Wyze Cam v4: Wi-Fi 6 Compatible Security Cameras & Bundles
Wyze Cam v4 and Wi-Fi 6 Compatibility: Ultimate Security with Advanced Connectivity
When it comes to home security cameras, Wyze Cam v4 stands out as a top choice, especially for users interested in the latest Wi-Fi 6 technology. Whether you want a single camera or a comprehensive security bundle, Wyze offers multiple options that combine crystal-clear video, smart features, and robust Wi-Fi 6 support for a stronger, more reliable connection.
Wyze Cam v4: Cutting-Edge Features and Wi-Fi 6 Support
Superior Video Quality and Night Vision
Wyze Cam v4 delivers stunning 2.5K Quad High Definition (QHD) video resolution, providing crystal-clear images and videos with rich detail. Thanks to its Wide Dynamic Range (WDR) technology, colors appear vibrant and natural even in challenging lighting conditions. One of the standout features is the Enhanced Color Night Vision, which uses advanced hardware to reveal details in low-light environments that traditional night vision cameras simply cannot capture. This means your home stays protected with vivid, colorful footage even after dark.
Wi-Fi 6 Compatibility for Stronger Connections
Wyze Cam v4 supports Wi-Fi 6, the latest wireless standard that offers faster speeds, better performance in crowded networks, and improved range. This ensures your camera maintains a stable and reliable connection, even at greater distances from your router. To take full advantage of this, a Wi-Fi 6 router is required.
Smart Home Integration and Easy Setup
Setting up the Wyze Cam v4 is hassle-free with Bluetooth® connectivity, eliminating the need for QR code scanning. It also integrates seamlessly with popular smart assistants like Amazon Alexa, Google Assistant, and IFTTT, allowing you to customize your home security experience.
Durable and Weather-Resistant Design
With an IP65 weather resistance rating, Wyze Cam v4 is built to withstand various weather conditions, making it suitable for both indoor and outdoor use. Its compact size and multiple mounting options—including magnetic mounts—make installation flexible and convenient.
Additional Security Features
  • Motion and sound detection with instant alerts to your phone
  • Motion detection zones to focus on specific areas
  • Smoke and CO alarm alerts with automatic video recording
  • Built-in 99 dB siren and motion-activated spotlight for deterrence
  • Continuous 24/7 local recording with microSD card support up to 512 GB (microSD card sold separately)
Wyze Cam v4 in home setting Wyze Cam v4 providing smart home security in a family playroom
Wyze Cam v4 Outdoor Bundle: Ready for All-Weather Protection
What’s Included?
The Wyze Cam v4 Outdoor Bundle is designed for those who want a complete outdoor security solution. It includes:
  • Wyze Cam v4 camera with 2.5K QHD resolution and Enhanced Color Night Vision
  • Wyze Outdoor Power Adapter for reliable outdoor power supply
  • 128GB Wyze MicroSD Card for continuous local recording
Enhanced Outdoor Durability and Features
This bundle leverages the same IP65 weather resistance as the standalone camera, ensuring it performs well in rain, snow, or shine. The motion-activated spotlight and siren add an extra layer of security by deterring intruders and lighting up your property at night.
Wi-Fi 6 Support and Smart Alerts
Like the standalone Wyze Cam v4, the outdoor bundle supports Wi-Fi 6 for a stronger connection and integrates with Alexa and Google Assistant for voice control and automation. Wyze Cam v4 mounted outdoors Wyze Cam v4 mounted outdoors, providing reliable home security
Wyze Cam v4 Home Security Bundle: Comprehensive Protection
For users seeking a more extensive security setup, the Wyze Cam v4 Home Security Bundle offers multiple cameras and accessories to cover indoor and outdoor areas.
Key Specifications
  • 2.5K QHD video resolution with Wide Dynamic Range
  • Enhanced Color Night Vision with 4 IR LEDs and 2 white spotlight LEDs
  • 115.8° diagonal field of view for broad coverage
  • 99 dB built-in siren and advanced two-way audio with noise and echo cancellation
  • Supports microSD cards up to 128GB for local storage
  • IP65 weather resistance for outdoor use
  • Wi-Fi 6 compatibility for improved wireless performance
  • Motion-activated spotlight and person detection for smarter alerts
This bundle is perfect for those who want to monitor multiple areas with high-quality video and smart features, all backed by Wyze’s reliable technology.
