Camera Floodlight Kits with Adjustable 2600 Lumen Bright LEDs
When it comes to securing your home with powerful illumination and smart surveillance, choosing the right camera floodlight kit is essential. Whether you want to brighten your driveway, monitor your front porch, or keep an eye on your backyard, these camera floodlight kits combine high-lumen LED lighting with advanced video capabilities to keep your property safe and well-lit.
Explore the top Wyze camera floodlight kits featuring adjustable bright LEDs around 2600 lumens and beyond, designed to deliver crystal-clear video, smart motion detection, and flexible installation options.
Wyze Cam Floodlight v2: Brilliant 2800 Lumen LEDs with Smart Features
Brighten your outdoor spaces with Wyze Cam Floodlight v2
The Wyze Cam Floodlight v2 is a standout choice for those seeking a camera floodlight kit with adjustable, ultra-bright LEDs. It features:
- 2800 Lumens of Adjustable LED Brightness: Two powerful floodlight heads provide intense illumination that can be motion-activated or set to ambient light mode for constant low-level lighting.
- 2K HD Video with Color Night Vision: Capture crystal-clear video day and night with a 160° wide-angle lens, ensuring you see more of your property with vivid detail.
- AI-Powered Light Control & Motion Detection: The floodlight intelligently adjusts brightness based on detected motion, reducing energy use while maximizing security.
- Two-Way Talk & 105dB Siren: Communicate with visitors or deter intruders directly through the Wyze app.
- 24/7 Local Recording: Supports microSD cards up to 256GB for continuous recording without subscription fees.
- Weatherproof IP65 Rating: Built to withstand rain, snow, and harsh outdoor conditions.
- Easy Installation: Compatible with a plug-in mount for simple DIY setup without the need for a junction box.
This kit is perfect for homeowners who want a bright, smart floodlight camera with flexible lighting control and reliable security features.
Wyze Cam Floodlight Pro: Ultra-Bright 3000 Lumens with Advanced AI
Experience pro-level security lighting with Wyze Cam Floodlight Pro
For those who demand the brightest and most intelligent floodlight camera, the Wyze Cam Floodlight Pro offers:
- 3000 Lumens of Adjustable, Dimmable LEDs: Three independently articulating floodlight panels allow you to customize light coverage and brightness to suit your outdoor space.
- 2.5K QHD Video Resolution: Ultra-high-definition video with a 180° ultra-wide field of view captures every detail with stunning clarity.
- Onboard AI Computer Vision: Motion-activated lights and notifications trigger only for selected objects like people and vehicles, minimizing false alarms.
- Motion-Activated Voice Deterrence & 105dB Siren: Scare off unwanted visitors with voice prompts and a loud siren.
- Dual-Band Wi-Fi Support: Connects seamlessly to both 2.4 GHz and 5 GHz networks for faster, more reliable streaming.
- Dusk-to-Dawn Automation & IP65 Weather Resistance: Automatically adjusts lighting based on ambient light and stands up to all weather conditions.
- 24/7 Recording with MicroSD Support: Store up to 30 days of footage locally.
This floodlight camera is ideal for larger properties or users who want the ultimate in brightness, AI-powered security, and video quality.
Floodlight Security Bundle: Combine Power and Convenience
If you want the best of both worlds, the
Floodlight Security Bundle pairs the Wyze Cam Floodlight Pro and Wyze Cam Floodlight v2 into one comprehensive kit:
- Combined Lumen Output: 2800 lumens from the v2 and 3000 lumens from the Pro, giving you versatile lighting options.
- 2K and 2.5K Video Quality: Enjoy detailed video coverage with wide fields of view (160° and 180° respectively).
- Smart Features: Both cameras include color night vision, AI motion detection, ambient light mode, and voice deterrence.
- Weatherproof and Durable: IP65-rated polycarbonate bodies ensure long-lasting outdoor performance.
- Flexible Mounting: Wall or ceiling mount options with included hardware.
- Cost-Effective Security Solution: Bundled pricing offers great value for enhanced home protection.
This bundle is perfect for users looking to secure multiple areas with high-lumen floodlights and smart cameras in one purchase.
Wyze Cam Floodlight Plug-In Mount: Simplify Installation
Easy plug-in mount for hassle-free floodlight installation
Installing a wired floodlight camera can be complicated, but the
Wyze Cam Floodlight Plug-In Mount makes it simple:
- Plug-and-Play Design: No need for a junction box or electrician; just plug into an outdoor outlet.
- Compatible with Wyze Floodlight v1, v2, and Pro: Works seamlessly with all Wyze floodlight cameras.
- 20-Foot Power Cord: Provides flexible placement options.
- Outdoor Safe & Weather Resistant: Rated for outdoor use with durable materials.
- Includes Mounting Hardware: Comes with everything needed for quick setup.
This accessory is ideal for renters or anyone wanting to avoid complex electrical work while still enjoying the benefits of a wired floodlight camera.
Wyze Cam Floodlight v2 + Plug-In Mount Bundle
For the ultimate convenience, the
Wyze Cam Floodlight v2 + Plug-In Mount bundle offers:
- 2800 Lumen Adjustable LEDs with 2K HD video and vibrant color night vision.
- 160° Wide-Angle View for broad coverage.
- Advanced Motion Detection & 105dB Siren for effective security alerts.
- Flexible Power Solution: The included plug-in mount allows easy installation without hardwiring.
- Velcro Cable Management: Keeps cords neat and tidy.
