Weather-Protected 20ft USB Extension Cable for Wyze Cam Outdoors
Weather Protected 20 ft USB Cable for Wyze Cam Outdoors
When placing your Wyze Cam outdoors, ensuring a reliable and weather-resistant power connection is essential. A 20 ft USB extension cable designed for outdoor use provides the perfect solution to extend your camera’s reach while protecting the cable from the elements. Wyze offers compatible accessories and cameras that are built to withstand outdoor conditions, making your home security setup both flexible and durable.
Wyze Cam v4: The Ultimate Outdoor Security Camera
The Wyze Cam v4 is a top choice for outdoor surveillance, especially when paired with a weather-protected 20 ft USB extension cable. This camera is engineered to perform in all weather conditions with an IP65 weather resistance rating, making it ideal for outdoor placement.
Key Features of Wyze Cam v4
  • 2.5K Quad High Definition (QHD) Resolution: Capture crystal-clear video with 2560x1440 resolution, providing detailed images day and night.
  • Enhanced Color Night Vision: See vibrant colors even in low-light conditions, thanks to advanced hardware that outperforms traditional night vision.
  • Wide Dynamic Range (WDR): Enjoy richer colors and better image quality with an upgraded image processor.
  • IP65 Weather Resistance: Designed to operate in rain, snow, or shine, ensuring reliable outdoor performance.
  • Integrated Spotlight & Siren: Motion-activated spotlight and a 99 dB siren help deter intruders and illuminate your property.
  • Advanced Two-Way Talk: Clearer conversations with AAC audio coding, a powerful amplifier, and an updated microphone.
  • Wi-Fi 6 Support: Maintain a stronger and more reliable connection at greater distances.
  • Continuous 24/7 Local Recording: Supports microSD cards up to 512 GB for uninterrupted local video storage without subscription fees.
  • Easy Setup & Mounting: Bluetooth® setup with a magnetic mount allows for quick installation without tools.
Outdoor Power and Cable Compatibility
To power your Wyze Cam v4 outdoors, Wyze offers a 20 ft USB extension cable that is weather protected and compatible with the camera’s micro USB power input. This cable extends your camera’s reach to distant power sources while maintaining durability against outdoor elements. Pairing the Wyze Cam v4 with the Wyze Outdoor Power Adapter ensures a secure and weatherproof power connection, perfect for outdoor installations.
“Wyze Cam v4 operates in any weather due to its IP65 weather-resistant rating.”
This makes it the perfect companion for a weather-protected USB extension cable outdoors.
Wyze Cam v4 mounted outdoors Wyze Cam v4 providing outdoor security with weatherproof design
Wyze Cam v4 Outdoor Bundle: Complete Outdoor Security Solution
For those looking for an all-in-one package, the Wyze Cam v4 Outdoor Bundle includes everything you need for a robust outdoor security setup:
  • Wyze Cam v4 with all the advanced features listed above.
  • Wyze Outdoor Power Adapter designed specifically for outdoor use.
  • 128GB Wyze MicroSD Card for continuous local recording.
  • Compatible with Alexa and Google Assistant for smart home integration.
Why Choose the Outdoor Bundle?
  • Cost-effective: Bundled price offers savings compared to buying components separately.
  • Ready for any weather: The power adapter and camera are both IP65 rated.
  • Extended recording: 128GB microSD card included for ample local storage.
  • Easy installation: Comes with all necessary accessories for quick setup.
This bundle is ideal if you want a hassle-free, weatherproof outdoor security system with a reliable power source and extended cable length.
Why Use a 20 ft USB Extension Cable for Your Wyze Cam Outdoors?
  • Flexible Camera Placement: Extend your camera’s power cable to reach distant outlets or power sources without relocating your camera.
  • Weather Protection: Outdoor-rated USB cables prevent damage from rain, snow, and UV exposure.
  • Maintain Continuous Power: Unlike battery-powered cameras, wired cameras like Wyze Cam v4 require constant power, which a long extension cable facilitates.
  • Compatibility: Wyze’s 20 ft USB extension cable is designed to work seamlessly with the Wyze Cam v4 and the outdoor power adapter.
Summary: Best Setup for Outdoor Wyze Cam with 20 ft USB Cable
ProductHighlights
Wyze Cam v4IP65 weather resistance, 2.5K QHD, color night vision, spotlight & siren, Wi-Fi 6
Wyze Cam v4 Outdoor BundleIncludes outdoor power adapter, 128GB microSD, all-weather ready
20 ft USB Extension CableWeather protected, extends power reach for outdoor placement
By combining the Wyze Cam v4 with a weather-protected 20 ft USB extension cable and the outdoor power adapter, you ensure your camera stays powered and protected in any outdoor environment, providing reliable home security day and night.