Wyze Cam v4 + FREE 32GB MicroSD Card: Great Value with Essential Features
If you want the Wyze Cam v4 with added storage right out of the box, this option includes a free 32GB microSD card, enabling you to start local recording immediately.
Highlights
  • 2.5K QHD resolution with Wide Dynamic Range
  • Enhanced Color Night Vision and motion-activated spotlight
  • Wi-Fi 6 support for a stable connection
  • Smoke and CO alerts with video recording
  • IP65 weather resistance for versatile placement
  • Compatible with Alexa and Google Assistant
This package is ideal for users looking for a cost-effective way to secure their home with the latest Wyze Cam v4 features and local storage included.
Why Choose Wyze Cam v4 with Wi-Fi 6?
Wyze Cam v4 combines advanced video technology, smart home integration, and the latest Wi-Fi 6 connectivity to deliver a security camera that is both powerful and easy to use. Whether you’re securing your home indoors or outdoors, Wyze Cam v4 offers reliable performance, vibrant video quality, and intelligent alerts to keep you informed and protected.
Summary of Wyze Cam v4 Wi-Fi 6 Compatible Products
Product NamePrice (USD)Key FeaturesStorage SupportWeather ResistanceBundle Option
Wyze Cam v4$100.002.5K QHD, Color Night Vision, Wi-Fi 6, SpotlightmicroSD up to 512GBIP65No
Wyze Cam v4 Outdoor Bundle$69.99Outdoor Power Adapter, 128GB microSD, Wi-Fi 6128GB microSD includedIP65Yes
Wyze Cam v4 Home Security Bundle$169.99Multiple cams, Person Detection, Spotlight, Wi-Fi 6128GB microSD maxIP65Yes
Wyze Cam v4 + FREE 32GB microSD$35.98Free microSD, Wi-Fi 6, Color Night Vision32GB microSD includedIP65No
By choosing any Wyze Cam v4 product, you ensure your home security system is future-proofed with Wi-Fi 6 compatibility, delivering faster, more reliable connections and enhanced smart features.
Outdoor security lifestyle Wyze Cam v4 Outdoor Bundle securing your home day and night
FeatureWyze Cam v4Wyze Cam v4 Outdoor BundleWyze Cam v4 Home Security BundleWyze Cam v4 + FREE 32GB MicroSD Card
Price$100.00$69.99$169.99$35.98
Resolution2.5K QHD (2560x1440)2.5K QHD (2560x1440)2.5K QHD (2560x1440)2.5K QHD
Color Night VisionYesYesYesYes
Night Vision Type4 IR LEDs + 2 white spotlight LEDs4 IR LEDs + 2 white spotlight LEDs4 IR LEDs + 2 white spotlight LEDsYes
Weather ResistanceIP65IP65IP65IP65
Motion-Activated SpotlightYesYesYesYes
AudioEnhanced Two-Way Talk, 99dB SirenEnhanced Two-Way Talk, 99dB SirenImproved 2-way audio, 99dB SirenEnhanced Two-Way Talk
Wi-Fi Support2.4 GHz Wi-Fi, Wi-Fi 6Wi-Fi 6Wi-Fi 6Wi-Fi 6
Local Storage SupportmicroSD card up to 512 GB128GB microSD Card included128GB microSD Card includedRequires microSD card (included 32GB)
Continuous RecordingYesYesYesYes
Motion & Sound DetectionYesYesYesYes
Smart Detection (Subscription)AvailableAvailableAvailableAvailable
Person DetectionYesYesYesYes
Smoke & CO AlertsYesYesYesYes
Field of View (DFOV x HFOV x VFOV)115.8° x 98.5° x 53.1°115.9° x 98.5° x 53.1°115.8° x 98.5° x 53.1°Not specified
Mounting OptionsStand, Wall, Ceiling, MagneticStand, Wall, Ceiling, MagneticStand, Wall, Ceiling, MagneticNot specified
Power Adapter IncludedIndoor 5V/1AWyze Outdoor Power Adapter includedIncluded (5V/1A adapter)Requires Outdoor Power Adapter
Bluetooth Version5.2Not specifiedNot specifiedNot specified
Video FPS (Day/Night)20 FPS / 15 FPSNot specified20 FPS / 15 FPSNot specified
Digital Zoom8xNot specified8xNot specified
Warranty1 Year1 Year1 YearNot specified
Included ItemsCamera onlyCamera, Outdoor Power Adapter, 128GB microSD CardCamera, 128GB microSD Card, Power AdapterCamera, Free 32GB microSD Card
Is Wyze Cam v4 compatible with Wi-Fi 6 networks?Yes, Wyze Cam v4 fully supports Wi-Fi 6, the latest wireless standard. This ensures faster speeds, improved performance in crowded networks, and a more reliable connection. To take full advantage of Wi-Fi 6, you will need a Wi-Fi 6 compatible router.
