Affordable HEPA Air Filter Replacements for Allergens and Viruses
When it comes to maintaining clean, allergen-free, and virus-reduced air in your home, choosing the right HEPA air filter replacement is essential. Affordable options that deliver high efficiency without compromising quality are key to breathing easier every day. Wyze offers a range of HEPA air filter replacements designed to target allergens, viruses, and harmful gases, all while fitting your budget.
Wyze Air Filter: Customizable HEPA Solutions for Every Need
Tailored Filtration for Allergens and Viruses
The Wyze Air Filter is a versatile, connected home accessory that lets you customize your air purification based on your specific environment. Whether you’re combating pet dander, allergens, viruses, or even formaldehyde and wildfire smoke, Wyze has a filter for you.
Filter Types:
- Allergen Filter (Standard) with True HEPA 13
- Formaldehyde Filter (Premium) with True HEPA 12 + MnO2
- Wildfire Filter (Special Use) with True HEPA 12
Efficiency:
- Virus and bacteria removal efficiency of 99%
- TVOC removal efficiency up to 98.9%
Performance:
- Particulate Matter CADR up to 362 m³/h (214 CFM)
- Formaldehyde CADR of 178 m³/h
- Service Life: 4 to 12 months depending on filter type
- Additional Features: Pre-filter and activated carbon layers for enhanced purification
This filter is designed to fit the Wyze Air Purifier, allowing you to switch filters based on your air quality needs and budget.
"You don’t drink the same drink or eat the same food as everyone else. Why should you breathe the same air?"
Keep your home’s air fresh and allergen-free with easy filter replacements.
Wyze Air Filter Subscription: Hassle-Free Replacement Filters
Convenient and Cost-Effective Filter Replacement
Never worry about forgetting to replace your HEPA filter with the Wyze Air Filter Subscription. This subscription service delivers replacement filters right to your door, ensuring your air purifier always performs at its best.
- Available Filter Types: Allergen, Formaldehyde, and Wildfire
Filter Composition:
- Pre-filter + True HEPA 13 + Activated Carbon (Allergen)
- Pre-filter + True HEPA 12 + MnO2 + Activated Carbon (Formaldehyde)
- Pre-filter + True HEPA 12 + Activated Carbon (Wildfire)
- Dimensions: 8.1" x 8.1" x 11.3"
- Pricing: Starting at $37.99 for allergen filters
This subscription is perfect for those who want to maintain optimal air quality without the hassle of tracking filter changes.
Wyze Air Purifier: Premium Air Cleaning with Smart Features
Powerful Air Purification Meets Smart Home Convenience
The Wyze Air Purifier combines premium HEPA filtration with smart technology to deliver clean air efficiently and quietly. It’s an affordable luxury that fits well within most budgets while offering advanced features.
Pre-installed Filter Options:
CADR Ratings:
- Allergen: 350 m³/h (206 CFM)
- Wildfire: 342 m³/h (201 CFM)
- Formaldehyde: 317 m³/h (186 CFM)
- Noise Levels: Whisper-quiet operation starting below 21 dBA
- Effective Area: Covers 450-550 sq. ft.
Smart Features:
- Compatible with Google Home and Alexa
- Real-time air quality alerts and laser particle detection (0.3 microns accuracy)
- Air quality measured 100 times per second
- Filter Life: Approximately 6 months
This purifier is ideal for anyone looking to improve indoor air quality with minimal noise and smart home integration.
Enjoy fresh, clean air with the Wyze Air Purifier in your living space.
Why Choose Wyze HEPA Air Filter Replacements?
- Affordable Pricing: High-quality HEPA filters starting under $40
- Customizable Options: Filters designed for allergens, formaldehyde, and wildfire smoke
- High Efficiency: True HEPA filtration with up to 99% virus and bacteria removal
- Convenient Subscription: Never miss a filter change with scheduled deliveries
- Smart Home Compatibility: Integrate with Alexa and Google Home for effortless control
Enhance Your Air Purifier with Wyze Plug for Smart Control
Pair your Wyze Air Purifier with the Wyze Plug to automate and control your air quality remotely. Schedule your purifier to run when you need it most or control it with voice commands.
