Discover Wyze Battery Cam Pro: Clear Color Night Vision for Superior Visibility
When it comes to home security, having a camera that offers clear, color night vision is a game changer. The
Wyze Battery Cam Pro stands out with its advanced CMOS-Starlight sensor and integrated white LEDs, providing vibrant, clear color footage even in low-light conditions. Unlike traditional infrared night vision cameras that show black and white images, this camera delivers true-to-life color video at night, enhancing visibility and detail for better security monitoring.
Stunning 2.5K HDR Video Resolution
The Wyze Battery Cam Pro captures video in crisp 2560 x 1440 (2.5K) HDR resolution, ensuring every detail is sharp and clear. Whether it’s day or night, the camera’s F1.6 lens aperture and wide 134° diagonal field of view cover a broad area, reducing blind spots around your property.
Advanced Night Vision Technology
Equipped with 2 IR LEDs (850 nm) and 2 powerful white LEDs (5500K, 187 lumens), the camera switches seamlessly between infrared and color night vision modes. This means you get bright, colorful images in the dark without sacrificing the stealth of traditional IR when needed.
Wire-Free and Weatherproof Design
Enjoy the freedom of wireless installation with no hub required. The camera runs on removable, rechargeable 6200mAh battery packs that last up to 6 months on a single charge. Rated IP65 for weather resistance, it performs reliably in temperatures from -20°C to 50°C (-4°F to 122°F), making it perfect for outdoor use year-round.
Smart Features and Integration
The Wyze Battery Cam Pro supports dual-band WiFi (2.4 & 5 GHz) and integrates smoothly with Alexa, Google Assistant, and IFTTT for voice control and automation. It also includes a built-in 100 dB siren and two-way audio with a MEMS digital microphone and speaker, allowing you to communicate directly through the camera.
Wyze Battery Cam Pro + Solar Panel: Extended Power for Continuous Security
For those seeking uninterrupted surveillance, the
Wyze Battery Cam Pro + Solar Panel bundle is an ideal solution. This package combines the powerful camera with a weather-resistant solar panel that keeps your camera charged using sunlight, reducing the need for manual recharging.
Solar-Powered Convenience
The solar panel features a 2.5W, 5V DC power rating and comes with a 13-foot micro USB cable for flexible mounting options. Its IP65 weatherproof rating ensures durability in all weather conditions, so your camera stays powered even during extended outdoor use.
Same High-Quality Video and Night Vision
This bundle maintains all the premium features of the Wyze Battery Cam Pro, including 2.5K HDR video, color night vision, radar + PIR motion detection, and integrated spotlight and siren. The solar panel simply enhances battery life, making it perfect for remote or hard-to-reach locations.
Enhance Your Setup with Wyze Accessories
Wyze Removable Battery Pack
Keep your Wyze Battery Cam Pro running longer with an extra
Wyze Removable Battery Pack. This 6200mAh rechargeable lithium-ion battery offers up to 6 months of power per charge and features a convenient USB-C charging port. Swapping batteries is quick and easy, ensuring your camera never goes offline.
Wyze Battery Charging Dock
Charge two batteries simultaneously with the
Wyze Battery Charging Dock. Compact and efficient, this dock fully charges batteries in approximately 8.5 hours, so you can always have a spare ready to go.
Wyze Battery Cam Solar Panel
If you prefer to power your camera with solar energy, the standalone
Wyze Battery Cam Solar Panel is a perfect accessory. It’s easy to mount with 360° rotation, weather-resistant, and includes all necessary mounting hardware and cables.
Why Choose Wyze Battery Cam Pro for Night Vision Security?
"Experience the next level of night vision with Wyze Battery Cam Pro’s clear color imaging, surpassing traditional infrared cameras for better visibility and security."
- Clear Color Night Vision: See vibrant, detailed footage at night.
- Long Battery Life: Up to 6 months on a single charge.
- Weatherproof & Durable: IP65 rating for all-season use.
- Smart Home Integration: Works with Alexa, Google Assistant, and IFTTT.
- Wireless & Flexible: No hub required, easy installation anywhere.
