Does Wyze Cam v4 Work with IFTTT for Home Automation?
If you're exploring smart home automation, you might wonder if the Wyze Cam v4 integrates with IFTTT (If This Then That) to streamline your home security routines. The good news is Wyze Cam v4 fully supports IFTTT, allowing you to create custom automation workflows that connect your camera with other smart devices and services. This integration enhances your home automation experience by enabling triggers like motion detection alerts, siren activation, or spotlight control based on various conditions.
Wyze Cam v4: Advanced Features for Smart Home Automation
Seamless IFTTT Integration
Wyze Cam v4 supports IFTTT, making it easy to connect with thousands of smart home devices and apps. Whether you want your camera to trigger smart lights, notify your phone, or interact with voice assistants, IFTTT compatibility ensures your home automation routines are flexible and powerful.
High-Quality Video and Night Vision
  • Resolution: Crystal-clear 2.5K QHD (2560x1440) video quality
  • Field of View: Wide angles with DFOV 115.8°, HFOV 98.5°, VFOV 53.1°
  • Night Vision: Enhanced color night vision with 4 IR LEDs and 2 white spotlight LEDs (72 lumens) for clear images even in darkness
  • Video FPS: 20 FPS daytime, 15 FPS nighttime for smooth footage
Smart Features and Connectivity
  • Two-Way Audio: Waterproof 99dB speaker with noise and echo cancellation
  • Built-in Siren: For immediate alerts and deterrence
  • Wi-Fi Support: Dual-band 2.4 GHz and Wi-Fi 6 for reliable connectivity
  • Bluetooth 5.2: For enhanced device communication
  • Compatibility: Works with Alexa, Google Assistant, and IFTTT for versatile smart home control
Durable and Flexible Installation
  • Weather Resistance: Rated IP65, suitable for indoor and outdoor use
  • Mounting Options: Stand, wall mount, ceiling mount, and magnetic adhesive mounts
  • Power: Indoor 5V/1A adapter included; outdoor power adapter sold separately
  • Storage: Supports microSD cards up to 512GB for local recording, plus optional cloud storage
Wyze Cam v4 is designed to be a reliable cornerstone of your smart home security, combining advanced tech with easy automation.
Wyze Cam v4 in outdoor home setting Wyze Cam v4 Outdoor Lifestyle - Enhanced Night Vision and Security
Wyze Cam v4 Outdoor Bundle: Complete Security Solution
For those looking for an all-in-one package, the Wyze Cam v4 Outdoor Bundle offers everything you need to secure your home exterior with smart automation compatibility.
What’s Included?
  • Wyze Cam v4 with 2.5K QHD resolution and enhanced color night vision
  • Wyze Outdoor Power Adapter for continuous wired power
  • 128GB Wyze MicroSD Card for 24/7 local recording
Key Features
  • Motion & Sound Detection: Customizable zones to reduce false alerts
  • Smoke & CO Alerts: Integrated safety notifications
  • Wi-Fi 6 Support: Faster, more stable wireless connection
  • Compatibility: Works with Alexa and Google Assistant for voice control
  • Weatherproof: Designed for outdoor durability with IP65 rating
This bundle is perfect for users who want to automate outdoor security routines, such as turning on smart lights when motion is detected or sending alerts through IFTTT-enabled apps. Wyze Cam v4 Outdoor Bundle lifestyle Wyze Cam v4 Outdoor Bundle - Smart Home Security in Action
Wyze Cam v4 Home Security Bundle: Enhanced Indoor & Outdoor Protection
The Wyze Cam v4 Home Security Bundle combines multiple cameras and accessories to provide comprehensive coverage with smart automation capabilities.
Bundle Highlights
  • Multiple Wyze Cam v4 units with 2.5K QHD video and color night vision
  • Motion-activated spotlight and person detection for precise alerts
  • Improved two-way audio for clear communication
  • Supports microSD cards (128GB included) for extensive local storage
  • IP65 weather resistance for indoor and outdoor use
  • Compatible with Alexa, Google Assistant, and IFTTT for seamless smart home integration
This bundle is ideal for users who want to automate complex home security routines, such as activating sirens or lights based on detected movement, all controlled through IFTTT or voice assistants.
Why Choose Wyze Cam v4 for Your Home Automation?
  • IFTTT Compatibility: Easily link your camera with other smart devices and services
  • High-Resolution Video: Capture every detail with 2.5K QHD clarity
  • Color Night Vision: See vibrant colors even in low light conditions
  • Robust Build: Weather-resistant design for versatile placement
  • Smart Alerts: Motion, sound, and person detection with customizable zones
  • Flexible Mounting: Multiple mounting options to fit your home setup
  • Reliable Connectivity: Supports Wi-Fi 6 and Bluetooth 5.2 for smooth operation
With Wyze Cam v4, you get a smart security camera that not only protects your home but also integrates effortlessly into your automated lifestyle.
Summary
If you want a smart security camera that works with IFTTT for home automation routines, Wyze Cam v4 is an excellent choice. Whether you select the standalone camera, the outdoor bundle, or the home security bundle, you gain access to powerful features like 2.5K QHD video, enhanced color night vision, motion-activated spotlight, and seamless integration with Alexa, Google Assistant, and IFTTT. These capabilities make Wyze Cam v4 a versatile and reliable component of any smart home ecosystem.