Features:
- Compatible with Alexa, Google Assistant, and IFTTT
- Easy scheduling and remote app control
- Compact design fits any outlet
- Pricing: Starting at $24.98 for a 2-pack
Smart control for your air purifier with Wyze Plug.
Conclusion
For affordable, effective HEPA air filter replacements that combat allergens and viruses, Wyze offers a comprehensive lineup of customizable filters, subscription services, and smart air purifiers. Whether you want to maintain fresh air in a small room or a larger living space, Wyze’s products provide excellent filtration performance, smart features, and budget-friendly options to keep your home’s air clean and healthy.
Product Tags Summary
What types of HEPA air filter replacements does Wyze offer?
Wyze offers three main types of HEPA air filter replacements: the Allergen Filter (Standard) with True HEPA 13, the Formaldehyde Filter (Premium) with True HEPA 12 + MnO2, and the Wildfire Filter (Special Use) with True HEPA 12. Each filter is designed to target specific air quality concerns such as allergens, viruses, formaldehyde, and wildfire smoke.How effective are Wyze HEPA air filters at removing allergens and viruses?
Wyze HEPA air filters are highly effective, offering up to 99% efficiency in removing viruses and bacteria. They also provide up to 98.9% efficiency in removing total volatile organic compounds (TVOCs), making them ideal for maintaining clean and healthy indoor air.How long do Wyze HEPA air filter replacements last?
The service life of Wyze HEPA air filter replacements ranges from 4 to 12 months, depending on the filter type and your specific air quality needs. The Wyze Air Purifier filter typically lasts around 6 months under normal usage.Are Wyze HEPA air filters affordable?
Yes, Wyze HEPA air filters are designed to be budget-friendly, with high-quality filters starting under $40. This makes it easy to maintain clean air in your home without overspending.Can I subscribe to automatic Wyze air filter replacements?
Yes, Wyze offers an Air Filter Subscription service that delivers replacement filters directly to your door. This convenient and cost-effective service ensures you never forget to replace your filter and helps maintain optimal air quality.What are the benefits of the Wyze Air Purifier?
The Wyze Air Purifier offers premium HEPA filtration, whisper-quiet operation (starting below 21 dBA), and smart features such as compatibility with Google Home and Alexa, real-time air quality alerts, and laser particle detection. It effectively covers areas of 450-550 sq. ft., making it suitable for most living spaces.How does the Wyze Air Purifier integrate with smart home systems?
The Wyze Air Purifier is compatible with Google Home and Alexa, allowing you to control your air quality with voice commands or through the Wyze app. It also provides real-time air quality alerts and measures air quality 100 times per second for accurate monitoring.What is the CADR rating of Wyze air filters and purifiers?
Wyze air filters and purifiers offer high Clean Air Delivery Rate (CADR) ratings: up to 362 m³/h (214 CFM) for particulate matter, 350 m³/h (206 CFM) for allergens, 342 m³/h (201 CFM) for wildfire smoke, and 317 m³/h (186 CFM) for formaldehyde. These ratings ensure efficient and rapid air purification.What additional features do Wyze HEPA air filters have?
Wyze HEPA air filters include pre-filter and activated carbon layers for enhanced purification. The Formaldehyde Filter also features MnO2 for advanced removal of harmful gases. These multi-layered filters help capture a wide range of pollutants, including allergens, viruses, and odors.How can I automate my Wyze Air Purifier?
You can automate your Wyze Air Purifier using the Wyze Plug, which is compatible with Alexa, Google Assistant, and IFTTT. The Wyze Plug allows you to schedule your purifier, control it remotely via the app, and integrate it seamlessly into your smart home setup.
