Best Refurbished Air Purifier for Allergen & VOC Removal
Best Refurbished Air Purifier for Allergen and VOC Removal
When it comes to maintaining a healthy indoor environment, especially for those sensitive to allergens and volatile organic compounds (VOCs), choosing the right air purifier is essential. Refurbished air purifiers offer an affordable yet reliable solution without compromising on performance. Among the top choices, the Wyze Air Purifier (Refurbished) stands out as a smart, efficient, and budget-friendly option designed to tackle allergens and VOCs effectively.
Wyze Air Purifier (Refurbished) – Affordable Excellence in Air Quality
Powerful Filtration for Allergens and VOCs
The refurbished Wyze Air Purifier is equipped with premium filters capable of removing allergens, formaldehyde, and wildfire smoke particles. It delivers a Clean Air Delivery Rate (CADR) of 350 m³/h, making it highly effective for rooms up to 550 sq. ft. This makes it ideal for bedrooms, living rooms, or home offices where clean air is a priority.
Smart Features for Modern Living
This model includes smart controls, air quality (AQ) alerts, and laser particle detection with 0.3-micron accuracy, ensuring you always know the air quality status in real-time. Compatible with Google Home and Alexa, it integrates seamlessly into your smart home ecosystem.
Quiet and Energy Efficient
Operating at just 21 decibels on its lowest setting, the Wyze Air Purifier runs whisper-quiet, perfect for nighttime use without disturbing your sleep. It consumes between 3.5 to 45 watts, balancing performance with energy efficiency.
"A luxury air purifier without a luxury price tag."
Specifications at a Glance
  • CADR: 350 m³/h (Allergen filter)
  • Room Coverage: Up to 550 sq. ft
  • Noise Level: 21 dBA (lowest setting)
  • Filter Life: 6 months recommended replacement
  • Smart Home Compatibility: Google Home, Alexa
  • Dimensions: 9.5" x 9.4" x 18.5"
  • Weight: Approx. 8.75 lbs (allergen filter)
Wyze Air Purifier – New Model with Customizable Filters
Tailor Your Air Quality Needs
The Wyze Air Purifier also offers a range of customizable filters designed to target specific air quality concerns:
  • Allergen Filter (Standard): Captures dust, pollen, and pet dander.
  • Formaldehyde Filter (Premium): Targets VOCs like formaldehyde, common in new furniture and building materials.
  • Wildfire Filter (Special Use): Designed for smoke and wildfire-related particles.
Each filter combines a pre-filter, True HEPA (HEPA 12 or 13 depending on type), and activated carbon to maximize removal efficiency. The formaldehyde filter boasts an impressive 98.9% TVOC removal efficiency.
High CADR and Long Filter Life
Filters provide CADR ratings up to 362 m³/h and service life ranging from 4 to 12 months depending on usage and filter type.
Easy Filter Replacement
Filters are lightweight and easy to replace, ensuring your purifier maintains peak performance without hassle.
Man replacing air purifier filter in home Keep your air purifier performing at its best with easy filter changes.
Why Choose a Refurbished Wyze Air Purifier?
  • Cost-Effective: Get premium air purification at a fraction of the price of new units.
  • Certified Quality: A-grade refurbished units undergo rigorous testing to ensure like-new performance.
  • Sustainability: Choosing refurbished helps reduce electronic waste and supports eco-friendly consumption.
  • Smart Features: Enjoy the same smart controls, AQ alerts, and laser particle detection as new models.
Summary: The Ideal Choice for Allergen and VOC Removal
For those seeking the best refurbished air purifier for allergens and VOC removal, the Wyze Air Purifier (Refurbished) offers unbeatable value, smart technology, and powerful filtration. Paired with customizable Wyze Air Filters, you can tailor your air purification to your specific needs, whether it’s allergens, formaldehyde, or wildfire smoke. Invest in clean, healthy air without breaking the bank—choose Wyze for trusted performance and smart home integration.
