24/7 Professional Easy Install Home Monitoring Kit with Free Trial & Emergency Alerts
Protect your home effortlessly with a comprehensive, professional-grade home monitoring system designed for easy installation and round-the-clock security. The Wyze Home Monitoring Core Starter Kit and its compatible accessories provide seamless protection, instant alerts, and emergency response capabilities — all backed by a free trial of professional monitoring.
Wyze Home Monitoring Core Starter Kit: Your All-in-One Security Solution
The
Wyze Home Monitoring Core Starter Kit is the foundation of your home’s security, offering 24/7 protection against intrusions and hazards with a simple, user-friendly setup.
- Professional 24/7 Monitoring Included: Comes with a free 3-month trial of professional monitoring, ensuring emergency dispatch and real-time alerts.
- Easy Installation: No tools required — just place the sensors and start monitoring immediately.
- Smart Sensors Included: Entry sensors notify you instantly when doors or windows open, while motion sensors detect movement without needing camera access.
- Mobile Insights: Receive notifications and monitor your home remotely via the Wyze app.
- Potential Insurance Discounts: Subscribing to professional monitoring may qualify you for home insurance savings.
Stay worry-free knowing your home is guarded day and night with a system designed for simplicity and reliability.
Easy installation with entry sensors for instant alerts
Wyze Sense Hub: The Smart Brain of Your Security System
At the heart of the Wyze monitoring system is the
Wyze Sense Hub, which connects all your sensors and devices, ensuring smooth communication and timely alerts.
- Robust Connectivity: Supports Ethernet, WiFi (2.4 GHz), Bluetooth 4.1 + BLE 5.1, and 915MHz RF communication.
- Wide Sensor Support: Connect up to 100 sensors for comprehensive coverage.
- Built-in Rechargeable Battery: Provides up to 10 hours of backup power during outages.
- Loud Siren: 88dB alarm to deter intruders and alert occupants.
- Compact & Stylish: Matte white base with a grey speaker top, designed to blend into your home environment.
This hub is essential for integrating all components, from entry sensors to motion detectors, creating a unified security network.
Wyze Sense Entry Sensor & Motion Sensor: Instant Alerts for Every Movement
Entry Sensor
- Detects when doors or windows open or close.
- Easy adhesive or screw installation.
- Compatible with Wyze Sense Hub and Wyze Home Monitoring.
- Receive instant notifications on your phone and hub.
Motion Sensor
- Detects motion within a 25-foot range and 120° field of view.
- Adjustable sensitivity settings to reduce false alarms.
- Battery life up to 18 months.
- Ideal for monitoring hallways, rooms, or entry points without cameras.
Motion sensor coverage for enhanced home security
Together, these sensors provide comprehensive detection of unauthorized access or unusual activity, keeping you informed in real time.
Wyze Sense Keypad: Convenient Remote Control & Emergency Alerts
The
Wyze Sense Keypad adds an extra layer of convenience and safety to your home monitoring system.
- Arm/Disarm Remotely: Control your security system from anywhere inside your home.
- Emergency Button: Quickly send alerts to first responders in case of an emergency.
- Compact & Portable: Place it anywhere for easy access.
- Requires Wyze Home Monitoring: Integrates seamlessly with your existing system.
This keypad is perfect for family members who want quick, tactile control over the security system without needing to use a smartphone app.
Remote disarm and emergency alerts at your fingertips
Why Choose Wyze Home Monitoring?
"Wyze Home Monitoring offers professional-grade security with easy DIY installation, affordable pricing, and a free trial of 24/7 emergency monitoring. It’s designed to keep your home safe, alert you instantly, and provide peace of mind — all controlled conveniently from your phone or keypad."
- No complicated setups or contracts.
- Expandable system with up to 100 sensors.
- Compatible with a variety of Wyze sensors for leak detection, entry, and motion.
- Affordable pricing with optional subscription plans for enhanced features.
Summary of Included Products
Product | Key Features |
Wyze Home Monitoring Core Starter Kit | 24/7 professional monitoring, entry & motion sensors, easy install |
Wyze Sense Hub | Central control hub, multiple connectivity options, siren alarm |
Wyze Sense Entry Sensor | Door/window open-close detection, instant alerts |
Wyze Sense Motion Sensor | Motion detection with adjustable sensitivity, long battery life |
Wyze Sense Keypad | Remote arm/disarm, emergency button, portable |
Final Thoughts
For homeowners seeking a reliable, professional, and easy-to-install home monitoring kit with free trial emergency alerts, the Wyze Home Monitoring system is an excellent choice. Its combination of smart sensors, a powerful hub, and convenient keypad control ensures your home stays protected 24/7 with minimal effort.
What is included in the Wyze Home Monitoring Core Starter Kit?
The Wyze Home Monitoring Core Starter Kit includes 24/7 professional monitoring with a free 3-month trial, entry and motion sensors, the Wyze Sense Hub, and an easy installation process. It provides instant alerts, emergency response capabilities, and can be expanded with additional Wyze sensors.How easy is it to install the Wyze Home Monitoring system?
The Wyze Home Monitoring system is designed for easy DIY installation with no tools required. Simply place the sensors where needed and connect them to the Wyze Sense Hub to start monitoring your home immediately.Does Wyze Home Monitoring offer professional 24/7 monitoring?
Yes, Wyze Home Monitoring includes professional 24/7 monitoring with a free 3-month trial. This service provides real-time alerts and emergency dispatch to keep your home protected at all times.How does the Wyze Sense Hub work?
The Wyze Sense Hub is the central control unit for the Wyze Home Monitoring system. It connects all sensors and devices, supports up to 100 sensors, offers multiple connectivity options (Ethernet, WiFi, Bluetooth, RF), and features a built-in rechargeable battery for up to 10 hours of backup power during outages.What types of sensors are compatible with Wyze Home Monitoring?
Wyze Home Monitoring is compatible with a variety of Wyze sensors, including entry sensors for doors and windows, motion sensors with adjustable sensitivity, and additional sensors for leak detection. The system supports up to 100 sensors for comprehensive home coverage.How do Wyze entry and motion sensors work?
Wyze entry sensors detect when doors or windows open or close and send instant notifications to your phone and hub. Wyze motion sensors detect movement within a 25-foot range and a 120° field of view, with adjustable sensitivity to reduce false alarms and a battery life of up to 18 months.Can I control the Wyze Home Monitoring system remotely?
Yes, you can control and monitor your Wyze Home Monitoring system remotely using the Wyze app on your smartphone. The Wyze Sense Keypad also allows you to arm or disarm the system and send emergency alerts from anywhere inside your home.Does Wyze Home Monitoring offer emergency alerts?
Yes, Wyze Home Monitoring provides instant emergency alerts through the Wyze app and the Wyze Sense Keypad, which features an emergency button to quickly notify first responders in case of an emergency.Is Wyze Home Monitoring eligible for home insurance discounts?
Subscribing to Wyze's professional monitoring service may qualify you for home insurance discounts. Check with your insurance provider for eligibility and details.Is there a contract required for Wyze Home Monitoring?
No, Wyze Home Monitoring does not require complicated setups or long-term contracts. You can enjoy professional-grade security with flexible, affordable subscription options.How loud is the Wyze Sense Hub siren?
The Wyze Sense Hub features an 88dB siren alarm designed to deter intruders and alert occupants in case of a security breach.What happens if there is a power outage?
The Wyze Sense Hub has a built-in rechargeable battery that provides up to 10 hours of backup power, ensuring your home monitoring system remains operational during power outages.
