Wyze Outdoor Security: Solar-Powered, Long-Lasting Protection
Long Duration Outdoor Security System with Wyze Camera and Solar Support
For those seeking a reliable, long-lasting outdoor security solution, combining Wyze's advanced cameras with solar-powered accessories offers an unbeatable setup. Whether you want continuous monitoring without frequent battery changes or a weatherproof system that withstands the elements, Wyze provides versatile options tailored for outdoor security.
Wyze Battery Cam Solar Panel: Extend Your Camera’s Battery Life
The Wyze Battery Cam Solar Panel is the perfect accessory to keep your Wyze Battery Cam Pro or Wyze Cam Outdoor v1/v2 powered continuously without the hassle of manual recharging.
Key Features:
  • Continuous Power Supply: Harness solar energy to extend your camera’s battery life, allowing for longer recording periods without interruption.
  • Weather Resistant: Built with an IP65 rating, this solar panel is dustproof and weatherproof, ideal for all outdoor conditions.
  • Flexible Mounting: Comes with a 13-foot weatherproof power cable and a 360° freestyle mount, enabling you to position it anywhere for maximum sun exposure.
  • Compatibility: Works seamlessly with Wyze Battery Cam Pro and Wyze Cam Outdoor versions 1 and 2.
Keep your outdoor security system running effortlessly with solar power, reducing downtime and maintenance.
Wyze Battery Cam Solar Panel in outdoor setting Solar panel providing continuous charging for Wyze cameras
Wyze Battery Cam Pro: Wireless Power with High-Definition Security
The Wyze Battery Cam Pro is a wireless, weatherproof security camera designed for outdoor use, offering high-resolution video and smart features without the need for a hub.
Highlights:
  • 2.5K HDR Video Resolution: Capture crystal-clear footage with vibrant colors and sharp details.
  • Up to 6 Months Battery Life: Powered by removable, rechargeable 6200mAh battery packs, which can be extended indefinitely with the Wyze Battery Cam Solar Panel.
  • Integrated Spotlight & Siren: Motion-activated spotlight and a 100 dB siren help deter intruders effectively.
  • Radar + PIR Motion Detection: Advanced sensors detect movement accurately, minimizing false alerts.
  • IP65 Weatherproof: Built to withstand rain, dust, and extreme temperatures from -4°F to 122°F.
  • Dual-Band Wi-Fi Support: Connects to both 2.4 GHz and 5 GHz networks for reliable streaming.
  • Two-Way Audio: Communicate through the built-in speaker and microphone for added security.
Enjoy the freedom of wireless installation combined with powerful security features and long-lasting battery life.
Wyze Battery Cam Pro lifestyle Wireless, rechargeable Wyze Battery Cam Pro mounted outdoors
Why Choose Wyze for Your Outdoor Security?
Wyze’s ecosystem is designed to provide flexible, affordable, and high-quality security solutions. By pairing the Wyze Battery Cam Pro with the Wyze Battery Cam Solar Panel, you get a system that:
  • Reduces Maintenance: Solar charging means fewer battery swaps and less downtime.
  • Offers Weatherproof Durability: Both camera and solar panel are rated IP65, ensuring reliable operation in rain, snow, or dust.
  • Supports Easy Installation: Wireless cameras and versatile mounting options make setup quick and hassle-free.
  • Delivers Smart Features: Motion detection, two-way audio, and integrated sirens enhance your home’s security.
  • Integrates Seamlessly: Compatible with Wyze app for live streaming, alerts, and cloud/local storage options.
Summary
For a long duration outdoor security system, the combination of Wyze Battery Cam Pro and Wyze Battery Cam Solar Panel is an excellent choice. This setup ensures continuous power through solar energy, wireless convenience, and robust weather resistance, all while delivering high-quality video and smart security features. Invest in Wyze’s solar-supported battery cameras to keep your property safe with minimal upkeep and maximum peace of mind.