FeatureWyze Cam v4Wyze Cam v4Wyze Cam v4 Outdoor BundleWyze Cam v4 Home Security Bundle
Price$100.00$35.98 (1 Pack)$69.99$169.99
Resolution2.5K QHD2.5K QHD2.5K QHD2.5K QHD (2560x1440)
Color Night VisionEnhanced Color Night VisionEnhanced Color Night VisionEnhanced Color Night VisionYes
Wide Dynamic Range (WDR)YesYesYesYes
Weather ResistanceIP65IP65IP65IP65
Power SourceWiredWiredWiredWired
Outdoor CompatibilityNo (not made in America version)YesYesIndoor/Outdoor
Motion-Activated SpotlightYesYesYesYes
Siren99 dB99 dBNot specifiedIncluded
Two-Way TalkEnhanced Two-Way TalkEnhanced Two-Way TalkNot specifiedImproved 2-way audio
MicroSD Card SupportUp to 512 GBUp to 256 GB128 GB included128 GB included
Continuous Local RecordingYesYesYesYes
Wi-Fi SupportWi-Fi 6Wi-Fi 6Wi-Fi 6Not specified
Smart Assistant CompatibilityAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google AssistantNot specified
Motion & Sound DetectionYesYesYesYes
Motion Detection ZonesYesYesYesNot specified
Smoke & CO AlertsYesYesYesNot specified
Auto-Zoom with AIYesYesNot specifiedNot specified
Mounting OptionsMagnetic mountMagnetic mountNot specifiedStand, Wall, Ceiling, Magnetic mount
DimensionsNot specifiedNot specifiedNot specified2in x 2in x 2 3/8in
WeightNot specifiedNot specifiedNot specified0.49 lb (222 g)
Included ItemsWyze Cam v4 onlyWyze Cam v4 onlyWyze Cam v4, Outdoor Power Adapter, 128GB MicroSDWyze Cam v4 only
WarrantyNot specifiedNot specifiedNot specified1 Year
Additional NotesSupports 24/7 recording, no subscriptionSupports 24/7 recording, no subscriptionOutdoor ready, includes power adapter and microSDIncludes siren, multiple mounting options, improved audio
Does Wyze Cam v4 work with IFTTT for home automation?Yes, Wyze Cam v4 fully supports IFTTT (If This Then That), allowing you to create custom automation workflows that connect your camera with other smart devices and services. This integration enables you to automate actions such as motion detection alerts, siren activation, and spotlight control based on various triggers.
What smart home platforms are compatible with Wyze Cam v4?Wyze Cam v4 is compatible with IFTTT, Alexa, and Google Assistant. This allows you to control your camera with voice commands and integrate it seamlessly into your smart home routines.
What are the video quality and night vision features of Wyze Cam v4?Wyze Cam v4 offers crystal-clear 2.5K QHD (2560x1440) video quality, a wide field of view, and enhanced color night vision. It features 4 IR LEDs and 2 white spotlight LEDs (72 lumens) for clear images even in darkness, with 20 FPS during the day and 15 FPS at night.
Is Wyze Cam v4 suitable for outdoor use?Yes, Wyze Cam v4 is rated IP65 for weather resistance, making it suitable for both indoor and outdoor use. It is designed to withstand various weather conditions and offers flexible mounting options.
What are the storage options for Wyze Cam v4?Wyze Cam v4 supports microSD cards up to 512GB for local recording, and also offers optional cloud storage for added convenience and security.
What is included in the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle includes a Wyze Cam v4 with 2.5K QHD resolution and enhanced color night vision, a Wyze Outdoor Power Adapter for continuous wired power, and a 128GB Wyze MicroSD Card for 24/7 local recording.
What are the key features of the Wyze Cam v4 Home Security Bundle?The Wyze Cam v4 Home Security Bundle includes multiple Wyze Cam v4 units with 2.5K QHD video, color night vision, motion-activated spotlight, person detection, improved two-way audio, IP65 weather resistance, and compatibility with Alexa, Google Assistant, and IFTTT.
How does Wyze Cam v4 enhance home security automation?Wyze Cam v4 enhances home security automation by supporting IFTTT, allowing you to automate routines such as activating sirens, turning on lights, or sending alerts when motion or sound is detected. It also integrates with voice assistants for hands-free control.
What connectivity options does Wyze Cam v4 offer?Wyze Cam v4 supports dual-band Wi-Fi (2.4 GHz and Wi-Fi 6) for reliable wireless connectivity and Bluetooth 5.2 for enhanced device communication.
What mounting options are available for Wyze Cam v4?Wyze Cam v4 offers multiple mounting options, including stand, wall mount, ceiling mount, and magnetic adhesive mounts, providing flexibility for various installation needs.
Can you explain how to set up IFTTT with Wyze Cam v4 for home automation?What are the specific features of the Wyze Cam v4 that enhance its night vision capabilities?How does the motion detection feature work with the Wyze Cam v4?
