100ft Permanent Outdoor LED Lights for Stunning Backyard Decor
100ft Permanent Outdoor LED Lights for Backyard Decor
Transform your backyard into a stunning outdoor oasis with smart, permanent LED lighting solutions designed to enhance ambiance, security, and convenience. Whether you're hosting a backyard soirée or simply want to enjoy a cozy evening outdoors, these Wyze smart lighting products offer versatile, durable, and easy-to-control options perfect for outdoor decor.
Wyze Plug Outdoor: Power Your Backyard Lights Rain or Shine
The Wyze Plug Outdoor is your ultimate companion for permanent outdoor LED lighting setups. Designed specifically for outdoor use, this smart plug lets you control your backyard lights and other outdoor devices effortlessly from anywhere.
Key Features:
  • IP64 Weather Resistant: Built to withstand rain, dust, dirt, and snow, ensuring reliable performance year-round.
  • Extended WiFi Range: Up to 300 feet in open space, so you can place your lights anywhere in your backyard without connectivity issues.
  • Two Outlets with Independent Controls: Manage two separate lighting zones or devices independently for customized backyard lighting.
  • Energy Monitoring: Track energy consumption and set alerts to optimize power usage.
  • Voice and App Control: Compatible with Alexa and Google Assistant for hands-free control, plus full scheduling and automation via the Wyze app.
  • High Output: 15 AMP with overload protection, suitable for powering multiple LED light strands or other outdoor decor.
Make your backyard lighting permanent and smart with the Wyze Plug Outdoor, perfect for 100ft LED string lights or other outdoor lighting fixtures. Backyard party with smart outdoor lighting Enjoy seamless control of your backyard lighting with Wyze Plug Outdoor.
Wyze Bulb White: Bright, Dimmable, and Suitable for Damp Outdoor Locations
Complement your outdoor LED setup with the Wyze Bulb White, a smart, dimmable LED bulb that delivers bright, warm to cool white light perfect for backyard ambiance.
Highlights:
  • Brightness Range: 30 to 800 lumens, adjustable to create the perfect mood.
  • Color Temperature: From cozy 2700K warm white to crisp 6500K daylight.
  • Dimmable: Easily adjust brightness via app or voice commands.
  • Suitable for Damp Locations: Ideal for covered outdoor areas like patios or pergolas.
  • Long Life: 25,000 hours of reliable lighting.
  • Smart Integrations: Works with Alexa, Google Assistant, and IFTTT for voice and automation control.
  • Easy Setup: Connects via 2.4GHz WiFi and Bluetooth for seamless smart home integration.
Use Wyze Bulb White in outdoor fixtures to add permanent, customizable lighting that enhances your backyard decor with smart convenience. Cozy backyard lighting with smart bulbs Create inviting outdoor spaces with Wyze Bulb White smart lighting.
Wyze Light Strip: Vibrant LED Accent Lighting for Outdoor Ambiance
For colorful, eye-catching backyard decor, the Wyze Light Strip offers brilliant LED accent lighting that can be installed permanently along decks, fences, or garden beds.
Features:
  • Length Options: Available in 16.4 ft and 32.8 ft lengths; combine multiple strips to cover up to 100ft with proper planning.
  • 16 Million Colors: Customize your backyard lighting with a full spectrum of colors.
  • Cuttable Design: Trim the strip to fit your exact space requirements.
  • Easy Mounting: Adhesive backing and included clips for secure installation.
  • Music Sync: Built-in microphone lets lights pulse to your favorite tunes.
  • Long Life: 25,000 hours of vibrant illumination.
  • Indoor Use Only: Best for covered or protected outdoor areas like patios or gazebos.
Add dynamic color and permanent LED lighting effects to your backyard with Wyze Light Strip, perfect for creating festive or relaxing atmospheres. Colorful LED accent lighting in outdoor setting Enhance your backyard with vibrant Wyze Light Strip LED lighting.
Why Choose Wyze for Your Backyard LED Lighting?
Wyze offers a comprehensive ecosystem of smart home products that make outdoor lighting permanent, customizable, and easy to control. From weather-resistant smart plugs to dimmable bulbs and colorful LED strips, Wyze products are designed to work seamlessly together, giving you full control over your backyard ambiance.
  • Smart Control Anywhere: Use the Wyze app or voice assistants to schedule, automate, and control your lights remotely.
  • Durability: Outdoor-rated products like Wyze Plug Outdoor ensure your lighting withstands the elements.
  • Energy Efficiency: Monitor and optimize your energy use with smart plugs and LED bulbs.
  • Expandable Ecosystem: Combine with other Wyze devices for enhanced home automation and security.