Alt text: Wyze Battery Cam Pro capturing clear color night vision footage outdoors
Alt text: Wyze Battery Cam Pro powered by solar panel in a garden setting
Alt text: Person using smartphone app to monitor Wyze Battery Cam Pro live feed
Summary of Wyze Battery Cam Pro Products
2.5K HDR, color night vision, wire-free, IP65 weatherproof, up to 6 months battery life.
Includes solar panel for extended battery life, same advanced camera features.
Extra rechargeable battery for uninterrupted power.
Charges two batteries simultaneously for convenience.
Weatherproof solar panel accessory for continuous charging.
Upgrade your home security with Wyze Battery Cam Pro and enjoy superior night vision clarity and reliable power options for peace of mind.
What is the Wyze Battery Cam Pro and how does it improve night vision security?
The Wyze Battery Cam Pro is a wireless outdoor security camera featuring advanced CMOS-Starlight sensor technology and integrated white LEDs. Unlike traditional infrared cameras that only provide black and white images at night, the Wyze Battery Cam Pro delivers clear, vibrant color night vision, enhancing visibility and detail for superior home security monitoring.What video resolution does the Wyze Battery Cam Pro offer?
The Wyze Battery Cam Pro captures video in crisp 2.5K HDR resolution (2560 x 1440), ensuring sharp, detailed footage both day and night. Its F1.6 lens aperture and wide 134° diagonal field of view help reduce blind spots around your property.How does the Wyze Battery Cam Pro switch between night vision modes?
The Wyze Battery Cam Pro is equipped with 2 IR LEDs and 2 powerful white LEDs, allowing it to seamlessly switch between infrared and color night vision modes. This provides bright, colorful images in the dark while maintaining the option for traditional IR stealth when needed.Is the Wyze Battery Cam Pro weatherproof and suitable for outdoor use?
Yes, the Wyze Battery Cam Pro is rated IP65 for weather resistance and operates reliably in temperatures from -20°C to 50°C (-4°F to 122°F), making it ideal for year-round outdoor use.How long does the Wyze Battery Cam Pro battery last on a single charge?
The Wyze Battery Cam Pro uses removable, rechargeable 6200mAh battery packs that can last up to 6 months on a single charge, depending on usage and environmental conditions.Does the Wyze Battery Cam Pro require a hub for installation?
No, the Wyze Battery Cam Pro is completely wire-free and does not require a hub for installation, making setup quick and flexible.What smart home integrations are supported by the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro supports dual-band WiFi (2.4 & 5 GHz) and integrates with Alexa, Google Assistant, and IFTTT for voice control and smart home automation.What is included in the Wyze Battery Cam Pro + Solar Panel bundle?
The Wyze Battery Cam Pro + Solar Panel bundle includes the advanced camera and a weather-resistant solar panel. The solar panel keeps your camera charged using sunlight, reducing the need for manual recharging and making it ideal for remote or hard-to-reach locations.How does the Wyze Battery Cam Solar Panel work?
The Wyze Battery Cam Solar Panel is a weatherproof accessory that provides continuous charging to your Wyze Battery Cam Pro using solar energy. It features a 2.5W, 5V DC power rating, a 13-foot micro USB cable for flexible mounting, and is easy to install with 360° rotation.What accessories are available for the Wyze Battery Cam Pro?
Available accessories include the Wyze Removable Battery Pack (extra rechargeable battery for up to 6 months of power), the Wyze Battery Charging Dock (charges two batteries simultaneously in about 8.5 hours), and the Wyze Battery Cam Solar Panel (for solar-powered charging).How do I extend the battery life of my Wyze Battery Cam Pro?
You can extend the battery life of your Wyze Battery Cam Pro by using the Wyze Battery Cam Solar Panel for continuous solar charging or by keeping extra Wyze Removable Battery Packs charged and ready to swap using the Wyze Battery Charging Dock.Does the Wyze Battery Cam Pro have two-way audio and a siren?
Yes, the Wyze Battery Cam Pro features two-way audio with a MEMS digital microphone and speaker, allowing you to communicate directly through the camera. It also includes a built-in 100 dB siren for added security.What makes the Wyze Battery Cam Pro a good choice for home security?
The Wyze Battery Cam Pro offers clear color night vision, long battery life, weatherproof durability, smart home integration, and wireless installation. These features make it an excellent choice for reliable and flexible home security.
