Top Security Cameras with Telephoto Zoom & Color Night Vision
Best Security Cameras with Telephoto Zoom and Color Night Vision
When it comes to securing your home or business, having a security camera that offers both telephoto zoom capabilities and vibrant color night vision is essential. These features allow you to capture detailed images from a distance and see clear, colorful footage even in low-light or nighttime conditions. Below, we highlight the top Wyze security cameras that excel in these areas, combining advanced technology, smart features, and reliable performance.
Wyze Cam OG Telephoto: Precision Zoom Meets Night Vision
Key Features:
  • 3x Telephoto Lens: Get closer to the action with a powerful 3x telephoto zoom, perfect for focusing on distant objects without losing clarity.
  • 1080p Full HD Video: Crisp and clear video quality ensures you never miss a detail.
  • Color Night Vision: Equipped with 4 IR LEDs, this camera delivers vibrant color footage even in the dark.
  • 8x Digital Zoom: Further enhance your view digitally for detailed monitoring.
  • IP65 Weather Resistance: Suitable for both indoor and outdoor use, built to withstand harsh weather conditions.
  • Two-Way Audio: Communicate clearly with built-in speaker and microphone featuring noise and echo cancellation.
  • Local Storage Support: Save footage locally with microSD card support up to 256GB.
  • Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for seamless smart home control.
Why Choose Wyze Cam OG Telephoto?
This camera is ideal for users who need detailed zoom capabilities combined with excellent night vision. Whether monitoring your driveway, backyard, or business premises, the Wyze Cam OG Telephoto offers sharp, colorful images day and night.
Wyze Cam v4: Enhanced Color Night Vision with 2.5K QHD Clarity
Key Features:
  • 2.5K Quad HD Resolution: Experience crystal-clear video with 2.5K QHD clarity, providing more detail than standard HD cameras.
  • Enhanced Color Night Vision: Advanced hardware allows the camera to capture stunning color footage in low-light conditions, revealing details invisible to the naked eye.
  • Motion-Activated Spotlight & Siren: Deter intruders with a built-in spotlight and a loud 99 dB siren.
  • Wide Dynamic Range (WDR): Produces vibrant colors and balanced images even in challenging lighting.
  • IP65 Weatherproof: Durable for outdoor use in all weather conditions.
  • 24/7 Local Recording: Continuous recording to microSD card (up to 256GB) without subscription fees.
  • Wi-Fi 6 Support: Ensures a stronger, more reliable connection.
  • Smart Assistant Compatibility: Works with Alexa, Google Assistant, and IFTTT.
Ideal Use Cases:
Perfect for homeowners seeking a versatile wired camera with superior night vision and high-resolution video. The Wyze Cam v4’s spotlight and siren add an extra layer of security, making it a great choice for front porches, backyards, and garages. Wyze Cam v4 in action Wyze Cam v4 providing clear security footage with color night vision
Wyze Cam Floodlight v2: Bright Illumination Meets Color Night Vision
Key Features:
  • 2800 Lumens LED Floodlights: Powerful lighting to illuminate large outdoor areas.
  • 2K Video Resolution: High-quality 2304 x 1296 video with color night vision.
  • 160° Wide-Angle View: Covers a broad area for comprehensive monitoring.
  • AI-Powered Light Control: Automatically adjusts lighting based on ambient conditions.
  • Dusk-to-Dawn Automation: Lights turn on/off automatically to save energy.
  • Built-in 105 dB Siren & Two-Way Audio: Communicate and deter intruders effectively.
  • IP65 Weather Resistance: Built to withstand rain, snow, and extreme temperatures.
  • Local Storage: Supports microSD cards up to 256GB for continuous recording.
  • Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT.
Why It Stands Out:
The Wyze Cam Floodlight v2 is perfect for those who want a security camera combined with powerful lighting. Its color night vision and wide field of view make it ideal for driveways, backyards, and front porches where visibility and deterrence are critical. Wyze Cam Floodlight v2 illuminating driveway Wyze Cam Floodlight v2 lighting up a driveway with color night vision
Wyze Bulb Cam: Discreet Security with Color Night Vision
Key Features:
  • 2K HD Video: Clear video quality with color night vision.
  • 2-in-1 Design: Combines a smart LED light bulb with a security camera.
  • 160° Super-Wide Field of View: Covers more area than traditional cameras.
  • Dimmable 800 Lumen LED Bulb: Adjustable brightness for perfect lighting.
  • Easy Installation: Fits most standard light fixtures, no extra wiring needed.
  • Motion-Activated Lighting & Alerts: Lights up and sends instant alerts when motion is detected.