What video quality does Wyze Cam v4 offer?Wyze Cam v4 delivers 2.5K Quad High Definition (QHD) video resolution, providing crystal-clear images and videos with rich detail. It also features Wide Dynamic Range (WDR) technology for vibrant and natural colors in various lighting conditions.
Does Wyze Cam v4 have color night vision?Yes, Wyze Cam v4 features Enhanced Color Night Vision, allowing you to see vivid, colorful footage even in low-light environments. This advanced hardware reveals details that traditional night vision cameras may miss.
Can Wyze Cam v4 be used outdoors?Absolutely. Wyze Cam v4 has an IP65 weather resistance rating, making it suitable for both indoor and outdoor use. It is designed to withstand rain, snow, and other challenging weather conditions.
What smart home platforms does Wyze Cam v4 work with?Wyze Cam v4 integrates seamlessly with popular smart home platforms, including Amazon Alexa, Google Assistant, and IFTTT. This allows for voice control and automation within your smart home ecosystem.
How easy is it to set up Wyze Cam v4?Setting up Wyze Cam v4 is quick and hassle-free thanks to Bluetooth® connectivity, which eliminates the need for QR code scanning. The camera also offers flexible installation options, including magnetic mounts.
What storage options are available for Wyze Cam v4?Wyze Cam v4 supports local storage via microSD cards. The standalone camera supports up to 512GB, while bundle options may include 32GB or 128GB microSD cards. Continuous 24/7 local recording is available when a microSD card is installed.
What security features does Wyze Cam v4 offer?Wyze Cam v4 includes motion and sound detection with instant alerts, customizable motion detection zones, smoke and CO alarm alerts with automatic video recording, a built-in 99 dB siren, and a motion-activated spotlight for added deterrence.
What is included in the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle includes a Wyze Cam v4 camera with 2.5K QHD resolution and Enhanced Color Night Vision, a Wyze Outdoor Power Adapter for reliable outdoor power, and a 128GB Wyze MicroSD Card for continuous local recording.
What is the difference between the Wyze Cam v4 Home Security Bundle and the standalone camera?The Wyze Cam v4 Home Security Bundle includes multiple cameras and accessories for comprehensive indoor and outdoor coverage, person detection, and advanced features like motion-activated spotlights. The standalone camera is ideal for single-area monitoring.
Does Wyze Cam v4 support continuous recording?Yes, Wyze Cam v4 supports continuous 24/7 local recording when a microSD card is installed. The camera can record and store footage locally for later review.
What is the field of view for Wyze Cam v4?Wyze Cam v4 offers a 115.8° diagonal field of view, providing broad coverage for monitoring large areas both indoors and outdoors.
Does Wyze Cam v4 have two-way audio?Yes, Wyze Cam v4 features advanced two-way audio with noise and echo cancellation, allowing you to communicate clearly through the camera.
Are there bundle options available for Wyze Cam v4?Yes, Wyze offers several bundle options for Wyze Cam v4, including the Outdoor Bundle, Home Security Bundle, and a package with a free 32GB microSD card. Each bundle is designed to meet different security needs and budgets.
What is the price range for Wyze Cam v4 products?Wyze Cam v4 products range from $35.98 for the camera with a free 32GB microSD card, up to $169.99 for the Home Security Bundle with multiple cameras and accessories.
What are the key features of the Wyze Cam v4?Can the Wyze Cam v4 be used outdoors?Are there any ongoing sales or discounts for the Wyze Cam v4?
