Bluetooth Outdoor LED String Lights for Home Ambiance
Bluetooth Controlled Outdoor LED String Lights for Home Ambiance
Create the perfect outdoor ambiance with smart, Bluetooth-controlled LED lighting solutions designed to elevate your home’s exterior atmosphere. Whether you're hosting a backyard soirée, decorating for the holidays, or simply enjoying a cozy evening under the stars, these smart lighting products offer seamless control, vibrant colors, and energy efficiency to transform your outdoor space.
Wyze Plug Outdoor: Smart Power for Your Outdoor LED Lights
Power your outdoor LED string lights effortlessly with the Wyze Plug Outdoor, a weather-resistant smart plug designed specifically for outdoor use. This device ensures your garden lights, inflatables, and other outdoor decorations are fully controllable from your smartphone or voice assistant, rain or shine.
Key Features:
  • IP64 Weather Resistant: Built to withstand rain, dust, dirt, and snow, making it perfect for outdoor environments.
  • Extended WiFi Range: Up to 300 feet in open space, allowing you to control outlets far from your home.
  • Dual Outlets with Independent Control: Manage two separate devices or light strings independently.
  • Energy Monitoring: Track energy consumption and set alerts to optimize power usage.
  • Voice Control Compatibility: Works seamlessly with Amazon Alexa and Google Assistant for hands-free operation.
  • High Power Output: 15 AMP with overload protection, suitable for powering multiple outdoor lighting setups.
Take full control of your outdoor ambiance with scheduling, remote on/off, and energy monitoring — all from the Wyze app.
Outdoor Evening Ambiance with Smart Lighting
Wyze Bulb Color BR30: Vibrant Color-Changing LED Bulbs for Outdoor Ambiance
Enhance your outdoor ambiance with the Wyze Bulb Color BR30, a dimmable, color-changing smart bulb that fits into standard recessed lighting fixtures. Perfect for patios, porches, or covered outdoor areas, this bulb offers millions of colors to set the mood for any occasion.
Product Highlights:
  • 16 Million Colors: Choose from a vast palette to create the perfect lighting scene.
  • Wide Lumen Range: From 30 to 950 lumens, providing both subtle and bright lighting options.
  • Dimmable & Custom Scenes: Adjust brightness and create personalized lighting moods.
  • Bluetooth & WiFi Connectivity: Control via the Wyze app or voice assistants.
  • Durability: Suitable for damp locations, ideal for covered outdoor spaces.
  • Long Life Expectancy: Up to 25,000 hours of use.
Whether you want a warm, inviting glow or a vibrant party atmosphere, the Wyze Bulb Color BR30 lets you customize your outdoor lighting with ease.
Wyze Light Strip: Brilliant LED Accent Lighting for Outdoor Decor
Add a splash of color and dynamic lighting effects to your outdoor space with the Wyze Light Strip. This LED strip is perfect for accentuating decks, railings, or garden features with vibrant, customizable lighting.
Features at a Glance:
  • 16 Million Colors: Illuminate your outdoor areas with a full spectrum of colors.
  • Cuttable & Adhesive Backing: Easily customize length and mount the strip wherever you want.
  • Music Sync Feature: Lights pulse and change with the beat of your favorite tunes using the built-in microphone.
  • Bluetooth & WiFi Control: Manage your lighting from the Wyze app or with voice commands.
  • Long Operating Temperature Range: Works well in outdoor conditions from -4°F to 122°F.
  • 25,000 Hours Lifespan: Durable and long-lasting LED technology.
Perfect for creating festive or relaxing outdoor environments, the Wyze Light Strip brings your outdoor decor to life with vibrant, customizable lighting.
Outdoor Patio with Colorful LED Light Strip
Why Choose Bluetooth-Controlled Outdoor LED Lighting?
Bluetooth-controlled LED lighting offers several advantages for outdoor home ambiance:
  • Easy Setup & Control: Connect and control your lights directly from your smartphone without complicated hubs.
  • Energy Efficiency: Smart scheduling and energy monitoring help reduce power consumption.
  • Voice Assistant Integration: Hands-free control via Alexa or Google Assistant enhances convenience.
  • Customization: Choose colors, brightness, and lighting scenes to match any mood or event.
  • Weather-Ready Devices: Designed to withstand outdoor elements, ensuring durability and safety.
Enhance Your Outdoor Ambiance with Wyze Smart Home Ecosystem
Pair your outdoor LED lighting with other Wyze smart home devices like the Wyze Plug Outdoor for power control, or the Wyze Switch to convert existing outdoor lights into smart lights controllable from anywhere. Together, these devices create a cohesive, smart outdoor lighting system that’s easy to manage and customize.
Summary of Bluetooth Controlled Outdoor LED Lighting Products
ProductKey BenefitsOutdoor SuitabilityControl Options
Wyze Plug OutdoorWeatherproof, dual outlets, energy monitoringYesApp, Voice (Alexa, Google)
Wyze Bulb Color BR30Color-changing, dimmable, damp location ratedSuitable for covered areasApp, Voice, Bluetooth
Wyze Light StripVibrant colors, music sync, cuttableIndoor use recommended (can be used in protected outdoor areas)App, Voice, Bluetooth
Transform your outdoor space into a smart, vibrant oasis with Bluetooth-controlled LED lighting that’s easy to install, energy-efficient, and fully customizable.
