Weatherproof Smart Outdoor LED String Lights with Yeelight App
Transform your outdoor space with smart, weatherproof LED lighting that you can control effortlessly using the Yeelight app. Whether you're hosting a backyard soirée, decorating for the holidays, or simply want to enhance your garden ambiance, these smart outdoor lighting solutions offer convenience, durability, and vibrant illumination.
Below, discover the top Wyze smart home products designed to power and illuminate your outdoor areas with seamless app control and weatherproof reliability.
Wyze Plug Outdoor: The Ultimate Weatherproof Smart Plug for Outdoor Lighting
Power your outdoor lights rain or shine with Wyze Plug Outdoor.
Key Features:
- IP64 Weather Resistant: Designed to withstand rain, dust, dirt, and snow, making it perfect for outdoor LED string lights and other garden devices.
- Dual Outlets with Independent Control: Manage two separate devices independently, ideal for controlling multiple light strands or decorations.
- Extended WiFi Range: Up to 300 feet in open space, so you can place your plugs anywhere in your yard without losing connection.
- Energy Monitoring: Track energy consumption and set alerts to optimize power usage.
- 15 AMP Output with Overload Protection: Supports high-power devices like outdoor heaters or pond pumps alongside your lighting.
- Voice and App Control: Compatible with Alexa, Google Assistant, and controlled via the Wyze app for hands-free convenience.
- Scheduling & Automation: Set timers or schedules to automate your outdoor lighting, perfect for evening ambiance or security lighting.
Power up your outdoor LED string lights with confidence, knowing your smart plug is built to handle the elements and keep your garden glowing.
Wyze Bulb White: Weather-Compatible Smart Bulb for Damp Outdoor Locations
Brighten your outdoor spaces with dimmable, weather-compatible smart bulbs.
Why Choose Wyze Bulb White for Outdoor Use?
- Suitable for Damp Locations: Perfect for covered patios, porches, or gazebos where moisture is present but bulbs are sheltered.
- Dimmable Brightness: Adjustable from 30 to 800 lumens, allowing you to set the perfect mood lighting.
- Wide Color Temperature Range: From warm 2700K to cool 6500K light, customize your outdoor ambiance.
- Long Life Expectancy: Up to 25,000 hours of reliable lighting.
- Smart Connectivity: Works with 2.4 GHz WiFi and Bluetooth, controllable via the Wyze app and compatible with Alexa, Google Assistant, and IFTTT.
- Energy Efficient: Only 9.5 watts power consumption.
- Operating Temperature Range: -4°F to 104°F, suitable for most outdoor climates.
Ideal for smart outdoor LED string lights in covered or semi-protected areas, these bulbs bring smart control and energy efficiency to your outdoor lighting setup.
Wyze Bulb Color BR30: Vibrant Color-Changing Smart Bulb for Outdoor Mood Lighting
Features:
- 16 Million Colors: Create stunning outdoor lighting scenes with a full spectrum of colors.
- Dimmable & Custom Scenes: Adjust brightness and set personalized lighting moods for parties or relaxing evenings.
- Suitable for Damp Locations: Safe for outdoor fixtures that are not fully enclosed.
- Voice & App Control: Easily control your bulbs with the Wyze app or voice assistants.
- Long Lifespan: 25,000 hours of use.
- Wide Operating Temperature: -4°F to 104°F, perfect for outdoor environments.
- High Brightness: Up to 950 lumens, bright enough to illuminate patios and decks.
Elevate your outdoor LED string lights with color-changing capabilities that sync with your lifestyle and events.
Why Choose Wyze Smart Outdoor Lighting Solutions?
Wyze smart products integrate seamlessly with your existing smart home ecosystem, offering:
- App Control: Manage all your outdoor lighting from the Wyze app, scheduling on/off times, grouping devices, and monitoring energy usage.
- Voice Commands: Compatible with Alexa and Google Assistant for hands-free control.
- Durability: Weatherproof designs ensure your outdoor lighting stays functional through rain, snow, and dust.
- Energy Efficiency: Smart scheduling and energy monitoring help reduce power consumption.
- Easy Installation: No hub required, just plug in and connect to your WiFi.
With Wyze’s weatherproof smart plugs and bulbs, your outdoor LED string lights become a smart, energy-efficient, and beautiful extension of your home.
Enhance Your Outdoor Ambiance Today
Bring your outdoor spaces to life with smart, weatherproof LED string lights controlled effortlessly via the Yeelight app and Wyze smart devices. Whether you want simple white lighting or vibrant color-changing effects, Wyze offers reliable, durable, and easy-to-use solutions for every outdoor lighting need.
