Top WiFi 6 Cameras with Color Night Vision & Local Storage
Best WiFi 6 Enabled Cameras with Color Night Vision and Local Storage
Looking for advanced security cameras that combine the latest WiFi 6 technology, vibrant color night vision, and reliable local storage? Discover the top Wyze cameras designed to keep your home safe day and night with crystal-clear video, smart features, and flexible storage options. Whether you want a wireless battery-powered cam, a wired plug-in camera, or a smart doorbell, these options deliver exceptional performance and convenience.
Wyze Cam v4 – Wired WiFi 6 Camera with Enhanced Color Night Vision
Experience unmatched security with the Wyze Cam v4, the clearest Wyze Cam ever made, now featuring WiFi 6 support for faster, more reliable connections.
Key Features:
  • 2.5K QHD Resolution: Capture stunningly detailed video with Quad HD clarity.
  • Enhanced Color Night Vision: See vibrant colors even in low-light conditions, surpassing traditional black-and-white night vision.
  • 24/7 Local Recording: Supports continuous recording to microSD cards up to 256GB, no subscription required.
  • IP65 Weather Resistance: Perfect for indoor or outdoor use, rain or shine.
  • Motion-Activated Spotlight & Siren: Deter intruders with a bright spotlight and loud siren.
  • Advanced Two-Way Audio: Clear communication with built-in mic and speaker.
  • Smart Detection & Alerts: Motion, sound, smoke, and CO alarms with customizable detection zones.
  • Easy Setup: Bluetooth® setup with magnetic mount for hassle-free installation.
  • Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT.
This wired camera is ideal for those who want continuous power and recording with the latest WiFi 6 technology, ensuring a strong connection even at greater distances. Wyze Cam v4 in use at home Wyze Cam v4 providing vibrant security day and night
Wyze Battery Cam Pro – Wireless Freedom with Local Storage and Color Night Vision
For ultimate flexibility, the Wyze Battery Cam Pro offers wire-free installation with powerful features including local storage and color night vision.
Highlights:
  • 2.5K HDR Video Resolution: High dynamic range for balanced, colorful images day or night.
  • Color Night Vision: See more details and colors in the dark with integrated spotlight.
  • Local Storage Support: Record motion events locally to a microSD card (sold separately) without subscription.
  • Dual-Band WiFi (2.4 & 5 GHz): Connect easily to your home network with WiFi 6 compatibility.
  • Radar + PIR Motion Detection: Double sensors for earlier and more precise motion alerts.
  • Removable Rechargeable Batteries: Hot-swap batteries to keep your camera running without downtime.
  • IP65 Weatherproof: Durable for outdoor use in all weather conditions.
  • Integrated Spotlight & Siren: Motion-activated 150-lumen LED light and loud siren for security.
  • Solar Panel Compatible: Extend battery life with optional solar charging.
This camera is perfect for those who want a wireless, portable security solution with local recording and vivid color night vision.
Wyze Bulb Cam – 2-in-1 Security Camera and Smart LED Light with Color Night Vision
The Wyze Bulb Cam combines a smart LED bulb with a security camera, offering color night vision and local storage in a simple, easy-to-install design.
Features:
  • 2K HD Video Resolution: Clear video with a wide 160° field of view.
  • Color Night Vision: See full-color video even in darkness using integrated lighting.
  • Local Storage Support: Compatible with microSD cards up to 256GB for local video storage.
  • Standard E26 Socket: Fits most outdoor light fixtures for seamless installation.
  • IP65 Weather Resistant: Built to withstand outdoor elements.
  • Motion-Activated Light & Alerts: Bright 800 lumens LED light activates on motion, plus instant push notifications.
  • Two-Way Audio & Siren: Built-in mic and speaker with a 95 dB siren for deterrence.
  • WiFi Connectivity: Connects via 2.4 GHz WiFi with Bluetooth Low Energy setup.
  • Smart Controls: Manual, scheduled, or automation-based lighting control via Wyze app.
Ideal for users wanting a discreet security camera integrated into outdoor lighting with local storage and color night vision. Wyze Bulb Cam installed outdoors Wyze Bulb Cam installed in outdoor light fixture
Wyze Duo Cam Battery Doorbell – Advanced Battery-Powered Video Doorbell with Local Storage
Upgrade your entryway security with the Wyze Duo Cam Battery Doorbell, featuring dual cameras, local storage, and color night vision.
