Smart Controlled Waterproof LED Lights for Patio Lighting Projects
Enhance your outdoor living space with smart, waterproof LED lighting solutions designed to bring convenience, style, and energy efficiency to your patio lighting projects. Whether you're hosting a backyard soirée or simply want to illuminate your outdoor area with ease, these smart lighting products offer seamless control, weather resistance, and vibrant illumination.
Wyze Plug Outdoor: The Ultimate Smart Outdoor Power Solution
Weatherproof and Durable for Outdoor Use
The
Wyze Plug Outdoor is engineered to power your patio lights and other outdoor devices rain or shine. With an IP64 weather rating, this smart plug withstands dust and water splashes, making it perfect for outdoor environments.
Smart Control at Your Fingertips
Control your outdoor lighting from anywhere using the Wyze app. Set schedules, monitor energy usage, and automate your patio lighting effortlessly. The plug supports voice commands via Alexa, adding hands-free convenience to your outdoor lighting setup.
Key Features:
- Dual outlets for powering multiple devices
- Overload protection for safety
- Operating temperature: -4°F to 120°F
- Connectivity: 2.4GHz WiFi and Bluetooth V4.2
- WiFi range: Up to 300 feet
- Compatibility: Android 5.0+ and iOS 9.0+
1-year warranty
Power your outdoor LED lights with confidence, knowing your smart plug is built to handle the elements and keep your patio glowing.
Smart outdoor lighting controlled via app
Wyze Bulb White: Reliable Smart LED Lighting for Damp Outdoor Areas
Bright, Dimmable, and Smart
The
Wyze Bulb White offers a wide brightness range from 30 to 800 lumens with dimmable controls, perfect for creating the ideal ambiance on your patio. Its 230° beam angle ensures broad, even light coverage.
Suitable for Damp Locations
While designed primarily for indoor use, this bulb is rated for damp locations, making it suitable for covered patios or areas protected from direct rain.
Smart Features:
- Color temperature: 2700K (warm) to 6500K (cool)
- Color rendering index: 90+ for natural light quality
- Life expectancy: 25,000 hours
- Voice control: Alexa, Google Assistant, IFTTT
- Operating temperature: -4°F to 104°F
Compatible with Android 9.0+ and iOS 15.0+
Create cozy or vibrant patio lighting scenes with easy app control and voice commands.
Smart white bulbs enhancing outdoor ambiance
Wyze Bulb Color BR30: Vibrant Color-Changing Smart Bulbs for Outdoor Mood Lighting
Transform Your Patio with 16 Million Colors
The
Wyze Bulb Color BR30 is a dimmable, color-changing smart bulb designed for recessed lighting fixtures. It offers an extensive palette of 16 million colors, allowing you to set the perfect mood for any outdoor occasion.
Designed for Damp Environments
This bulb is suitable for damp locations, making it ideal for covered patios and outdoor lighting fixtures that are shielded from direct exposure.
Standout Features:
- Lumen range: 30 to 950 lumens for bright or subtle lighting
- Color temperature: 1800K to 6500K
- Power: 11.5 watts (equivalent to 75W incandescent)
Not compatible with dimmer switches
Elevate your patio lighting with customizable colors and smart automation to match every event or mood.
Why Choose Smart Waterproof LED Lighting for Your Patio?
Smart LED lights designed for outdoor use combine durability with convenience. They allow you to control your patio lighting remotely, schedule on/off times, and even adjust brightness or color to suit your lifestyle. Waterproof and weather-resistant features ensure your lighting withstands the elements, providing reliable performance year-round.
Summary of Smart Patio Lighting Products
Product | Weatherproof | Smart Control | Key Features | Use Case |
Wyze Plug Outdoor | Yes (IP64) | App + Voice | Dual outlets, energy monitoring | Power outdoor lights/devices |
Wyze Bulb White | Damp Rated | App + Voice | Dimmable, wide color temp range | Covered patios, damp areas |
Wyze Bulb Color BR30 | Damp Rated | App + Voice | 16 million colors, dimmable | Mood lighting, recessed fixtures |
Invest in these smart controlled waterproof LED lighting solutions to create a stunning, energy-efficient, and easily manageable patio lighting system that enhances your outdoor living experience.
What are the benefits of using smart controlled waterproof LED lights for patio lighting?
Smart controlled waterproof LED lights offer convenience, energy efficiency, and style for your patio. They allow you to control your outdoor lighting remotely, set schedules, adjust brightness or color, and ensure reliable performance in various weather conditions thanks to their weather-resistant features.Is the Wyze Plug Outdoor suitable for outdoor use?
Yes, the Wyze Plug Outdoor is specifically designed for outdoor environments. It has an IP64 weather rating, making it resistant to dust and water splashes, so you can confidently use it to power patio lights and other outdoor devices rain or shine.How can I control my patio lights with the Wyze Plug Outdoor?
You can control your patio lights connected to the Wyze Plug Outdoor using the Wyze app from anywhere. The plug also supports voice commands via Alexa, allowing for hands-free operation. You can set schedules, monitor energy usage, and automate your lighting easily.What devices are compatible with the Wyze Plug Outdoor?
The Wyze Plug Outdoor is compatible with devices running Android 5.0+ and iOS 9.0+. It connects via 2.4GHz WiFi and Bluetooth V4.2, with a WiFi range of up to 300 feet.Is the Wyze Bulb White suitable for outdoor use?
The Wyze Bulb White is rated for damp locations, making it suitable for covered patios or outdoor areas protected from direct rain. It is not recommended for areas exposed to direct water.What features does the Wyze Bulb White offer for patio lighting?
The Wyze Bulb White offers a brightness range from 30 to 800 lumens, dimmable controls, a wide color temperature range (2700K to 6500K), and a high color rendering index (90+). It can be controlled via app or voice commands (Alexa, Google Assistant, IFTTT) and is rated for 25,000 hours of use.Can I use the Wyze Bulb Color BR30 for outdoor lighting?
Yes, the Wyze Bulb Color BR30 is suitable for damp locations, making it ideal for covered patios and outdoor lighting fixtures that are shielded from direct exposure to rain.What makes the Wyze Bulb Color BR30 ideal for mood lighting on patios?
The Wyze Bulb Color BR30 offers 16 million color options, is dimmable, and has a brightness range from 30 to 950 lumens. It can be controlled via app or voice commands, allowing you to customize your patio lighting to match any event or mood.Are Wyze smart bulbs compatible with voice assistants?
Yes, both the Wyze Bulb White and Wyze Bulb Color BR30 are compatible with Alexa, Google Assistant, and IFTTT, enabling convenient voice control for your patio lighting.What is the life expectancy of Wyze smart bulbs for outdoor use?
Both the Wyze Bulb White and Wyze Bulb Color BR30 have a life expectancy of 25,000 hours, providing long-lasting and reliable lighting for your patio.Can I use Wyze smart bulbs with dimmer switches?
The Wyze Bulb Color BR30 is not compatible with dimmer switches. It is recommended to use the app or voice control features to adjust brightness.What is the operating temperature range for Wyze outdoor lighting products?
The Wyze Plug Outdoor operates between -4°F and 120°F, while the Wyze Bulb White and Wyze Bulb Color BR30 operate between -4°F and 104°F, making them suitable for most outdoor environments.