This kit is perfect for those who want a bright, smart floodlight camera with the easiest installation method available.
Why Choose Wyze Camera Floodlight Kits?
"Dominate the dark with powerful, adjustable LEDs and smart AI features that keep your home safe and well-lit."
Wyze camera floodlight kits combine high lumen output with advanced video technology and smart home integration. Whether you choose the 2800 lumen Wyze Cam Floodlight v2 or the ultra-bright 3000 lumen Floodlight Pro, you get:
- Superior night vision with color video.
- Wide-angle lenses for maximum coverage.
- Intelligent motion detection with customizable alerts.
- Weatherproof designs built to last.
- Easy DIY installation options including plug-in mounts.
- Integration with Alexa, Google Assistant, and IFTTT for smart home control.
Protect your home with bright, reliable lighting and crystal-clear video surveillance that adapts to your needs.
Summary of Camera Floodlight Kits with Adjustable 2600+ Lumen LEDs
Product | LED Brightness | Video Resolution | Field of View | Special Features | Installation |
Wyze Cam Floodlight v2 | 2800 lumens | 2K HD | 160° | Color Night Vision, AI Light Control | Hardwired or Plug-In |
Wyze Cam Floodlight Pro | 3000 lumens | 2.5K QHD | 180° | AI Computer Vision, Voice Deterrence | Hardwired or Plug-In |
Floodlight Security Bundle | 2800 + 3000 | 2K + 2.5K QHD | 160° + 180° | Bundle Value, All Pro Features | Hardwired or Plug-In |
Wyze Cam Floodlight v2 + Mount | 2800 lumens | 2K HD | 160° | Plug-In Mount Included | Plug-In Mount |
Enhance your home security with these powerful, adjustable camera floodlight kits that deliver bright illumination and smart surveillance in one sleek package.
What are the main features of Wyze Cam Floodlight v2?
Wyze Cam Floodlight v2 offers 2800 lumens of adjustable LED brightness, 2K HD video with color night vision, AI-powered light control and motion detection, two-way talk, a 105dB siren, 24/7 local recording with microSD support, IP65 weatherproof rating, and easy installation with a plug-in mount option.How bright is the Wyze Cam Floodlight Pro and what makes it unique?
The Wyze Cam Floodlight Pro delivers 3000 lumens of adjustable, dimmable LED lighting with three independently articulating panels. It features 2.5K QHD video resolution, a 180° ultra-wide field of view, onboard AI computer vision for smart motion detection, motion-activated voice deterrence, a 105dB siren, dual-band Wi-Fi support, dusk-to-dawn automation, and IP65 weather resistance.What is included in the Floodlight Security Bundle?
The Floodlight Security Bundle combines the Wyze Cam Floodlight Pro and Wyze Cam Floodlight v2, offering a total of 5800 lumens (2800 + 3000), 2K and 2.5K video quality, wide fields of view (160° and 180°), smart features like color night vision and AI motion detection, weatherproof IP65-rated bodies, flexible mounting options, and bundled pricing for cost-effective home security.How does the Wyze Cam Floodlight Plug-In Mount simplify installation?
The Wyze Cam Floodlight Plug-In Mount allows for plug-and-play installation without the need for a junction box or electrician. It features a 20-foot power cord for flexible placement, is compatible with Wyze Floodlight v1, v2, and Pro, is outdoor safe and weather resistant, and includes all necessary mounting hardware.Can I install Wyze camera floodlight kits without hardwiring?
Yes, Wyze camera floodlight kits such as the Wyze Cam Floodlight v2 and Pro can be installed using the plug-in mount accessory, which allows for easy DIY installation without hardwiring. This is ideal for renters or those who want a hassle-free setup.What smart features do Wyze camera floodlight kits offer?
Wyze camera floodlight kits provide smart features including AI-powered motion detection, customizable alerts, color night vision, two-way talk, voice deterrence, 105dB siren, and integration with Alexa, Google Assistant, and IFTTT for seamless smart home control.Are Wyze camera floodlight kits weatherproof?
Yes, all Wyze camera floodlight kits are IP65 weatherproof, making them suitable for outdoor use in rain, snow, and harsh weather conditions.Do Wyze camera floodlight kits support local video recording?
Yes, Wyze camera floodlight kits support 24/7 local video recording via microSD cards (up to 256GB), allowing you to store footage without subscription fees.What is the difference between Wyze Cam Floodlight v2 and Pro?
Wyze Cam Floodlight v2 features 2800 lumens, 2K HD video, and a 160° field of view, while the Pro model offers 3000 lumens, 2.5K QHD video, a 180° field of view, advanced AI computer vision, and dual-band Wi-Fi support for enhanced performance and coverage.Which Wyze camera floodlight kit is best for large properties?
The Wyze Cam Floodlight Pro is ideal for large properties due to its ultra-bright 3000 lumens, 180° ultra-wide field of view, 2.5K QHD video resolution, and advanced AI-powered security features.Can I use Wyze camera floodlight kits with smart home systems?
Yes, Wyze camera floodlight kits integrate with popular smart home systems such as Alexa, Google Assistant, and IFTTT, allowing for voice control and automation.What is included in the Wyze Cam Floodlight v2 + Plug-In Mount bundle?
The Wyze Cam Floodlight v2 + Plug-In Mount bundle includes the 2800 lumen Wyze Cam Floodlight v2, a plug-in mount for easy installation, a 160° wide-angle camera, advanced motion detection, a 105dB siren, and velcro cable management for a tidy setup.
