Best Wyze Battery Cam Pro: Outdoor Security with Color Night Vision
Best Rechargeable Battery Powered Outdoor Security Cameras with Color Night Vision
When it comes to securing your outdoor spaces, having a reliable, rechargeable battery-powered security camera with advanced features like color night vision is essential. The Wyze Battery Cam Pro series stands out as one of the best options available, combining high-resolution video, smart detection technology, and weatherproof durability. Below, we explore the key products in this lineup to help you choose the perfect outdoor security camera solution.
Wyze Battery Cam Pro: Premium Wire-Free Security
Stunning 2.5K HDR Video Quality
The Wyze Battery Cam Pro delivers crystal-clear 2.5K HDR video resolution (2560 x 1440), ensuring you never miss a detail. Its CMOS-Starlight sensor paired with an F1.6 lens captures vibrant, sharp images even in low-light conditions.
Color Night Vision with Integrated Spotlight
Unlike traditional infrared night vision, this camera features 2 white LEDs (5500K, 187 lumens) that provide full-color night vision. The integrated spotlight not only enhances visibility but also acts as a deterrent for unwanted visitors.
Advanced Motion Detection & Siren
Equipped with radar and PIR motion sensors, the camera accurately detects movement while minimizing false alerts. A built-in 100 dB siren can be triggered remotely to scare off intruders.
Long-Lasting Rechargeable Battery
Powered by a removable 6200mAh rechargeable battery pack, the Wyze Battery Cam Pro can last up to 6 months on a single charge. Charging takes approximately 9 hours, making it convenient for long-term outdoor use.
Weatherproof & Versatile Installation
With an IP65 rating, this camera withstands rain, dust, and extreme temperatures (-20°C to 50°C). It supports both 2.4 GHz and 5 GHz WiFi bands and integrates seamlessly with Alexa, Google Assistant, and IFTTT.
Dimensions & Design
Compact and lightweight (0.94 lbs), the camera measures 2.5 x 1.8 x 3.5 inches and comes in sleek black or white matte finishes. It includes a standard 1/4” - 20 mounting option with a wall mount for easy setup.
Experience peace of mind with a wire-free, high-performance security camera that keeps watch day and night.
Outdoor security camera in garden setting Alt text: Wyze Battery Cam Pro mounted outdoors with spotlight on
Wyze Battery Cam Pro + Solar Panel: Continuous Power for Extended Security
All the Features of Wyze Battery Cam Pro
This bundle includes the same advanced 2.5K HDR camera with color night vision, radar + PIR motion detection, and integrated spotlight & siren.
Solar Panel for Extended Battery Life
The included solar panel is IP65 weather-resistant and designed to mount easily anywhere outdoors. It harnesses solar energy to keep your camera powered longer, reducing the need for frequent battery charging.
Convenient and Eco-Friendly
With a 13-foot power cable and 360° adjustable mount, the solar panel ensures your camera stays charged using clean, renewable energy — perfect for remote or hard-to-reach locations.
Keep your security camera running day and night without interruption, thanks to solar power.
Home exterior with solar-powered security camera Alt text: Solar panel powering Wyze Battery Cam Pro on home exterior
Wyze Battery Cam Solar Panel Accessory: Power Up Your Camera
Extend Your Camera’s Runtime
If you already own a Wyze Battery Cam Pro, the Wyze Battery Cam Solar Panel is the perfect accessory to keep your camera charged continuously.
Weatherproof and Easy to Install
Rated IP65 for weather resistance, this solar panel comes with a wall mount and all necessary hardware. Its 2.5W, 5V DC power rating and 13-foot cable provide flexible installation options.
Compatibility
Works seamlessly with Wyze Battery Cam Pro and Wyze Cam Outdoor v1/v2 models.
Say goodbye to battery anxiety and enjoy uninterrupted outdoor surveillance.
Why Choose Wyze Battery Cam Pro Series?
  • Wire-Free Convenience: No hubs or complicated wiring needed.
  • High-Resolution Video: 2.5K HDR for clear, detailed footage.
  • Color Night Vision: See true colors even in the dark.
  • Long Battery Life: Up to 6 months per charge with rechargeable packs.
  • Smart Detection: Radar + PIR sensors reduce false alarms.
  • Weatherproof Durability: IP65 rating for all-season use.
  • Smart Home Integration: Works with Alexa, Google Assistant, and IFTTT.
  • Expandable Power Options: Solar panel accessory for continuous charging.
Additional Accessories to Enhance Your Setup
Wyze Removable Battery Pack
Keep extra fully charged batteries on hand for uninterrupted security. Each 6200mAh lithium-ion battery lasts up to 6 months and charges via USB-C in about 9 hours.
Wyze Battery Charging Dock
Charge two batteries simultaneously with this compact dock, ensuring you always have a backup ready.
Secure your home or business with the best rechargeable battery-powered outdoor security cameras featuring color night vision. The Wyze Battery Cam Pro and its solar-powered options offer unbeatable value, performance, and convenience for modern outdoor surveillance.
