Wyze Universal Long Metal Mount – Heavy Duty Adjustable for Cams
Wyze Universal Long Mount (Heavy Duty Metal) for Wyze Cams
If you're looking for a durable, adjustable, and heavy-duty metal mount designed specifically for Wyze cameras, the Wyze Universal Mount (Long) is the perfect accessory to enhance your camera setup. This mount is engineered to provide versatile mounting options, making it ideal for both indoor and outdoor applications such as ceilings, patios, or walls.
Key Features of the Wyze Universal Long Mount
  • Heavy-Duty Metal Construction: Crafted from robust metal, this mount ensures long-lasting durability and stability for your Wyze cameras.
  • Long Neck Design: The extended neck allows for flexible positioning, giving you the ability to adjust your camera angle precisely.
  • Compatibility: Works with Wyze cameras that use the standard 1/4”-20 mount, including Wyze Cam v1, v2, v3, v3 Pro, Pan v1, Pan v2, Pan v3, Outdoor v1, Outdoor v2, and Battery Cam Pro.
  • Not Compatible: Please note it does not fit Wyze Cam OG or OG Telephoto models.
  • Easy Installation: Comes with 3 drywall anchors and Philips screws for secure mounting on various surfaces.
  • Load Bearing: Supports up to 70 oz (2 kg), ensuring your camera stays firmly in place.
Specifications
  • Color: White with a matte finish
  • Weight: 2 oz (57 g)
  • Dimensions: 2 in x 2 in x 3.8 in
  • Included Items: Wyze Universal Metal Mount x1, Screw Assembly x1
This mount is perfect for users who want a reliable and adjustable mounting solution that can handle heavier cameras or outdoor conditions without compromising on style or functionality.
Compatible Wyze Cameras for the Universal Long Mount
To maximize the benefits of the Wyze Universal Long Mount, pairing it with compatible Wyze cameras is essential. Here are some popular Wyze cameras that work seamlessly with this mount:
Wyze Cam v4
  • Video Quality: 2.5K QHD (2560x1440) resolution with wide dynamic range and color night vision.
  • Field of View: 115.8° diagonal, 98.5° horizontal, 53.1° vertical.
  • Durability: Weather-resistant with an IP65 rating, suitable for indoor and outdoor use.
  • Connectivity: Supports Wi-Fi 6 and Bluetooth 5.2.
  • Features: Two-way talk, built-in siren, noise and echo cancellation.
  • Mounting Options: Stand, wall mount, ceiling mount, and magnetic wall mount.
  • Dimensions: 2 in x 2 in x 2 3/8 in; weight 0.49 lb (222 g).
The Wyze Cam v4 is a versatile and high-performance camera that pairs perfectly with the Universal Long Mount for flexible placement and enhanced security coverage.
Why Choose the Wyze Universal Long Mount?
"A durable camera mount with a longer neck designed to provide versatile mounting applications such as the ceiling or patio."
  • The heavy-duty metal build ensures your camera stays secure in any environment.
  • Adjustable design allows for precise camera positioning.
  • Compatible with a wide range of Wyze cameras, making it a universal solution for your mounting needs.
  • Easy to install with included hardware, saving you time and effort.
Enhance Your Home Security Setup
Pairing the Wyze Universal Long Mount with Wyze cameras like the Wyze Cam v4 or other compatible models allows you to create a comprehensive and flexible home security system. Whether you want to monitor your patio, ceiling, or any other area, this mount provides the stability and adjustability needed for optimal camera placement. Outdoor Wyze Cam Mounted on Patio Alt text: Wyze camera mounted on patio ceiling with adjustable metal mount
Summary
The Wyze Universal Long Mount is the ideal heavy-duty, adjustable metal mount for Wyze cameras that require a longer neck for versatile mounting. Its compatibility with most Wyze cameras and robust construction make it a must-have accessory for anyone looking to enhance their camera installation options.
What is the Wyze Universal Long Mount (Heavy Duty Metal) used for?The Wyze Universal Long Mount is a durable, adjustable, heavy-duty metal mount designed specifically for Wyze cameras. It provides versatile mounting options for both indoor and outdoor applications, such as ceilings, patios, or walls, ensuring your camera stays securely in place.
Which Wyze cameras are compatible with the Wyze Universal Long Mount?The Wyze Universal Long Mount is compatible with Wyze cameras that use the standard 1/4”-20 mount, including Wyze Cam v1, v2, v3, v3 Pro, Pan v1, Pan v2, Pan v3, Outdoor v1, Outdoor v2, and Battery Cam Pro. It is not compatible with Wyze Cam OG or OG Telephoto models.
Is the Wyze Universal Long Mount suitable for outdoor use?Yes, the Wyze Universal Long Mount is crafted from heavy-duty metal, making it ideal for both indoor and outdoor use. Its robust construction ensures durability and stability in various environments, including patios and exterior walls.
How much weight can the Wyze Universal Long Mount support?The Wyze Universal Long Mount can support up to 70 oz (2 kg), making it suitable for heavier Wyze cameras and ensuring your device remains securely mounted.
What is included with the Wyze Universal Long Mount?The package includes one Wyze Universal Metal Mount and a screw assembly, which consists of 3 drywall anchors and Philips screws for easy and secure installation on various surfaces.
What are the dimensions and color of the Wyze Universal Long Mount?The Wyze Universal Long Mount measures 2 inches x 2 inches x 3.8 inches and weighs 2 oz (57 g). It comes in a white color with a matte finish.
Is the Wyze Universal Long Mount easy to install?Yes, the Wyze Universal Long Mount is designed for easy installation. It comes with all necessary hardware, including drywall anchors and Philips screws, allowing you to securely mount your camera on ceilings, walls, or patios.
Why should I choose the Wyze Universal Long Mount for my Wyze camera?The Wyze Universal Long Mount offers a heavy-duty metal build, an adjustable long neck for precise camera positioning, broad compatibility with most Wyze cameras, and easy installation. It is an ideal solution for users seeking a reliable and flexible mounting option for enhanced home security.
Can I use the Wyze Universal Long Mount with the Wyze Cam v4?Yes, the Wyze Universal Long Mount is fully compatible with the Wyze Cam v4, allowing for flexible placement and enhanced security coverage both indoors and outdoors.
What are the installation requirements for the Wyze Universal Long Mount?Can the Wyze Universal Long Mount be used for both indoor and outdoor applications?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Universal Long Mount?
