Buy Refurbished Wyze Air Purifier with Smart Controls for Remodeling
Where to Buy a Refurbished Wyze Air Purifier with Smart Controls for Remodeling
If you're remodeling your home and want to ensure the air quality is top-notch, a Wyze Air Purifier is an excellent choice. Especially if you are looking for a refurbished model with smart controls, Wyze offers a reliable, affordable, and feature-packed option that fits perfectly into any modern smart home setup.
Refurbished Wyze Air Purifier: Affordable Smart Air Quality Solution
Premium Features at a Great Price
The (Refurbished) Wyze Air Purifier is a smart, connected home device designed to clear the air efficiently and quietly. It comes with:
  • 350 CADR (Clean Air Delivery Rate) for effective purification in rooms up to 550 sq. ft.
  • Whisper-quiet operation at just 21 decibels, perfect for living rooms, bedrooms, or home offices.
  • Smart controls compatible with Google Home and Alexa, allowing you to monitor and control air quality remotely.
  • Laser particle detection with high accuracy (0.3 microns) and real-time air quality alerts.
  • Pre-installed filter options including Allergen, Formaldehyde, or Wildfire filters tailored to your specific needs.
  • Recommended filter replacement every 6 months to maintain optimal performance.
  • Certified by CARB for safety and environmental standards.
Why Choose Refurbished?
Buying refurbished means you get the same trusted Wyze Air Purifier technology at a reduced price of $139.99 USD, making it a budget-friendly option during your remodeling project without compromising on quality or smart features.
"A luxury air purifier without a luxury price tag."
Wyze Air Purifier in Kitchen Enhance your home's air quality during remodeling with Wyze Air Purifier.
Wyze Air Purifier: Brand New with Advanced Smart Controls
If you prefer a brand-new unit, the Wyze Air Purifier offers the same powerful features with a choice of three premium filters:
  • Allergen Filter (Standard) – Ideal for everyday dust, pollen, and pet dander.
  • Formaldehyde Filter (Premium) – Perfect for newly remodeled homes to combat off-gassing from paints and building materials.
  • Wildfire Filter (Special Use) – Designed for areas affected by smoke and wildfire particles.
Key Specifications
  • Dimensions: 9.5" x 9.4" x 18.5"
  • Weight: Approximately 8.75 to 9.32 lbs depending on filter type.
  • Noise Levels: Ranges from <20.8 dBA on low to <52.1 dBA on high.
  • Power: 120V/60 Hz, energy-efficient 3.5 to 45W.
  • Smart Home Compatibility: Works seamlessly with Alexa and Google Home.
  • Air Quality Measurement: 100 times per second for real-time updates.
Prices range from $169.99 to $194.99 USD depending on the filter variant.
Customize Your Air with Wyze Air Filters and Subscription
Wyze Air Filter Options
To maintain clean air tailored to your environment, Wyze offers a variety of replacement filters compatible with both new and refurbished purifiers:
  • Allergen Filter – HEPA 13 with activated carbon, excellent for allergens.
  • Formaldehyde Filter – HEPA 12 with MnO2 and activated carbon, targeting chemical gases.
  • Wildfire Filter – HEPA 12 with activated carbon, optimized for smoke and wildfire particles.
Each filter offers high TVOC removal efficiency (up to 98.9%) and virus/bacteria filtration efficiency of 99%.
Convenient Filter Subscription
Never worry about forgetting to replace your filter with the Wyze Air Filter Subscription service. Choose your filter type and receive replacements on a schedule that fits your needs, ensuring your air purifier always performs at its best.
Why Wyze Air Purifier is Perfect for Remodeling Projects
Remodeling often introduces dust, chemical fumes, and allergens into your home environment. The Wyze Air Purifier, especially the refurbished model with smart controls, offers:
  • Real-time air quality monitoring to keep you informed.
  • Smart alerts to notify you when air quality drops or filters need replacement.
  • Quiet operation so it won’t disturb your daily activities or relaxation.
  • Affordable pricing that fits remodeling budgets.
  • Multiple filter options to target specific pollutants common in remodeling environments.
Summary
For those remodeling their homes and seeking a smart, efficient, and affordable air purifier, the (Refurbished) Wyze Air Purifier is a top choice. It combines premium filtration, smart home integration, and whisper-quiet operation at a budget-friendly price. Complement it with Wyze’s customizable filters and subscription service to maintain fresh, clean air effortlessly.
Related Products (Not directly related to air purifiers but part of Wyze smart home ecosystem)
  • Wyze Cam v2 (Refurbished) – Affordable home security camera with 1080p HD, night vision, and Alexa/Google Assistant compatibility.
  • Wyze Scale Ultra – Smart scale for health tracking with Wi-Fi connectivity and detailed body composition metrics.