Product Summary
Product | Weatherproof | Control App | Key Feature |
Wyze Plug Outdoor | Yes (IP64) | Wyze App | Dual outlets, energy monitor |
Wyze Bulb White | Suitable for damp locations | Wyze App | Dimmable white light |
Wyze Bulb Color BR30 | Suitable for damp locations | Wyze App | 16 million colors, dimmable |
Feature | Wyze Plug Outdoor | Wyze Bulb White | Wyze Bulb Color BR30 |
Type | Outdoor Smart Plug | Smart LED Bulb (White) | Smart Color-Changing BR30 Bulb |
Price (Starting) | $15.99 (1 Pack) | $23.99 (2 Pack) | $27.98 (2 Pack) |
Size/Pack Options | 1 Pack, 2 Pack | 2 Pack, 4 Pack, 6 Pack | 2 Pack, 4 Pack |
Connectivity | WiFi (2.4 GHz), App Control, Alexa Voice | Bluetooth, WiFi (2.4 GHz), App Control, Alexa/Google Voice | WiFi (2.4 GHz), Bluetooth, App Control, Voice Control |
Weather Resistance | IP64 (Rain, Dust, Snow) | Indoor (No weather rating) | Suitable for Damp Locations |
Power Output | 15 AMP Output with Overload Protection | 9.5W (approx. from 800 lumens) | 11.5W |
Energy Monitoring | Yes | No | No |
Control | App & Voice Control | App & Voice Control | App & Voice Control |
Scheduling & Automation | Yes | Yes | Yes |
Dimmable | N/A | Yes | Yes |
Color Temperature Range | N/A | 2700K - 6500K | 1800K - 6500K |
Lumens | N/A | 800 lumens | 30 - 950 lumens |
Color Options | N/A | White only | 16 million colors |
CRI (Color Rendering Index) | N/A | 90+ | 90+ |
Voice Assistant Integration | Alexa | Alexa, Google Assistant | Alexa, Google Assistant |
App Features | Monitor usage, set schedules, energy alerts | Sleep routines, vacation mode, grouping | Sleep routines, vacation mode, music mode |
Suitable For | Outdoor use (garden lights, inflatables) | Indoor lighting | Indoor recessed lighting fixtures |
WiFi Range | Up to 300 ft (open space) | N/A | N/A |
Outlets | 2 outlets with independent control | N/A | N/A |
Are Wyze smart outdoor LED string lights weatherproof?
Yes, Wyze smart outdoor LED string lights and related products like the Wyze Plug Outdoor are designed to be weatherproof. The Wyze Plug Outdoor features an IP64 weather resistance rating, making it suitable for use in rain, dust, dirt, and snow. Wyze Bulb White and Wyze Bulb Color BR30 are also suitable for damp outdoor locations such as covered patios and porches.How can I control Wyze outdoor LED string lights?
You can control Wyze outdoor LED string lights and other Wyze smart lighting products using the Wyze app. The app allows you to turn lights on or off, set schedules, adjust brightness, and monitor energy usage. Wyze devices are also compatible with Alexa and Google Assistant for convenient voice control.What is the range of the Wyze Plug Outdoor for outdoor lighting?
The Wyze Plug Outdoor offers an extended WiFi range of up to 300 feet in open space, allowing you to place your smart plug anywhere in your yard without losing connection.Can I use Wyze Bulb White and Wyze Bulb Color BR30 outdoors?
Yes, both Wyze Bulb White and Wyze Bulb Color BR30 are suitable for outdoor use in damp locations, such as covered patios, porches, or gazebos. They are not recommended for fully exposed or unprotected outdoor areas.Do Wyze smart outdoor lighting products support energy monitoring?
Yes, the Wyze Plug Outdoor features built-in energy monitoring, allowing you to track energy consumption and set alerts to optimize power usage for your outdoor lighting and other connected devices.Are Wyze outdoor lighting products easy to install?
Yes, Wyze outdoor lighting products are designed for easy installation. No hub is required—simply plug in the device and connect it to your WiFi network using the Wyze app.Can I automate my outdoor lighting with Wyze products?
Absolutely. Wyze smart outdoor lighting products support scheduling and automation through the Wyze app. You can set timers, create schedules, and automate your outdoor lights for convenience, security, and energy efficiency.What are the key features of the Wyze Plug Outdoor?
The Wyze Plug Outdoor offers IP64 weather resistance, dual outlets with independent control, extended WiFi range, energy monitoring, 15 AMP output with overload protection, voice and app control, and scheduling and automation features.What is the lifespan of Wyze smart bulbs for outdoor use?
Both Wyze Bulb White and Wyze Bulb Color BR30 have a long lifespan of up to 25,000 hours, providing reliable and durable lighting for your outdoor spaces.Can I create color-changing outdoor lighting scenes with Wyze bulbs?
Yes, the Wyze Bulb Color BR30 offers 16 million colors and dimmable brightness, allowing you to create vibrant, personalized outdoor lighting scenes for parties, holidays, or relaxing evenings.
Can you tell me more about the features of the Wyze Plug Outdoor?How does the Wyze app control the outdoor lighting?Do you have any ongoing sales or discounts for outdoor lighting products?
