Home Monitoring Kit with Wireless Sensors and Emergency Alerts
Protecting your home has never been easier or smarter. With the latest Wyze home monitoring solutions, you can secure your space using wireless sensors that detect motion, entry, and even leaks — all while receiving instant emergency alerts on your phone. Whether you want to monitor your house, RV, or travel trailer, these kits and components offer seamless integration, 24/7 professional monitoring options, and easy installation.
Wyze Home Monitoring Core Starter Kit: Your All-in-One Wireless Security Solution
The
Wyze Home Monitoring Core Starter Kit is designed to keep your home safe around the clock with a simple, effective system that requires no complicated setup.
- Wireless Entry Sensor: Place it on doors or windows and get instant notifications on your phone and Sense Hub when they open.
- Motion Sensor: Detects movement inside your home without needing to watch camera feeds constantly.
- 24/7 Professional Monitoring: Optional subscription provides emergency dispatch and potential insurance discounts.
- Easy Installation: No tools required — just place the sensors and start monitoring.
- Peace of Mind: Stay worry-free knowing your home is protected day and night.
This kit is perfect for homeowners who want a reliable, wireless monitoring system that covers the essentials of home security.
Lifestyle image showing easy installation of entry sensors on a door.
Wyze Sense Hub: The Smart Brain Behind Your Monitoring System
The
Wyze Sense Hub acts as the central communication point for all your wireless sensors, ensuring fast and reliable alerts.
- Connectivity: Supports Ethernet, WiFi (2.4 GHz), Bluetooth 4.1 + BLE 5.1, and 915MHz RF communication.
- Range: Covers up to 500 feet to sensors, ideal for large homes or multi-room setups.
- Battery Backup: Built-in rechargeable battery with up to 10 hours of backup power.
- Siren: Loud 88db siren to alert you and deter intruders.
- Supports Up to 100 Sensors: Easily expand your system with additional sensors as needed.
Compact and stylish with a matte white finish, the Sense Hub is designed for indoor use and integrates seamlessly with the Wyze app for real-time monitoring.
Wyze Sense Motion Sensor: Detect Movement with Precision
Add an extra layer of security with the
Wyze Sense Motion Sensor, which detects motion within a 25-foot range and a 120° field of view.
- Adjustable Sensitivity: Customize detection settings to reduce false alarms.
- Easy Mounting: Comes with adhesive backing and optional screws for secure placement.
- Long Battery Life: Up to 18 months on a single battery.
- Compatibility: Works with Wyze Sense v2 and Wyze Home Monitoring systems.
- Indoor Use: Perfect for monitoring hallways, living rooms, or entryways.
This sensor helps you know when someone is moving inside your home without needing to watch camera footage constantly.
Lifestyle image showing motion sensor placement in a home corner.
Wyze Sense Leak Sensor & Probe: Early Warning for Water Leaks
Protect your home from water damage with the
Wyze Sense Leak Sensor & Probe. This sensor alerts you immediately if it detects leaks, helping you prevent costly repairs.
- Leak Detection: Monitors for water presence and sends instant alerts.
- Compatible with Wyze Sense v2 and Home Monitoring: Requires the Wyze Sense Hub.
- Indoor Use Only: Designed for basements, kitchens, bathrooms, or near appliances.
- Operating Range: Works reliably within 500 feet of the hub.
- Multiple Configurations: Available in sensor and probe bundles for versatile placement.
Wyze Sense Keypad: Arm, Disarm, and Emergency Alerts at Your Fingertips
The
Wyze Sense Keypad offers convenient control over your home security system from anywhere inside your home.
- Remote Disarming: Arm or disarm your system quickly without using your phone.
- Emergency Button: Send first responders immediately with a dedicated on-device alert.
- Requires Wyze Home Monitoring: Integrates fully with your existing Wyze system.
- Portable Placement: Place it anywhere for easy access.
- Bluetooth Connectivity: Communicates securely with the Wyze Sense Hub.
This keypad is ideal for families or anyone who wants quick, tactile control over their home security.
Lifestyle image showing keypad mounted near a door for easy access.
Why Choose Wyze Home Monitoring Kits?
