Home Monitoring Starter Kit with Motion and Door Sensors for Quick Setup
Protect your home effortlessly with a comprehensive
home monitoring starter kit that includes essential motion and door sensors. Designed for quick installation and seamless integration, these devices provide reliable security alerts to keep your space safe 24/7. Whether you’re new to smart home security or upgrading your system, this starter kit offers everything you need for immediate peace of mind.
Wyze Home Monitoring Core Starter Kit: All-in-One Security Solution
The
Wyze Home Monitoring Core Starter Kit is the perfect foundation for your home security setup. It combines multiple sensors and a keypad into one easy-to-install package, ensuring your home is protected from unwanted intrusions and hazards.
Key Features:
- Includes: 1 Wyze Sense Hub, 2 Wyze Entry Sensors, 1 Wyze Motion Sensor, and 1 Wyze Keypad
- Wireless Sensors: Supports up to 100 sensors for scalable security
- Motion Detection: Covers up to 25 feet with precise detection to avoid false alarms from pets
- Entry Sensors: Detects door/window open and close status with left-open alerts
- Battery Life: Long-lasting 18-month battery for sensors, plus built-in hub battery backup lasting 10 hours
- Siren: Loud 88db siren to deter intruders immediately
- Operating Conditions: Designed for indoor use, functioning reliably between 32°F to 104°F (0°C to 40°C)
- Keypad: Wireless with backlit keys and emergency button for quick disarm and alerting first responders
The Wyze Home Monitoring Core Starter Kit offers a simple, no-fuss setup that gets your home protected in minutes without complicated wiring or tools.
Easy installation and reliable entry sensors for your home
Wyze Sense Motion Sensor: Smart Motion Detection
Enhance your home security with the
Wyze Sense Motion Sensor, designed to detect movement within a 25-foot range and a 120° field of view. This sensor is ideal for monitoring hallways, living rooms, or entryways.
Highlights:
- Precision Detection: Adjustable sensitivity settings to detect people, not pets
- Installation: Adhesive backing for quick mounting on walls or optional screw installation for extra security
- Compatibility: Requires Wyze Sense v2 Hub or Wyze Home Monitoring system
- Compact Design: Small and discreet, blending seamlessly into your home décor
Place the motion sensor strategically to receive instant alerts on your phone whenever motion is detected, helping you stay informed and secure.
Wide field of detection for motion sensing
Wyze Sense Entry Sensor: Door and Window Monitoring
The
Wyze Sense Entry Sensor is essential for monitoring doors and windows, alerting you immediately when they are opened or closed. This sensor is a must-have for any home monitoring starter kit.
Features:
- Open/Close Detection: Know instantly if a door or window is opened or left ajar
- Wireless and Easy to Install: Adhesive-backed for quick placement on any door or window frame
- Battery Life: Up to 18 months on a single battery
- Compatibility: Works with Wyze Sense v2 Hub or Wyze Home Monitoring system
- Pack Options: Available in convenient 3-packs for multiple entry points
Keep track of all your entry points and receive timely notifications to prevent unauthorized access.
Wyze Sense Keypad: Convenient Remote Control
Included in the starter kit, the
Wyze Sense Keypad allows you to arm or disarm your security system remotely with ease.
Benefits:
- Wireless Operation: No wiring needed, place it anywhere indoors
- Backlit Keys: Easy to use even in low light conditions
- Emergency Button: Quickly alert first responders in case of an emergency
- Secure Access: Control your home security system without needing your phone
Secure and easy keypad control for your system
Why Choose This Home Monitoring Starter Kit?
This starter kit is designed for quick setup and reliable performance, making it ideal for anyone looking to secure their home without hassle. The combination of motion and door sensors ensures comprehensive coverage, while the keypad and hub provide centralized control and professional-grade monitoring capabilities.
- Quick Setup: Adhesive mounts and wireless connectivity mean no tools or complicated installation.
- Expandable System: Add more sensors as needed to cover your entire home.
- Professional Monitoring: Optional plans available for 24/7 professional monitoring and emergency response.
- Pet-Friendly Motion Detection: Avoid false alarms caused by pets with adjustable sensor settings.
Summary of Included Products
Wyze Sense Entry Sensor (3-Pack)
Wyze Sense Keypad
Secure your home today with this easy-to-install, reliable home monitoring starter kit featuring motion and door sensors for quick setup and peace of mind.
What is included in the Wyze Home Monitoring Core Starter Kit?
The Wyze Home Monitoring Core Starter Kit includes 1 Wyze Sense Hub, 2 Wyze Entry Sensors, 1 Wyze Motion Sensor, and 1 Wyze Keypad. This all-in-one package provides the essential components for comprehensive home security.How easy is it to install the Wyze Home Monitoring Starter Kit?
The Wyze Home Monitoring Starter Kit is designed for quick and easy installation. The sensors and keypad use adhesive backing for tool-free mounting, and the system is wireless, so no complicated wiring is required.How does the Wyze Sense Motion Sensor work?
The Wyze Sense Motion Sensor detects movement within a 25-foot range and a 120° field of view. It features adjustable sensitivity settings to avoid false alarms from pets and can be installed using adhesive or screws.Can I monitor doors and windows with the Wyze Sense Entry Sensor?
Yes, the Wyze Sense Entry Sensor is designed to monitor doors and windows. It alerts you instantly when a door or window is opened or left ajar, helping you keep track of all entry points in your home.Is the Wyze Home Monitoring system expandable?
Yes, the Wyze Home Monitoring system supports up to 100 wireless sensors, allowing you to expand coverage throughout your home as needed.What is the battery life of the Wyze sensors?
The Wyze sensors have a long-lasting battery life of up to 18 months. The hub also features a built-in battery backup that lasts up to 10 hours in case of power outages.Does the Wyze Home Monitoring Kit have a siren?
Yes, the Wyze Home Monitoring Core Starter Kit includes a loud 88db siren to deter intruders immediately when an alert is triggered.Is the Wyze Home Monitoring system pet-friendly?
Yes, the Wyze Sense Motion Sensor features adjustable sensitivity settings to help avoid false alarms caused by pets.Can I control the Wyze Home Monitoring system without my phone?
Yes, the Wyze Sense Keypad allows you to arm or disarm your security system remotely without needing your phone. It features backlit keys for easy use in low light and an emergency button for quick alerts.Is professional monitoring available with the Wyze Home Monitoring Kit?
Yes, optional plans are available for 24/7 professional monitoring and emergency response, providing an extra layer of security for your home.What are the operating conditions for the Wyze Home Monitoring system?
The Wyze Home Monitoring system is designed for indoor use and operates reliably between 32°F to 104°F (0°C to 40°C).What do I need for the Wyze Sense Motion and Entry Sensors to work?
The Wyze Sense Motion and Entry Sensors require a Wyze Sense v2 Hub or the Wyze Home Monitoring system for operation and integration with your home security setup.