FeatureWyze Cam v4Wyze Cam v4 Outdoor BundleWyze Cam v4 (American Made)
Price$35.98 (1 Pack)$69.99$100.00
Color OptionsBlack, Clear (sold out), Grey, WhiteBlack, Grey, WhiteWhite, Grey
Resolution2.5K QHD (2560x1440)2.5K QHD (2560x1440)2.5K QHD (2560x1440)
Night VisionEnhanced Color Night Vision + B&WEnhanced Color Night Vision + B&WEnhanced Color Night Vision + B&W
SpotlightMotion-activated spotlightMotion-activated spotlightMotion-activated spotlight
SirenYes (99 dB)Yes (99 dB)Yes (99 dB)
AudioEnhanced Two-Way Talk, Noise Echo CancellationEnhanced Two-Way Talk, Noise Echo CancellationEnhanced Two-Way Talk, Noise Echo Cancellation
Field of View (DFOV x HFOV x VFOV)115.9° x 98.5° x 53.1°115.9° x 98.5° x 53.1°115.8° x 98.5° x 53.1°
Wide Dynamic Range (WDR)YesYesYes
Weather ResistanceIP65IP65IP65
Wi-Fi SupportWi-Fi 6, 2.4 GHzWi-Fi 6, 2.4 GHzWi-Fi 6, 2.4 GHz
Bluetooth Version5.25.25.2
Local StoragemicroSD card up to 256GB (sold separately)Includes 128GB microSD cardmicroSD card up to 512GB (sold separately)
Cloud StorageOptional with subscriptionOptional with subscriptionOptional with subscription
Continuous RecordingYes (wired)Yes (wired)Yes (wired)
Power AdapterIndoor USB Power Adapter includedIncludes Wyze Outdoor Power AdapterIndoor USB Power Adapter included
Outdoor UseRequires Outdoor Power Adapter (sold separately)Outdoor ready with included Outdoor Power AdapterRequires Outdoor Power Adapter (sold separately)
Mounting OptionsStand, Wall mount, Ceiling mount, Magnetic mountStand, Wall mount, Ceiling mount, Magnetic mountStand, Wall mount, Ceiling mount, Magnetic mount
Dimensions2in x 2in x 2 3/8in2in x 2in x 2 3/8in2in x 2in x 2 3/8in
Weight0.49 lb (222 g)0.49 lb (222 g)0.49 lb (222 g)
Operating Temperature-4ºF to 122ºF (-20ºC to 50ºC)-4ºF to 122ºF (-20ºC to 50ºC)-4ºF to 122ºF (-20ºC to 50ºC)
Warranty1 Year1 Year1 Year
Included in BoxWyze Cam v4, Quick Start Guide, Wall Mount Plate & Tape, Screw Kit, Indoor USB Power Adapter, 6-ft USB cableWyze Cam v4, Wyze Outdoor Power Adapter, 128GB microSD CardWyze Cam v4, Quick Start Guide, Wall Mount Plate & Tape, Screw Kit, Indoor USB Power Adapter, 6-ft USB cable
Special NotesBOGO 25% off offer availableBundle includes outdoor power adapter & microSD cardMade in America initiative, higher price point
What is the benefit of using a 20 ft weather-protected USB extension cable for Wyze Cam outdoors?A 20 ft weather-protected USB extension cable allows you to place your Wyze Cam further from power outlets while ensuring the cable is protected from rain, snow, and UV exposure. This provides flexible camera placement and maintains a reliable power connection for continuous outdoor security.
Is the 20 ft USB extension cable compatible with Wyze Cam v4?Yes, the 20 ft USB extension cable is specifically designed to be compatible with the Wyze Cam v4 and its micro USB power input, making it ideal for outdoor installations.
How does the Wyze Cam v4 perform in outdoor weather conditions?The Wyze Cam v4 is engineered for outdoor use with an IP65 weather resistance rating, allowing it to operate reliably in rain, snow, or shine.
What features make the Wyze Cam v4 suitable for outdoor security?Wyze Cam v4 offers 2.5K QHD resolution, enhanced color night vision, wide dynamic range, integrated spotlight and siren, advanced two-way talk, Wi-Fi 6 support, and continuous 24/7 local recording, making it an excellent choice for outdoor security.
What is included in the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle includes the Wyze Cam v4, a weatherproof outdoor power adapter, a 128GB Wyze MicroSD card for continuous local recording, and is compatible with Alexa and Google Assistant for smart home integration.
Why should I choose the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle is cost-effective, includes all necessary accessories for outdoor installation, provides ample local storage, and ensures both the camera and power adapter are weatherproof for reliable outdoor security.
Do I need a special power adapter for outdoor use with Wyze Cam v4?Yes, it is recommended to use the Wyze Outdoor Power Adapter, which is designed for outdoor use and provides a secure, weatherproof power connection for your Wyze Cam v4.
Can I use the Wyze Cam v4 for continuous 24/7 recording outdoors?Yes, the Wyze Cam v4 supports continuous 24/7 local recording with microSD cards up to 512GB, and the outdoor bundle includes a 128GB microSD card for extended recording.
Is the installation of Wyze Cam v4 and its accessories easy?Yes, the Wyze Cam v4 features Bluetooth setup and a magnetic mount for quick, tool-free installation. The outdoor bundle includes all necessary accessories for a hassle-free setup.
How does the weather-protected USB extension cable help maintain continuous power for Wyze Cam v4?The weather-protected USB extension cable ensures your Wyze Cam v4 remains powered at all times, even when placed far from indoor outlets, by providing a durable and weather-resistant connection suitable for outdoor environments.
Can you tell me more about the Wyze Cam v4's features for outdoor use?What is the IP65 weather resistance rating, and how does it benefit the Wyze Cam v4?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Cam v4 or its accessories?