FeatureWyze Battery Cam ProWyze Battery Cam Pro + Solar PanelWyze Battery Cam Solar Panel
Product TypeCameraCamera + Accessory BundleAccessory
Video Resolution2.5K HDR2.5K HDRN/A
Power SourceRemovable, Rechargeable Battery PacksRemovable, Rechargeable Battery + Solar PanelSolar Panel (extends battery life)
WirelessYes, Wire-Free, No Hub RequiredYes, Wire-Free, No Hub RequiredN/A
Motion DetectionRadar + PIR Motion DetectionRadar + PIR Motion DetectionN/A
Integrated Spotlight & SirenYesYesN/A
Weatherproof RatingIP65IP65IP65
WiFi Support2.4 & 5 GHz2.4 & 5 GHzN/A
Local RecordingYes (with microSD card)Yes (with microSD card)N/A
Battery LifeUp to 6 months per charge (6200mAh battery)Extended with Solar PanelN/A
Solar Power RatingN/AIncluded (2.5W, 5VDC)2.5W, 5VDC
Solar Panel DimensionsN/AIncluded (173 mm x 120 mm x 17 mm)173 mm x 120 mm x 17 mm
Solar Panel Cable LengthN/AIncluded (13 ft / 4m)13 ft (4m)
Mounting OptionsWall, Ceiling (with Universal Mount)Wall, Ceiling (with Universal Mount)360° Mount, Weather Resistant
Price (USD)$89.98 (1 Pack White/Black)$109.98 (Bundle White/Black)$24.99 (Solar Panel), $5.99 (USB-C Adapter)
Included ItemsCamera onlyCamera + Solar PanelSolar panel, mount, cables, screws, guide
What makes the Wyze Battery Cam Pro one of the best rechargeable battery-powered outdoor security cameras?The Wyze Battery Cam Pro stands out due to its 2.5K HDR video quality, color night vision with integrated spotlight, advanced radar and PIR motion detection, long-lasting rechargeable battery, weatherproof IP65 rating, and seamless integration with Alexa, Google Assistant, and IFTTT.
Does the Wyze Battery Cam Pro offer color night vision?Yes, the Wyze Battery Cam Pro features color night vision using two white LEDs (5500K, 187 lumens) and an integrated spotlight, allowing you to see full-color images even in low-light conditions.
How long does the Wyze Battery Cam Pro battery last on a single charge?The Wyze Battery Cam Pro is powered by a removable 6200mAh rechargeable battery pack that can last up to 6 months on a single charge, depending on usage and environmental conditions.
Is the Wyze Battery Cam Pro weatherproof for outdoor use?Yes, the Wyze Battery Cam Pro has an IP65 weatherproof rating, making it resistant to rain, dust, and extreme temperatures ranging from -20°C to 50°C, ensuring reliable outdoor performance year-round.
Can I use a solar panel with the Wyze Battery Cam Pro for continuous power?Absolutely. The Wyze Battery Cam Pro + Solar Panel bundle includes a weather-resistant solar panel that keeps your camera charged using renewable energy, reducing the need for frequent battery charging and providing continuous outdoor surveillance.
What is included with the Wyze Battery Cam Pro + Solar Panel bundle?The bundle includes the Wyze Battery Cam Pro camera with all its advanced features, plus an IP65-rated solar panel with a 13-foot power cable and a 360° adjustable mount for easy installation and extended battery life.
Is the Wyze Battery Cam Solar Panel compatible with other Wyze cameras?Yes, the Wyze Battery Cam Solar Panel is compatible with the Wyze Battery Cam Pro and Wyze Cam Outdoor v1/v2 models, providing flexible and continuous power options for your outdoor security cameras.
How does the Wyze Battery Cam Pro detect motion and reduce false alerts?The Wyze Battery Cam Pro uses a combination of radar and PIR (Passive Infrared) motion sensors to accurately detect movement while minimizing false alerts, ensuring you are only notified of genuine activity.
What smart home systems does the Wyze Battery Cam Pro work with?The Wyze Battery Cam Pro integrates seamlessly with popular smart home platforms, including Amazon Alexa, Google Assistant, and IFTTT, allowing for convenient voice control and automation.
Are there additional accessories available for the Wyze Battery Cam Pro?Yes, you can enhance your setup with accessories like the Wyze Removable Battery Pack for quick battery swaps and the Wyze Battery Charging Dock, which allows you to charge two batteries simultaneously for uninterrupted security.
What are the dimensions and design features of the Wyze Battery Cam Pro?The Wyze Battery Cam Pro is compact and lightweight, measuring 2.5 x 1.8 x 3.5 inches and weighing 0.94 lbs. It comes in black or white matte finishes and includes a standard 1/4” - 20 mounting option with a wall mount for easy installation.
How long does it take to fully charge the Wyze Battery Cam Pro battery?Charging the 6200mAh removable battery pack for the Wyze Battery Cam Pro takes approximately 9 hours using a USB-C connection.
What are the key features of the Wyze Battery Cam Pro?How does the color night vision work on the Wyze Battery Cam Pro?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Battery Cam Pro?
