar and passive infrared (PIR) sensors, the Wyze Battery Cam Pro offers early and precise motion detection. Customize detection zones in the app to focus on specific areas around your barn or shed, reducing false alerts.
Flexible Mounting and Power Options
Mount the camera anywhere with the included mounts or upgrade to the Wyze Universal Mount for ceiling or eave installations. Hot-swap battery packs to keep your camera running without downtime.
Wyze Battery Cam Pro + Solar Panel: Continuous Power for Remote Locations
Solar-Powered Security for Extended Monitoring
For barns or sheds located far from power sources, the Wyze Battery Cam Pro + Solar Panel bundle is an ideal solution. The solar panel converts sunlight into power, significantly extending battery life and reducing the need for manual recharging.
All the Features of the Battery Cam Pro
This bundle includes everything the Wyze Battery Cam Pro offers: 2.5K HDR video, color night vision, integrated spotlight and siren, radar + PIR motion detection, and IP65 weatherproofing.
Easy Installation and Weather Resistance
The solar panel is designed for outdoor use with an IP65 rating and comes with a 13-foot power cable for flexible placement. This ensures your camera stays powered even in remote or hard-to-reach locations.
Protect your barn or shed day and night with a camera that never runs out of power.
Wyze Battery Cam Pro installed outdoors on a barn wall at dusk, spotlight illuminating the area Alt text: Wyze Battery Cam Pro monitoring a barn at night with spotlight on
Bird Feeder Wireless Camera Bundle: Dual Purpose Monitoring and Birdwatching
Combine Security with Nature Watching
The Bird Feeder Wireless Camera Bundle includes the Wyze Battery Cam Pro, a Wyze Bird Feeder, and a Wyze Solar Panel. This bundle is perfect if you want to monitor your barn or shed while also enjoying live views of visiting birds.
Features Tailored for Outdoor Use
  • Weather-resistant IP65 rating for all components
  • Wire-free setup with solar power support
  • Bird feeder designed to attract a variety of birds with vibrant colors and durable polycarbonate material
  • Live video streaming and recording via the Wyze app
Ideal for Barns, Sheds, and Gardens
This bundle not only secures your property but also adds a delightful birdwatching experience, making it a unique and functional addition to your outdoor space.
Why Choose Wyze Battery Cam Pro for Barn and Shed Security?
  • Advanced night vision with color imaging ensures clear visibility in darkness
  • Wireless and weatherproof design allows flexible placement without wiring hassles
  • Integrated spotlight and siren provide active deterrence against intruders
  • Radar + PIR motion detection reduces false alarms and improves accuracy
  • Optional solar power keeps your camera running longer in remote locations
  • Local recording support with microSD card for continuous event capture without subscription
With Wyze Battery Cam Pro, you get professional-grade security tailored for outdoor environments like barns and sheds, combining convenience, durability, and smart technology.
Wyze Battery Cam Pro mounted on a shed exterior with solar panel attached, surrounded by greenery Alt text: Wyze Battery Cam Pro with solar panel mounted on a shed exterior
Enhance Your Setup with Wyze Accessories
  • Wyze Battery Charging Dock: Charge two battery packs simultaneously to minimize downtime.
  • Wyze Universal Mount (Long): Perfect for ceiling or eave mounting to get the best vantage point.
  • Wyze MicroSD Cards: Enable local recording to save footage directly on the camera.
These accessories help you customize your barn or shed monitoring system for maximum efficiency and ease of use.
Conclusion
For advanced night vision monitoring of barns or sheds, the Wyze Battery Cam Pro and its solar-powered variant offer unmatched flexibility, clarity, and smart features. Whether you need a standalone camera or a solar-powered solution for remote areas, Wyze provides reliable, weatherproof security cameras that keep your property safe around the clock. Person checking Wyze app on smartphone while standing near a barn at night Alt text: User monitoring barn security camera feed on smartphone at night
Protect your barn or shed with Wyze Battery Cam Pro — the smart, wire-free, and weatherproof night vision camera designed for outdoor security.