Cozy Outdoor Evening with Smart Lighting
FeatureWyze Plug OutdoorWyze Bulb Color BR30Wyze Light Strip
TypeOutdoor Smart PlugColor-changing Smart Bulb (BR30)LED Accent Light Strip
Usage LocationOutdoor (IP64 Weather Resistant)Indoor (Standard E26 recessed/can fixtures)Indoor Only
ConnectivityWiFi (300 ft range)WiFiWiFi & Bluetooth
Power SourcePlug-in (15 AMP Output)Standard bulb socket (E26 base)Corded Electric (12V adapter)
ControlWyze App, Voice (Alexa)Wyze App, Voice (Alexa, Google Assistant)Wyze App, Voice (Alexa, Google Assistant)
Number of Outlets/Light Zones2 Outlets, independently controlledSingle bulbSingle customizable zone
Color OptionsN/A16 million colors + tunable white16 million colors
BrightnessN/A30 - 950 lumensLumens per meter: Blue 0.8lm, Red 1.0lm, Green 2.5lm per LED
Weather ResistanceIP64 (rain, dust, snow resistant)Not weather resistantNot weather resistant
Scheduling & MonitoringEnergy monitoring, usage alerts, schedulesCustom lighting scenes, routines, notificationsTimers & automations
Special FeaturesOverload protection, voice commandsSun Match, Music Mode, Brilliant notificationsCuttable, adhesive backing, music sync
Sizes/Variants1 Pack ($15.99), 2 Pack ($34.98)2-Pack ($27.98), 4-Pack ($49.98)16.4 ft ($19.99), 32.8 ft ($35.99)
WarrantyNot specified30-day hassle-free returnsNot specified
What are Bluetooth controlled outdoor LED string lights?Bluetooth controlled outdoor LED string lights are smart lighting solutions that allow you to customize and control your outdoor lighting ambiance directly from your smartphone. These lights offer features like vibrant color options, energy efficiency, and seamless integration with smart home devices, making them perfect for patios, gardens, and outdoor gatherings.
How does the Wyze Plug Outdoor enhance outdoor LED lighting?The Wyze Plug Outdoor is a weather-resistant smart plug designed for outdoor use. It allows you to control your outdoor LED string lights, inflatables, and other decorations remotely via the Wyze app or voice assistants like Alexa and Google Assistant. With features like dual independent outlets, energy monitoring, and extended WiFi range, it provides reliable and convenient power management for your outdoor lighting.
Is the Wyze Plug Outdoor weatherproof?Yes, the Wyze Plug Outdoor is IP64 weather resistant, meaning it is built to withstand rain, dust, dirt, and snow. This makes it ideal for powering outdoor LED lights and decorations in various weather conditions.
Can I control Wyze outdoor lighting products with my voice?Yes, Wyze outdoor lighting products such as the Wyze Plug Outdoor, Wyze Bulb Color BR30, and Wyze Light Strip are compatible with Amazon Alexa and Google Assistant, allowing for hands-free voice control.
What are the benefits of using Wyze Bulb Color BR30 for outdoor ambiance?The Wyze Bulb Color BR30 is a smart, color-changing LED bulb that fits standard recessed fixtures, making it perfect for patios, porches, or covered outdoor areas. It offers 16 million colors, adjustable brightness, and is suitable for damp locations. You can control it via Bluetooth, WiFi, or voice assistants, and it has a long lifespan of up to 25,000 hours.
Are Wyze Light Strips suitable for outdoor use?Wyze Light Strips are recommended for indoor use but can be used in protected outdoor areas such as covered patios or under eaves. They offer vibrant, customizable lighting with 16 million colors, music sync features, and easy installation with adhesive backing.
How do I control Wyze outdoor LED lighting products?You can control Wyze outdoor LED lighting products using the Wyze app on your smartphone, via Bluetooth or WiFi. Additionally, these products support voice control through Amazon Alexa and Google Assistant for added convenience.
What are the energy efficiency features of Wyze outdoor lighting products?Wyze outdoor lighting products offer energy monitoring and smart scheduling features, allowing you to track power consumption and set timers to optimize energy use. This helps reduce electricity costs while maintaining your desired outdoor ambiance.
Can I customize the color and brightness of my outdoor LED lights?Yes, both the Wyze Bulb Color BR30 and Wyze Light Strip allow you to choose from 16 million colors and adjust brightness levels. You can also create custom lighting scenes and moods to match any occasion or event.
What is the lifespan of Wyze outdoor LED lighting products?Wyze Bulb Color BR30 and Wyze Light Strip both have a long lifespan of up to 25,000 hours, ensuring durable and reliable performance for your outdoor lighting needs.
Do I need a hub to use Wyze Bluetooth controlled outdoor LED lights?No, Wyze Bluetooth controlled outdoor LED lights do not require a hub. You can connect and control them directly from your smartphone using the Wyze app, making setup quick and easy.
How can I create a smart outdoor lighting system with Wyze products?You can create a smart outdoor lighting system by pairing Wyze LED lighting products with the Wyze Plug Outdoor for power control and the Wyze Switch to convert existing outdoor lights into smart lights. This allows you to manage and customize your entire outdoor lighting setup from anywhere.
What are the key features of the Wyze Plug Outdoor?Can the Wyze Bulb Color BR30 be used in damp locations?Do you have any deals, ongoing sales, discounts, or promotions?
