Durable Wyze Cam Mount for Extra Long Bracket Installations
Durable Wyze Cam Mount for Extra Long Camera Bracket Installation
When it comes to securely installing your Wyze Cam with an extra long camera bracket, durability and compatibility are key. Whether you have a Wyze Cam v2, v3, or the latest models, having the right mounting accessories ensures your camera stays firmly in place, providing reliable surveillance and peace of mind.
Wyze Cam Mounting Kit: The Ultimate Durable Mounting Solution
Designed for Wyze Cam v2, v3, and v3 Pro
The Wyze Cam Mounting Kit is specifically crafted to support Wyze Cam v2, Wyze Cam v3, and Wyze Cam v3 Pro models. This kit is perfect for users who need a sturdy and reliable mounting solution that accommodates extra long camera bracket installations.
What’s Included?
  • Wall Plate x1: Provides a solid base for mounting your camera securely.
  • USB Extension Cable (5 feet) x1: Extra length for flexible camera placement without worrying about power source proximity.
  • Adhesive Tape x1: Strong adhesive for mounting on various surfaces.
  • Screw Set x1: For a more permanent and secure installation.
Why Choose This Mounting Kit?
  • Durability: Made to withstand everyday wear and tear, ensuring your camera stays mounted safely.
  • Extended Reach: The included 5-foot USB extension cable allows for extra-long bracket setups, perfect for hard-to-reach or unconventional mounting spots.
  • Versatility: Compatible with multiple Wyze Cam models, making it a versatile accessory for your smart home security setup.
“Secure your Wyze Cam with confidence using a mounting kit designed for durability and extended installation options.”
Additional Wyze Camera Options for Outdoor and Enhanced Security
While the Wyze Cam Mounting Kit is ideal for mounting your existing cameras with extra-long brackets, consider these Wyze camera bundles and kits that offer advanced features and outdoor compatibility.
Wyze Cam v4 Outdoor Bundle
  • 2.5K QHD Resolution: Crystal-clear video quality for detailed monitoring.
  • Enhanced Color Night Vision: See vibrant colors even in low light.
  • Motion-Activated Spotlight: Adds an extra layer of security by illuminating detected movement.
  • 24/7 Local Recording: Continuous recording with microSD card support.
  • Wi-Fi 6 Support: Faster and more reliable wireless connection.
  • Compatibility: Works seamlessly with Alexa and Google Assistant.
  • Outdoor Ready: Weatherproof design for reliable outdoor use.
This bundle includes the Wyze Cam v4, an outdoor power adapter, and a 128GB microSD card, making it a comprehensive solution for outdoor surveillance.
Whole Home Security Starter Kit
  • Includes Wyze Cam v4, Wyze Video Doorbell v2, and Wyze Home Monitoring Starter Kit.
  • Available in multiple colors: Black, Grey, and White.
  • Ideal for users looking to secure their entire home with a combination of indoor and outdoor cameras.
Why Invest in Durable Mounting Accessories?
Proper mounting is crucial for maximizing the performance and longevity of your Wyze Cam. Using a durable mounting kit with an extra-long bracket installation:
  • Ensures stable camera positioning for optimal viewing angles.
  • Prevents accidental falls or damage caused by weak mounts.
  • Allows flexible placement options, including high or hard-to-reach areas.
  • Enhances the overall security setup by maintaining camera integrity.
Summary
For those seeking a durable Wyze Cam mount with extra-long bracket installation, the Wyze Cam Mounting Kit stands out as the best choice. It offers all the essentials — a sturdy wall plate, adhesive, screws, and a 5-foot USB extension cable — to support extended mounting setups for Wyze Cam v2, v3, and v3 Pro models. Pair this mounting kit with advanced Wyze camera bundles like the Wyze Cam v4 Outdoor Bundle or the Whole Home Security Starter Kit for a comprehensive, reliable, and flexible home security system.
