Top 2K Floodlight Security Cameras with Smart Voice & Motion Alerts
Best 2K Floodlight Security Cameras with Smart Voice and Motion Alerts
When it comes to securing your home with powerful lighting and crystal-clear video, 2K floodlight security cameras with smart voice and motion alerts are the ultimate solution. These devices not only illuminate your property with bright LEDs but also provide intelligent motion detection and voice deterrence to keep intruders at bay. Below, we explore the top Wyze products that perfectly match your need for 2K floodlight cameras equipped with smart voice and motion alert features.
Wyze Cam Floodlight v2: Brilliant 2K Security with Smart Features
Wyze Cam Floodlight v2 illuminating driveway at night Bright floodlight security camera with motion detection The Wyze Cam Floodlight v2 is a standout choice for anyone seeking a 2K floodlight camera with smart voice and motion alerts. It combines powerful illumination with advanced video and AI features to keep your home safe day and night.
Key Features:
  • 2K Video with Color Night Vision: Capture crystal-clear footage with 2304 x 1296 resolution, even in low light, thanks to color night vision.
  • 2800 Lumens LED Floodlights: Two adjustable, motion-activated LED lights brighten your property, turning night into day.
  • 160° Wide-Angle View: See more of your surroundings with a broad field of view, reducing blind spots.
  • AI-Powered Light Control & Motion Alerts: The camera intelligently detects motion and triggers lights and alerts, helping you respond quickly.
  • Two-Way Talk & 105dB Siren: Communicate with visitors or scare off intruders using the built-in mic, speaker, and loud siren.
  • Ambient Light Mode: Provides a constant low-level light that brightens when motion is detected, enhancing security without harsh lighting.
  • 24/7 Local Recording: Continuous recording to a microSD card (up to 256GB) means no subscription is required to save your footage.
  • Dusk-to-Dawn Automation & IP65 Weather Resistance: Automatically turns on at night and withstands all weather conditions.
  • Smart Assistant Integration: Works seamlessly with Alexa and Google Home for voice commands and live feed viewing.
The Wyze Cam Floodlight v2 is perfect for homeowners who want a reliable, bright, and smart security camera that actively protects their property with voice alerts and motion detection.
Wyze Cam Floodlight Pro: Premium 2.5K QHD Security with AI Precision
Woman with dog near home secured by Wyze Cam Floodlight Pro Advanced floodlight camera with AI motion detection For those who want the next level of security, the Wyze Cam Floodlight Pro offers enhanced video quality and smarter AI-powered detection.
Highlights:
  • 2.5K QHD Resolution (2560 x 1440): Ultra-clear video quality for detailed monitoring.
  • 180° Wide-Angle Lens: Covers a wider area with diagonal 180° field of view.
  • 3000 Lumens Brightness: Three dimmable LED panels provide powerful illumination.
  • AI Computer Vision: Detects specific objects like people and vehicles, reducing false alerts.
  • Motion-Activated Voice Deterrence: Automatically warns intruders with a voice prompt.
  • Dual-Band WiFi (2.4 & 5 GHz): Ensures stable and fast connectivity.
  • Two-Way Talk & 105dB Siren: Communicate or deter with loud siren and talk feature.
  • 24/7 Local Storage: Supports microSD cards up to 256GB for continuous recording.
  • IP65 Weatherproof & Wide Temperature Range: Built to withstand harsh outdoor conditions.
  • Smart Home Compatibility: Works with Alexa, Google Assistant, and IFTTT for automation.
The Floodlight Pro is ideal for users who want a high-end, intelligent floodlight camera that acts like a personal security guard with precise motion detection and voice alerts.
Floodlight Security Bundle: Combine Power and Convenience
If you want to maximize your home security setup, consider the Floodlight Security Bundle which pairs the Wyze Cam Floodlight Pro with the Wyze Cam Floodlight v2. This bundle offers:
  • Dual 2K and 2.5K Cameras: Get comprehensive coverage with two powerful floodlight cameras.
  • Super-Bright LEDs & Wide Field of View: Illuminate and monitor your property extensively.
  • Motion-Activated Voice Deterrence & Ambient Light Mode: Smart lighting and voice alerts to deter unwanted visitors.
  • 24/7 MicroSD Recording: Continuous local storage for both cameras.
  • IP65 Water Resistance: Durable for all weather conditions.
  • Smart Assistant Integration: Control and monitor via Alexa, Google Assistant, and IFTTT.
This bundle is perfect for larger properties or those wanting layered security with multiple floodlight cameras working in tandem.
Why Choose a 2K Floodlight Security Camera with Smart Voice and Motion Alerts?
"A 2K floodlight camera with smart voice and motion alerts is your home's vigilant guardian, combining bright illumination, sharp video, and intelligent alerts to keep your property safe and sound."
  • Enhanced Visibility: 2K resolution ensures you see every detail clearly, day or night.
  • Active Deterrence: Motion-activated lights and voice alerts warn off intruders before they get close.
  • Smart Notifications: Receive instant alerts on your phone when motion is detected, so you can act fast.
  • Two-Way Communication: Talk to visitors or delivery personnel remotely.
  • Weatherproof & Reliable: Designed to withstand outdoor elements and operate continuously.
  • Easy Integration: Works with popular smart home ecosystems for seamless control.
