100ft Smart Outdoor LED String Lights with Weather Resistant Design
Enhance your outdoor living space with smart lighting solutions that combine convenience, durability, and advanced technology. Whether you're hosting a backyard party or illuminating your garden path, having weather-resistant smart outdoor LED string lights ensures your space stays bright and beautiful rain or shine. Below, discover the perfect smart outdoor companion products designed to power and control your 100ft LED string lights with ease and reliability.
Wyze Plug Outdoor: The Ultimate Weather-Resistant Smart Plug for Outdoor Lighting
Designed for All-Weather Use
The
Wyze Plug Outdoor is built to withstand the elements with an
IP64 weather-resistant rating, making it ideal for powering your 100ft smart outdoor LED string lights. Whether it's rain, dust, snow, or dirt, this plug keeps your lights running smoothly without worry.
Extended WiFi Range for Flexible Placement
With a
long-range WiFi capability of up to 300 feet in open spaces, you can place your smart plug almost anywhere outdoors. This extended range ensures seamless connectivity and control, even if your router is inside the house.
Dual Outlets with Independent Control
Featuring
two separate outlets, the Wyze Plug Outdoor allows you to control different lighting zones or devices independently. For example, turn off your string lights while keeping other decorations powered on, all from the Wyze app or via voice commands.
Smart Features for Effortless Control
- Energy Monitoring: Track your outdoor lighting energy consumption to optimize usage and save on electricity bills.
- App & Voice Control: Use the Wyze app or voice assistants like Alexa to turn your lights on or off without stepping outside.
- 15 AMP Output with Overload Protection: Safely power high-demand devices like roof de-icers or pond pumps alongside your LED string lights.
Power your outdoor LED string lights with confidence, knowing your smart plug is designed for durability and smart automation.
Enjoy seamless outdoor lighting control with Wyze Plug Outdoor.
Wyze Plug: Smart Indoor Plug for Complementary Lighting Control
Perfect for Indoor Use and Protected Outdoor Areas
While the
Wyze Plug is designed for
indoor use only, it offers excellent smart control for your indoor LED string lights or other devices. It supports scheduling, voice commands, and energy monitoring, making it a versatile addition to your smart home ecosystem.
Compact and Easy to Use
- Available in 2-pack and 4-pack sizes, the Wyze Plug fits easily into any outlet without blocking adjacent sockets.
- Compatible with Alexa, Google Assistant, and IFTTT, it integrates smoothly with your existing smart home setup.
Key Specs
- Output: 15A Max
- Connectivity: 2.4GHz WiFi
- Operating Temperature: -4°F to 104°F (-20°C to 40°C)
- Certifications: ETL certified for safety
- Warranty: 1 Year
Use the Wyze Plug indoors to complement your outdoor lighting setup, ensuring your entire home is smart and energy-efficient.
Why Choose Weather-Resistant Smart Plugs for Outdoor LED String Lights?
Outdoor LED string lights require reliable power sources that can handle unpredictable weather conditions. Using a weather-resistant smart plug like the Wyze Plug Outdoor ensures your lighting stays on without interruption, while smart features provide convenience and energy savings.
Benefits Include:
- Durability: IP64 rating protects against rain and dust.
- Convenience: Control lights remotely via app or voice commands.
- Energy Efficiency: Monitor and manage power consumption easily.
- Safety: Overload protection prevents electrical hazards.
Conclusion
For your 100ft smart outdoor LED string lights, the
Wyze Plug Outdoor is the ideal choice to provide weather-resistant, smart power control with extended WiFi range and dual outlets. Pair it with the
Wyze Plug indoors for a complete smart lighting experience throughout your home. Together, these smart plugs offer durability, convenience, and energy efficiency to brighten your outdoor spaces effortlessly.
Product Highlights
Wyze Plug Outdoor
- IP64 Weather Resistant
- Dual Outlets with Independent Control
- 300 ft WiFi Range
- Energy Monitoring & Voice Control
Wyze Plug (Indoor)
- Compact Design
- Alexa & Google Assistant Compatible
- 15A Max Output
- Easy Scheduling & Energy Monitoring
What makes the Wyze Plug Outdoor suitable for 100ft smart outdoor LED string lights?
The Wyze Plug Outdoor is ideal for 100ft smart outdoor LED string lights because it features an IP64 weather-resistant design, dual independently controlled outlets, a long-range WiFi capability of up to 300 feet, and energy monitoring. These features ensure reliable, safe, and convenient power control for your outdoor lighting in any weather.Is the Wyze Plug Outdoor weather-resistant?
Yes, the Wyze Plug Outdoor is IP64 weather-resistant, protecting it from rain, dust, snow, and dirt. This makes it perfect for powering outdoor LED string lights and other devices in any weather conditions.Can I control my outdoor LED string lights remotely with the Wyze Plug Outdoor?
Absolutely. The Wyze Plug Outdoor allows you to control your outdoor LED string lights remotely using the Wyze app or voice assistants like Alexa. This means you can turn your lights on or off without stepping outside.How many devices can I control with the Wyze Plug Outdoor?
The Wyze Plug Outdoor features two separate outlets, allowing you to control two devices or lighting zones independently. Each outlet can be managed individually through the Wyze app or via voice commands.Does the Wyze Plug Outdoor support energy monitoring?
Yes, the Wyze Plug Outdoor includes energy monitoring, enabling you to track the power consumption of your outdoor LED string lights and other connected devices. This helps you optimize usage and save on electricity bills.What is the WiFi range of the Wyze Plug Outdoor?
The Wyze Plug Outdoor offers an extended WiFi range of up to 300 feet in open spaces, ensuring reliable connectivity even if your router is located inside your home.Is the Wyze Plug suitable for outdoor use?
No, the Wyze Plug is designed for indoor use only. For outdoor applications, such as powering 100ft LED string lights, the Wyze Plug Outdoor is recommended due to its weather-resistant features.What smart home systems are compatible with Wyze Plug and Wyze Plug Outdoor?
Both Wyze Plug and Wyze Plug Outdoor are compatible with Alexa and Google Assistant, allowing for convenient voice control. The indoor Wyze Plug also supports IFTTT for additional automation options.What safety features does the Wyze Plug Outdoor offer?
The Wyze Plug Outdoor provides overload protection with a 15 AMP output, ensuring safe operation for high-demand devices like roof de-icers or pond pumps, in addition to your LED string lights.Can I use the Wyze Plug to control indoor LED string lights?
Yes, the Wyze Plug is perfect for controlling indoor LED string lights and other devices. It offers scheduling, energy monitoring, and voice control, making it a versatile addition to your smart home.What are the benefits of using a weather-resistant smart plug for outdoor LED string lights?
Using a weather-resistant smart plug like the Wyze Plug Outdoor ensures durability against the elements, remote control convenience, energy efficiency through monitoring, and enhanced safety with overload protection for your outdoor LED string lights.
