Wyze Cam v4 Compatibility: Smart Home & Device Integration Guide
Wyze Cam v4 Compatibility and Features
Wyze Cam v4 is a versatile and powerful security camera designed to provide unmatched home and outdoor surveillance with broad compatibility and advanced features. Whether you are looking for a standalone camera or a complete security bundle, Wyze Cam v4 offers seamless integration with popular smart home ecosystems and supports multiple mounting and power options to fit your needs.
Wyze Cam v4: Core Specifications and Compatibility
Crystal-Clear 2.5K QHD Resolution
Wyze Cam v4 delivers stunning 2.5K Quad High Definition (2560x1440) video quality, capturing every detail with clarity. This makes it ideal for monitoring your home or business with sharp, vibrant footage.
Enhanced Color Night Vision
Unlike traditional black-and-white night vision, Wyze Cam v4 features enhanced color night vision powered by advanced hardware and 4 IR LEDs plus 2 white spotlight LEDs. This allows you to see more vivid details even in low-light or dark environments.
Wide Dynamic Range (WDR)
The camera’s upgraded image processor supports Wide Dynamic Range, ensuring balanced exposure and vibrant colors in scenes with varying lighting conditions, such as bright sunlight and shadows.
Weather Resistance and Mounting Flexibility
Rated IP65 for weather resistance, Wyze Cam v4 is suitable for both indoor and outdoor use. It can withstand rain, snow, and extreme temperatures (-4ºF to 122ºF operating range). Multiple mounting options include stand, wall mount, ceiling mount, and magnetic adhesive mounts, making installation easy and adaptable.
Connectivity and Smart Home Integration
Wyze Cam v4 supports 2.4 GHz Wi-Fi and Wi-Fi 6 for a stronger, more reliable connection. It pairs effortlessly with Alexa, Google Assistant, and IFTTT, allowing voice control and automation within your smart home setup. Bluetooth 5.2 simplifies setup without the need for QR codes.
Local and Cloud Storage Options
Record continuously with local storage support for microSD cards up to 512GB (sold separately), or opt for cloud storage with a subscription plan for added convenience and backup.
Advanced Detection and Alerts
The camera features motion and sound detection with customizable detection zones. It can alert you instantly on your phone when motion or sound is detected, including smoke and CO alarms, enhancing your home’s safety.
Audio and Siren Features
Wyze Cam v4 includes enhanced two-way talk with noise and echo cancellation, a powerful 99dB siren, and a motion-activated spotlight to deter intruders or light your path.
Phone Compatibility
Compatible with Android 9.0+ and iOS 15.0+, the Wyze app provides full control and monitoring from your smartphone.
Outdoor security camera lifestyle Wyze Cam v4 in action outdoors with enhanced night vision
Wyze Cam v4 Outdoor Bundle: Ready for All Conditions
What’s Included
  • Wyze Cam v4 (available in Black, Grey, or White)
  • Wyze Outdoor Power Adapter for reliable outdoor power
  • 128GB Wyze MicroSD Card for continuous local recording
Key Features
This bundle is designed for outdoor security with the same 2.5K QHD resolution and enhanced color night vision as the standalone camera. The included outdoor power adapter ensures your camera stays powered in all weather conditions, while the 128GB microSD card allows for 24/7 local recording without subscription fees.
Smart Home Compatibility
Supports Alexa and Google Assistant for voice commands and automation. Wi-Fi 6 support ensures a stable connection even at greater distances.
Motion-Activated Spotlight and Siren
The spotlight and siren provide active deterrence against intruders, making this bundle a comprehensive outdoor security solution.
Wyze Cam v4 Home Security Bundle: Complete Protection
Bundle Highlights
  • Wyze Cam v4 with 2.5K QHD video and enhanced color night vision
  • Motion-activated spotlight and 99dB siren for active security
  • 128GB microSD card included for local continuous recording
  • IP65 weather resistance for indoor and outdoor use
  • Advanced person detection and customizable motion zones
Enhanced Audio and Video
Improved two-way audio with noise cancellation ensures clear communication. The camera’s CMOS Starlight Sensor and wide field of view (115.8° diagonal) cover large areas effectively.
Easy Installation and Mounting
Multiple mounting options including magnetic mounts make setup quick and tool-free.