FeatureWyze Battery Cam ProWyze Battery Cam Pro + Solar PanelBird Feeder Wireless Camera Bundle
Video Resolution2.5K HDR2.5K HDR2.5K HDR (Wyze Battery Cam Pro included)
Power SourceRemovable, Rechargeable Battery PacksBattery + Wyze Solar Panel (continuous power)Battery + Wyze Solar Panel (included)
Spotlight & SirenIntegrated Spotlight & SirenIntegrated Spotlight & SirenIntegrated Spotlight & Siren (Wyze Battery Cam Pro)
Motion DetectionRadar + PIR Motion DetectionRadar + PIR Motion DetectionRadar + PIR Motion Detection (Wyze Battery Cam Pro)
Weatherproof RatingIP65IP65IP65 (Camera & Bird Feeder)
WiFi Support2.4 & 5 GHz2.4 & 5 GHz2.4 & 5 GHz (Camera)
Local RecordingYes (MicroSD card, not included)Yes (MicroSD card, not included)Yes (MicroSD card, not included)
Included AccessoriesNoneWyze Solar PanelWyze Bird Feeder, Wyze Solar Panel
Bird FeederNoNoYes (Blue or Brown, 1 Liter seed capacity)
Camera Colors AvailableBlack, WhiteBlack, WhiteBlack, White (Camera); Blue, Brown (Bird Feeder)
Price (USD)$89.98 (1 Pack)$109.98 (Bundle)$139.98 - $154.96 (Bundle)
Dimensions (Camera)2.5" x 1.8" x 3.5"2.5" x 1.8" x 3.5"Camera: 2.5" x 1.8" x 3.5"; Bird Feeder: 7.48" x 10.12" x 8.58"
Weight (Camera)0.94 lb0.94 lbCamera: 0.94 lb; Bird Feeder: 2.5 lb
Additional FeaturesRemovable battery packs, dual-band WiFi, Bluetooth setup, two-way audioSame as Battery Cam Pro + Solar continuous powerBird Feeder with macro lens adapter, Alexa/Google/IFTTT integration
WarrantyNot specifiedNot specified1 year
What makes the Wyze Battery Cam Pro ideal for barn and shed monitoring?The Wyze Battery Cam Pro is perfect for barn and shed monitoring due to its advanced night vision with color imaging, wireless and weatherproof design (IP65 rating), integrated spotlight and siren for active deterrence, and radar + PIR motion detection for accurate alerts. Its high-definition 2.5K HDR video ensures clear footage day and night.
Does the Wyze Battery Cam Pro offer color night vision for low-light conditions?Yes, the Wyze Battery Cam Pro features color night vision, allowing you to see more details in low-light environments. This is especially useful for barns and sheds where lighting may be minimal but security is essential.
Is the Wyze Battery Cam Pro weatherproof and suitable for outdoor use?Absolutely. The Wyze Battery Cam Pro has an IP65 weatherproof rating, making it resistant to rain, dust, and harsh outdoor conditions. It is designed specifically for outdoor environments like barns, sheds, and gardens.
How does the Wyze Battery Cam Pro detect motion around my barn or shed?The Wyze Battery Cam Pro uses advanced motion detection technology that combines radar and passive infrared (PIR) sensors. This dual system provides early and precise motion detection, and you can customize detection zones in the Wyze app to focus on specific areas and reduce false alerts.
Can I install the Wyze Battery Cam Pro without wiring or a power outlet?Yes, the Wyze Battery Cam Pro is completely wire-free thanks to its removable, rechargeable battery pack. You don’t need any power outlets or complicated wiring, making installation easy and flexible for barns and sheds.
What is the benefit of the Wyze Battery Cam Pro + Solar Panel bundle for remote locations?The Wyze Battery Cam Pro + Solar Panel bundle is ideal for barns or sheds located far from power sources. The solar panel converts sunlight into power, significantly extending the camera’s battery life and reducing the need for manual recharging, ensuring continuous security monitoring.
Can I record footage locally on the Wyze Battery Cam Pro?Yes, the Wyze Battery Cam Pro supports local recording with a microSD card. This allows you to save footage directly on the camera for continuous event capture without needing a subscription.
What accessories are available to enhance my Wyze barn or shed security setup?Wyze offers several accessories to enhance your setup, including the Wyze Battery Charging Dock (for charging two battery packs simultaneously), Wyze Universal Mount (for ceiling or eave mounting), and Wyze MicroSD Cards (for local recording). These accessories help you customize your monitoring system for maximum efficiency.
What is included in the Bird Feeder Wireless Camera Bundle?The Bird Feeder Wireless Camera Bundle includes the Wyze Battery Cam Pro, a Wyze Bird Feeder, and a Wyze Solar Panel. This bundle is perfect for monitoring your barn or shed while also enjoying live views of visiting birds, combining security with birdwatching.
How easy is it to install the Wyze Battery Cam Pro and its solar panel?Installation is straightforward. The camera is wire-free and comes with included mounts, and the solar panel features a 13-foot power cable for flexible placement. Both the camera and solar panel are weather-resistant, making them easy to set up in various outdoor locations.
What are the key features of the Wyze Battery Cam Pro for outdoor monitoring?How does the color night vision feature work on the Wyze Battery Cam Pro?Do you have any ongoing sales or discounts for the Wyze Battery Cam Pro?
