Subscribe to Air Filter Deliveries for Easy Air Quality Maintenance
Maintaining clean and healthy air in your home has never been easier. With Wyze’s innovative air filtration products and convenient subscription service, you can ensure your indoor air quality stays optimal without the hassle of remembering to reorder filters. Discover how Wyze Air Purifier, Wyze Air Filter, and the Wyze Air Filter Subscription work together to provide you with customizable, effective, and effortless air purification.
Wyze Air Purifier: Smart, Powerful, and Quiet
The Wyze Air Purifier is designed to clear the air in your living space with premium filtration technology and smart home integration.
Key Features:
- High CADR Performance: Delivers up to 350 m³/h (206 CFM) particulate matter clean air delivery rate, efficiently covering 450-550 ft².
- Multiple Filter Options: Comes with pre-installed Allergen Filter (Standard), Formaldehyde Filter (Premium), or Wildfire Filter (Special Use) tailored to your specific air quality needs.
- Ultra-Quiet Operation: Runs at whisper-quiet noise levels starting below 21 dBA, perfect for bedrooms and living rooms.
- Smart Controls & Alerts: Compatible with Google Home and Alexa, featuring laser particle detection with 0.3-micron accuracy and real-time air quality alerts.
- Sleek Design: Compact dimensions (9.5" x 9.4" x 18.5") and modern gray finish fit seamlessly into any home environment.
“A luxury air purifier without a luxury price tag.”
Keep your air purifier performing at its best with easy filter changes.
Wyze Air Filter: Customize Your Air Quality
Why breathe the same air as everyone else? Wyze Air Filters allow you to customize your air purification based on your environment and health concerns.
Filter Variants:
- Allergen Filter (Standard): HEPA 13 filter with activated carbon, ideal for removing pet dander, dust, and common allergens.
- Formaldehyde Filter (Premium): HEPA 12 with MnO2 and activated carbon, specifically designed to reduce formaldehyde and harmful gases.
- Wildfire Filter (Special Use): HEPA 12 with activated carbon, optimized for wildfire smoke and particulate removal.
Specifications:
- Dimensions: 8.1" x 8.1" x 11.3"
- Weight: Ranges from 1.5 to 1.9 lbs depending on filter type
- TVOC Removal Efficiency: Up to 98.9%
- Service Life: 4 to 12 months depending on filter variant
These filters are compatible with the Wyze Air Purifier and can be tailored to your unique air quality needs, whether you’re combating allergens, chemical pollutants, or wildfire smoke.
Wyze Air Filter Subscription: Hassle-Free Replacement Filters Delivered
Never worry about running out of clean filters again. The Wyze Air Filter Subscription service delivers replacement filters right to your door on a schedule that fits your usage.
Benefits of Subscription:
- Convenient Delivery: Receive allergen, formaldehyde, or wildfire filters automatically without reordering.
- Consistent Air Quality: Maintain peak purifier performance with timely filter replacements.
- Flexible Plans: Choose the filter type and delivery frequency that suits your home environment.
- Cost-Effective: Avoid last-minute purchases and ensure you always have fresh filters on hand.
Each replacement filter matches the specifications of the original Wyze Air Filter, including pre-filter, True HEPA, and activated carbon layers, ensuring the same high level of air purification.
Why Choose Wyze for Your Air Quality Needs?
Wyze combines smart technology, customizable filtration, and subscription convenience to make air quality maintenance effortless and effective. Whether you’re sensitive to allergens, concerned about chemical pollutants, or living in an area prone to wildfire smoke, Wyze has a filter solution for you — backed by smart home integration and easy filter management.
“Customize your air like you customize your burger. Well done! Hold the formaldehyde!”
Summary of Products for Air Quality Maintenance
Product Name | Purpose | Price Range (USD) | Key Features |
Wyze Air Purifier | Smart air purifier device | $169.99 - $194.99 | Smart controls, 350 CADR, quiet |
Wyze Air Filter | Customizable replacement filters | $37.99 - $63.99 | Allergen, Formaldehyde, Wildfire |
Wyze Air Filter Subscription | Filter delivery subscription | $37.99 - $63.99 | Automatic filter replacement |
By subscribing to Wyze Air Filter deliveries, you ensure your home’s air stays fresh and healthy year-round with minimal effort. Experience the convenience of smart air purification combined with personalized filter options and scheduled replacements.
Breathe easy in a smart, clean home environment.
Take control of your indoor air quality today with Wyze’s smart air purification system and subscription service — because your air deserves the same care as your lifestyle.
What is the Wyze Air Purifier and how does it improve indoor air quality?
The Wyze Air Purifier is a smart, powerful, and ultra-quiet air purification device designed to efficiently clean the air in your home. It features premium filtration technology, a high Clean Air Delivery Rate (CADR) of up to 350 m³/h, and covers spaces of 450-550 ft². With smart home integration, real-time air quality alerts, and multiple filter options, it helps maintain optimal indoor air quality effortlessly.What types of air filters are available for the Wyze Air Purifier?
Wyze offers three types of air filters for its air purifier: the Allergen Filter (Standard) for removing pet dander, dust, and common allergens; the Formaldehyde Filter (Premium) for reducing formaldehyde and harmful gases; and the Wildfire Filter (Special Use) optimized for wildfire smoke and particulate removal. Each filter is designed to address specific air quality concerns.How does the Wyze Air Filter Subscription service work?
The Wyze Air Filter Subscription service delivers replacement filters directly to your door on a schedule that fits your needs. You can choose the filter type and delivery frequency, ensuring you always have fresh filters without the hassle of reordering. This service helps maintain consistent air quality and peak purifier performance.What are the benefits of subscribing to Wyze Air Filter deliveries?
Subscribing to Wyze Air Filter deliveries offers several benefits, including convenient automatic delivery of replacement filters, consistent air quality through timely filter changes, flexible subscription plans, and cost savings by avoiding last-minute purchases. It ensures your air purifier always operates at its best.Are Wyze Air Filters customizable for different air quality needs?
Yes, Wyze Air Filters are customizable to address various air quality needs. You can select from Allergen, Formaldehyde, or Wildfire filters based on your environment and health concerns, ensuring tailored air purification for your home.How often should I replace my Wyze Air Filter?
The recommended replacement interval for Wyze Air Filters ranges from 4 to 12 months, depending on the filter variant and your usage. The subscription service can be tailored to your preferred replacement schedule to ensure optimal air quality.Is the Wyze Air Purifier compatible with smart home systems?
Yes, the Wyze Air Purifier is compatible with Google Home and Alexa, allowing you to control the device and receive real-time air quality alerts through your smart home ecosystem.What is the price range for Wyze air quality products?
The Wyze Air Purifier is priced between $169.99 and $194.99. Wyze Air Filters and the Air Filter Subscription service range from $37.99 to $63.99, depending on the filter type and subscription plan.What makes Wyze Air Purifier filters effective?
Wyze Air Purifier filters use a combination of pre-filter, True HEPA, and activated carbon layers to capture up to 98.9% of total volatile organic compounds (TVOCs) and remove allergens, harmful gases, and smoke particles, ensuring high-efficiency air purification.Why should I choose Wyze for my air quality maintenance?
Wyze offers a comprehensive air quality solution with smart technology, customizable filtration options, and a convenient subscription service. Whether you need to address allergens, chemical pollutants, or wildfire smoke, Wyze provides effective, effortless, and cost-efficient air purification tailored to your needs.
