Wyze Home Security Systems: Smart Cameras & Doorbells for Safety
Comprehensive Home Security Systems for Every Need
Protecting your home has never been easier with the latest range of Wyze home security systems. Whether you want to monitor your indoor spaces, keep an eye on the outdoors, or secure your entryways, Wyze offers a variety of smart cameras and devices designed to fit your lifestyle and security requirements. Explore the features and benefits of each product to find the perfect solution for your home.
Wyze Cam v4: Crystal-Clear Outdoor and Indoor Surveillance
Experience unmatched security with the Wyze Cam v4, a versatile camera designed for both indoor and outdoor use. It boasts a stunning 2.5K QHD resolution that delivers crystal-clear video quality, ensuring you never miss a detail.
  • Enhanced Color Night Vision: See vibrant colors even in low light, improving nighttime monitoring.
  • Motion-Activated Spotlight: Automatically lights up when motion is detected, deterring intruders.
  • 24/7 Local Recording: Continuous recording with local storage options for peace of mind.
  • Wi-Fi 6 Support: Faster and more reliable connectivity.
  • Smart Assistant Compatibility: Works seamlessly with Alexa and Google Assistant.
  • Wide Field of View: DFOV 115.8°, HFOV 98.5°, VFOV 53.1° for broad coverage.
  • Durable Build: Polycarbonate body with glass and plastic lens materials.
Available in multiple colors (Black, Clear, Grey, White) and pack options, the Wyze Cam v4 is perfect for comprehensive home monitoring.
Wyze Cam Pan v3: 360° Pan and Tilt with Weather Resistance
For dynamic coverage, the Wyze Cam Pan v3 offers a full 360° pan and 180° tilt, allowing you to monitor every corner of your property with a single camera.
  • Indoor/Outdoor Use: Fully IP65 weather resistant for reliable outdoor performance (requires separate outdoor power adapter).
  • High-Quality Video: Crisp video streaming in both black and white color options.
  • Flexible Installation: Ideal for patios, garages, and indoor spaces.
  • Smart Features: Motion tracking and alerts keep you informed in real-time.
<img src="https://www.wyze.com/cdn/shop/files/IMG_4216-5_1.jpg?v=1670422469&width=1500" alt="Wyze Cam Pan v3 in snowy outdoor setting">
Wyze Cam Pan v3 providing weather-resistant outdoor security
Wyze Battery Cam Pro: Wire-Free, High-Resolution Security
If you prefer a wire-free solution, the Wyze Battery Cam Pro is an excellent choice with its rechargeable battery packs and no hub requirement.
  • 2.5K HDR Video Resolution: Clear and detailed video quality.
  • Integrated Spotlight & Siren: Enhances security with active deterrence.
  • Radar + PIR Motion Detection: Advanced sensors for accurate motion alerts.
  • Weatherproof Design: IP65 rating ensures durability in all weather conditions.
  • Dual-Band Wi-Fi Support: Compatible with both 2.4 GHz and 5 GHz networks.
  • Removable Battery Packs: Easy to recharge and swap.
Available in Black and White, this camera offers flexible placement anywhere around your home.
Wyze Bulb Cam: 2-in-1 Security and Smart Lighting
Combine security and lighting with the innovative Wyze Bulb Cam, a smart LED light bulb with a built-in 2K HD security camera.
  • Color Night Vision: See clear video footage even in the dark.
  • Instant Motion Alerts: Stay informed of any activity around your home.
  • Remote Lighting Control: Adjust your lighting from anywhere using the Wyze app.
  • Easy Installation: Fits most standard light fixtures without complicated setup.
  • Local Video Storage: No subscription required for storing footage.
  • Durable and Certified: IP65 rating with FCC, IC, and UL certifications.
<img src="https://www.wyze.com/cdn/shop/files/Wyze_Bulb_Cam_Shopify-07.jpg?v=1746478547&width=1500" alt="Wyze Bulb Cam installed in outdoor light fixture">
Wyze Bulb Cam providing smart lighting and security
Wyze Video Doorbell v2: Stay Connected at Your Front Door
Never miss a visitor with the Wyze Video Doorbell v2, offering clear 2K video and essential doorbell features.
  • High-Resolution Video: 2K clarity for detailed monitoring.