  • 24/7 Local Recording: Supports microSD cards up to 256GB.
  • Two-Way Audio: Speak to visitors or pets remotely.
  • Smart Home Compatible: Works with Alexa, Google Assistant, and IFTTT.
Best For:
Ideal for users who want a subtle security solution integrated into existing outdoor lighting. The Wyze Bulb Cam is perfect for porches, garages, and patios where you want both illumination and surveillance without bulky cameras. Wyze Bulb Cam installed in outdoor fixture Wyze Bulb Cam installed in an outdoor light fixture for discreet security
Wyze Cam Pan v3: 360° Coverage with Telephoto Zoom
Key Features:
  • 360° Horizontal & 180° Vertical Rotation: Pan and tilt to cover every angle.
  • 1080p Full HD Video: Clear video with 8x digital zoom.
  • Color Night Vision: Four IR LEDs provide vibrant night footage.
  • IP65 Weatherproof: Suitable for indoor and outdoor use.
  • Fast Rotation Speed: Up to 110° per second for quick tracking.
  • Two-Way Audio: Built-in speaker and microphone with noise cancellation.
  • Local Storage: Supports microSD cards up to 256GB.
  • Smart Assistant Support: Alexa, Google Assistant, and IFTTT compatible.
Why It’s Great:
The Wyze Cam Pan v3 is perfect for users who want full coverage with the ability to zoom in on specific areas. Its pan and tilt features combined with color night vision make it a versatile choice for both indoor and outdoor security.
Conclusion
For those seeking security cameras with telephoto zoom and color night vision, Wyze offers a range of options tailored to different needs:
  • Wyze Cam OG Telephoto for focused zoom and clear night vision.
  • Wyze Cam v4 for high-resolution video and enhanced color night vision with spotlight.
  • Wyze Cam Floodlight v2 for powerful lighting combined with color night vision.
  • Wyze Bulb Cam for discreet, integrated lighting and security.
  • Wyze Cam Pan v3 for 360° coverage with zoom and color night vision.
Each camera supports local storage, smart home integration, and robust weather resistance, ensuring reliable security day and night.
Protect your home with the best in telephoto zoom and color night vision technology — see more, know more, and stay safer.
Product Highlights Summary
  • Wyze Cam OG Telephoto: 3x telephoto zoom, 1080p HD, color night vision, IP65.
  • Wyze Cam v4: 2.5K QHD, enhanced color night vision, spotlight, Wi-Fi 6.
  • Wyze Cam Floodlight v2: 2800 lumens, 2K video, color night vision, AI light control.
  • Wyze Bulb Cam: 2K HD, color night vision, smart LED bulb, easy install.
  • Wyze Cam Pan v3: 360° pan/tilt, 1080p, 8x zoom, color night vision.
Secure your property with Wyze’s cutting-edge cameras designed for clarity, color, and control.
FeatureWyze Cam OG TelephotoWyze Cam v4Wyze Cam Floodlight v2Wyze Bulb CamWyze Cam Pan v3
ResolutionNot specified (improved live HD video)2.5K QHD (2560x1440)2K (2304x1296)2K (2304x1296)1080p (1920x1080)
Field of View27° (3x Telephoto lens)115.9° (D) x 98.5° (H) x 53.1° (V)160° Diagonal160° diagonal / 166° diagonal (various)120° FOV
Night VisionColor Night VisionEnhanced Color Night VisionColor Night VisionColor Night Vision + IR Night VisionIR Night Vision (4 IR LEDs 850 nm)
AudioImproved 2-way audioEnhanced Two-Way Talk, 99 dB speakerBuilt-in speaker and microphone; 2-way audioBuilt-in digital microphone; 2-way audioBuilt-in speaker and microphone; 2-way audio; Noise & Echo cancellation
Siren Volume90 dB user-activated siren99 dB built-in siren105 dB siren95 dB at 4 inNot specified
Zoom3x Telephoto zoom8x digital zoomNo zoomDigital zoom8x digital zoom
Weather ResistanceIP65IP65IP65IP65IP65
Power SourceWiredWiredHardwired120V AC (bulb socket)Wired
Local Storage SupportmicroSD up to 256GBmicroSD up to 512GBmicroSD up to 256GBmicroSD up to 256GB (exFAT)microSD up to 256GB (exFAT)
Cloud StorageSubscription-based (Cam Plus)Subscription-based (Cam Plus)Subscription-based (Cam Plus)Stored in AWS cloudSubscription-based (Cam Plus)
ConnectivityWi-Fi (2.4 GHz)Wi-Fi 6 (2.4 GHz & Wi-Fi 6)Wi-Fi 2.4 GHzWi-Fi 2.4 GHzWi-Fi 2.4 GHz
Smart Assistant IntegrationNot specifiedAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTNot specifiedAlexa, Google Assistant, IFTTT
