Extend Your Wyze Cam Reach with the 20ft USB Extension Cable
If you're looking to monitor your driveway from inside your home but find the standard Wyze Cam USB cable too short, the
Wyze Cam USB Extension Cable - 20ft is the perfect solution. This accessory allows you to place your Wyze Cam further away from power outlets, giving you the flexibility to position your camera exactly where you need it for optimal driveway coverage.
Key Features of the Wyze Cam USB Extension Cable - 20ft
- Length: 20 feet of additional USB cable length to extend your camera’s reach.
- Compatibility: Works seamlessly with Wyze Cam v2, v3, v4, v3 Pro, Pan v2/v3, OG Standard, and OG Telephoto models.
- Easy Setup: Simply plug the extension cable between your camera and power source—no complicated installation required.
- Affordable: Priced at just $7.99, it’s a cost-effective way to enhance your home security setup.
Say goodbye to short cables and enjoy the freedom to place your Wyze Cam exactly where you need it.
Alt text: Wyze Cam monitoring driveway from inside home with extended USB cable
Enhance Your Driveway Security with Wyze Cam v4 Outdoor Bundle
For those wanting a comprehensive outdoor security solution, the
Wyze Cam v4 Outdoor Bundle offers advanced features tailored for driveway monitoring and more.
Why Choose Wyze Cam v4 Outdoor Bundle?
- Crystal-clear 2.5K QHD Resolution: Capture every detail with stunning clarity.
- Enhanced Color Night Vision: See your driveway clearly even in low light or darkness.
- Motion-Activated Spotlight: Automatically lights up when motion is detected, deterring unwanted visitors.
- 24/7 Local Recording: Continuous recording with included 128GB microSD card ensures you never miss a moment.
- Wi-Fi 6 Support: Faster and more reliable connectivity for smooth streaming.
- Smart Home Compatibility: Works with Alexa and Google Assistant for voice control and automation.
- Weatherproof Design: Built to withstand outdoor conditions, perfect for driveway placement.
This bundle includes the Wyze Cam v4, an outdoor power adapter, and a microSD card, making it a complete package for your outdoor security needs.
Alt text: Outdoor home security camera monitoring driveway at night
Power Your Wyze Cam Pan v3 Anywhere with the Lamp Socket v2 Bundle
If your driveway monitoring setup involves the
Wyze Cam Pan v3, the
Pan v3 + Lamp Socket v2 Bundle is an excellent accessory to consider. It allows you to power your camera through a lamp socket, eliminating the need for a nearby power outlet.
Benefits of the Pan v3 + Lamp Socket v2 Bundle
- Power Without Outlet: Use existing lamp sockets (E26) to power your Wyze Cam Pan v3.
- Compatible Devices: Supports Wyze Cam v3, v3 Pro, v4, OG, and Pan v3 models.
- Compact and Lightweight: Easy to install with dimensions of 56.5mm x 56.5mm x 65mm and weighing only 80g.
- Smart Connectivity: Connects via 2.4GHz Wi-Fi and Bluetooth for seamless integration.
- Durability: Suitable for damp locations, perfect for covered outdoor areas like porches or garages.
- Energy Efficient: Supports CFL or LED bulbs under 20W (incandescent bulbs not recommended).
This bundle is ideal for users who want to place their Pan v3 camera in locations where power outlets are scarce but lamp sockets are available.
Summary: Perfect Solutions for Driveway Monitoring
- Wyze Cam USB Extension Cable - 20ft: Extend your camera’s reach indoors to monitor your driveway without moving power sources.
- Wyze Cam v4 Outdoor Bundle: Advanced outdoor camera with superior video quality, night vision, and spotlight for comprehensive driveway security.
- Pan v3 + Lamp Socket v2 Bundle: Power your Pan v3 camera through lamp sockets, offering flexible installation options.
Each of these products enhances your ability to monitor your driveway effectively, ensuring your home stays safe and secure.
Product Highlights
What is the Wyze Cam USB Extension Cable - 20ft and how does it help with driveway monitoring?
The Wyze Cam USB Extension Cable - 20ft is a 20-foot long USB cable designed to extend the reach of your Wyze Cam. It allows you to position your camera further from power outlets, making it easier to monitor areas like your driveway from inside your home.Which Wyze Cam models are compatible with the 20ft USB Extension Cable?
The 20ft USB Extension Cable is compatible with Wyze Cam v2, v3, v4, v3 Pro, Pan v2, Pan v3, OG Standard, and OG Telephoto models.How do I install the Wyze Cam USB Extension Cable?
Installation is simple—just plug the extension cable between your Wyze Cam and the power source. No complicated setup or tools are required.What is included in the Wyze Cam v4 Outdoor Bundle for driveway security?
The Wyze Cam v4 Outdoor Bundle includes the Wyze Cam v4, an outdoor power adapter, and a 128GB microSD card. This bundle provides everything you need for comprehensive outdoor and driveway monitoring.What features make the Wyze Cam v4 Outdoor Bundle ideal for driveway monitoring?
The Wyze Cam v4 Outdoor Bundle offers 2.5K QHD resolution, enhanced color night vision, a motion-activated spotlight, 24/7 local recording, Wi-Fi 6 support, smart home compatibility, and a weatherproof design—making it perfect for monitoring your driveway.Can I power my Wyze Cam Pan v3 without a nearby power outlet?
Yes, with the Pan v3 + Lamp Socket v2 Bundle, you can power your Wyze Cam Pan v3 using an existing E26 lamp socket, eliminating the need for a nearby power outlet.Which Wyze Cam models are compatible with the Lamp Socket v2 Bundle?
The Lamp Socket v2 Bundle is compatible with Wyze Cam v3, v3 Pro, v4, OG, and Pan v3 models.Is the Lamp Socket v2 Bundle suitable for outdoor use?
Yes, the Lamp Socket v2 Bundle is suitable for damp locations, making it ideal for covered outdoor areas such as porches or garages.What type of bulbs can I use with the Lamp Socket v2 Bundle?
The Lamp Socket v2 Bundle supports CFL or LED bulbs under 20W. Incandescent bulbs are not recommended.How much does the Wyze Cam USB Extension Cable - 20ft cost?
The Wyze Cam USB Extension Cable - 20ft is affordably priced at $7.99.
