Wyze Cam v4: Wi-Fi 6 Security Camera with 2.5K HD Video
Discover Wyze Cam v4 with Wi-Fi 6 Support
If you're searching for a smart security camera that supports the latest Wi-Fi 6 technology, the Wyze Cam v4 lineup is your perfect match. Designed to deliver crystal-clear 2.5K Quad High Definition video, enhanced color night vision, and robust connectivity, Wyze Cam v4 ensures your home stays safe and connected like never before.
Wyze Cam v4: Advanced Features and Specifications
Stunning 2.5K Quad HD Video Quality
Wyze Cam v4 captures your surroundings in vivid detail with 2.5K QHD resolution (2560x1440). This high resolution ensures you never miss a moment, whether it's day or night.
Enhanced Color Night Vision
Unlike traditional black-and-white night vision, Wyze Cam v4 uses enhanced hardware and dual white spotlight LEDs to provide vibrant color images even in low-light conditions. This "superhero vision" helps you identify details that other cameras might miss.
Wide Dynamic Range (WDR) for Vibrant Colors
An upgraded image processor enables Wide Dynamic Range, balancing bright and dark areas in your footage for rich, true-to-life colors and improved image quality.
Wi-Fi 6 Connectivity for Stronger, Faster Connections
Wyze Cam v4 supports Wi-Fi 6, the latest wireless standard, allowing for a more reliable connection at greater distances. This means smoother video streaming and faster alert notifications when paired with a Wi-Fi 6 router.
Weather-Resistant and Versatile Mounting
Rated IP65 for weather resistance, Wyze Cam v4 can be used indoors or outdoors. Its compact size (2in x 2in x 2 3/8in) and multiple mounting options—including magnetic wall mount and ceiling mount—make installation flexible and tool-free.
Smart Features for Enhanced Security
  • Motion and sound detection with customizable detection zones
  • Smoke and CO alarm alerts with automatic video recording
  • Auto-zoom with AI-powered Smart Focus to track important activity
  • Two-way talk with noise and echo cancellation
  • Built-in 99 dB siren and motion-activated spotlight for deterrence
Local and Cloud Storage Options
Supports microSD cards up to 512 GB for continuous 24/7 local recording without subscription fees. Cloud storage is also available with optional subscription plans for advanced AI detections.
Smart Home Integration
Works seamlessly with Amazon Alexa, Google Assistant, and IFTTT for voice control and automation.
Wyze Cam v4 mounted outdoors with vibrant night vision Experience vibrant color night vision with Wyze Cam v4 outdoors
Wyze Cam v4 Outdoor Bundle: Complete Security Solution
The Wyze Cam v4 Outdoor Bundle offers everything you need for reliable outdoor security at a great value. This bundle includes:
  • Wyze Cam v4 with 2.5K QHD resolution and enhanced color night vision
  • Wyze Outdoor Power Adapter designed for all weather conditions
  • 128GB Wyze MicroSD Card for continuous local recording
Why Choose the Outdoor Bundle?
  • Ready for rain, snow, or shine with IP65 weather resistance
  • Motion-activated spotlight and siren to deter intruders
  • Wi-Fi 6 support for stable connectivity even in challenging outdoor environments
  • Compatible with Alexa and Google Assistant for smart home convenience
This bundle is perfect for those who want a plug-and-play outdoor security camera with all essential accessories included.
Wyze Cam v4 Home Security Bundle: Enhanced Indoor and Outdoor Protection
For comprehensive home security, the Wyze Cam v4 Home Security Bundle combines multiple cameras with accessories to cover your entire property. Key features include:
  • Multiple Wyze Cam v4 units with 2.5K QHD video and color night vision
  • 128GB Class 10 microSD cards for extended local storage
  • Improved two-way audio and built-in siren for clear communication and deterrence
  • IP65 weather resistance for indoor and outdoor use
  • Motion-activated spotlight and person detection for precise alerts
  • Wi-Fi 6 connectivity for reliable performance
This bundle is ideal for users seeking a robust, scalable security system with smart detection capabilities.
Family enjoying home security with Wyze Cam v4 Peace of mind with Wyze Cam v4 protecting your home day and night
Wyze Cam v4 + FREE 32GB MicroSD Card: Great Value Offer
Get the powerful Wyze Cam v4 with a free 32GB microSD card included, perfect for users who want to start recording locally right away. This package features:
  • 2.5K QHD resolution with enhanced color night vision
  • IP65 weather resistance for versatile placement
  • Motion-activated spotlight and siren for added security
  • Wi-Fi 6 support for fast, stable connections
  • Local storage with included microSD card (expandable up to 512GB)
This option is excellent for budget-conscious buyers who want the latest Wyze Cam v4 features plus immediate local recording capability.