FeatureWyze Battery Cam Solar PanelWyze Battery Cam Pro
TypeAccessoryCamera
Video ResolutionN/A2.5K HDR (2560 x 1440)
Power SourceSolar Panel (extends battery life)Removable, Rechargeable Battery Packs (6200mAh)
Battery LifeExtends battery life of compatible camerasUp to 6 months on one charge
CompatibilityWyze Cam Outdoor v1/v2, Wyze Battery Cam ProStandalone camera
Weather ResistanceIP65 (weatherproof and dustproof)IP65 Weatherproof
Mounting360° Freestyle Mount, mountable anywhereMultiple mounting options including wall and ceiling mounts
Power Cable Length13-foot weatherproof power cableN/A
WirelessN/AYes, supports 2.4 & 5 GHz WiFi
Motion DetectionN/ARadar + PIR Motion Detection
Integrated Spotlight & SirenN/AYes, 150 lumens LED spotlight & 100 dB siren
Local StorageN/ASupports up to 256 GB microSD cards
Cloud StorageN/AAvailable with Cam Plus subscription
Dimensions173 mm x 120 mm x 17 mm2.5 x 1.8 x 3.5 inches
WeightNot specified0.94 lbs
Price$24.99 (Solar Panel), $5.99 (USB-C Adapter Cable)From $89.98 (single camera)
What is the Wyze Battery Cam Solar Panel and how does it work?The Wyze Battery Cam Solar Panel is an accessory designed to provide continuous solar-powered charging for Wyze Battery Cam Pro and Wyze Cam Outdoor v1/v2. It harnesses solar energy to keep your camera’s battery charged, reducing the need for manual recharging and ensuring uninterrupted outdoor security monitoring.
Which Wyze cameras are compatible with the Wyze Battery Cam Solar Panel?The Wyze Battery Cam Solar Panel is compatible with the Wyze Battery Cam Pro and Wyze Cam Outdoor versions 1 and 2, allowing these cameras to benefit from continuous solar charging.
How weatherproof are Wyze outdoor security cameras and solar panels?Both the Wyze Battery Cam Pro and the Wyze Battery Cam Solar Panel are rated IP65, making them dustproof and weatherproof. They are designed to withstand rain, snow, dust, and extreme temperatures ranging from -4°F to 122°F, ensuring reliable performance in various outdoor conditions.
How long does the Wyze Battery Cam Pro battery last, and can it be extended?The Wyze Battery Cam Pro features removable, rechargeable 6200mAh battery packs that can last up to 6 months on a single charge. By connecting the camera to the Wyze Battery Cam Solar Panel, you can extend the battery life indefinitely with continuous solar charging.
What are the key features of the Wyze Battery Cam Pro for outdoor security?The Wyze Battery Cam Pro offers 2.5K HDR video resolution, up to 6 months of battery life, an integrated motion-activated spotlight and 100 dB siren, advanced radar and PIR motion detection, IP65 weatherproofing, dual-band Wi-Fi support (2.4 GHz and 5 GHz), and two-way audio for communication.
Is the installation of Wyze outdoor security cameras and solar panels easy?Yes, Wyze outdoor security cameras and solar panels are designed for easy, wireless installation. The solar panel includes a 13-foot weatherproof power cable and a 360° freestyle mount, allowing flexible placement for optimal sun exposure and quick setup.
How does solar power benefit my Wyze outdoor security system?Using solar power with your Wyze outdoor security system reduces the need for frequent battery changes, minimizes maintenance, and ensures your cameras remain powered for continuous monitoring, even in remote or hard-to-reach locations.
What smart security features does the Wyze Battery Cam Pro offer?The Wyze Battery Cam Pro includes smart features such as radar and PIR motion detection to minimize false alerts, a motion-activated spotlight, a 100 dB siren to deter intruders, two-way audio for communication, and seamless integration with the Wyze app for live streaming, alerts, and storage options.
Why should I choose Wyze for my outdoor security needs?Wyze offers flexible, affordable, and high-quality outdoor security solutions. By combining the Wyze Battery Cam Pro with the Wyze Battery Cam Solar Panel, you get a weatherproof, low-maintenance system with advanced features like high-definition video, smart motion detection, and easy wireless installation, all managed through the Wyze app.
What are the key features of the Wyze Battery Cam Solar Panel?How does the Wyze Battery Cam Pro compare to other outdoor security cameras?Do you have any deals, ongoing sales, discounts, or promotions?
