Wyze Cam Pan Replacement Plate & Mount Kit for Easy Repositioning
Wyze Cam Pan Replacement Plate for Easy Camera Repositioning
If you're looking to enhance your Wyze Cam Pan experience with effortless repositioning and flexible mounting options, the
Wyze Cam Pan v3 combined with the
Wyze Cam Mounting Kit is your perfect solution. This setup allows you to easily adjust your camera's angle and position without hassle, ensuring optimal coverage and security for your home or outdoor space.
Wyze Cam Pan v3: The Ultimate 360° Security Camera
The Wyze Cam Pan v3 is a versatile indoor/outdoor security camera designed for seamless 360° horizontal panning and 180° vertical tilting. Its advanced features make it ideal for users who want comprehensive coverage with easy repositioning capabilities.
Key Features:
- 360° Horizontal & 180° Vertical View: Complete panoramic coverage with smooth, fast rotation up to 110° per second.
- Weather Resistant (IP65 Rated): Durable polycarbonate body and weatherproof design make it perfect for outdoor use (with optional outdoor power adapter).
- High-Definition Video: Crisp 1080p Full HD resolution with H.264 video encoding ensures clear footage day and night.
- Night Vision: Equipped with 4 IR LEDs (850 nm) for reliable night monitoring.
- Two-Way Audio: Built-in speaker and microphone with noise and echo cancellation for clear communication.
- Smart Integrations: Compatible with Alexa, Google Assistant, and IFTTT for smart home automation.
- Flexible Mounting: Uses a standard 1/4"-20 screw mount, allowing easy attachment to various mounting plates and accessories.
Dimensions & Design:
- Matte finish in Black or White.
- Compact size: 124mm (H) x 60mm (W) x 63mm (D).
- Lightweight at just 11.29 oz (320 g).
The Wyze Cam Pan v3’s smooth pan and tilt combined with its weatherproof design make it a reliable choice for both indoor and outdoor security needs.
Experience weather-resistant security with Wyze Cam Pan v3 outdoors.
Wyze Cam Mounting Kit: Simplify Your Camera Installation and Repositioning
To make repositioning your Wyze Cam Pan v3 effortless, the
Wyze Cam Mounting Kit is an essential accessory. This kit provides everything you need to securely mount your camera and adjust its position with ease.
What’s Included:
- Wall Plate for stable mounting.
- Adhesive tape for quick, no-drill installation.
- Longer 5-foot Micro USB extension cable for flexible power placement.
- Complete screw set for secure attachment.
Compatibility:
- Designed specifically for Wyze Cam v2, Wyze Cam v3, and Wyze Cam v3 Pro.
- Enables easy swapping and repositioning without removing the entire camera setup.
With this mounting kit, repositioning your Wyze Cam Pan is quick and convenient, allowing you to adapt your security coverage as your needs change.
Why Choose Wyze Cam Pan v3 with Mounting Kit for Easy Repositioning?
- Effortless Adjustments: The mounting kit’s wall plate and adhesive allow you to quickly detach and reattach your camera, making repositioning simple.
- Secure & Stable: The screw mount and adhesive tape ensure your camera stays firmly in place, even in outdoor conditions.
- Enhanced Coverage: Combined with the Pan v3’s 360° rotation, you can cover every angle without blind spots.
- Weatherproof & Durable: Both the camera and mounting kit are built to withstand outdoor elements, providing reliable security year-round.
Additional Wyze Cameras for Consideration
While the Wyze Cam Pan v3 and Mounting Kit are ideal for dynamic repositioning, here are other Wyze cameras that offer excellent features but may not support the same pan-and-tilt flexibility:
Wyze Cam v4
- 2.5K QHD resolution with enhanced color night vision.
- Multiple mounting options including magnetic mounts.
- IP65 weather resistance for outdoor use.
- Ideal for fixed-position monitoring with superior image quality.
Wyze Cam OG
- 1080p HD resolution with built-in spotlight.
- Faster live streaming and improved two-way audio.
- Weather resistant for indoor/outdoor use.
- Great for straightforward, fixed-angle security.
Conclusion
For users seeking
easy camera repositioning and flexible mounting, the
Wyze Cam Pan v3 paired with the
Wyze Cam Mounting Kit offers the best solution. This combination provides smooth 360° coverage, weather resistance, and hassle-free installation, making it perfect for both indoor and outdoor security needs.
Upgrade your home security setup today with Wyze’s innovative pan camera and mounting accessories for effortless repositioning and comprehensive coverage.
Easy mounting and repositioning with Wyze Cam Mounting Kit.