  • Local microSD Storage: Save video footage without monthly fees.
  • Two-Way Audio: Communicate with visitors in real-time.
  • Motion-Activated Voice Deterrence: Automatically warns unwanted guests.
  • Real-Time Alerts: Instant notifications on your smartphone.
  • Sleek Design: Available in black, fits seamlessly on any doorframe.
Wyze Cam OG: Fast, Reliable Indoor/Outdoor Monitoring
The Wyze Cam OG is the next generation Wyze camera with improved speed and features for everyday security.
  • Quicker Live-Streaming: Faster video feed with 3X quicker notifications.
  • Improved Two-Way Audio: Clear communication with visitors or family.
  • Built-In Spotlight: Enhances night vision and deters intruders.
  • 1080p Full HD Video: Crisp and clear footage.
  • Wide 120° Field of View: Covers large areas indoors or outdoors.
  • Multiple Color Options: Black and White to match your decor.
<img src="https://www.wyze.com/cdn/shop/files/2_way_talk-03.png?v=1670674480&width=1500" alt="Wyze Cam OG with two-way audio feature">
Wyze Cam OG with clear two-way audio for indoor security
Why Choose Wyze Home Security Systems?
"Wyze offers affordable, high-quality home security solutions that combine smart technology with user-friendly features, making home protection accessible to everyone."
With a variety of cameras tailored for different environments and needs, Wyze ensures your home is monitored 24/7 with crystal-clear video, smart alerts, and seamless integration with your smart home ecosystem.
Conclusion
From wired to wireless, indoor to outdoor, and even smart lighting solutions, Wyze’s home security systems provide comprehensive protection tailored to your lifestyle. Choose the right combination of cameras and devices to keep your home safe, secure, and connected.
Product Highlights Summary
  • Wyze Cam v4: Advanced outdoor camera with 2.5K QHD and spotlight
  • Wyze Cam Pan v3: 360° pan/tilt with weather resistance
  • Wyze Battery Cam Pro: Wire-free, rechargeable, 2.5K HDR video
  • Wyze Bulb Cam: 2-in-1 smart light and security camera
  • Wyze Video Doorbell v2: 2K video doorbell with two-way audio
  • Wyze Cam OG: Fast live streaming with built-in spotlight
Secure your home today with Wyze’s innovative and affordable home security systems!
FeatureWyze Cam v4Wyze Cam Pan v3Wyze Battery Cam ProWyze Bulb CamWyze Video Doorbell v2Wyze Cam OG
TypeWired CameraWired Pan & Tilt CameraBattery CameraLighting Camera (Bulb)Wired Video DoorbellWired Camera
Video Resolution2.5K QHD (2560 x 1440)2.5K (2560 x 1440)2.5K HDR (2560 x 1440)2K HD (2304 x 1296)2K (2048 x 1536)1080p (1920 x 1080)
Field of View (Diagonal)115.9°360° Pan / 180° Tilt134°166°166.8°120°
Night VisionEnhanced Color Night VisionColor Night Vision (Starlight Sensor)2 IR LEDs + 2 White LEDs (Color)Color Night Vision + IR6 x 940nm IR lights4 IR LEDs (850nm)
AudioEnhanced Two-Way TalkTwo-Way AudioTwo-Way Audio (Speaker & Mic)Two-Way AudioTwo-Way AudioBuilt-in Speaker & Mic (Upgraded)
SirenYes (Integrated)NoYes (100 dB)Yes (95 dB)Yes (Digital Voice Deterrence)Yes (90 dB user-activated)
SpotlightMotion-activated SpotlightNoIntegrated SpotlightSmart LED Light BulbNoBuilt-in Spotlight (40 Lumens)
Power SourceWiredWiredRemovable Rechargeable Battery120V AC (Bulb)Wired (16V-24V AC)Wired (5V/1A adapter)
Weather ResistanceIP65IP65IP65IP65IP65IP65
Local StoragemicroSD up to 256GBmicroSD up to 256GBmicroSD up to 256GBmicroSD up to 256GBmicroSD up to 256GBmicroSD up to 256GB
Wireless ConnectivityWi-Fi 6Wi-Fi 2.4 GHzWi-Fi 2.4 & 5 GHzWi-Fi 2.4 GHzWi-Fi 2.4 GHzWi-Fi 2.4 GHz
BluetoothYes (Bluetooth for setup)Not specifiedBLE 5.1BLE 4.2 / BLE Low EnergyNot specifiedNot specified
Smart Assistant IntegrationAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google AssistantAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
DimensionsNot specifiedNot specified2.5 x 1.8 x 3.5 inNot specified4.3 x 1.7 x 0.9 in1.89 x 1.89 x 1.89 in