Special Features3x faster notifications, Color Night Vision, IP65, 3x telephoto lens, 90 dB sirenMotion-activated spotlight, Wide Dynamic Range (WDR), Smoke & CO alerts, AI Auto-Zoom2800 Lumens LED floodlight, Ambient Light Mode, Dusk-to-Dawn automation2-in-1 camera and smart LED bulb, motion-activated light, up to 800 lumens brightness360° pan, 180° tilt, 110°/sec rotation speed, noise & echo cancellation
Dimensions / WeightNot specified2in x 2in x 2 3/8in; 0.49 lb (222 g)9.5in x 7.7in x 7.0in; 2.76 lbs (1.25 kg)Not specified124mm x 60mm x 63mm; 11.29 oz (320 g)
Release Year20232024Not specifiedNot specifiedNot specified
What are the best Wyze security cameras with telephoto zoom and color night vision?The top Wyze security cameras featuring telephoto zoom and color night vision include the Wyze Cam OG Telephoto, Wyze Cam v4, Wyze Cam Floodlight v2, Wyze Bulb Cam, and Wyze Cam Pan v3. Each model offers advanced features such as high-resolution video, smart home integration, and robust weather resistance for reliable security day and night.
What is the Wyze Cam OG Telephoto and what features does it offer?The Wyze Cam OG Telephoto is a security camera equipped with a 3x telephoto lens for detailed zoom, 1080p Full HD video, color night vision with 4 IR LEDs, 8x digital zoom, IP65 weather resistance, two-way audio, local storage support up to 256GB, and compatibility with Alexa, Google Assistant, and IFTTT.
How does the Wyze Cam v4 enhance night vision security?The Wyze Cam v4 features enhanced color night vision with advanced hardware, 2.5K Quad HD resolution for crystal-clear video, a motion-activated spotlight and 99 dB siren for deterrence, wide dynamic range (WDR), IP65 weatherproofing, 24/7 local recording, Wi-Fi 6 support, and smart assistant compatibility.
What makes the Wyze Cam Floodlight v2 ideal for outdoor security?The Wyze Cam Floodlight v2 combines 2800 lumens of LED floodlights with 2K video resolution and color night vision. It offers a 160° wide-angle view, AI-powered light control, dusk-to-dawn automation, a built-in 105 dB siren, two-way audio, IP65 weather resistance, local storage up to 256GB, and smart home integration.
What is the Wyze Bulb Cam and where is it best used?The Wyze Bulb Cam is a 2-in-1 device that combines a smart LED light bulb with a 2K HD security camera featuring color night vision. It offers a 160° super-wide field of view, dimmable 800 lumen LED bulb, easy installation in standard light fixtures, motion-activated lighting and alerts, 24/7 local recording, two-way audio, and smart home compatibility. It is ideal for porches, garages, and patios where discreet security is desired.
How does the Wyze Cam Pan v3 provide 360° security coverage?The Wyze Cam Pan v3 offers 360° horizontal and 180° vertical rotation for complete coverage, 1080p Full HD video with 8x digital zoom, color night vision with four IR LEDs, IP65 weatherproofing, fast rotation speed, two-way audio, local storage up to 256GB, and compatibility with Alexa, Google Assistant, and IFTTT.
Do Wyze security cameras support local storage?Yes, all featured Wyze security cameras support local storage via microSD cards up to 256GB, allowing for continuous 24/7 recording without subscription fees.
Are Wyze security cameras weatherproof for outdoor use?Yes, Wyze security cameras such as the Wyze Cam OG Telephoto, Wyze Cam v4, Wyze Cam Floodlight v2, and Wyze Cam Pan v3 are IP65 weather resistant, making them suitable for both indoor and outdoor use in various weather conditions.
Can Wyze security cameras be integrated with smart home systems?Yes, all highlighted Wyze security cameras are compatible with popular smart home platforms including Alexa, Google Assistant, and IFTTT, enabling seamless integration and control.
What are the benefits of color night vision in Wyze security cameras?Color night vision in Wyze security cameras allows you to capture clear, colorful footage even in low-light or nighttime conditions, providing more detail and better identification compared to traditional black-and-white night vision.
What are the main differences between the Wyze Cam OG Telephoto and the Wyze Cam v4?Can you explain how the color night vision feature works in the Wyze cameras?Do you have any ongoing sales or discounts for the Wyze security cameras?