Feature | Wyze Cam Pan v3 | Wyze Cam Mounting Kit |
Type | Camera | Accessory |
Purpose | Indoor/outdoor 360° pan and 180° tilt security camera | Mounting bracket, adhesive, longer Micro USB cable |
Weather Resistance | IP65 (requires Outdoor Power Adapter for outdoor use) | Not specified |
Pan/Tilt Range | 360° horizontal, 180° vertical | N/A |
Motion Tracking | Yes | N/A |
Two-Way Audio | Yes | N/A |
Night Vision | Color Night Vision with Starlight Sensor | N/A |
Power Cable Length | 6' (1.8 m) | Includes longer Micro USB cable |
Mounting | Screw 1/4" - 20 | Mounting bracket included |
Compatibility | Wyze Cam Pan v3 | Wyze Cam v2, v3, v3 Pro |
Included Items | Camera, 6' micro USB cable, Power Adapter, Mounting Kit, Quick Start Guide | Mounting bracket, adhesive, longer Micro USB cable |
Price | $39.98 (1 Pack, White or Black) | $5.99 |
Warranty | 1 Year | Not specified |
What is the Wyze Cam Pan v3 and what makes it unique?
The Wyze Cam Pan v3 is a versatile indoor/outdoor security camera featuring 360° horizontal panning and 180° vertical tilting. Its unique features include weather resistance (IP65 rated), 1080p Full HD video, night vision, two-way audio, and compatibility with Alexa, Google Assistant, and IFTTT. This makes it ideal for users seeking comprehensive coverage and easy camera repositioning.How does the Wyze Cam Mounting Kit simplify camera repositioning?
The Wyze Cam Mounting Kit includes a wall plate, adhesive tape, a 5-foot Micro USB extension cable, and a complete screw set. This kit allows you to quickly detach and reattach your Wyze Cam Pan v3, making repositioning effortless without the need to remove the entire camera setup.Is the Wyze Cam Pan v3 suitable for outdoor use?
Yes, the Wyze Cam Pan v3 is IP65 weather resistant, making it suitable for both indoor and outdoor use. Its durable polycarbonate body and weatherproof design ensure reliable performance in various weather conditions, especially when paired with the optional outdoor power adapter.What mounting options are available for the Wyze Cam Pan v3?
The Wyze Cam Pan v3 uses a standard 1/4"-20 screw mount, allowing for flexible attachment to various mounting plates and accessories. The Wyze Cam Mounting Kit further enhances mounting flexibility with its wall plate, adhesive tape, and screw set.Which Wyze cameras are compatible with the Wyze Cam Mounting Kit?
The Wyze Cam Mounting Kit is designed specifically for the Wyze Cam v2, Wyze Cam v3, and Wyze Cam v3 Pro, enabling easy swapping and repositioning for these models.What are the key features of the Wyze Cam Pan v3?
Key features of the Wyze Cam Pan v3 include 360° horizontal and 180° vertical coverage, 1080p Full HD video, night vision with 4 IR LEDs, two-way audio with noise and echo cancellation, weather resistance (IP65), smart home integration, and a compact, lightweight design.How does the Wyze Cam Pan v3 with Mounting Kit enhance home security?
The Wyze Cam Pan v3 with Mounting Kit provides smooth 360° coverage, easy repositioning, secure and stable mounting, and weatherproof durability. This combination ensures comprehensive security coverage for both indoor and outdoor spaces, adapting to your changing needs.Are there other Wyze cameras suitable for fixed-position monitoring?
Yes, the Wyze Cam v4 and Wyze Cam OG are excellent options for fixed-position monitoring. The Wyze Cam v4 offers 2.5K QHD resolution and enhanced color night vision, while the Wyze Cam OG features 1080p HD resolution with a built-in spotlight. Both are weather resistant and ideal for users who do not require pan-and-tilt functionality.What is included in the Wyze Cam Mounting Kit?
The Wyze Cam Mounting Kit includes a wall plate for stable mounting, adhesive tape for no-drill installation, a 5-foot Micro USB extension cable for flexible power placement, and a complete screw set for secure attachment.Why should I choose the Wyze Cam Pan v3 with Mounting Kit for easy camera repositioning?
Choosing the Wyze Cam Pan v3 with Mounting Kit allows for effortless camera adjustments, secure and stable mounting, enhanced coverage with 360° rotation, and weatherproof durability. This setup is perfect for users who need flexible, reliable, and comprehensive home or outdoor security.
What are the key features of the Wyze Cam Pan v3?Can the Wyze Cam Pan v3 be used outdoors?Do you have any deals, ongoing sales, discounts, or promotions?
