Does Wyze Cam v4 Need a Base Station or Hub to Operate?
Does Wyze Cam v4 Require a Base Station or Hub?
If you're considering the Wyze Cam v4 for your home or outdoor security, a common question is whether it requires a base station or hub to operate. The good news is Wyze Cam v4 does not require a base station or hub. It connects directly to your Wi-Fi network (supports both 2.4 GHz Wi-Fi and Wi-Fi 6), making setup simple and flexible without the need for additional hardware. This standalone capability makes Wyze Cam v4 an excellent choice for users who want straightforward installation and reliable performance without the complexity or cost of a hub.
Wyze Cam v4: Standalone Smart Security Camera
Key Features and Specs
  • Connectivity: Direct Wi-Fi connection (2.4 GHz and Wi-Fi 6), no hub needed
  • Video Quality: Crystal-clear 2.5K QHD (2560x1440) resolution with 8x digital zoom
  • Field of View: Wide angles - 115.8° diagonal, 98.5° horizontal, 53.1° vertical
  • Sensor: CMOS Starlight Sensor for enhanced low-light performance
  • Night Vision: 4 IR LEDs plus 2 white spotlight LEDs for color night vision
  • Audio: Waterproof 99dB speaker with two-way talk and built-in siren
  • Storage: Supports microSD cards up to 512GB for local storage; cloud storage available with subscription
  • Weather Resistance: Rated IP65 for indoor and outdoor use
  • Mounting Options: Stand, wall mount, ceiling mount, and magnetic adhesive mount
  • Compatibility: Works with Alexa, Google Assistant, and IFTTT
  • Power: Powered via 6-foot flat micro USB to USB-A cable; indoor power adapter included
The Wyze Cam v4 is designed for easy installation and versatile placement without the need for a hub, making it ideal for both indoor and outdoor security setups.
Wyze Cam v4 mounted outdoors Wyze Cam v4 providing outdoor security with color night vision
Wyze Cam v4 Outdoor Bundle: Enhanced Security with Accessories
For those looking for a complete outdoor security solution, the Wyze Cam v4 Outdoor Bundle offers the same powerful camera features plus essential accessories:
  • Includes: Wyze Cam v4, Wyze Outdoor Power Adapter, and a 128GB Wyze MicroSD Card
  • Enhanced Color Night Vision: Motion-activated spotlight for clear nighttime footage
  • 24/7 Local Recording: Continuous recording capability with included microSD card
  • Wi-Fi 6 Support: Faster, more reliable wireless connection
  • Smart Alerts: Motion and sound detection with customizable detection zones
  • Compatibility: Works seamlessly with Alexa and Google Assistant
  • Power Source: Wired power for uninterrupted operation
  • Weatherproof: Designed specifically for outdoor use with IP65 rating
This bundle is perfect for users who want a ready-to-go outdoor security system with local storage and reliable power, all without needing a hub or base station.
Wyze Cam v4 + FREE 32GB MicroSD Card: Value and Convenience
If you want the Wyze Cam v4 with added storage right out of the box, this package includes a free 32GB microSD card: Same 2.5K QHD resolution and color night vision Motion-activated spotlight and person detection Unlimited video length storage on microSD Wi-Fi 6 support and smart home integrations Wired power with outdoor power adapter required Ideal for users who want local storage without cloud fees This option provides excellent value and convenience, ensuring you can start recording locally immediately without purchasing additional accessories.
Wyze Cam v4 Home Security Bundle: Comprehensive Protection
For a more complete home security setup, the Wyze Cam v4 Home Security Bundle offers:
  • Multiple Wyze Cam v4 cameras with 2.5K QHD resolution and enhanced color night vision
  • Improved 2-way audio for clearer communication
  • Indoor and outdoor use with IP65 weather resistance
  • Motion-activated spotlight and person detection for precise alerts
  • 128GB Class 10 UHS-3 microSD card included for extensive local storage (~192 hours of HD video)
  • Multiple mounting options and easy installation without a hub
  • Compatibility with Alexa, Google Assistant, and IFTTT
This bundle is designed for users who want a robust, scalable security system with everything needed for immediate deployment. Family home security lifestyle Wyze Cam v4 securing a family home with easy installation
Summary: No Hub Needed for Wyze Cam v4
Wyze Cam v4 and its bundles operate independently without requiring a base station or hub. They connect directly to your home Wi-Fi network, simplifying setup and reducing costs. Whether you choose the standalone camera, outdoor bundle, or home security bundle, you get powerful features like 2.5K QHD video, color night vision, local storage options, and smart home compatibility — all without extra hardware.
Why Choose Wyze Cam v4?
  • Hassle-Free Setup: No hub or base station needed
  • High-Quality Video: Crisp 2.5K resolution with wide dynamic range
  • Versatile Use: Indoor/outdoor with weather resistance
  • Smart Features: Person detection, motion zones, two-way talk, and siren
  • Flexible Storage: Local microSD and optional cloud plans
  • Smart Home Integration: Alexa, Google Assistant, and IFTTT support
Wyze Cam v4 is a top choice for anyone seeking affordable, reliable, and easy-to-use smart security cameras without the complexity of additional hubs.