Outdoor Wyze Cam Installation Secure your Wyze Cam outdoors with durable mounts and extended brackets. Home Security Setup Flexible mounting options for comprehensive home surveillance.
FeatureWyze Cam Mounting KitWyze Cam v4 Outdoor BundleWhole Home Security Starter Kit
Product TypeAccessoriesSecurity Camera BundleSecurity Kit
Included ItemsMounting bracket, adhesive, longer Micro USB cable1x Wyze Cam v4, 1x Wyze Outdoor Power Adapter, 1x Wyze MicroSD Card 128GB1x Wyze Cam v4, 1x Wyze Video Doorbell v2, 1x Wyze Home Monitoring Starter Kit
Compatible CamerasWyze Cam v2, v3, v3 ProWyze Cam v4Wyze Cam v4
Video ResolutionN/A2.5K QHD (2560x1440)2.5K QHD (2560x1440)
Night VisionN/AEnhanced Color Night VisionEnhanced Color Night Vision
Outdoor UseNoYes (with Outdoor Power Adapter)Yes (Wyze Cam v4 included)
Power Adapter IncludedNoYes (Wyze Outdoor Power Adapter)No (not specified)
StorageN/A128GB microSD card includedNot specified
ConnectivityN/AWi-Fi 6, Alexa, Google Assistant compatibleNot specified
Price$5.99$69.99$155.95
WarrantyNot specified30-day hassle-free returnsNot specified
What Wyze Cam models are compatible with the Wyze Cam Mounting Kit?The Wyze Cam Mounting Kit is specifically designed to support Wyze Cam v2, Wyze Cam v3, and Wyze Cam v3 Pro models, ensuring a secure and durable installation for these cameras.
What is included in the Wyze Cam Mounting Kit for extra long camera bracket installation?The Wyze Cam Mounting Kit includes a sturdy wall plate, a 5-foot USB extension cable for flexible placement, strong adhesive tape for mounting on various surfaces, and a screw set for permanent installation.
Why should I choose a durable Wyze Cam mount with an extra-long bracket?A durable Wyze Cam mount with an extra-long bracket ensures stable camera positioning, prevents accidental falls or damage, allows flexible placement in hard-to-reach areas, and enhances the overall security of your surveillance setup.
Can the Wyze Cam Mounting Kit be used for outdoor installations?While the Wyze Cam Mounting Kit is ideal for secure and extended indoor installations, for outdoor use, consider pairing it with weatherproof Wyze cameras like the Wyze Cam v4 Outdoor Bundle, which is specifically designed for outdoor environments.
What are the benefits of the 5-foot USB extension cable included in the Wyze Cam Mounting Kit?The 5-foot USB extension cable provides extra length for flexible camera placement, making it easier to install your Wyze Cam in high, hard-to-reach, or unconventional locations without worrying about the proximity to a power source.
What advanced features does the Wyze Cam v4 Outdoor Bundle offer?The Wyze Cam v4 Outdoor Bundle features 2.5K QHD resolution, enhanced color night vision, a motion-activated spotlight, 24/7 local recording with microSD card support, Wi-Fi 6 compatibility, and a weatherproof design for reliable outdoor surveillance.
What is included in the Whole Home Security Starter Kit from Wyze?The Whole Home Security Starter Kit includes a Wyze Cam v4, Wyze Video Doorbell v2, and the Wyze Home Monitoring Starter Kit. It is available in Black, Grey, and White, providing a comprehensive solution for both indoor and outdoor home security.
How does using a durable mounting kit improve Wyze Cam performance?Using a durable mounting kit ensures your Wyze Cam remains securely in place, maintains optimal viewing angles, prevents accidental falls, and extends the lifespan of your camera by protecting it from damage caused by weak or unstable mounts.
Can you tell me more about the features of the Wyze Cam Mounting Kit?Is the Wyze Cam Mounting Kit compatible with the Wyze Cam v4?Are there any ongoing promotions or discounts for the Wyze Cam Mounting Kit?