Summary of Top 2K Floodlight Security Cameras
ProductResolutionField of ViewLumensAI Motion DetectionVoice AlertsStorageSmart Home IntegrationPrice Range
Wyze Cam Floodlight v22K (2304x1296)160°2800Yes (with Cam Plus)YesmicroSD (256GB)Alexa, Google Home, IFTTT$89.98
Wyze Cam Floodlight Pro2.5K QHD (2560x1440)180°3000Advanced AIYesmicroSD (256GB)Alexa, Google Home, IFTTT$149.98
Floodlight Security Bundle2K & 2.5K160° & 180°2800 & 3000YesYesmicroSD (256GB)Alexa, Google Home, IFTTT$209.96
Enhance Your Home Security Today
Choosing a 2K floodlight security camera with smart voice and motion alerts means investing in peace of mind. Whether you select the affordable Wyze Cam Floodlight v2, the advanced Floodlight Pro, or the comprehensive Floodlight Security Bundle, you get powerful lighting, sharp video, and intelligent alerts that keep your home safe and secure.
FeatureWyze Cam Floodlight v2Wyze Cam Floodlight ProFloodlight Security Bundle
Video Resolution2K (2304 x 1296)2.5K QHD (2560 x 1440)Includes Floodlight v2 (2K) & Floodlight Pro (2.5K)
Field of View160°180° Diagonal, 170° Horizontal, 95° VerticalIncludes Floodlight v2 (160°) & Floodlight Pro (180°)
LED Brightness (Lumens)28003000Includes Floodlight v2 (2800) & Floodlight Pro (3000)
Night VisionColor Night VisionColor Night VisionColor Night Vision
Motion DetectionPIR sensor, 270° detection areaAI computer visionAI computer vision (Pro), PIR (v2)
Motion-Activated LightsYes, adjustable and motion-activatedYes, adjustable, dimmable, AI-poweredYes, adjustable and motion-activated
Ambient Light ModeYesYesYes
Two-Way TalkYesYesYes
Siren105 dB105 dB105 dB
AI Detection (with Cam Plus)People, Pets, Vehicle, PackagePeople, Pets, Vehicle, PackagePeople, Pets, Vehicle, Package
Local Recording24/7 local recording (microSD up to 256GB)24/7 local recording (microSD up to 256GB)24/7 local recording (microSD up to 256GB)
Cloud Storage (Cam Plus)YesYesYes
Wi-Fi Compatibility2.4 GHz2.4 & 5 GHz dual-band2.4 & 5 GHz dual-band
Weather ResistanceIP65IP65IP65
Power SupplyHardwired 110-120V ACHardwired 110-120V ACHardwired 110-120V AC
InstallationDIY, plug-in mount option availableDIY, plug-in mount option availableIncludes both Floodlight v2 & Pro with plug-in mounts option
Smart Assistant IntegrationAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Warranty1 Year1 Year1 Year
Price$89.98$149.98$209.96 (Bundle price, discounted from $239.96)
What are the benefits of a 2K floodlight security camera with smart voice and motion alerts?A 2K floodlight security camera with smart voice and motion alerts offers enhanced visibility with high-resolution video, active deterrence through motion-activated lights and voice alerts, instant smart notifications to your phone, two-way communication with visitors, weatherproof reliability, and seamless integration with popular smart home systems like Alexa and Google Home.
What is the difference between Wyze Cam Floodlight v2 and Wyze Cam Floodlight Pro?The Wyze Cam Floodlight v2 features 2K resolution (2304 x 1296), a 160° wide-angle view, 2800 lumens of brightness, and smart voice and motion alerts. The Wyze Cam Floodlight Pro offers higher 2.5K QHD resolution (2560 x 1440), a wider 180° field of view, 3000 lumens, advanced AI-powered object detection, dual-band WiFi, and premium smart home integration. Both support two-way talk, a 105dB siren, and local microSD storage.
Does the Wyze Cam Floodlight v2 support color night vision?Yes, the Wyze Cam Floodlight v2 supports color night vision, allowing you to capture clear, full-color footage even in low-light conditions.
How does motion-activated voice deterrence work on Wyze floodlight cameras?Motion-activated voice deterrence uses AI to detect movement and automatically plays a voice prompt to warn intruders, helping to deter unwanted visitors before they approach your property.
Can I store video footage locally on Wyze floodlight security cameras?Yes, both the Wyze Cam Floodlight v2 and Floodlight Pro support 24/7 local recording to a microSD card (up to 256GB), so you can save your footage without a subscription.
Are Wyze floodlight security cameras weatherproof?Yes, Wyze floodlight security cameras are IP65 weather resistant, making them suitable for outdoor use in various weather conditions.
Do Wyze floodlight cameras work with Alexa and Google Home?Yes, Wyze floodlight cameras are compatible with Alexa and Google Home, allowing you to control the cameras and view live feeds using voice commands.
What is included in the Wyze Floodlight Security Bundle?The Wyze Floodlight Security Bundle includes both the Wyze Cam Floodlight v2 and the Wyze Cam Floodlight Pro, providing dual 2K and 2.5K cameras, super-bright LEDs, wide field of view, motion-activated voice deterrence, ambient light mode, 24/7 microSD recording, IP65 water resistance, and smart assistant integration.
How bright are the LED floodlights on Wyze security cameras?The Wyze Cam Floodlight v2 features 2800 lumens of brightness with two adjustable LED lights, while the Wyze Cam Floodlight Pro offers 3000 lumens with three dimmable LED panels, ensuring powerful illumination for your property.
Can I use two-way talk with Wyze floodlight security cameras?Yes, both Wyze Cam Floodlight v2 and Floodlight Pro have built-in microphones and speakers, allowing you to communicate with visitors or deter intruders using the two-way talk feature.
What are the key features of the Wyze Cam Floodlight v2?How does the AI-powered motion detection work in the Wyze Cam Floodlight Pro?Do you have any deals, ongoing sales, discounts, or promotions?