Why Wyze Cam v4 is the Best Wi-Fi 6 Security Camera Choice
"Wyze Cam v4 combines cutting-edge Wi-Fi 6 technology with superior video quality and smart home integration, making it a top choice for modern home security."
  • Wi-Fi 6 support ensures your camera stays connected with less interference and better range.
  • 2.5K QHD video and enhanced color night vision provide crystal-clear footage day and night.
  • Robust weather resistance and versatile mounting allow indoor or outdoor use.
  • Smart alerts and AI-powered tracking keep you informed about what matters most.
  • Affordable bundles and accessories make it easy to customize your security setup.
Upgrade your home security with Wyze Cam v4 and enjoy the benefits of the latest wireless technology combined with advanced camera features.
Wyze Cam v4 lifestyle image showing outdoor security Wyze Cam v4 blends seamlessly into your smart home security system
Summary of Wyze Cam v4 Wi-Fi 6 Supported Products
Product NameKey FeaturesPrice Range
Wyze Cam v42.5K QHD, Color Night Vision, Wi-Fi 6, IP65$35.98+
Wyze Cam v4 Outdoor BundleIncludes Outdoor Power Adapter & 128GB microSD$69.99
Wyze Cam v4 Home Security BundleMulti-camera pack, 128GB microSD, Wi-Fi 6$169.99
Wyze Cam v4 + FREE 32GB microSDStarter pack with free microSD card$35.98
Choose the Wyze Cam v4 product that fits your security needs and enjoy the benefits of Wi-Fi 6 connectivity for a smarter, safer home.
# Product Tags and Highlights
FeatureWyze Cam v4Wyze Cam v4 Outdoor BundleWyze Cam v4 (Regular)Wyze Cam v4 Home Security BundleWyze Cam v4 + FREE 32GB MicroSD Card
Price$35.98 (1 Pack)$69.99$100.00$169.99$35.98
Color OptionsBlack, Clear (sold out), Grey, WhiteBlack, Grey, WhiteWhite, GreyNot specifiedBlack, Grey, White
Resolution2.5K QHD (2560x1440)2.5K QHD (2560x1440)2.5K QHD (2560x1440)2.5K QHD (2560x1440)2.5K QHD
Night VisionEnhanced Color Night VisionEnhanced Color Night VisionEnhanced Color Night VisionEnhanced Color Night VisionEnhanced Color Night Vision
SpotlightMotion-activated spotlightMotion-activated spotlightMotion-activated spotlightMotion-activated spotlightMotion-activated spotlight
SirenYes (99 dB)YesYesYesYes
AudioEnhanced Two-Way TalkEnhanced Two-Way TalkEnhanced Two-Way TalkImproved 2-way audioEnhanced Two-Way Talk
Weather ResistanceIP65IP65IP65IP65IP65
Wi-Fi SupportWi-Fi 6Wi-Fi 6Wi-Fi 6Wi-Fi 6Wi-Fi 6
Local RecordingmicroSD card up to 512GB (sold separately)Includes 128GB microSD cardmicroSD card up to 512GB (sold separately)Includes 128GB microSD cardmicroSD card up to 512GB (sold separately)
Continuous 24/7 RecordingYesYesYesYesYes
Outdoor UseRequires Outdoor Power Adapter (sold separately)Includes Wyze Outdoor Power AdapterRequires Outdoor Power Adapter (sold separately)Indoor/Outdoor with IP65 ratingRequires Outdoor Power Adapter (sold separately)
Motion & Sound DetectionYesYesYesYesYes
Smart Assistant CompatibilityAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Field of View (FOV)115.9° (D) x 98.5° (H) x 53.1° (V)115.9° (D) x 98.5° (H) x 53.1° (V)115.8° (D) x 98.5° (H) x 53.1° (V)115.8° (D) x 98.5° (H) x 53.1° (V)Not specified
Digital Zoom8x8x8x8xNot specified
Wide Dynamic Range (WDR)YesYesYesYesYes
Smoke & CO AlertsYesYesYesYesYes
Mounting OptionsStand, Wall, Ceiling, MagneticStand, Wall, Ceiling, MagneticStand, Wall, Ceiling, MagneticStand, Wall, Ceiling, MagneticNot specified
Warranty1 Year1 Year1 Year1 YearNot specified
Included AccessoriesUSB Power Adapter, Mounting Kit, CableOutdoor Power Adapter, 128GB microSD cardUSB Power Adapter, Mounting Kit, CableUSB Power Adapter, Mounting Kit, CableUSB Power Adapter, Mounting Kit, Cable
Bundle ContentsSingle camera kitCamera + Outdoor Power Adapter + 128GB microSDSingle camera kitHome Security Bundle (multiple cameras likely)Single camera + free 32GB microSD card
What is Wyze Cam v4 and what are its main features?Wyze Cam v4 is a smart security camera that supports the latest Wi-Fi 6 technology. Its main features include 2.5K Quad HD video resolution, enhanced color night vision, wide dynamic range for vibrant colors, IP65 weather resistance for indoor and outdoor use, motion and sound detection, smoke and CO alarm alerts, auto-zoom with AI-powered Smart Focus, two-way talk, a built-in 99 dB siren, motion-activated spotlight, and support for both local and cloud storage.
