Premium Protection Bundles in Matte Black and Satin Nickel
Looking for a premium protection bundle in sleek matte black or elegant satin nickel finishes? Wyze offers smart home security bundles designed to provide comprehensive protection with style and convenience. Whether you want to secure your front porch or your entire property, these bundles combine advanced cameras, smart locks, and easy installation options to keep your home safe and connected.
The Front Porch Security Bundle: Matte Black Elegance
Overview
The Front Porch Security Bundle is the ultimate smart home solution for securing your entryway. Available with the Wyze Lock Bolt in matte black, this bundle offers a seamless combination of video doorbell and smart lock technology.
Key Features
- 1080p HD Video Doorbell: View your front porch in crisp 1080p HD with a wide 120° vertical and 88° horizontal field of view.
- Two-Way Audio: Greet visitors or deter unwanted guests with clear two-way audio featuring noise and echo cancellation.
- Remote Lock/Unlock: Control your Wyze Lock Bolt remotely via the Wyze app, and monitor lock history for added security.
- Weather-Resistant Design: The video doorbell is IP65 rated, built to withstand outdoor conditions.
- Smart Home Integration: Compatible with Alexa and Google Assistant for voice control convenience.
Style and Finish
- The Wyze Lock Bolt comes in a sophisticated matte black finish, perfectly complementing modern home aesthetics.
- The bundle includes the Wyze Video Doorbell and Chime, providing a complete front porch security solution.
"Meet the ultimate smart home front porch security bundle. With Wyze Video Doorbell and Chime, view your front porch in 1080p HD and say hello with two-way audio. With Wyze Lock, unlock and lock the door remotely and view your lock history in the Wyze app."
Wyze Cam Floodlight Pro + Plug-In Mount: Matte Black or Satin Nickel Options
Overview
For professional-grade yard security, the Wyze Cam Floodlight Pro + Plug-In Mount bundle offers a powerful floodlight camera system with easy plug-and-play installation—no junction box required.
Key Features
- 2K HD Resolution: Capture clear, detailed video with color night vision.
- 180° Field of View: Wide coverage to eliminate blind spots around your property.
- 3000-Lumen LEDs: Three adjustable light panels provide bright illumination to deter intruders.
- Dual-Band Wi-Fi: Connects seamlessly to 2.4 GHz and 5.0 GHz networks.
- Plug-In Mount: Flexible power solution with a 20ft cable and no need for electricians or complex installation.
Color Variants
- Available in Matte Black and White for both the floodlight and plug-in mount, allowing you to match your home’s exterior style.
- Satin nickel is not explicitly listed but the black and white options provide versatile choices for modern and classic looks.
Ultimate Security Bundle (13-piece): Comprehensive Home Protection
Overview
The Ultimate Security Bundle is a complete smart home security system designed to protect every corner of your property, inside and out. While the lock included is in silver, this bundle offers unmatched security features and smart connectivity.
Included Devices
- Wyze Cam Duo Doorbell: Dual cameras for full head-to-toe and front porch visibility with two-way audio.
- Wyze Lock Bolt: Fast fingerprint reader and illuminated keypad (silver finish).
- Multiple Cameras: Includes 2× Wyze Cam Pan v3, 2× Wyze Cam v4, and 2× Wyze Battery Cam Pro for versatile indoor and outdoor coverage.
- Sensors and Hub: Motion sensor, entry sensors, and Wyze Sense Hub for instant alerts and monitoring.
Features
- Smart alerts and motion tracking with color night vision.
- Wire-free and plug-in cameras for flexible placement.
- Centralized control through the Wyze app for easy management.
"The best smart home security system, designed to protect every corner of your property—inside and out. This powerful package combines intelligent cameras, advanced entry protection, and seamless connectivity for unmatched peace of mind."
Why Choose Wyze Premium Protection Bundles?
- Stylish Finishes: Matte black options provide a modern, sleek look that blends seamlessly with your home’s exterior.
- Easy Installation: Plug-in mounts and wireless connectivity reduce installation hassle and cost.
- Smart Integration: Compatible with popular voice assistants and fitness or home apps.
- Comprehensive Security: From front porch monitoring to full property coverage, Wyze bundles offer scalable solutions.
- Trusted Technology: High-resolution cameras, advanced sensors, and smart locks ensure your home stays safe.
Summary of Available Bundles in Matte Black or Satin Nickel
Bundle Name | Matte Black Available | Satin Nickel Available | Key Components |
Front Porch Security Bundle | Yes (Wyze Lock Bolt) | No | Video Doorbell, Lock Bolt, Chime |
Wyze Cam Floodlight Pro Bundle | Yes | No (White or Black) | Floodlight Camera, Plug-In Mount |
Ultimate Security Bundle | No (Silver Lock) | No | Multiple Cameras, Lock Bolt (Silver) |
Conclusion
For premium protection bundles in matte black, the
Front Porch Security Bundle and
Wyze Cam Floodlight Pro + Plug-In Mount are your best choices, combining style, convenience, and advanced security features. While satin nickel is not explicitly offered, the available finishes provide elegant options to suit your home’s design. Choose Wyze for smart, reliable, and stylish home security solutions.
What Wyze premium protection bundles are available in matte black?
Wyze offers the Front Porch Security Bundle and the Wyze Cam Floodlight Pro + Plug-In Mount in a sleek matte black finish. These bundles combine advanced security features with modern style to protect your home.Does Wyze offer premium protection bundles in satin nickel?
Currently, Wyze does not offer premium protection bundles in satin nickel. The main color options available are matte black, white, and silver (for some lock components).What is included in the Wyze Front Porch Security Bundle?
The Wyze Front Porch Security Bundle includes a Wyze Lock Bolt in matte black, a Wyze Video Doorbell, and a Chime. This bundle provides 1080p HD video, two-way audio, remote lock/unlock via the Wyze app, and smart home integration.What are the key features of the Wyze Cam Floodlight Pro + Plug-In Mount bundle?
The Wyze Cam Floodlight Pro + Plug-In Mount bundle features 2K HD resolution, color night vision, a 180° field of view, 3000-lumen adjustable LEDs, dual-band Wi-Fi, and a plug-in mount for easy installation without a junction box. It is available in matte black and white.Is the Wyze Ultimate Security Bundle available in matte black or satin nickel?
The Wyze Ultimate Security Bundle is not available in matte black or satin nickel. The included Wyze Lock Bolt comes in a silver finish, and the bundle focuses on comprehensive home protection with multiple cameras and sensors.Are Wyze security bundles easy to install?
Yes, Wyze security bundles are designed for easy installation. Many products feature plug-in mounts, wireless connectivity, and do not require professional installation or complex wiring.Do Wyze premium protection bundles work with Alexa or Google Assistant?
Yes, Wyze premium protection bundles are compatible with popular voice assistants like Alexa and Google Assistant, allowing for convenient voice control and smart home integration.What makes Wyze premium protection bundles a good choice for home security?
Wyze premium protection bundles offer high-resolution cameras, advanced sensors, smart locks, stylish finishes, easy installation, and seamless smart home integration, providing comprehensive and reliable home security.Can I monitor and control Wyze security devices remotely?
Yes, you can monitor and control Wyze security devices remotely using the Wyze app. Features include live video streaming, remote lock/unlock, and viewing lock history for added security.Which Wyze bundle is best for front porch security?
The Wyze Front Porch Security Bundle is the best choice for front porch security. It includes a 1080p HD video doorbell, two-way audio, a matte black Wyze Lock Bolt, and a chime for comprehensive entryway protection.
