Expand Wireless Home Security with Wyze Solar Panel Kits
Enhance Your Wireless Home Security with Wyze Solar Panel Kits
Expanding your wireless home security system has never been easier or more efficient. Leveraging Wyze’s innovative solar panel kits alongside their advanced battery-powered cameras allows you to enjoy extended battery life, weather-resistant durability, and seamless wireless operation. Whether you want to monitor your front porch, backyard, or any outdoor space, Wyze offers smart solutions that keep your home safe while minimizing maintenance.
Wyze Battery Cam Solar Panel: Power Your Security with Sunlight
Key Features and Benefits
- Extended Battery Life: Attach the Wyze Battery Cam Solar Panel to your Wyze Battery Cam Pro or Wyze Cam Outdoor (v1/v2) to significantly extend the camera’s battery life by harnessing solar energy.
- Weather Resistant: Rated IP65, this solar panel withstands rain, dust, and harsh outdoor conditions, ensuring reliable performance year-round.
- Flexible Mounting: The included 360° adjustable mount and 13-foot USB-C power cable allow you to position the panel optimally for maximum sun exposure anywhere around your home.
- Compact and Efficient: Measuring 173 mm x 120 mm x 17 mm with a 2.5W, 5VDC solar power rating, it’s designed to be unobtrusive yet powerful.
What’s Included
- Solar panel with white frame and black solar cells
- Wall mount and screws for easy installation
- Micro USB and USB-C adapter cables
- Quick start guide for hassle-free setup
Harness the power of the sun to keep your Wyze cameras running longer without the need for frequent recharging.
Wyze Battery Cam Pro: Advanced Wireless Security Camera
Cutting-Edge Specifications
- 2.5K HDR Video Resolution: Capture crystal-clear footage with 2560 x 1440 resolution and H.264 encoding.
- Wireless and Wire-Free: Operates on removable, rechargeable 6200mAh battery packs lasting up to 6 months on a single charge.
- Integrated Spotlight & Siren: Built-in spotlight and 100 dB siren enhance security by deterring intruders.
- Radar + PIR Motion Detection: Dual sensors provide accurate motion alerts with fewer false alarms.
- Weatherproof Design: IP65 rating ensures durability in rain, snow, and extreme temperatures (-20°C to 50°C).
- Connectivity: Supports both 2.4 GHz and 5 GHz WiFi bands for stable streaming.
- Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for voice control and automation.
- Two-Way Audio: Communicate directly through the camera with built-in microphone and speaker.
Dimensions & Colors
- Compact size: 2.5 x 1.8 x 3.5 inches, weighing just 0.94 lbs
- Available in sleek black or white matte finishes
Wyze Battery Cam Pro + Solar Panel Bundle: Ultimate Wireless Security Solution
Why Choose the Bundle?
- Combines the powerful Wyze Battery Cam Pro with the solar panel accessory for continuous, worry-free operation.
- Enjoy all the camera’s advanced features plus the convenience of solar-powered battery extension.
- Ideal for remote locations or areas where frequent battery charging is inconvenient.
Features at a Glance
- 2.5K HDR video with color night vision and local/cloud recording options.
- Integrated spotlight, siren, and radar + PIR motion detection.
- IP65 weatherproof rating for reliable outdoor use.
- Supports microSD cards up to 256GB and Cam Plus cloud storage.
- Compatible with Android 9.0+ and iOS 15.0+ devices.
This bundle is perfect for homeowners seeking a robust, low-maintenance security setup that leverages renewable energy.
Why Expand Your Wireless Security with Wyze Solar Panel Kits?
- Reduced Maintenance: Solar panels reduce the need to manually recharge camera batteries, saving time and effort.
- Eco-Friendly: Solar power is a clean, renewable energy source that helps lower your carbon footprint.
- Flexible Installation: Wireless cameras paired with solar panels can be installed virtually anywhere without worrying about power outlets.
- Reliable Performance: IP65 weather resistance ensures your security system stays operational in all weather conditions.
Conclusion
For homeowners looking to expand their wireless home security, Wyze’s Battery Cam Pro combined with the Solar Panel accessory offers a smart, sustainable, and highly effective solution. Whether purchased separately or as a convenient bundle, these products provide long-lasting power, advanced security features, and easy installation — all designed to keep your home safe and monitored around the clock.
Secure your home effortlessly with solar-powered Wyze cameras.
Easy 360° mounting for optimal solar exposure.
Wireless freedom combined with extended battery life.