Feature(Refurbished) Wyze Air PurifierWyze Air PurifierWyze Air FilterWyze Air Filter Subscription
TypeRefurbishedConnected HomeConnected Home (Accessory)Hardware Subscription
Price$139.99$169.99 - $194.99$37.99 - $63.99$37.99 - $63.99
Variants (Pre-installed filter)Any FilterAllergen Filter (Standard), Formaldehyde Filter (Premium), Wildfire Filter (Special Use)Allergen Filter (Standard), Formaldehyde Filter (Premium), Wildfire Filter (Special Use)Allergen Filter, Formaldehyde Filter, Wildfire Filter
CADR (Clean Air Delivery Rate)350 CADR350 CADR (12,000 cu ft/hr)214 - 186 CFM (varies by filter type)214 - 186 CFM (varies by filter type)
Noise Level21 decibels (whisper-quiet)21 - 54 decibelsN/AN/A
Filter TypePremium filtersTrue HEPA + Activated Carbon (varies by filter)Pre-filter + True HEPA 12/13 + Activated CarbonPre-filter + True HEPA 12/13 + Activated Carbon
Smart Controls & FeaturesSmart controls, AQ alerts, laser particle detectionSmart controls, AQ alerts, laser particle detection, Alexa & Google Home compatibleN/AN/A
Filter Service LifeN/AN/A4-12 months (varies by filter)4-12 months (varies by filter)
WeightNot specifiedNot specified1.5 - 1.9 lb (varies by filter)1.5 - 1.9 lb (varies by filter)
DimensionsNot specified8.1" x 8.1" x 11.3"8.1" x 8.1" x 11.3"8.1" x 8.1" x 11.3"
Return PolicyFinal Sale, No returns30-day hassle-free returnsProducts of No ReturnProducts of No Return
Additional NotesLuxury air purifier without luxury price tagAuto Mode, child lock, app control, hyper-local AQ dataCustomize air filtration to specific needsReplacement filters for Wyze Air Purifier
Where can I buy a refurbished Wyze Air Purifier with smart controls?You can purchase a refurbished Wyze Air Purifier with smart controls directly from the official Wyze website. Refurbished models offer the same trusted technology and features as new units, but at a reduced price, making them an affordable choice for home remodeling projects.
What are the key features of the refurbished Wyze Air Purifier?The refurbished Wyze Air Purifier features a 350 CADR for effective air purification in rooms up to 550 sq. ft., whisper-quiet operation at just 21 decibels, smart controls compatible with Google Home and Alexa, laser particle detection for real-time air quality alerts, and a choice of pre-installed filters including Allergen, Formaldehyde, or Wildfire filters.
How much does a refurbished Wyze Air Purifier cost?A refurbished Wyze Air Purifier is available for $139.99 USD, offering a budget-friendly solution for those looking to improve air quality during home remodeling without compromising on smart features or performance.
What types of filters are available for the Wyze Air Purifier?Wyze offers three types of filters for their air purifiers: the Allergen Filter (HEPA 13 with activated carbon), the Formaldehyde Filter (HEPA 12 with MnO2 and activated carbon), and the Wildfire Filter (HEPA 12 with activated carbon). Each filter targets specific pollutants such as allergens, chemical gases, or smoke particles.
How often should I replace the filter in my Wyze Air Purifier?It is recommended to replace the filter in your Wyze Air Purifier every 6 months to maintain optimal air purification performance. Wyze also offers a convenient filter subscription service to ensure you never miss a replacement.
Is the Wyze Air Purifier compatible with smart home systems?Yes, the Wyze Air Purifier is compatible with both Google Home and Alexa, allowing you to monitor and control your air quality remotely using smart controls.
What makes the Wyze Air Purifier ideal for home remodeling projects?The Wyze Air Purifier is perfect for remodeling projects because it provides real-time air quality monitoring, smart alerts for air quality and filter replacement, quiet operation, affordable pricing, and multiple filter options to target dust, chemical fumes, and allergens commonly introduced during remodeling.
What is the difference between the refurbished and brand new Wyze Air Purifier?Both refurbished and brand new Wyze Air Purifiers offer the same powerful features, including smart controls and advanced filtration. The main difference is the price, with refurbished units being more affordable. Brand new units may offer a wider range of filter options and come at a higher price point.
How does the Wyze Air Filter Subscription work?The Wyze Air Filter Subscription allows you to choose your preferred filter type and receive automatic replacements on a schedule that fits your needs. This ensures your air purifier always operates at peak performance and you never forget to replace your filter.
What are the specifications of the Wyze Air Purifier?The Wyze Air Purifier measures 9.5" x 9.4" x 18.5", weighs between 8.75 and 9.32 lbs depending on the filter, operates at noise levels from <20.8 dBA (low) to <52.1 dBA (high), and uses 120V/60 Hz power with energy consumption between 3.5 and 45W. It also measures air quality 100 times per second for real-time updates.
What are the benefits of using a refurbished Wyze Air Purifier compared to a brand new one?Can you explain how the smart controls work with the Wyze Air Purifier?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Air Purifier?
