Wireless Home Monitoring System Kit with Entry and Motion Sensors Included
Secure your home effortlessly with a comprehensive wireless home monitoring system kit that includes essential entry and motion sensors. Designed to provide real-time alerts and seamless integration, these devices work together to keep your home safe and monitored from anywhere.
Core of Your Home Security: Wyze Sense Hub
The
Wyze Sense Hub acts as the central brain of your home monitoring system. It connects all your sensors and devices, ensuring instant alerts and smooth communication between components.
Key Features:
- Central control unit for all Wyze Sense sensors
- Sends real-time alerts to your smartphone
- Compatible with Wyze Home Monitoring system
- Easy setup and reliable connectivity
The Wyze Sense Hub is essential for any Wyze home monitoring setup, providing the backbone for your security network.
Stay connected and secure with Wyze’s smart home monitoring.
Detect Every Movement: Wyze Sense Motion Sensor
Keep an eye on any unexpected activity with the
Wyze Sense Motion Sensor. This sensor detects motion within a 25-foot range and a wide 120° field of view, making it perfect for monitoring hallways, entryways, or any room.
Key Features:
- Motion detection up to 25 feet
- Adjustable sensitivity settings for customized alerts
- Battery life up to 18 months for long-term use
- Easy installation with adhesive backing or screws
- Compatible with Wyze Sense Hub and Wyze Home Monitoring
Ideal for detecting intruders or monitoring activity in your home, the motion sensor adds a vital layer of security.
Monitor Every Entry Point: Wyze Sense Entry Sensor
The
Wyze Sense Entry Sensor detects when doors, windows, or cabinets open or close, providing instant notifications to your phone. This sensor is a must-have for monitoring all access points in your home.
Key Features:
- Detects open/close status of doors and windows
- Requires Wyze Sense Hub for operation
- Compatible with Wyze Sense v2 and Wyze Home Monitoring
- Compact and easy to install with adhesive backing
- Perfect for securing entry points and valuables
Stay informed about every entry and exit in your home with these reliable sensors.
Convenient Control: Wyze Sense Keypad
Arm or disarm your home security system remotely with the
Wyze Sense Keypad. This device offers quick access to your system’s status and emergency functions without needing your phone.
Key Features:
- Arm and disarm your system remotely
- Emergency button for quick first responder alerts
- Indoor use with permanent adhesive mounting
- Supports up to 100 accessories for scalable security
The keypad provides an easy and secure way to manage your home monitoring system on the go.
Control your home security system with ease and confidence.
Why Choose a Wireless Home Monitoring System Kit?
Wireless home monitoring kits with entry and motion sensors offer flexible, scalable, and easy-to-install solutions for modern home security. They eliminate the need for complex wiring and allow you to monitor your home remotely via smartphone apps.
- Seamless Integration: All Wyze sensors connect through the Wyze Sense Hub, creating a unified security network.
- Real-Time Alerts: Receive instant notifications on your phone when motion is detected or doors/windows open.
- Expandable System: Add more sensors or accessories as needed, supporting up to 100 devices per hub.
- Long Battery Life: Sensors like the motion detector offer up to 18 months of battery life, reducing maintenance.
- User-Friendly: Easy installation with adhesive backing and simple app controls make setup hassle-free.
Summary of Included Products
Product | Functionality | Price |
Wyze Sense Hub | Central hub for sensors | $45.98 |
Wyze Sense Motion Sensor | Detects motion up to 25 ft | $20.98 |
Wyze Sense Entry Sensor | Detects door/window open/close | $41.98 (3-pack) |
Wyze Sense Keypad | Arm/disarm system remotely | $27.98 |
Secure your home with a reliable wireless home monitoring system kit that includes entry and motion sensors. With Wyze’s smart technology, you can protect your home effortlessly and stay connected no matter where you are.
What is included in the Wyze Wireless Home Monitoring System Kit?
The Wyze Wireless Home Monitoring System Kit includes the Wyze Sense Hub (central control unit), Wyze Sense Motion Sensor, Wyze Sense Entry Sensor (3-pack), and Wyze Sense Keypad. These components work together to provide comprehensive home security with real-time alerts and easy installation.How does the Wyze Sense Hub work in the home monitoring system?
The Wyze Sense Hub acts as the central brain of your home monitoring system. It connects all Wyze sensors and devices, ensuring instant alerts and seamless communication between components. The hub is essential for integrating and managing your home security network.What features does the Wyze Sense Motion Sensor offer?
The Wyze Sense Motion Sensor detects motion up to 25 feet with a wide 120° field of view. It features adjustable sensitivity settings, a battery life of up to 18 months, and easy installation with adhesive backing or screws. It is compatible with the Wyze Sense Hub and Wyze Home Monitoring system.How does the Wyze Sense Entry Sensor enhance home security?
The Wyze Sense Entry Sensor detects when doors, windows, or cabinets are opened or closed, sending instant notifications to your smartphone. It is compact, easy to install with adhesive backing, and is ideal for monitoring all access points in your home. The sensor requires the Wyze Sense Hub for operation.What is the function of the Wyze Sense Keypad?
The Wyze Sense Keypad allows you to arm or disarm your home security system remotely without using your phone. It features an emergency button for quick first responder alerts, supports up to 100 accessories, and is designed for indoor use with permanent adhesive mounting.Can I expand my Wyze home monitoring system with additional sensors?
Yes, the Wyze home monitoring system is expandable. The Wyze Sense Hub supports up to 100 accessories, allowing you to add more motion sensors, entry sensors, or other compatible devices as needed for scalable security.How do I receive alerts from the Wyze home monitoring system?
You receive real-time alerts directly to your smartphone whenever motion is detected or when doors and windows are opened or closed. The Wyze app provides instant notifications, keeping you informed about your home’s security status from anywhere.Is the Wyze Wireless Home Monitoring System easy to install?
Yes, the Wyze Wireless Home Monitoring System is designed for easy installation. Most sensors and devices come with adhesive backing for quick setup, and the system is managed through a user-friendly app, eliminating the need for complex wiring.What are the benefits of choosing a wireless home monitoring system kit?
Wireless home monitoring kits like Wyze offer flexible, scalable, and easy-to-install solutions for modern home security. They eliminate the need for complex wiring, provide real-time alerts, support remote monitoring via smartphone, and allow for easy expansion with additional sensors.How long do the batteries last in Wyze sensors?
Wyze sensors, such as the motion detector, offer up to 18 months of battery life, reducing the need for frequent maintenance and ensuring long-term reliability for your home security system.