Front yard vibrant colors Experience vibrant colors and wide dynamic range with Wyze Cam v4
Wyze Cam v4 + FREE 32GB MicroSD Card: Great Value Offer
Features
  • Same powerful 2.5K QHD resolution and enhanced color night vision
  • IP65 weather resistance for versatile placement
  • Motion-activated spotlight and person detection
  • Wi-Fi 6 support for reliable connectivity
  • Includes a free 32GB microSD card for local recording
This option is perfect for users who want the full Wyze Cam v4 experience with added storage right out of the box.
Summary: Wyze Cam v4 Compatibility
Wyze Cam v4 is compatible with a wide range of devices and smart home platforms, including:
  • Smartphones: Android 9.0+ and iOS 15.0+
  • Smart Assistants: Amazon Alexa, Google Assistant, and IFTTT
  • Wi-Fi Networks: 2.4 GHz Wi-Fi and Wi-Fi 6 routers
  • Storage: microSD cards up to 512GB for local recording
  • Power: Wired with options for outdoor power adapters
Its IP65 weather resistance and multiple mounting options make it suitable for both indoor and outdoor use, while advanced features like color night vision, motion detection zones, and smoke/CO alerts provide comprehensive security.
Wyze Cam v4 is designed to integrate seamlessly into your smart home ecosystem, offering reliable, high-quality video surveillance with flexible compatibility and easy setup.
Wyze Cam lifestyle indoor Wyze Cam v4 fits perfectly in any indoor environment
Conclusion
If you are searching for a security camera with excellent compatibility, advanced features, and flexible installation options, Wyze Cam v4 and its bundles are an outstanding choice. Whether for indoor monitoring or outdoor protection, Wyze Cam v4 offers crystal-clear video, smart alerts, and integration with your favorite smart home devices.
Product Tags Summary
  • Wyze Cam v4 (Standalone and variants)
  • Wyze Cam v4 Outdoor Bundle
  • Wyze Cam v4 Home Security Bundle
  • Wyze Cam v4 + FREE 32GB MicroSD Card
Each product is designed to meet different user needs while maintaining full compatibility with modern smart home systems and providing superior video quality and security features.
FeatureWyze Cam v4Wyze Cam v4 Outdoor BundleWyze Cam v4Wyze Cam v4 Home Security BundleWyze Cam v4 + FREE 32GB MicroSD Card
Price$35.98 (1 Pack)$69.99$100.00$169.99$35.98
Resolution2.5K QHD (2560x1440)2.5K QHD2.5K Quad HD2.5K QHD (2560x1440)2.5K QHD
Color Night VisionYesEnhanced Color Night VisionEnhanced Color Night VisionYesYes
Night Vision LEDs4 IR LEDs + 2 white spotlight LEDsNot specified (IP65 weather resistant)Not specified4 IR LEDs (850 nm) + 2 white spotlight LEDs (72 lumens)Not specified
Weather ResistanceIP65IP65IP65IP65IP65
Motion-Activated SpotlightYesYesYesYesYes
Siren99 dBNot specifiedNot specifiedIncluded (99 dB)Not specified
Audio QualityEnhanced Two-Way TalkEnhanced Two-Way TalkAdvanced Audio Coding (AAC), improved micImproved 2-way audioNot specified
Local RecordingUp to 256GB microSD (microSD sold separately)24/7 local recording, 128GB microSD includedUp to 512GB microSD (sold separately)128GB microSD includedRequires microSD card (sold separately)
Wi-Fi SupportWi-Fi 6Wi-Fi 6Wi-Fi 6Wi-Fi 6Wi-Fi 6
Smart Assistant CompatibilityAlexa, Google Assistant, IFTTTAlexa, Google AssistantAlexa, Google Assistant, IFTTTAlexa, Google AssistantAlexa, Google Assistant
Motion & Sound DetectionYesYesYesYesYes
Motion Detection ZonesYesYesYesNot specifiedYes
Smoke & CO AlertsYesYesYesYesYes
Power SourceWiredWiredWiredWiredWired
Outdoor CompatibilityYesYesNo (but supports outdoor power adapter)Indoor/OutdoorRequires outdoor power adapter
Mounting OptionsMagnetic base, metal plateNot specifiedMagnetic base, metal plateStand, wall, ceiling, magnetic wall mountNot specified
Field of View (FOV)115.9° (D) x 98.5° (H) x 53.1° (V)Not specifiedNot specifiedDFOV 115.8°, HFOV 98.5°, VFOV 53.1°Not specified
Additional Included ItemsNoneWyze Outdoor Power Adapter, 128GB MicroSD CardNoneNone32GB MicroSD Card included
WarrantyNot specifiedNot specifiedNot specified1 YearNot specified
What is the video resolution of Wyze Cam v4?Wyze Cam v4 features a crystal-clear 2.5K Quad High Definition (QHD) resolution (2560x1440), delivering sharp and vibrant video quality for detailed home and outdoor surveillance.