Standout Specs:
  • Dual 2K Cameras: Front camera captures 2K video, bottom camera covers packages with 1080p.
  • Local Storage: Supports up to 256GB microSD card for 24/7 local recording.
  • Color Night Vision: See visitors and packages clearly at night.
  • Battery Powered & Hardwired Options: Flexible power with removable battery pack or hardwired setup.
  • Motion-Activated Voice Deterrence: Warn visitors with a customizable voice message.
  • Two-Way Audio & Siren: Communicate with visitors and deter intruders.
  • IP65 Weatherproof: Reliable in all weather conditions.
  • WiFi 5 GHz & 2.4 GHz Support: Strong wireless connection.
  • Smart Home Compatible: Works with Alexa, Google Assistant, and IFTTT.
Perfect for those who want a smart, battery-powered doorbell with local storage and vivid night vision. Wyze Duo Cam Doorbell lifestyle Wyze Duo Cam Battery Doorbell securing a home entrance
Why Choose Wyze Cameras with WiFi 6, Color Night Vision, and Local Storage?
"Protect your home with the latest technology that delivers clear, colorful video day and night, reliable local storage, and fast WiFi 6 connectivity."
  • WiFi 6 Support: Ensures faster, more stable connections for smooth video streaming and quick alerts.
  • Color Night Vision: See more than just shadows—capture true colors and details in low light.
  • Local Storage Options: Keep your footage safe and accessible without monthly fees or cloud dependency.
  • Weatherproof Designs: Use indoors or outdoors with confidence.
  • Smart Features: Motion detection, two-way talk, sirens, and smart home integration for complete control.
Choose the Wyze camera that fits your lifestyle and security needs, and enjoy peace of mind with cutting-edge features.
Summary of Featured Cameras
ProductWiFi 6Color Night VisionLocal StoragePower TypeWeatherproofPrice Range
Wyze Cam v4YesYesYesWiredIP65$35.98+
Wyze Battery Cam ProDual-Band (2.4/5 GHz)YesYesBattery (Rechargeable)IP65$89.98+
Wyze Bulb Cam2.4 GHzYesYesWired (Light Socket)IP65$49.98
Wyze Duo Cam Battery Doorbell2.4/5 GHzYesYesBattery/HardwiredIP65$89.98+
Protect your home with Wyze’s innovative cameras that combine WiFi 6 connectivity, vibrant color night vision, and flexible local storage options. Whether you prefer wired or wireless, indoor or outdoor, there’s a Wyze camera ready to secure your space with crystal-clear video and smart features.
FeatureWyze Battery Cam ProWyze Cam v4Wyze Bulb CamWyze Duo Cam Battery Doorbell
Video Resolution2.5K HDR (2560x1440)2.5K QHD (2560x1440)2K HD (2304x1296)Front: 2K (2048x1536), Bottom: 1080p
Field of View (FOV)Not specified exact degrees115.9° (D) x 98.5° (H) x 53.1° (V)160° (FOV), 166° diagonalFront: 132° H x 100° V, Bottom: 121° H x 60° V
Night VisionColor Night VisionEnhanced Color Night VisionColor Night Vision + IR Night VisionIR Night Vision
SpotlightIntegrated, 150 lumens, motion-activatedMotion-activated spotlightNo spotlightNo spotlight
Siren VolumeNot specified99 dB95 dB at 4 in90 dB
Two-Way AudioYesYesYesYes
Power SourceBattery (removable, rechargeable)WiredWired (120V AC bulb socket)Battery or Hardwired (10-24V AC)
Weather ResistanceIP65IP65IP65IP65
Wi-Fi Support2.4 & 5 GHz Wi-Fi2.4 GHz Wi-Fi + Wi-Fi 62.4 GHz Wi-Fi2.4 & 5 GHz Wi-Fi
Bluetooth SetupYesYes (Bluetooth 5.2)Yes (Bluetooth 4.2, BLE)Yes (Bluetooth 5.0)
Local StoragemicroSD card support (up to 256GB)microSD card support (up to 512GB)microSD card support (up to 256GB)microSD card support (up to 256GB)
Cloud StorageOptional (Cam Plus subscription)Optional (Cam Plus subscription)AWS Cloud storageAWS Cloud storage
Motion DetectionRadar + PIR sensors, custom zonesMotion & Sound Detection, custom zonesMotion detection with alertsAI detections, motion zones
Additional FeaturesRemovable battery packs, solar panel optionAuto-zoom with AI, built-in siren, spotlight2-in-1 camera and smart LED bulbDual camera views (people & packages), motion-activated voice deterrence