"Wyze offers a comprehensive, wireless home monitoring solution that is easy to install, affordable, and scalable. With professional monitoring options and smart sensors, you can protect your home and loved ones with confidence."
- Wireless sensors mean no complicated wiring or drilling.
- Real-time alerts keep you informed wherever you are.
- Expandable system supports up to 100 sensors.
- Optional professional monitoring for emergency response.
- Compatible with a wide range of Wyze smart home products.
Summary of Included Products for Your Home Monitoring Kit
Product Name | Key Features | Price Range |
Wyze Home Monitoring Core Starter Kit | Entry & motion sensors, 3-month monitoring included | $111.98 |
Wyze Sense Hub | Central hub, siren, multi-protocol connectivity | $45.98 |
Wyze Sense Motion Sensor | 25 ft range, adjustable sensitivity | $20.98 |
Wyze Sense Leak Sensor & Probe | Leak detection, probe options | $13.98+ |
Wyze Sense Keypad | Arm/disarm, emergency button | $27.98 |
Equip your home with these wireless sensors and emergency alert devices to create a smart, responsive security system tailored to your needs.
Protect your home effortlessly with Wyze’s wireless home monitoring kits — smart, reliable, and designed for your peace of mind.
What is included in the Wyze Home Monitoring Core Starter Kit?
The Wyze Home Monitoring Core Starter Kit includes wireless entry sensors, a motion sensor, and the Wyze Sense Hub. It also comes with a 3-month professional monitoring subscription, providing instant emergency alerts and easy installation with no tools required.How does the Wyze Sense Hub work in my home security system?
The Wyze Sense Hub acts as the central communication point for all your wireless sensors. It supports Ethernet, WiFi, Bluetooth, and RF communication, covers up to 500 feet, has a built-in 10-hour battery backup, and features an 88db siren to alert you and deter intruders. It can support up to 100 sensors for scalable home security.Can I receive emergency alerts on my phone with Wyze home monitoring?
Yes, Wyze home monitoring kits send instant emergency alerts to your phone whenever motion, entry, or leaks are detected, keeping you informed in real time wherever you are.Is professional monitoring available with Wyze home security systems?
Yes, Wyze offers optional 24/7 professional monitoring with emergency dispatch services. This subscription can also provide potential insurance discounts and added peace of mind.How easy is it to install Wyze wireless sensors?
Wyze wireless sensors are designed for easy, tool-free installation. Simply place the sensors where needed, such as on doors, windows, or in rooms, and start monitoring immediately.What is the range of the Wyze Sense Hub and sensors?
The Wyze Sense Hub covers up to 500 feet to connected sensors, making it suitable for large homes, multi-room setups, and even RVs or travel trailers.How does the Wyze Sense Motion Sensor work?
The Wyze Sense Motion Sensor detects movement within a 25-foot range and a 120° field of view. It features adjustable sensitivity to reduce false alarms, easy mounting options, and up to 18 months of battery life.What does the Wyze Sense Leak Sensor & Probe do?
The Wyze Sense Leak Sensor & Probe monitors for water leaks and sends instant alerts to your phone if water is detected. It is ideal for use in basements, kitchens, bathrooms, or near appliances to help prevent costly water damage.Can I expand my Wyze home monitoring system with additional sensors?
Yes, the Wyze Sense Hub supports up to 100 sensors, allowing you to easily expand your system with additional entry, motion, or leak sensors as needed.What is the Wyze Sense Keypad and how does it work?
The Wyze Sense Keypad allows you to arm or disarm your home security system without using your phone. It features a dedicated emergency button for immediate alerts, portable placement, and secure Bluetooth connectivity with the Wyze Sense Hub.Are Wyze home monitoring products suitable for RVs and travel trailers?
Yes, Wyze home monitoring kits and wireless sensors are ideal for houses, RVs, and travel trailers, offering flexible installation and reliable security wherever you need it.Do Wyze home monitoring products require wiring or drilling?
No, Wyze home monitoring products use wireless sensors that do not require complicated wiring or drilling, making installation quick and hassle-free.Are Wyze home monitoring products compatible with other Wyze smart home devices?
Yes, Wyze home monitoring kits are compatible with a wide range of Wyze smart home products, allowing you to create a comprehensive and integrated smart home security system.