Summary of Recommended Products for 100ft Permanent Outdoor LED Lighting
ProductOutdoor UseKey BenefitControl Options
Wyze Plug OutdoorYes (IP64)Weatherproof smart plug with dual outlets and energy monitoringApp, Alexa, Google Assistant
Wyze Bulb WhiteDamp areasBright, dimmable white LED bulb for covered outdoor fixturesApp, Alexa, Google Assistant
Wyze Light StripIndoor onlyColorful LED strip for accent lighting with music syncApp control
Create a stunning, permanent LED lighting setup for your backyard with these Wyze smart products, designed to bring convenience, style, and smart automation to your outdoor decor.
FeatureWyze Plug OutdoorWyze Bulb WhiteWyze Light Strip
TypeOutdoor Smart PlugSmart LED Light BulbLED Accent Light Strip
UsageOutdoorIndoorIndoor Only
Size/Length1 Pack, 2 Pack2 Pack, 4 Pack, 6 Pack16.4 ft, 32.8 ft
Price Range$15.99 - $34.98$23.99 - $59.99$19.99 - $35.99
Weather ResistanceIP64 (Rain, dust, dirt, snow resistant)Not specified (Indoor use)No
WiFi RangeUp to 300 ftBluetooth setup, no WiFi range specified802.11 b/g/n 2.4 GHz, Bluetooth
Power SourcePlug-inScrew-in bulbCorded Electric
Output/Power15 AMP Output with Overload Protection800 lumens, 2700K-6500K, dimmable18W (16.4 ft), 36W (32.8 ft)
Color OptionsN/AWhite (tunable color temperature)16 million colors (single color per LED)
ControlWyze app, Alexa voice commandsWyze app, Alexa/Google Assistant voiceWyze app, Bluetooth
Energy MonitoringYesNoNo
Number of Outlets/LEDs2 Outlets, independent controlSingle bulb per pack30 LEDs per meter (RGB)
WeatherproofYesNoNo
Customizable ZonesN/AN/A1
Mounting MethodPlug-inStandard bulb socketAdhesive backing
Special FeaturesEnergy monitoring, scheduling, overload protectionSun Match, Sleep Routines, Vacation ModeMusic sync with built-in microphone
What are the best permanent outdoor LED lights for backyard decor?Wyze offers a range of smart, permanent outdoor LED lighting solutions ideal for backyard decor, including the Wyze Plug Outdoor for powering lights, Wyze Bulb White for bright and dimmable lighting in damp locations, and Wyze Light Strip for vibrant accent lighting. These products are designed for durability, smart control, and easy installation.
Is the Wyze Plug Outdoor weatherproof and suitable for permanent outdoor use?Yes, the Wyze Plug Outdoor is IP64 weather resistant, making it suitable for permanent outdoor use. It is built to withstand rain, dust, dirt, and snow, ensuring reliable performance year-round for your backyard lighting and other outdoor devices.
How can I control my backyard LED lights with Wyze products?You can control your backyard LED lights using the Wyze app on your smartphone or through voice commands with Alexa and Google Assistant. The Wyze Plug Outdoor, Wyze Bulb White, and Wyze Light Strip all support smart scheduling, automation, and remote control for maximum convenience.
Can I use Wyze Bulb White in outdoor fixtures?Wyze Bulb White is suitable for damp outdoor locations, such as covered patios or pergolas. It is not recommended for direct exposure to rain or extreme weather, but it works perfectly in protected outdoor fixtures.
How long do Wyze outdoor LED lights last?Both the Wyze Bulb White and Wyze Light Strip offer a long lifespan of up to 25,000 hours, providing reliable and energy-efficient lighting for your backyard decor.
Can I create colorful accent lighting outdoors with Wyze Light Strip?Yes, the Wyze Light Strip offers 16 million colors and can be installed in covered or protected outdoor areas like patios or gazebos. It is designed for indoor use but can be used outdoors if protected from direct exposure to the elements.
How many Wyze Light Strips do I need to cover 100ft?Wyze Light Strips are available in 16.4 ft and 32.8 ft lengths. You can combine multiple strips to cover up to 100ft, ensuring you plan your installation to fit your space requirements.
Does the Wyze Plug Outdoor support energy monitoring?Yes, the Wyze Plug Outdoor features energy monitoring, allowing you to track energy consumption and set alerts to optimize power usage for your backyard lighting and other outdoor devices.
Are Wyze outdoor lighting products compatible with smart home systems?Wyze outdoor lighting products, including the Wyze Plug Outdoor and Wyze Bulb White, are compatible with Alexa, Google Assistant, and IFTTT, making them easy to integrate into your existing smart home ecosystem.
What are the benefits of using Wyze smart products for backyard LED lighting?Wyze smart products offer smart control from anywhere, weather-resistant durability, energy efficiency, and an expandable ecosystem. You can automate, schedule, and customize your backyard lighting for ambiance, security, and convenience.
What are the key features of the Wyze Plug Outdoor for controlling backyard lights?Can the Wyze Bulb White be used in damp outdoor locations?Do you have any deals, ongoing sales, discounts, or promotions for outdoor lighting products?