DimensionsNot specified2in x 2in x 2 3/8inBulb size fits standard E26 socket5.90in x 1.88in x 1.18in
Operating Temperature-4°F to 122°F (-20°C to 50°C)-4°F to 122°F (-20°C to 50°C)-4°F to 122°F (-20°C to 50°C)-4°F to 122°F (-20°C to 50°C)
WarrantyNot specified1 Year1 Year1 Year
What are the benefits of WiFi 6 enabled security cameras?WiFi 6 enabled security cameras offer faster and more stable wireless connections, ensuring smooth video streaming, quicker alerts, and reliable performance even at greater distances from your router. This advanced technology helps reduce lag and interference, making your home security system more efficient.
Which Wyze cameras support color night vision?All the featured Wyze cameras—including Wyze Cam v4, Wyze Battery Cam Pro, Wyze Bulb Cam, and Wyze Duo Cam Battery Doorbell—support color night vision. This feature allows you to see vibrant, full-color video even in low-light or nighttime conditions, providing clearer and more detailed footage than traditional black-and-white night vision.
Do Wyze cameras offer local storage without a subscription?Yes, Wyze cameras support local storage via microSD cards (up to 256GB, depending on the model), allowing you to record and access footage without the need for a monthly subscription. This gives you full control over your video recordings and helps you avoid ongoing cloud storage fees.
What is the difference between wired and wireless Wyze cameras?Wired Wyze cameras, like the Wyze Cam v4 and Wyze Bulb Cam, require a constant power source and are ideal for continuous recording. Wireless options, such as the Wyze Battery Cam Pro and Wyze Duo Cam Battery Doorbell, use rechargeable batteries for flexible placement and easy installation, making them perfect for areas without nearby power outlets.
Are Wyze cameras weatherproof for outdoor use?Yes, all featured Wyze cameras are IP65 weather resistant, making them suitable for both indoor and outdoor use. They are designed to withstand rain, dust, and varying temperatures, ensuring reliable performance in different weather conditions.
Can Wyze cameras be integrated with smart home systems?Wyze cameras are compatible with popular smart home platforms, including Amazon Alexa, Google Assistant, and IFTTT. This allows you to control your cameras, receive alerts, and automate actions using your preferred smart home ecosystem.
What is color night vision and how does it improve security?Color night vision uses advanced sensors and integrated lighting to capture full-color video in low-light or nighttime environments. This provides more detail and clarity compared to traditional black-and-white night vision, making it easier to identify people, vehicles, and other important details in your security footage.
Which Wyze camera is best for wireless, battery-powered security?The Wyze Battery Cam Pro and Wyze Duo Cam Battery Doorbell are the best options for wireless, battery-powered security. Both offer local storage, color night vision, and flexible installation, with the Duo Cam Battery Doorbell also featuring dual cameras for enhanced entryway monitoring.
How does local storage work on Wyze cameras?Local storage on Wyze cameras works by inserting a compatible microSD card (up to 256GB, depending on the model) into the camera. This allows you to record and store video footage directly on the device, enabling 24/7 continuous recording or event-based recording without relying on cloud services.
What smart features do Wyze cameras offer?Wyze cameras come with a range of smart features, including motion and sound detection, customizable detection zones, two-way audio, integrated sirens, motion-activated spotlights, and instant push notifications. These features help you monitor your property more effectively and respond quickly to potential security threats.
Can you tell me more about the Wyze Cam v4 and its features?What are the differences between the Wyze Battery Cam Pro and the Wyze Bulb Cam?Do you have any ongoing sales or discounts for Wyze cameras?