Feature(Refurbished) Wyze Air PurifierWyze Air PurifierWyze Air Filter
TypeRefurbishedConnected HomeConnected Home (Accessory)
Price$139.99$169.99 - $194.99 (depending on filter)$37.99 - $63.99 (depending on filter)
Pre-installed Filter OptionsAny FilterAllergen (Standard), Formaldehyde (Premium), Wildfire (Special Use)Allergen (Standard), Formaldehyde (Premium), Wildfire (Special Use)
CADR350 m³/hAllergen: 350 m³/h, Wildfire: 342 m³/h, Formaldehyde: 317 m³/hAllergen: 362 m³/h, Wildfire: 342 m³/h, Formaldehyde: 317 m³/h
Noise Level21 dBLevel 1: <20.8 dBA to Level 4: <52.1 dBANot specified
Room Size CoverageUp to 550 sq. ft (42 m²)450-550 sq. ftNot applicable (filter only)
Filter LifeEvery 6 months6 months4-12 months depending on filter type
Filter TypesAllergen, Formaldehyde, WildfireAllergen, Formaldehyde, WildfireAllergen, Formaldehyde, Wildfire
Filter CompositionNot specifiedNot specifiedPre-filter + True HEPA 13/12 + Activated Carbon (varies by filter)
FeaturesSmart controls, AQ alerts, laser particle detectionSmart controls, AQ alerts, laser particle detectionPre-filter, HEPA 12/13, Activated Carbon
Power SupplyAC 120V / 60 Hz120V/60 Hz, 3.5 to 45WNot applicable (filter only)
CertificationsCARB certifiedNot specifiedNot specified
WeightNot specified8.75 - 9.32 lb (depending on filter)1.5 - 1.9 lb (depending on filter)
DimensionsNot specified9.5" x 9.4" x 18.5" (243 mm x 240 mm x 472 mm)8.1" x 8.1" x 11.3" (205 mm x 205 mm x 286 mm)
Smart Home CompatibilityYesGoogle Home, AlexaNo
Air Quality MeasurementLaser particle detectionLaser particle sensor accuracy 0.3 microns, measures 100 times/secNot applicable
Additional NotesLuxury air purifier without luxury price tagMultiple noise levels and flow ratesCustom filters to target specific pollutants
What makes the Wyze Air Purifier (Refurbished) the best choice for allergen and VOC removal?The Wyze Air Purifier (Refurbished) stands out for its powerful filtration system, capable of removing allergens, formaldehyde, and wildfire smoke particles. With a high Clean Air Delivery Rate (CADR) of 350 m³/h and coverage for rooms up to 550 sq. ft, it effectively targets allergens and volatile organic compounds (VOCs), making it ideal for bedrooms, living rooms, and home offices.
How does the refurbished Wyze Air Purifier compare to a new model?Refurbished Wyze Air Purifiers offer the same smart features, filtration performance, and reliability as new models but at a fraction of the price. Each refurbished unit undergoes rigorous testing to ensure like-new quality, making it a cost-effective and sustainable choice.
What smart features are included with the Wyze Air Purifier (Refurbished)?The Wyze Air Purifier (Refurbished) includes smart controls, real-time air quality alerts, and laser particle detection with 0.3-micron accuracy. It is compatible with Google Home and Alexa, allowing seamless integration into your smart home ecosystem.
How quiet is the Wyze Air Purifier during operation?The Wyze Air Purifier operates at just 21 decibels on its lowest setting, making it whisper-quiet and perfect for nighttime use without disturbing your sleep.
What types of filters are available for the Wyze Air Purifier?Wyze Air Purifiers offer a range of customizable filters: the Allergen Filter (standard) for dust, pollen, and pet dander; the Formaldehyde Filter (premium) for VOCs like formaldehyde; and the Wildfire Filter (special use) for smoke and wildfire-related particles. Each filter combines a pre-filter, True HEPA, and activated carbon for maximum efficiency.
How often should I replace the filter in my Wyze Air Purifier?It is recommended to replace the filter every 6 months for optimal performance. However, filter life can range from 4 to 12 months depending on usage and filter type.
Is it easy to replace the filters in the Wyze Air Purifier?Yes, Wyze Air Purifier filters are lightweight and designed for easy replacement, ensuring your air purifier maintains peak performance with minimal hassle.
What are the energy consumption and room coverage specifications of the Wyze Air Purifier?The Wyze Air Purifier consumes between 3.5 to 45 watts, balancing energy efficiency with performance. It effectively covers rooms up to 550 sq. ft, making it suitable for most living spaces.
Why should I choose a refurbished air purifier over a new one?Choosing a refurbished air purifier is cost-effective, environmentally friendly, and offers certified quality. Refurbished units help reduce electronic waste and provide the same smart features and filtration performance as new models at a lower price.
How effective is the Wyze Air Purifier at removing VOCs and formaldehyde?The Wyze Air Purifier, especially when equipped with the Formaldehyde Filter, is highly effective at removing VOCs, including formaldehyde. The formaldehyde filter boasts a 98.9% total VOC removal efficiency, making it ideal for homes with new furniture or building materials.
What are the smart features included in the Wyze Air Purifier?How does the Wyze Air Purifier compare to other air purifiers in terms of noise level?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Air Purifier?