FeatureWyze Cam v4Wyze Cam v4 Outdoor BundleWyze Cam v4 + FREE 32GB MicroSD CardWyze Cam v4 Home Security BundleWyze Cam v4
Price (USD)100.0069.9935.98169.99107.94 (1 Pack) / 35.98 (single) / 71.96 (2 Pack)
ResolutionNot specified2.5K QHD2.5K QHD2.5K QHD (2560x1440)2.5K QHD
Color Night VisionNot specifiedEnhanced Color Night VisionYesYesEnhanced Color Night Vision
Motion-Activated SpotlightNot specifiedYesYesYesYes
Local RecordingNot specified24/7 local recording24/7 local recording24/7 local recording24/7 local recording
Wi-Fi SupportNot specifiedWi-Fi 6Wi-Fi 6Wi-Fi 6Wi-Fi 6
Smart Assistant CompatibilityNot specifiedAlexa, Google AssistantAlexa, Google AssistantAlexa, Google AssistantAlexa, Google Assistant
Weather ResistanceNot specifiedNot specifiedIP65IP65Not specified
SensorCMOS Starlight SensorNot specifiedNot specifiedNot specifiedCMOS Starlight Sensor
Field of View115.8° (DFOV), 98.5° (HFOV), 53.1° (VFOV)Not specifiedNot specifiedNot specifiedDFOV 115.8°, HFOV 98.5°, VFOV 53.1°
Body MaterialPolycarbonateNot specifiedNot specifiedNot specifiedPolycarbonate
Lens MaterialGlass, PlasticNot specifiedNot specifiedNot specifiedGlass + Plastic
Audio QualityNot specifiedNot specifiedNot specifiedImproved 2-way audioNot specified
Indoor/Outdoor UseNot specifiedNot specifiedNot specifiedIndoor/OutdoorNot specified
Variants ColorsWhite, GreyBlack, Grey, WhiteBlack, Grey, WhiteNot specifiedBlack, Clear, Grey, White
Packs AvailableSingle onlySingle onlySingle onlySingle only1 Pack, 2 Pack, 3 Pack
Does Wyze Cam v4 require a base station or hub?No, Wyze Cam v4 does not require a base station or hub. It connects directly to your Wi-Fi network (supports both 2.4 GHz Wi-Fi and Wi-Fi 6), making setup simple and flexible without the need for additional hardware.
How does Wyze Cam v4 connect to the internet?Wyze Cam v4 connects directly to your home Wi-Fi network, supporting both 2.4 GHz Wi-Fi and Wi-Fi 6 for a fast and reliable connection. No hub or base station is needed.
Is Wyze Cam v4 suitable for outdoor use?Yes, Wyze Cam v4 is rated IP65 for weather resistance, making it suitable for both indoor and outdoor use. It is designed to withstand various weather conditions.
What video quality does Wyze Cam v4 offer?Wyze Cam v4 provides crystal-clear 2.5K QHD (2560x1440) resolution with 8x digital zoom, ensuring high-quality video footage for your security needs.
Does Wyze Cam v4 support night vision?Yes, Wyze Cam v4 features 4 IR LEDs and 2 white spotlight LEDs for enhanced color night vision, allowing you to see clearly even in low-light conditions.
What storage options are available for Wyze Cam v4?Wyze Cam v4 supports local storage with microSD cards up to 512GB and also offers cloud storage options with a subscription. Some bundles include a microSD card for immediate local recording.
Is Wyze Cam v4 compatible with smart home devices?Yes, Wyze Cam v4 works with Alexa, Google Assistant, and IFTTT, allowing for seamless integration with your smart home ecosystem.
What mounting options are available for Wyze Cam v4?Wyze Cam v4 offers versatile mounting options, including stand, wall mount, ceiling mount, and magnetic adhesive mount, making it easy to install in various locations.
What is included in the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle includes the Wyze Cam v4, a Wyze Outdoor Power Adapter, and a 128GB Wyze MicroSD Card. It is designed for enhanced outdoor security with continuous local recording and weatherproof features.
Does Wyze Cam v4 offer two-way audio?Yes, Wyze Cam v4 features a waterproof 99dB speaker with two-way talk and a built-in siren, allowing you to communicate and deter intruders remotely.
Can I use Wyze Cam v4 without a cloud subscription?Yes, you can use Wyze Cam v4 with local storage by inserting a microSD card. This allows for continuous or event-based recording without the need for a cloud subscription.
What power source does Wyze Cam v4 use?Wyze Cam v4 is powered via a 6-foot flat micro USB to USB-A cable, and an indoor power adapter is included. For outdoor use, a weatherproof power adapter is available in certain bundles.
What are the key features of the Wyze Cam v4?Can the Wyze Cam v4 be used for both indoor and outdoor security?How does the night vision feature work on the Wyze Cam v4?