Does Wyze Cam v4 have color night vision?Yes, Wyze Cam v4 is equipped with enhanced color night vision, utilizing advanced hardware and a combination of 4 IR LEDs and 2 white spotlight LEDs to provide vivid, full-color footage even in low-light or dark environments.
Is Wyze Cam v4 weather resistant?Wyze Cam v4 is rated IP65 for weather resistance, making it suitable for both indoor and outdoor use. It can withstand rain, snow, and extreme temperatures ranging from -4ºF to 122ºF.
What smart home platforms is Wyze Cam v4 compatible with?Wyze Cam v4 integrates seamlessly with popular smart home ecosystems, including Amazon Alexa, Google Assistant, and IFTTT, allowing for voice control and automation.
What Wi-Fi networks does Wyze Cam v4 support?Wyze Cam v4 supports both 2.4 GHz Wi-Fi and Wi-Fi 6 networks, ensuring a strong and reliable connection for your security needs.
Can I use Wyze Cam v4 with my smartphone?Yes, Wyze Cam v4 is compatible with Android devices running version 9.0 or higher and iOS devices running version 15.0 or higher. The Wyze app provides full control and monitoring from your smartphone.
What storage options are available for Wyze Cam v4?Wyze Cam v4 supports local storage with microSD cards up to 512GB (sold separately) for continuous recording. Cloud storage is also available through a subscription plan for added convenience and backup.
Does Wyze Cam v4 offer motion and sound detection?Yes, Wyze Cam v4 features advanced motion and sound detection with customizable detection zones. It can send instant alerts to your phone when motion, sound, or smoke/CO alarms are detected.
What audio features does Wyze Cam v4 have?Wyze Cam v4 includes enhanced two-way talk with noise and echo cancellation, allowing for clear communication. It also features a powerful 99dB siren and a motion-activated spotlight for added security.
What mounting options are available for Wyze Cam v4?Wyze Cam v4 offers multiple mounting options, including stand, wall mount, ceiling mount, and magnetic adhesive mounts, making installation flexible and easy for any environment.
What is included in the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle includes a Wyze Cam v4 (available in Black, Grey, or White), a Wyze Outdoor Power Adapter for reliable outdoor power, and a 128GB Wyze MicroSD Card for continuous local recording.
What is included in the Wyze Cam v4 Home Security Bundle?The Wyze Cam v4 Home Security Bundle includes a Wyze Cam v4 with 2.5K QHD video, enhanced color night vision, a motion-activated spotlight, a 99dB siren, a 128GB microSD card for local recording, and IP65 weather resistance.
Does Wyze Cam v4 support person detection and customizable motion zones?Yes, Wyze Cam v4 offers advanced person detection and customizable motion zones, allowing you to focus on specific areas and receive relevant alerts.
Is there a Wyze Cam v4 bundle with a free microSD card?Yes, the Wyze Cam v4 + FREE 32GB MicroSD Card bundle provides the camera with all its advanced features and includes a free 32GB microSD card for local recording right out of the box.
What power options are available for Wyze Cam v4?Wyze Cam v4 is powered via a wired connection and offers options for outdoor power adapters, ensuring reliable operation in all conditions.
How easy is it to install Wyze Cam v4?Wyze Cam v4 is designed for easy installation with multiple mounting options, including magnetic mounts for quick, tool-free setup both indoors and outdoors.
What are the different mounting options available for the Wyze Cam v4?Can the Wyze Cam v4 be used indoors as well as outdoors?Are there any ongoing sales or discounts for the Wyze Cam v4?