WeightNot specifiedNot specified0.94 lbsNot specifiedNot specified4.1 oz (116 g)
Additional FeaturesAI Auto-Zoom, Motion-activated spotlight, Smoke & CO alerts360° Pan & 180° Tilt, Motion Tracking, Privacy ModeRadar + PIR Motion Detection, Up to 6 months battery life2-in-1 camera & smart bulb, Motion-activated light, Up to 800 lm brightnessMotion-activated voice deterrence, Digital zoomFaster live streaming, 3X faster notifications, Custom detection zones
Price (1 Pack)$35.98$39.98$159.98$49.98$44.98$29.98
What types of Wyze home security cameras are available?Wyze offers a comprehensive range of home security cameras, including the Wyze Cam v4, Wyze Cam Pan v3, Wyze Battery Cam Pro, Wyze Bulb Cam, Wyze Video Doorbell v2, and Wyze Cam OG. Each camera is designed to meet different security needs, from indoor and outdoor monitoring to wire-free and smart lighting solutions.
What are the key features of the Wyze Cam v4?The Wyze Cam v4 features 2.5K QHD resolution for crystal-clear video, enhanced color night vision, a motion-activated spotlight, 24/7 local recording, Wi-Fi 6 support, smart assistant compatibility, a wide field of view, and a durable build. It is suitable for both indoor and outdoor use.
Is the Wyze Cam Pan v3 suitable for outdoor use?Yes, the Wyze Cam Pan v3 is fully IP65 weather resistant, making it ideal for both indoor and outdoor use. For outdoor installation, a separate outdoor power adapter is required.
What makes the Wyze Battery Cam Pro a good wire-free security option?The Wyze Battery Cam Pro is a wire-free security camera with rechargeable, removable battery packs, 2.5K HDR video resolution, integrated spotlight and siren, radar and PIR motion detection, weatherproof IP65 design, and dual-band Wi-Fi support. It does not require a hub and can be placed anywhere around your home.
How does the Wyze Bulb Cam combine lighting and security?The Wyze Bulb Cam is a 2-in-1 device that functions as both a smart LED light bulb and a 2K HD security camera. It offers color night vision, instant motion alerts, remote lighting control via the Wyze app, easy installation in standard light fixtures, local video storage, and is IP65 rated for durability.
What are the benefits of the Wyze Video Doorbell v2?The Wyze Video Doorbell v2 provides 2K high-resolution video, local microSD storage without monthly fees, two-way audio for real-time communication, motion-activated voice deterrence, instant smartphone alerts, and a sleek black design that fits any doorframe.
What improvements does the Wyze Cam OG offer?The Wyze Cam OG features quicker live-streaming with 3X faster notifications, improved two-way audio, a built-in spotlight for enhanced night vision, 1080p Full HD video, a wide 120° field of view, and is available in black and white color options for both indoor and outdoor use.
Do Wyze security cameras require a subscription for video storage?Many Wyze cameras, such as the Wyze Cam v4, Wyze Bulb Cam, and Wyze Video Doorbell v2, offer local video storage options using microSD cards, allowing you to save footage without a monthly subscription.
Are Wyze home security systems compatible with smart home assistants?Yes, Wyze home security cameras, including the Wyze Cam v4, are compatible with popular smart home assistants like Alexa and Google Assistant for seamless integration into your smart home ecosystem.
Why should I choose Wyze home security systems?Wyze home security systems are affordable, high-quality, and user-friendly. They offer a variety of smart cameras and devices with advanced features like high-resolution video, smart alerts, weather resistance, and easy integration with your smart home, making comprehensive home protection accessible to everyone.
What features does the Wyze Cam v4 offer for outdoor security?Can you explain how the motion-activated spotlight works on the Wyze Cam v4?Do you have any ongoing sales or discounts for the Wyze home security systems?