Feature | Wyze Battery Cam Solar Panel | Wyze Battery Cam Pro | Wyze Battery Cam Pro + Solar Panel |
Type | Accessory | Camera | Camera + Accessory Bundle |
Video Resolution | N/A | 2.5K HDR (2560 x 1440) | 2.5K HDR (2560 x 1440) |
Wireless | N/A | Yes | Yes |
Power Source | Solar Panel (extends battery life) | Removable, Rechargeable Battery Packs (6200mAh) | Removable, Rechargeable Battery Packs + Solar Panel |
Battery Life | Extends battery life | Up to 6 months | Up to 6 months (extended with solar panel) |
Weather Resistance | IP65 Weather Resistant | IP65 Weatherproof | IP65 Weatherproof |
Compatible Cameras | Wyze Cam Outdoor v1/v2, Battery Cam Pro | Wyze Battery Cam Pro | Wyze Battery Cam Pro |
Mounting | 360° Freestyle Mount, mountable anywhere | Flexible mounting options, includes wall mount | Flexible mounting options + solar panel mount |
Power Cable Length | 13-foot weatherproof cable | N/A | Included with solar panel |
Integrated Spotlight & Siren | N/A | Yes | Yes |
Motion Detection | N/A | Radar + PIR Motion Detection | Radar + PIR Motion Detection |
Night Vision | N/A | Color Night Vision | Color Night Vision |
Local Storage Support | N/A | Supports up to 256GB microSD cards | Supports up to 256GB microSD cards |
WiFi Support | N/A | 2.4 & 5 GHz WiFi | 2.4 & 5 GHz WiFi |
Dimensions | N/A | 2.5 x 1.8 x 3.5 inches | 2.5 x 1.8 x 3.5 inches |
Weight | N/A | 0.94 lbs | 0.94 lbs |
Price | $24.99 (sold out) | $89.98 (1 Pack) | $109.98 |
What are the benefits of using Wyze Solar Panel Kits for home security?
Wyze Solar Panel Kits offer extended battery life for your Wyze cameras by harnessing solar energy, reducing the need for frequent recharging. They are weather-resistant, eco-friendly, and allow for flexible installation anywhere around your home without the need for power outlets.Which Wyze cameras are compatible with the Wyze Battery Cam Solar Panel?
The Wyze Battery Cam Solar Panel is compatible with the Wyze Battery Cam Pro and Wyze Cam Outdoor (v1/v2) models, allowing you to extend their battery life using solar power.How weather-resistant are Wyze solar panels and cameras?
Both Wyze solar panels and cameras are rated IP65, making them weather-resistant and capable of withstanding rain, dust, snow, and extreme temperatures ranging from -20°C to 50°C.What is included in the Wyze Battery Cam Solar Panel kit?
The Wyze Battery Cam Solar Panel kit includes a solar panel with a white frame and black solar cells, a wall mount with screws, micro USB and USB-C adapter cables, and a quick start guide for easy installation.How long does the Wyze Battery Cam Pro battery last on a single charge?
The Wyze Battery Cam Pro operates on removable, rechargeable 6200mAh battery packs that can last up to 6 months on a single charge, depending on usage and environmental conditions.What advanced features does the Wyze Battery Cam Pro offer?
The Wyze Battery Cam Pro features 2.5K HDR video resolution, integrated spotlight and 100 dB siren, radar plus PIR motion detection for accurate alerts, two-way audio, and compatibility with Alexa, Google Assistant, and IFTTT for smart home integration.Can I purchase the Wyze Battery Cam Pro and Solar Panel as a bundle?
Yes, Wyze offers a bundle that combines the Battery Cam Pro with the Solar Panel accessory, providing a complete wireless security solution with continuous, solar-powered operation and all the advanced features of the camera.Is the Wyze Battery Cam Pro + Solar Panel bundle suitable for remote locations?
Absolutely. The bundle is ideal for remote locations or areas where frequent battery charging is inconvenient, as the solar panel keeps the camera powered for longer periods without manual intervention.What storage options are available for Wyze Battery Cam Pro?
The Wyze Battery Cam Pro supports local storage with microSD cards up to 256GB and offers cloud storage options through Cam Plus for flexible video recording and playback.What devices are compatible with the Wyze Battery Cam Pro and Solar Panel?
The Wyze Battery Cam Pro and Solar Panel are compatible with Android devices running version 9.0 or higher and iOS devices running version 15.0 or higher.
What are the installation requirements for the Wyze Battery Cam Solar Panel?Can the Wyze Battery Cam Pro be used without the solar panel?Do you have any deals, ongoing sales, discounts, or promotions?