Does Wyze Cam v4 support Wi-Fi 6?Yes, Wyze Cam v4 supports Wi-Fi 6, the latest wireless standard. This provides stronger, faster, and more reliable connections, especially when paired with a Wi-Fi 6 router, resulting in smoother video streaming and faster alert notifications.
What video quality does Wyze Cam v4 offer?Wyze Cam v4 offers stunning 2.5K Quad HD (QHD) video quality with a resolution of 2560x1440, ensuring you capture every detail in vivid clarity both day and night.
How does the enhanced color night vision work on Wyze Cam v4?Wyze Cam v4 uses enhanced hardware and dual white spotlight LEDs to provide vibrant color night vision, even in low-light conditions. This allows you to see more details at night compared to traditional black-and-white night vision cameras.
Is Wyze Cam v4 weather-resistant?Yes, Wyze Cam v4 is rated IP65 for weather resistance, making it suitable for both indoor and outdoor use. It can withstand rain, snow, and other challenging weather conditions.
What storage options are available for Wyze Cam v4?Wyze Cam v4 supports local storage with microSD cards up to 512GB for continuous 24/7 recording without subscription fees. Cloud storage is also available through optional subscription plans, which offer advanced AI detections.
Does Wyze Cam v4 work with smart home systems?Yes, Wyze Cam v4 integrates seamlessly with Amazon Alexa, Google Assistant, and IFTTT, allowing for voice control and smart home automation.
What is included in the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle includes a Wyze Cam v4 with 2.5K QHD resolution and enhanced color night vision, a Wyze Outdoor Power Adapter for all-weather use, and a 128GB Wyze MicroSD Card for continuous local recording.
What does the Wyze Cam v4 Home Security Bundle offer?The Wyze Cam v4 Home Security Bundle includes multiple Wyze Cam v4 units, 128GB Class 10 microSD cards for extended local storage, improved two-way audio, built-in siren, IP65 weather resistance, motion-activated spotlight, person detection, and Wi-Fi 6 connectivity for comprehensive indoor and outdoor protection.
Is there a Wyze Cam v4 package with a free microSD card?Yes, there is a Wyze Cam v4 package that includes a free 32GB microSD card, allowing you to start recording locally right away. The camera also supports expandable storage up to 512GB.
How does Wyze Cam v4 enhance home security?Wyze Cam v4 enhances home security with features like motion and sound detection, customizable detection zones, smoke and CO alarm alerts, AI-powered auto-zoom and Smart Focus, two-way talk, a built-in siren, motion-activated spotlight, and reliable Wi-Fi 6 connectivity.
What mounting options are available for Wyze Cam v4?Wyze Cam v4 offers versatile mounting options, including a magnetic wall mount and ceiling mount. Its compact size and tool-free installation make it easy to place the camera wherever you need it.
What are the available Wyze Cam v4 bundles and their prices?Wyze Cam v4 is available in several bundles: the standard Wyze Cam v4 ($35.98+), Wyze Cam v4 Outdoor Bundle with power adapter and 128GB microSD card ($69.99), Wyze Cam v4 Home Security Bundle with multiple cameras and 128GB microSD cards ($169.99), and Wyze Cam v4 with a free 32GB microSD card ($35.98).
What are the key features of the Wyze Cam v4?Can you tell me more about the enhanced color night vision of the Wyze Cam v4?Do you have any ongoing sales or promotions for the Wyze Cam v4?
